Re: Problems with IET trains from April 2021
25.8.2025 (Monday) 07:16 - All running AOK
Posted by ChrisB at 16:13, 24th August 2025
Wonder how long it'll be before this 'problem' in RTT is raised again?
Posted by BBM at 10:02, 24th August 2025
A nice problem to have -
1A84 1020 Penzance to London Paddington
Left Penzance as 5 cars.
9 added at Plymouth!
Showing 14 cars to London!
This is a well-known issue on RTT, there's a recent thread on Rail UK Forums which explains how it happens:
https://www.railforums.co.uk/threads/22-coach-pendolino.290852/
Posted by GBM at 08:59, 24th August 2025
08:27 Plymouth to London Paddington due 11:59
Facilities on the 08:27 Plymouth to London Paddington due 11:59.
Will be formed of 8 coaches instead of 10.
One carriage locked out of use I wonder?
It then forms the 12:30 London Paddington to Bristol Temple Meads due 14:05
16:00 Bristol Temple Meads to London Paddington due 17:37
18:00 London Paddington to Plymouth due 21:31
Finally 5C25 2202 Plymouth to Laira T.& R.S.M.D.
Posted by grahame at 07:25, 24th August 2025
Totally confused on this one,did 14 coaches actually make the journey from the west of England to Paddington?
If it did how was the train accommodated at Paddington?
I would be surprised if 14 carriages made Paddington.  Maximum platformed is 12 IET carriages (but how would you do that?) in Platform 1, but a long lead out past the old parcels / mail platform without points might provide an exceptional ability to handle more?
From the sectional appendix PDF - here:
If that "26 chains" on the left is the distance to the first point, then physically 20 carriages of 26 metres could just fit in there.
Posted by infoman at 03:35, 24th August 2025
Posted by stuving at 23:37, 22nd August 2025
Reminded me of the 23-car lash up through Tonbridge :
https://www.youtube.com/watch?v=jta4c9FMmCA
Is there a theoretical maximum of IETs that can be coupled together?
Yes, as specified for passenger operation it's two units and 312 m - twelve vehicles. Given the unit lengths in existence that means only trains that actually operate now.
For ECS and rescue modes, twice that is allowed. That means any train operating now can rescue any other, but it does not have to haul anything longer than it is. Thus some theoretical possibilities such as 5+5+5+9 might be allowed as ECS, but not for rescue (i.e. with passengers on board the rescued train).
Posted by Fourbee at 20:21, 22nd August 2025
Posted by ChrisB at 12:30, 22nd August 2025
Carting those 9 out of use I think
Posted by GBM at 12:27, 22nd August 2025
Posted by Witham Bobby at 12:25, 22nd August 2025
Sooo, first gen DMU heating... how'd it work?
If you want to know more, the Railcar Society website has a useful WR guide to DMU heaters:
https://www.railcar.co.uk/documentation/
Scroll down the page a little to find it
A manual for the Smiths heaters can be found by scrolling a little further
Now I'm down a rabbit hole:
https://preserved.railcar.co.uk/documentation/tsu-89-99-heaters.pdf
[Edit: to add information]
Posted by Witham Bobby at 12:16, 22nd August 2025
AI generated answer:
First generation diesel multiple units (DMUs) on British Railways were primarily fitted from new with Smiths combustion heaters, although a few were initially equipped with a similar type manufactured by Dragonair, which were later replaced by the Smiths version due to recurring problems.
 These heaters operated by burning fuel to generate heat, with the fan end of the heater being colour coded to indicate the unit's heat output; the warmer 50,000 BTU units, differing only in their fuel pumps, were typically fitted to vehicles carrying a single heater, such as Class 108s.
 Vehicles with two heaters generally required one of each hand, as the glow plug needed to be positioned on the side facing outwards for ease of access.
 The heaters were controlled through a system that included a flame detection thermostat and were integrated into the vehicle's control system.
 In 1977, British Rail determined that electrical faults and heater reliability could be improved by electrically insulating the heaters from the vehicle body, achieved by using rubber pads on mounting straps, rubber tubing in the fuel pipe, and insulating bushes made of GRP at both ends of the heater to prevent metal-to-metal contact.
AI-generated answer. Please verify critical facts.
It's AI generated, but corresponds well with my recollection of the heaters on the Park Royal sets we had on the WSR in the mid/late 1970s
Posted by Mark A at 12:08, 22nd August 2025
Posted by Witham Bobby at 09:36, 22nd August 2025
A fault on the train, but it can run through to Paddington empty?
Door fault?  Aircon intake fault - filling passenger cabin with diesel exhaust?
Oh, happy memories of first generation DMU heating!
That kerosene and sulphur smell that took your breath away!
Posted by Ralph Ayres at 09:20, 22nd August 2025
Posted by grahame at 13:45, 21st August 2025
Posted by GBM at 13:41, 21st August 2025
Eh?
12:15 Penzance to London Paddington due 17:31
12:15 Penzance to London Paddington due 17:31 has been cancelled.
Customers making journeys within Devon and Somerset can travel with Cross Country's Edinburgh service as far as Taunton, which departs Plymouth at 14:27.
RTT at Penzance shows -
1A88 1215 Penzance to London Paddington   This service is cancelled.
This service was cancelled due to a problem with the traction equipment (MD).
AND
5A88 1215 Penzance to London Paddington
Empty Coaching Stock
Posted by ChrisB at 19:52, 23rd April 2025
Another update from Richard Clinnick. This has been going on so long that he's now on his 3rd job since the start, and is now editor, Modern Railways...
So far treated - 7 5car 800/0s, 3 9car 800/3s, 12 5car 802/0s and 6 802/1s
800013 & 802017 currently at Eastleigh
In total, there are 93 IETs, 57 owned by Agility. Of those, 28 5car 800/0s and 18 9car 800/3s still need to be treated That  leaves 36 IETs owned by Eversholt of which 9 5car 802/0s and 7 9car 802/1s have yet to be treated
[if these figures don't add up, they're Richard's not mine!]
Posted by ChrisB at 20:34, 6th March 2025
Richard Clinnick (editor, Modern Railways) tweeted a fleet update on GWRs IETs with the cracking problem still ongoing....
Just 38 IETs from the fleets of GWR and LNER have been through Eastleigh works for repairs so far. 800110 has been through twice!  Currently there are 800013, 800110 & 802102.
Still to go from GWR -
800002-012/014-016/019-021/023/025/027/029-036/301-302/304-308/311-321
802004-006/009/013/014/017/018/020/022/101/103-106/109/110/112/113
plus another 33 sets from LNER.
So many years yet.....
Posted by grahame at 14:14, 6th March 2025
Debate cars vs coaches! (I seem to remember we did have that debate a while ago).
https://www.firstgreatwestern.info/coffeeshop/index.php?topic=27903 - and we included "carriages" but not "vehicles".
Posted by GBM at 13:17, 6th March 2025
I've noticed 'recently/a while ago' that there were a few 5 car units doing the rounds(more trains than usual, etc).
However, it is now more common to see 5 cars from Penzance to Paddington with no additional cars at Plymouth.
It is easy to say West Country services must be 9 or 10 cars at all times, but that means perhaps Bristol/Wales/Hereford lose out.
Whilst Hitachi might well be working quietly behind the scenes, I'm surprised that the 5 car issues have not been sorted at all.
The IET's are 5 car/coaches units, or a 9 car/coach formation anyway.
Posted by bradshaw at 08:09, 6th June 2024
The Paignton service has been reinstated starting from Taunton, using a 3 car unit, according to Journey Check.
Running as 3C70 ecs from Bristol according to Traksy
Posted by Timmer at 07:11, 6th June 2024
08:03 London Paddington to Penzance due 13:07
08:03 London Paddington to Penzance due 13:07 will call additionally at Castle Cary.
Just wondering why a problem will give an additional station stop?
I've seen it on other trips since IET's started.
I would say likely to do with the 07:03 being cancelled:
07:03 London Paddington to Paignton due 10:16 will be cancelled.
Posted by GBM at 07:06, 6th June 2024
Posted by chuffed at 09:57, 5th February 2024
In the early days of the project, many promises were made about the quality and reliability of these new trains.
In the early days of the project, many promises were made about the quality and reliability of these new ..............roads/hospitals/libraries/sports centres/airports/aircraft carriers/armoured cars/mail deliveries/bank availabilities/flood prevention schemes/electric cars/supermarket cashiers/Boeing 737s/etc/etc................this could be a whole new thread in itself for an election year
Posted by Clan Line at 13:09, 3rd February 2024
Posted by broadgage at 12:25, 3rd February 2024
Sadly as with so many things these day, IET built to a price ,not to a standard.
I thought that the price was relatively high, one criticism of the project was the substantial cost of the trains. IET=Incredibly Expensive Trains ! According to some critics.
Posted by TaplowGreen at 08:50, 3rd February 2024
We need something more robust, successful and enduring - like the APT perhaps?
Posted by Western Pathfinder at 08:43, 3rd February 2024
Posted by IndustryInsider at 19:07, 2nd February 2024
Whatever happens it’s down to Hitachi to sort out as part of the maintenance contract.
Just like they are quietly doing with the cracks issue that people were getting excited about.
Posted by FarWestJohn at 18:40, 2nd February 2024
And that is just the parts you can see!!
Posted by bobm at 16:17, 2nd February 2024
It will be that salt ridden sea air on the Northumberland coast.....
Posted by broadgage at 16:15, 2nd February 2024
Aluminium is very vulnerable to corrosion especially if in contact with steel.
Did someone use steel fixings at the factory?, or subsequently during maintenance, either is a rather basic error.
Even different grades of aluminium alloy are liable to corrosion if used in contact with each other.
Electrical leakage currents through aluminium  structures can also accelerate corrosion. DC is worst.
Posted by BBM at 13:47, 2nd February 2024
Industry expert Gareth Dennis has posted on X some quite alarming photos of corrosion on LNER Azumas:
https://twitter.com/GarethDennis/status/1753413827067097297
Posted by IndustryInsider at 11:18, 29th January 2024
According to this, Unite accepted the pay offer:-
https://www.cityam.com/400-rmt-workers-at-hitachi-to-strike-on-saturday-until-1-february/
Thanks for that.  Might explain the confusion.
Posted by broadgage at 10:40, 29th January 2024
Stickers have finally started appearing on the trolley/urn store in the middle of the IETs.  Passengers have been confusing them for toilets since they were introduced!
How many crew can you get in a crew storage area ? what type of crew are stored there? how long can they be stored for? and has this been agreed with the Unions?
Two full sized crew, or three small ones.
Catering crew, mainly, possibly hitachi fitters
Two hours at a time, without being let out for exercise.
Strike bruvvers !
Posted by ray951 at 08:39, 29th January 2024
Posted by Southernman at 23:55, 28th January 2024
A Hitachi Rail spokesperson said: “We are disappointed at RMT’s decision to carry out industrial action.
“We believe the combination of last year’s pay increase, and this year’s pay proposal, is fair and highly competitive in the current economic environment. As demonstrated by Unite members accepting the same offer this week and ending their planned industrial action.
Posted by IndustryInsider at 22:37, 28th January 2024
That dispute is only in Hitachi LNER depots, not GWR.
Not according to the official press release from UNITE:
https://www.unitetheunion.org/news-events/news/2024/january/national-strike-by-hitachi-rail-workers-over-pay
Posted by grahame at 21:22, 28th January 2024
The short forms are all down to the withdrawal of the Castle sets & IETs▸ being transferred westwards to cover.
Also covering the shortage of other DMUs. Last Wednesday one of the Bristol-Worcester workings was being covered by a 5 car IET.
There are 17 class 153 in store. One wonders if too early - I know the need for disabled loos these days but really wonder if 2 x 158 trains could run as 1 x 158 + 2 x 153.  Of course, whilst one wonders, one expects there's a very good reason why castles and 153s (and the 6 stored 156s) could be be used.
Posted by ChrisB at 21:18, 28th January 2024
yes, indeed.
Posted by TonyN at 20:52, 28th January 2024
Posted by ChrisB at 20:35, 28th January 2024
Another poor customer experience for those aboard the 1635 Paddington to Plymouth 5 vice 10 and absolutely rammed according to my wife who’s on the train. First declassified. Not listed on JC as being short formed.
Could well be linked to the Hitachi maintenance staff industrial action which started yesterday and runs until Friday.
The short forms are all down to the withdrawal of the Castle sets & IETs being transferred westwards to cover.
Posted by Timmer at 17:26, 28th January 2024
I expect you will be told to be grateful they managed to find 5!
Or that it even ran at all. Next Sunday it won’t be.
Posted by Timmer at 17:24, 28th January 2024
Journey check has now been updated to include the 1635:
16:35 London Paddington to Plymouth due 20:04
Facilities on the 16:35 London Paddington to Plymouth due 20:04.
Will be formed of 5 coaches instead of 9. Service full and standing from Reading.
I can assure the person writing this that the train was full and standing when it left Paddington.
Posted by IndustryInsider at 17:21, 28th January 2024
Posted by TaplowGreen at 16:56, 28th January 2024
Posted by IndustryInsider at 16:53, 28th January 2024
Posted by Timmer at 16:39, 28th January 2024
Posted by PhilWakely at 09:10, 24th January 2024
Answering my own question.  Looking at Realtime Trains it was 166 207 as far as Exeter St Davids and then 150 248 forward from there.   Thinking about it, are turbos cleared on the main line past Newton Abbot?
Yes
Posted by bobm at 08:39, 24th January 2024
Posted by bobm at 08:19, 24th January 2024
Was it even three coaches or was it swapped for two on the way?  I am told it was 150 248 that arrived at Plymouth.
Posted by TaplowGreen at 05:14, 24th January 2024
Westbury to Plymouth in a Turbo??? Ouch.
Not ideal no. But fair play to GWR for able to provide something for travellers from Westbury onwards.
Being a Turbo, there will of course be first class accommodation; just declassified.
Of course. One can only hope that said travellers were suitably grateful.
Posted by IndustryInsider at 22:45, 23rd January 2024
And Turbos routinely cover much longer trips such as Cardiff<>Portsmouth of course.
Posted by Timmer at 21:39, 23rd January 2024
Posted by TaplowGreen at 21:01, 23rd January 2024
17:36 London Paddington to Plymouth due 21:25
17:36 London Paddington to Plymouth due 21:25 will be reinstated.
It will be started from Westbury.
It will no longer call at London Paddington, Reading, Newbury and Pewsey.
Will be formed of 3 coaches instead of 9.
 First class not available. Catering is not available. There are no reservations on this service. Toilet facilities are reduced. Disabled toilet facilities are reduced.
Posted by GBM at 08:33, 18th January 2024
I'm not sure if it was at our "Meet the Manager" but I have heard that said.  But then more are needed now that the HSTs have been reduced to just three daily diagrams.
Apologies, yes. Or no. It wasn't here, but on someone's vlog - Mark , and two other gents talking about trains.
Posted by grahame at 22:04, 17th January 2024
Didn't the MD of GWR advise the forum "Meet the Manager" that they were in the process of arranging with Hitachi better availability of IET's!
Posted by GBM at 21:32, 17th January 2024
The 1635 Paddington to Plymouth was only five vice ten, only went as far as Exeter, was absolutely rammed leaving Paddington and was not listed on Journeycheck as being shorformed. I know II has mentioned before you can’t rely on JC to give the complete picture.
I had elderly relatives on this train. Fortunately they just managed to get a seat, though not together and certainly not the ones that I had been booked for them.
The reason given was the usual ‘more trains than usual needing repairs at the same time.’
Posted by Timmer at 19:43, 17th January 2024
Posted by bobm at 19:19, 17th January 2024
Lower availability today in Cornwall
05:03 Penzance to London Paddington due 09:55
Facilities on the 05:03 Penzance to London Paddington due 09:55.
Will be formed of 5 coaches instead of 10. There are no reservations on this service. (No added coaches at Plymouth).
Also
07:12 Plymouth to Penzance due 09:19
07:12 Plymouth to Penzance due 09:19 will be reinstated.
Will be formed of 2 coaches instead of 9. First class not available. There are no reservations on this service.
This turns into
10:20 Penzance to London Paddington due 15:27
Facilities on the 10:20 Penzance to London Paddington due 15:27.
Will be formed of 2 coaches instead of 9 to Plymouth. First class not available to Plymouth. There are no reservations on this service to Plymouth.
I am told by a couple of passengers that the 10:20 was in fact formed of a 5 car IET.   Looks like there was a set swap at Penzance with an incoming service from Bristol Temple Meads.   The 5 car ran all the way to London with no change of train or attachment at Plymouth.
As reported on other occasions this wasn't updated on Journeycheck.
Posted by GBM at 08:56, 17th January 2024
Of course, residents in Melksham would be delighted to have a regular 2 car train daily with a half hour service!
So Cornwall shouldn't complain.
Posted by GBM at 08:54, 17th January 2024
Also
This turns into
Posted by a-driver at 23:57, 18th October 2023
The IET which failed at Teignmouth this morning seems to have been moved to Newton Abbot platform 1 and is currently sitting there with a headcode 5H17. Is this saying what I think it means?!
No, that’s the IET that failed at Teignmouth Tuesday evening on 1C92
Posted by bobm at 22:02, 18th October 2023
No that’s a different IET.
Full story here  http://www.firstgreatwestern.info/coffeeshop/index.php?topic=28017.0
Posted by RobT at 21:34, 18th October 2023
Posted by ChrisB at 19:30, 18th October 2023
Did they really spell 'lose' and 'losing' with two 'o's?
Posted by 1st fan at 19:03, 18th October 2023
At least three IET sets succumbed to the Dawlish/Teignmouth waves thanks to Storm Babet.
Indeed as reported on Dawlish Today
https://www.dawlish-today.co.uk/news/storm-babet-causes-chaos-on-the-dawlish-to-teignmouth-railway-line-644760
: Dawlish Today
Last night, one Great Western Railway train was battered by sea spray, causing it to loose power in five out its six engines. It managed to limp to Newton Abbot where it remains.
Another GWR train failed at Dawlish, loosing all six of its engines. It was towed to safety at 2am this morning.
This morning saw the complete engine failure of yet another train, this time dying at Teignmouth.
2am ouch!
Posted by Clan Line at 10:49, 18th October 2023
Some days have seen more units available than needed...though not always in the right places .
A bit like the "wrong sort of snow" then  ?
Posted by PhilWakely at 09:46, 18th October 2023
Posted by GBM at 11:21, 16th October 2023
Engine reliability and general fleet availability has now improved significantly.  Some days have seen more units available than needed...though not always in the right places to avoid the odd short form.
Unfortunately 06:05 Penzance to London Paddington due 11:29
06:05 Penzance to London Paddington due 11:29 has been cancelled.
Posted by IndustryInsider at 11:10, 16th October 2023
Posted by CyclingSid at 06:51, 16th October 2023
I have a better idea ...
What, a general election?
Posted by grahame at 22:38, 15th October 2023
Just a thought.....perhaps it should be Hopwood challenging Harper.
I would suspect that questions have been asked from GWR to the DfT.
Should we invite Mark Harper to a "Meet the Secretary of State" session?
Go on, he can only say no. I'd be interested in reading anything more he had to say.
Hmmm ... invite sent.   Didn't say "no" - didn't even acknowledge ...
Posted by ChrisB at 17:58, 2nd October 2023
Quite possibly the same stock.
Posted by Mark A at 17:42, 2nd October 2023
Two of the last IETs I've taken have been worryingly juddery - sufficiently so that in both cases I've flagged it to the train manager.
+1. That feeling with certain IET trains that you're not riding *in* something, more like riding *on* it.
Posted by Witham Bobby at 09:53, 2nd October 2023
This morning I was on the 10.53 out of Paddington in Coach D, and there were continuous judders all through the carriage. I first noticed it around the Heathrow junction, but it continued pretty much all the way through to Oxford, and then became more intense between Oxford and Hanborough again.
Not sure if these are just the expected autumn wheel flats (I'm not any sort of engineer let alone a train engineer!) but I don't recall noticing anything this bad on any other train.
I had a very rough ride on a Paddington to Worcester IET just under a month ago.  I didn't think it was wheelflats, but something weird with the leading bogie, which definitely was hunting.  Not a nice experience, with fingers crossed that the wheel flanges managed to stay on the right fact of the rail
Posted by TonyK at 15:56, 1st October 2023
Oh dear, that would never have been  allowed in the olden days when that  train was the Golden Hind!
Or if it was running late, the Golden Behind.
Posted by bradshaw at 08:17, 1st October 2023
Introduced in 1964 between Plymouth and Paddington, after Drake’s ship that left from Plymouth. Later extended to Penzance
Posted by broadgage at 04:28, 1st October 2023
AFAIK, the Golden Hind has always been an early evening departure from Paddington to Penzance, the last through train to Penzance that runs every weekday, and an early morning departure from Penzance to London.
Timings have varied a bit over the years, but generally the first direct up train and last direct down train that runs every weekday, excluding the sleeper.
Posted by IndustryInsider at 13:59, 30th September 2023
I don’t think the 10:53 from Paddington to Worcester has ever been called ‘The Golden Hind’.
Posted by Jamsdad at 12:15, 30th September 2023
Posted by Richard Fairhurst at 15:34, 29th September 2023
Posted by grahame at 16:04, 23rd August 2023
I appreciate that some actually like them and blame the endless short formations on things other than the trains, but from the point of view of the average passenger, new trains=shorter trains.
I'm not sure that the average passenger gives a toss about train length. It's much for about frequency, reliability,  reasonable journey time, and some comfort, including enough capacity to be comfortable.
I grumbled on Saturday about a 2 car being sent out on our 09:10 - first southbound train of the day. The grumble was not because of the length as such - it was because families could not sit together, children were on knees and some were standing rather together rather than jamming themselves into the middle seats of separate 3s.  Give us an hourly 2 car each way to spread the load and we'll be happy for a short while (except it will be so popular that will become overcrowded!
Passenger comfort and facilities are a bit subjective, but are generally accepted to be inferior to the previous trains. As a passenger group, we can "keep up the pressure" on GWR, but I doubt that much will be achieved.
We tend to decry the negative changes for years but celebrate the positive ones for just days, though.  And there are times that "keeping up the pressure" appear to achieve nothing but for all we know we may have prevented a negative change.
The present industrial disputes will eventually end, but I do not believe that we, as a passenger group can do much to accelerate the process.
Agreed; I have been scratching my head look at how we can help and can't come up with much.  Even strongly showing we want the issues solved can be counterproductive because the sides (yes, I have said "sides") see that as support for the railways and they see themselves as the railway angels or saviours.
And after the strikes end, we will face the normal staff shortages. GWR, and before them FGW have proved incapable of or unwilling to recruit enough staff to run reliably run a full service. This has been the case for YEARS and any near term improvement seems most unlikely.
Agreed;  I think it is industry wide though!
[/quote]
Posted by broadgage at 12:00, 23rd August 2023
How can WE - as passengers / a passenger group help all the players to make things better for customers, which I am going to define as making for a (more) reliable train service?
I do not believe that there is much WE can do. The IETs are unreliable, and seem unlikely to improve much for some years at least. I appreciate that some actually like them and blame the endless short formations on things other than the trains, but from the point of view of the average passenger, new trains=shorter trains.
Posted by bobm at 12:09, 22nd August 2023
Anyone know where things are with regard to the number of units still waiting for remedial work following the cracks issue?
Posted by IndustryInsider at 10:16, 22nd August 2023
There’s certainly a bit of a crisis of availability at the moment.  No slack in the system (as Mark Hopwood confessed in the ‘Meet The Manager’) and further overall stock reductions to come shortly from the mandate of the DfT does not bode at all well longer term, even when IET availability improves.
Posted by bradshaw at 10:09, 22nd August 2023
More than 20 Cl80x out of action yesterday due to repairs with 9 Castles working instead of the planned 7.
Source Richard Clinnick on Twitter/X
https://x.com/clinnick1/status/1693899436076794039?s=61&t=VlafMC5gF9tidw36b1Y8JQ
Posted by GBM at 11:05, 19th August 2023
Several reduced formations to/from Cornwall today.
Also many stopping/starting short in Devon and Cornwall.
Posted by grahame at 07:41, 15th August 2023
Seeming lots of 10 and 9 cars down to 5 cars today.  I wonder what the maths is - are more 9 cars out of service than 5 cars, or is it just an arithmetic quirk?  Are there trains that are running as 9 cars when they would normally be 5, but not being reported? The fleet looks like:
36 - 5 car 800/0 800-001 to 800-036
22 - 5 car 802/0 802-001 to 802-022
21 - 9 car 800/3 800-301 to 800-321
14 - 9 car 802/1 802-101 to 802-114
Posted by PhilWakely at 18:45, 14th August 2023
We had a running commentary from a concerned parent waiting at Exeter St David's for their charges who were on 1C78.
Apparently, they were told to decamp at Westbury and board 1C85 (1436 PAD-PGN) which was formed of 5-car 802016, which fairly obviously could not cope with the additional load. After a further delay, an empty 9-car turned up to continue 1C78 onto Plymouth**.
Edit....
** It appears that 1B16 (1318 PAD-CDF), formed of 9-car 800312, was caped at Swindon 'due to an issue with the train crew' and the unit sent to Westbury as 5C78 to replace the stricken 800316 (which was eventually sent to Stoke Gifford)
Posted by IndustryInsider at 17:11, 14th August 2023
Looks like it was replaced with 800312 on 5Z78 from Swindon.
https://www.realtimetrains.co.uk/service/gb-nr:86585/2023-08-14/detailed#allox_id=0
Yes, please disregard my previous post - I put two and two together and got five, rather than nine! :-)
Posted by Trowres at 17:00, 14th August 2023
1C78 definitely 9 cars passing Dawlish.
Posted by ChrisB at 16:55, 14th August 2023
Ugh, so the 1100 pax are now in those 5cars!
Posted by RobT at 16:53, 14th August 2023
Posted by IndustryInsider at 16:50, 14th August 2023
1C78 currently at Exeter St Davids (16:42). Presumably the set was switched at Westbury, but how was this achieved?
It was a 10-car unit, so the rear one (which is the one that had the pan damaged) would have been detached at Westbury.
[EDIT] Please disregard this post.
Posted by Trowres at 16:43, 14th August 2023
Posted by ChrisB at 16:11, 14th August 2023
What remains of the pant probably neds tying/strapping down before being allowed to move further
Posted by Gordon the Blue Engine at 16:05, 14th August 2023
800316 is now (at 1605) showing as 5C78 FAIL at Westbury P1.  Perhaps it is quite likes Westbury and doesn’t want to leave even if it is cluttering up the station.  It is/was called “#Lionesses” – is this a bad omen?
Posted by ChrisB at 15:45, 14th August 2023
Probably coz they are all going to stations west of Exeter....
Posted by grahame at 15:29, 14th August 2023
"Our stranded #GWR train expected in Westbury in an hour, or so, where we can get off, many miles from where anyone wants to be.
The good people of Westbury will be very sad to read that view of their town ...
