| Re: So what do we expect of a nationalised GWR? Posted by REVUpminster at 15:20, 25th June 2026 | ![]() ![]() ![]() |
Devon and Cornwall improvements under GWR have only happened because they were led by the nose, someone else was paying, screaming and kicking.
They could have improved Newquay, Okehampton, Barnstaple services, half hour trains at Paignton 20 years ago but didn't want to spend the money as they saw no return.
So it cannot be worse.
| Re: So what do we expect of a nationalised GWR? Posted by Electric train at 15:53, 18th May 2026 | ![]() ![]() ![]() |
Several posts refer to the problems with IET reliability, is this now admitted to be a problem ? I thought that the official view was they are fine, and so much better than the HSTs. A significant number of forum members seem to back the official view.
I thought it was only me, and a few others who held differing views.
My comment about the reliability of the class 800 is they are not maintained by the new combined infrastructure / train operator organisation but is reliant on a contract with a supplier. HST were in their early days had a horrendously bad failure rate, it was just the fact that BR had an over supply of traction and rolling stock it did not show up as bad; the TOC's knew how to deal with HST problems through their life; but as the HST's aged they were becoming very expensive to keep in service
| Re: So what do we expect of a nationalised GWR? Posted by grahame at 05:21, 17th May 2026 | ![]() ![]() ![]() |
I would suspect (no facts to hand - so a guess) that they're as reliable as the other trains if not better, but that does not make them perfect with near-100% availability. And I have a suspicion that specifications and targets are set which work with optimistic availability without very many spares. That's fine whilst you accept that you'll get the occasional lack of stock / short form / cancellation, but that very much depends on what you're (as operator / specifier in future too) willing to accept.
I am in Western mainland Europe as write this, and I am struck by the train yards with substantial numbers of multiple units sitting there. And I contrast that with passing Reading which at times seems like an array of empty sidings with everything in use. Again, no figures. And yesterday I was on a train with one of the doors along the unit marked as "this door out of action" and we had to use the one just through to get on/off on the left hand side. Not seen as an issue here, but perhaps in the UK it would have resulted in a carriage out of use, or even a whole train out, and with no spare?
Much more to write up in due course, or perhaps to confine to memory banks. But the system here is not perfect either. Yesterday from Helsingborg to Osnabroeuk showed a number of just the same issues as we have in the UK, and much of the great way that the railway actually works too.
Back on topic - nationalised GWR and what to expect. I will be following up your ideas in addition to mine (many similar / overlapping - but some of yours are more technical). I do especially like the "let's have everything coupleable to everything else" ... and I find myself wondering if that allows us to have a common pool such that when there are planned engineering works, or special events, rolling stock is not limited to the TOC / area of normal use but can be moved around - congestion-buster trains that cover Glastonbury one weekend, the Great North run the next, and the Celitic v Rangers match the one after. I am aware that intercoupleing to some extent may set a standard in stone and be a limiter to improved technology ...
| Re: So what do we expect of a nationalised GWR? Posted by broadgage at 19:10, 16th May 2026 | ![]() ![]() ![]() |
| Re: So what do we expect of a nationalised GWR? Posted by Electric train at 13:05, 13th May 2026 | ![]() ![]() ![]() |
The benefits may not be seen as a "wow" impact day one or even week one, however a lookback a year on should reveal improvements in performance.
Why do you think performance will improve, GWR haven't managed it for months, and if got same equipment (but it will be bit older, and possibly more worn out, and same staff on the ground doing same as they do today. So what makes you think they can do better.
https://www.gwr.com/-/media/gwr-sc-website/files/publications/performance-report/gwr-performance-report-period-2613.pdf
Most recent period failed to run 2.59% of trains,
Of those that ran, only 65.56% were on time, and 2.39% were over 15 minutes late
350 were shortformed below DfT minimum (12.5 trains per day)
..... more likely to be, welcome to your nationalised railway where third of trains are late, some don't run, and reasonable chance will be less carriages than ideal.
The combining of GWR TOC and GW Route will improve performance and time keeping as I said lets take a look in a years time; however the challenge maybe the reliability of the class 800's and the aging diesel fleet
| Re: So what do we expect of a nationalised GWR? Posted by Electric train at 13:00, 13th May 2026 | ![]() ![]() ![]() |
One thing you might ponder is this.
Currently the budgets for infrastructure (NR) and operations (TOCs, however owned) are both fixed by DfT but are quite separate. The transfers between them (access charges and delay "compensation") are known before these budgets are fixed. So when NR runs out of money (not infrequent) it does not impact the finances of the operations side.
The plan is to merge the infrastructure and operations branches into a single organisation, and for this to make any sense at all in management terms it must imply a common budget. So now, when a big infrastructure project overruns in time and money, where does the extra money needed get taken from?
Railway Control Period 7 (aka CP7) 1 April 2024 – 31 March 2029 is the last one, a new system of Railway funding is being put in place this I have been informed will combine infrastructure and rolling stock renewals / enhancements into a single determination.
As the TOC's and NR Routes commence the merge into single business units the budget is in effect a single budget, there are ORR and DfT governance rules in place because GBR is still not a full legal entity; there already a number of TOC's and NR routes (the first in July 2025 was Southeastern Trains and NR Kent Route merged to form South Eastern Railway)
I know the senior railway management are very mindful not to crash head long (literally) into change. A workshop I attended before I retired focused very much about getting the management structural change done safely. Many of the now senior managers were young junior staff / manages at privatisation and witnessed the hastily changed structure of the railway management, they do not want to see the likes of Hatfield, Southall, Ladbroke Grove, Potters Barr as a result of their leadership decisions. Whether the Government / DfT can be kept away from applying pressure on the industry to change quickly for political reasons is yet to be seen
| Re: So what do we expect of a nationalised GWR? Posted by John D at 12:37, 13th May 2026 | ![]() ![]() ![]() |
| Re: So what do we expect of a nationalised GWR? Posted by stuving at 11:06, 13th May 2026 | ![]() ![]() ![]() |
| Re: So what do we expect of a nationalised GWR? Posted by Electric train at 07:47, 13th May 2026 | ![]() ![]() ![]() |
A bit of a reality check ..........
Nothing will change overnight.
The NR Route and GWR TOC executive boards in consultation with DfT will have been working on the shape of the structure of the GW.
Future rolling stock, IET's are with the Route for at least a decade or 2, 387 will be in the TV for many years. Replacement for the Diesel fleets my guess early 2030's
The current legislation limits what can be done, ie the forming of GBR and the bringing into public ownership the franchised TOC's; it be interesting to see what is in todays Kings speech relating to the railways, could we see the reshaping of the NR Routes and former TOC areas? The handing over the London Metro services to TfL and similar the other Mayoral areas in England?
| Re: So what do we expect of a nationalised GWR? Posted by ChrisB at 20:54, 12th May 2026 | ![]() ![]() ![]() |
From the BBC
What GWR nationalisation means for passengers
Following the announcement that rail operator Great Western Railway (GWR) is to be brought under public ownership in December, train passengers may be wondering if the move will make any difference to things like ticket fares, jobs and timetables.
The Swindon-based operator, which is owned by FirstGroup, has run services and linked London to the south-west of England and Wales since 1996.
Several rail firms around the country are already publicly owned, including Great Anglia and South Western Railway. Welsh services were nationalised in 2021 and Scotland took trains into public ownership the following year.
The government plans to nationalise nearly all rail services in England by 2027.
When will GWR be nationalised?
The government confirmed that GWR will be nationalised on 13 December.
A spokesperson for the rail operator said they welcomed the clarity provided by the announcement and would continue to work closely with the Department for Transport (DfT).
Helen Godwin, mayor for the West of England Combined Authority, also welcomed the news.
"We deserve four trains an hour at stations across our growing regional rail network," she said.
"We will continue working with partners to deliver the infrastructure needed to make that ambition a reality."
What is nationalisation?
Nationalisation means bringing something under the control and ownership of the state or government.
The UK's rail system was fully nationalised shortly after World War Two, with the government owning all the networks and trains.
However, the industry was privatised in the 1990s and companies took over the operation of trains.
The rail infrastructure is managed by publicly-owned Network Rail while passenger train services are run by individual operators which are both privately and publicly owned.
The nationalisation process forms part of the Rail Public Ownership Bill which was the first major piece of legislation passed by the Labour government when it came into power in 2024.
The bill allows ministers to take operators back into public control as their contracts expire. Most of the freight operators will remain in private hands.
South Western Railway was the first company to be nationalised as its franchise ended in May 2025.
What is Great British Railways?
Eventually, all the train operators are likely to become part of a new organisation called Great British Railways (GBR).
The planned state-owned company will operate most of the country's rail infrastructure and the majority of passenger rail services as well as devolved and open-access operators.
For now, the train companies we are all familiar with will remain in stations around the country.
Will train fares go down?
No - but they will not go up this year.
Last year, the government announced a freeze on fares in England until March 2027.
The cap applies to regulated fares and includes season tickets and off-peak returns.
The government estimated that the move would save commuters on more expensive routes more than £300.
Transport Secretary Heidi Alexander previously said the focus of renationalising the country's rail network would be on improving services and infrastructure, rather than lowering ticket prices.
Will ticket buying methods change?
Unlike GWR, Transport for Wales (TfW), Cross Country and South Wales Metro network offers the option of pay as you go to passengers travelling between stations in South Wales. This facility is available in the West of England.
The payment method means passengers do not need tickets and they pay the best-value fare as prices are capped at a daily and weekly level to provide the best value.
Passengers travelling through the Severn Tunnel do not benefit from the scheme.
It is not yet known if the companies that are yet to be nationalised in England will offer the payment method.
What will happen to GWR staff?
In 2024, the government said it expected existing contractual terms and conditions for staff working at privately-owned operators like GWR to remain in place as ownership transfers , externalinto the public domain.
Transport union RMT welcomed the establishment of GBR as a "once in a generation opportunity" but said it would seek discussions with the government to ensure the working conditions of the entire railway workforce were "protected and improved" with the new operator.
Is rail nationalisation good or bad?
The government said that ending payments to private sector operators would save £150m a year.
According to statistics, the government spent £21.6bn on railways in 2024-25, external, which was a 6.5% decrease compared to the previous year.
Although the government expects to save money through the nationalisation process, there is a risk for them if something goes wrong on the railways as there will be nobody else to blame.
It also hopes to establish an independent watchdog - the Passenger Standards Authority - to "champion improvement in service against a range of measures".
| Re: So what do we expect of a nationalised GWR? Posted by TaplowGreen at 20:10, 12th May 2026 | ![]() ![]() ![]() |
A culture of Customer service like this.........?
| Re: So what do we expect of a nationalised GWR? Posted by Witham Bobby at 14:20, 12th May 2026 | ![]() ![]() ![]() |
Some thoughts on what might be desirable outcomes:
Rolling stock that is compatible with other rolling stock in terms of couplings and inter-operability
Enough rolling stock to provide services that don't become crammed with passengers
An amount of spare capacity so that "more trains needing repairs than normal" does not result in cancellations
Traincrews that can work different types of rolling stock/multiple units/locos rather than having limited and specialised capabilities
Trains running on different routes that provide proper connections at stations where they meet
Improved attention to important basics like lineside vegetation and waterways/drains clearance
Reduction in cash spent on consultants to tell railway managers stuff they should already know
Enough spare traction at strategic locations so that failed trains are not stranded for hours on end waiting rescue
| Re: So what do we expect of a nationalised GWR? Posted by broadgage at 12:52, 12th May 2026 | ![]() ![]() ![]() |
Less legroom.
Fewer tables.
Shorter trains.
No buffets.
| Re: So what do we expect of a nationalised GWR? Posted by PhilWakely at 11:58, 12th May 2026 | ![]() ![]() ![]() |
2 A trustworthy fare system so we can just swipe in and out and know the cost +
3 Advance fare quotas at lower fares reduced or even eliminated -
The cost of a ticket from A to B, whether walk-up ticket or a discounted Advance ticket, to be the same, whether bought direct from GBR or from a third-party retailer (in other words, third-party retailers should not be allowed to undercut the 'official' price; and all proceeds to be put back into the railways.
| Re: So what do we expect of a nationalised GWR? Posted by ChrisB at 09:49, 12th May 2026 | ![]() ![]() ![]() |
Many electric scooters are already carried on trains.
| Re: So what do we expect of a nationalised GWR? Posted by grahame at 05:09, 12th May 2026 | ![]() ![]() ![]() |
So - what may the next 15 years bring for Great British Railways as a track and train nationalised organisation? As I was travelling yesterday, I jotted down some possibilities - positive and negative - for the passenger. Which would be a result of GBR and which might have come anyway, whoever operates the services, I know not. What I do know is that there are may positive and negative outcomes possible in future years - anything from radical positive change to negative changes, via stagnation and direction changing where (IMHO) long term thought and planning would be best.
Here are 90 items I came up with, ranging from the probable to the fanciful ...
1 A requirement to scan in and out at the end of each ticket -
4 All named trains and rolling stock to have names removed -
5 All new trains to be British built +
6 An end to the go-stop-go of franchise and management contract changes +
7 And end to operator and government blaming each other; more FOI +
8 Cash ticket sales only available at independent shops -
9 Catering counters on long distance trains +
10 Catering withdrawn from journeys under 200 minutes -
11 Charge for baggage on seats +
12 Charge for big people occupying 2 (or more!) seats -
13 Charge for cycle parking at station +
14 Charge for use of on-train loos -
15 Charges for dogs and bicycles carried by train -
16 Charges for use of luggage space -
17 Closure on inconvenient stations -
18 Connections being improved across previous-operator boundaries +
19 Consistent fare system +
20 Delay repay claims to be made to causer of delay - e.g. freight operator or God (as in "act of god") -
21 Delay/Repay being phased out or made leaner -
22 Electrification extended only in marginal constituencies -
23 Electric scooters to be allowed on trains +
24 Elimination of lots of delay attribution but retain knowledge correction +
25 End of peak times - same fare any time +
26 Eurostar service to be nationalised too and extended to Welsh and Scottish capitals +
27 Extra local stops added into long distance trains -
28 Fewer fare options with better value ones being removed -
29 Fewer staffed stations -
30 First class abolished -
31 First class on turbos re-instated in the 2+2 saloons -
32 Free travel for health service employees +
33 Government agencies being judge, jury and advocates for all side when things go wrong -
34 Groupsave removed in the interest of uniformity -
35 Halts to be built at many bridges, with local trains provided at which train manager locks / unlocks gate +
36 ID required when travelling by train -
37 Improved services only provided if supported by Council Tax -
38 Investment into improved infrastucture +
39 Local Transport authorities getting more and funded regional autonomy +
40 Longer term network-wide service planning +
41 Longer trains +
42 Managers and those with customer responsibility require to use the train / stations they are responsible for +
43 More / all trains becoming driver only operated +
44 More comfortable seats +
45 More electrification and battery trains +
46 Nationalisation of catering on station premises -
47 Network and other regional railcards being scrapped -
48 New generation of double deck trains (low deck between bogies) to increase capacity +
49 New lines and stations opened where appropriate +
50 New railcard available to all - loyalty cards with progressive discount +
51 Off peak and super off peak being reduced in time -
52 Older trains not replaced -
53 Onward travel to be guaranteed between all public transport in, to and from UK +
54 Operating "company" free to replace trains by buses whenever they chose -
55 Peak fares on late evening trains -
56 Peak fares to reflect peak travel times, not when rail can get away with it -
57 Price-per-mile based fare system +
58 Pullman dining and sleeper services no longer running -
59 Quieter services being culled -
60 Radical new fare system, based on 10p per mile +
61 Reduction in shareholder dividends +
62 Reduction of signalling to stop-and-proceed on level crossings -
63 Reductions in line speed / maintenance to lower standards -
64 Removal of financial support to Community Rail Partnerships -
65 Requirement to hold insurance when travelling by train -
66 Reservations no longer being free -
67 Seats in IETs replaces by wooden slat benches in a fit of honesty -
68 Security scanners at platform entrances -
69 Services improved to meet passenger and community aspirations and needs +
70 Services to be reduced where an open access operator has rights to run trains -
71 Staff motivation activity - "write in and tell us your best experience" +
72 Station and train cleaning halved -
73 Stations to be closed when platforms are icy -
74 Stations to be gated by 2035; passenger join single door for ticket checks at other stations +
75 Stations without Access for All to be closed to ensure 100% accessible network -
76 Statutory right to Community Rail input with elected passenger representatives +
77 Sunday services reduced to solve staffing issues -
78 System to let passengers easily call up a taxi and charge if their journey fails +
79 Through ticketing across all stations and other public transport in Europe +
80 Ticket transferrable between buses and trains +
81 Ticket valid via any route offering the fastest journey at that time of day +
82 Train routes to be split to ensure better reliability, through passengers changing -
83 Train service frequency reductions -
84 Trains slowed to improve timekeeping -
85 Trains to be operated by GBR onwards over heritage lines by right +
86 Trains to be repainted in a uniform, nationalistic livery +
87 Transfer of away-from-track maintenance and funding responsibility to local autorities -
88 Transport focus reports being purely academic -
89 UK rover tickets being priced the same for UK residents as for overseas visitors +
90 Update of service level algorithms to more consider social need and environment +
91 Updating system to develop timetables and train lengths to best suit needs +
As just headlines, these may need further explanation - please ask in comments, and please add your own options.
| Re: So what do we expect of a nationalised GWR? Posted by Kernow Otter at 18:33, 11th May 2026 | ![]() ![]() ![]() |
There will doubtless be an attempt to close down the sleeper service.
| Re: So what do we expect of a nationalised GWR? Posted by TaplowGreen at 13:27, 11th May 2026 | ![]() ![]() ![]() |
Unfortunately, cost cutting is likely their first starter-for-ten, so don't expect additional services anytime soon - especially those that can still be travelled with a change of train. You might persuade (if you can find anyone to talk to with any clout) them to timetable the change better
I wonder if cost cutting may take the form of reinvigorating the ticket office closure programme and other peripheral services rather than the core business of running trains?
| Re: So what do we expect of a nationalised GWR? Posted by Mark A at 13:04, 11th May 2026 | ![]() ![]() ![]() |
Yup, the DfT that, presented with the 'Opportunities' of a rebuilt London Bridge station, thought it was an opportunity to cut services, tidy up the use of the crossover at Lewisham - and also ramp up the number of passengers that needed to use London Bridge as an interchange, severing a slew of through services to places that people want to go (no offence intended, Cannon Street). Said changes were grudgingly and very partially rolled back, but South Eastern services there are still not what they were.
It would be rewarding for the likes of the following approach - an inclusive strategy scorecard - to have a variety that takes a deep dive into rail transport and evaluated the network for improvements in the routes it offers - e.g. interregional services have dwindled but that's not always as a result of decline in popularity and passenger numbers. Useful for everyone and particularly useful for two groups: 'Encumbered travellers' and disabled people.
https://www.gov.uk/government/publications/inclusive-transport-strategy-scorecard/inclusive-strategy-scorecard-summary-of-key-changes-between-2019-and-2023
| Re: So what do we expect of a nationalised GWR? Posted by anthony215 at 12:46, 11th May 2026 | ![]() ![]() ![]() |
First thing to state is that DfTO confirmed that there would be one GBR overall branding eventually - although the names may remain on those brandings. To commence once all TOCs are nationalised.
GWR Churchward not likely to happen until "the mid-2030s"
Pity porterbrook haven't fitted a class 350/2 with batteries and 3rd rail does as a demonstrator for the north downs line
| Re: So what do we expect of a nationalised GWR? Posted by ChrisB at 12:31, 11th May 2026 | ![]() ![]() ![]() |
| Re: So what do we expect of a nationalised GWR? Posted by Mark A at 12:01, 11th May 2026 | ![]() ![]() ![]() |
The Melksham campaign was gratifyingly far-reaching (not least that it was audible from far and wide). Hearing of the campaign I recall a rail trip to Melksham to attend a produ tive meeting you hosted in your training room, it's really good that the campaign reminded the industry of what it needed to be doing (even if one of the things the Melksham service needs - and indeed the benefits would be more widespread - that is, more appropriate infrastructure to provide for the traffic the line's handling even at the present day not to mention its potential).
Then... the forum... finding that the thriving Bristol - Waterloo service that I used regularly, and earmarked by the previous franchise for increased provision as it obviously had unmet potential - was about to go in the bin completely, courtesy of the DfT and their friends in the viral community, putting an ear into the forum the impending demise of the service seemed to be rather flying under the radar both within this forum and within various railway support and promotion groups - something that quickly changed. Even though the DfT was unable to swallow its pride and the Bristol - Waterloo service went, I'm still very grateful to all the people who spoke up and worked in support of changing that decision. Given the changes to travel patterns served by the railway I'm hopeful that the railway industry has this service on a peg somewhere and ready to be taken down off the wall - it's a good fit for this "Less commuting / more travel to education / travel to friends / travel for events / travel for tourism / car-free travel / travel that meets accessibility needs" interlude.
| Re: So what do we expect of a nationalised GWR? Posted by grahame at 07:24, 11th May 2026 | ![]() ![]() ![]() |
I often write to help me remember, and to clear fact in my head by putting them down "on paper". I publish / comment where that may be of even minimal benign interest and - I admit - I do love (and thank you) for the odd bit of feedback. Just occasionally, something takes off. Late last week (Friday announcement - they usually are) was that our train franchise / operating contract will move from the commercial company First group to a government company on 13th December, and I explain on Facebook at https://www.facebook.com/graham.ellis.melksham/posts/pfbid02LaM9mBLwKh6E8aP2ctVt1Cwz83p5C1GQUpCWGPgjkiALwdDPQWEQHuoQq5jG5k9bl and shared on our forum at https://www.passenger.chat/r32002.html a sorta-explanation of what it might mean, what some expectations are, and what it might mean in practise.
Reducing it down to most basic terms, it's going to be very much down to government decisions, and decisions by their now-civil-servants who know (or don't know) what they are doing, and political direction / interference with things like stop-go funding and popularity aspects as to where it goes, and how much is left to the best people to chose in many cases with some potentially hard decisions that not everyone agrees.
My forum post has been read 407 times as I write, my Facebook post has had an astonishing 91,000 views from an estimated 57,000 people - and with 4,500 clicking through to read it and nearly 100 comments so far in addition to "likes", suggesting I have hit a nerve. Thank you for the comments - they are so valuable and they help inform me so much better of the mood and thoughts of interested parties, and over the next couple of days, I'll be looking ahead as to what may and may not occur. There is evidence, by the way, that the numbers are genuine; 97% from the UK which I would not expect where I simply being harvested by automata for search engines and AI, and the depth of replies on Facebook confirm I have really reached new readers.
Perhaps this bodes well for the future - confirms there is a broad spectrum, of interested and concerned parties out there willing to express their views and inputs. On a personal note, it confirms that I am something of a minor influencer and nothing more I love than to see (for example) our local train working. On Thursday, about 5 p.m., I got off the train at Swindon and was approached by a chap returning to Melksham / Trowbridge / Westbury. "Are you Graham Ellis" he asked, and when I confirmed he thanked me - right back to out petition 20 years ago and all the other activities that have helped up have *that* service he was about to use. Of course, I don't actually run the trains, and I have many, many people who help - I am a bit of a figurehead - but it really gives me a warm feeling of being part of achieving something and make my activity worthwhile.
| Re: So what do we expect of a nationalised GWR? Posted by ChrisB at 16:50, 9th May 2026 | ![]() ![]() ![]() |
| Re: So what do we expect of a nationalised GWR? Posted by Mark A at 11:00, 9th May 2026 | ![]() ![]() ![]() |
Also available on Bluesky (unless someone has an account, X is pretty much a closed book, Bluesky's essentially a public web site.)
https://bsky.app/profile/noeldolphin.bsky.social/post/3mle5putw6c2j
| Re: So what do we expect of a nationalised GWR? Posted by bradshaw at 09:24, 9th May 2026 | ![]() ![]() ![]() |
This is an interesting read, on Twitter/X, the first post is below
Yesterday was @railforum_uk's TOCTalk conference heavily led by DfTO (DfT Operator). Here's my top take-aways: 1) All 3 DfTO speakers said focus was on reducing the net subsidy to rail in the short term. Lots of ways to improve decision-making & drive better value, but.... (1/8)
https://x.com/noeldolphin/status/2052784732102877671?s=61&t=VlafMC5gF9tidw36b1Y8JQ
| So what do we expect of a nationalised GWR? Posted by grahame at 07:25, 9th May 2026 | ![]() ![]() ![]() |
Yesterday brought the official announcement that GWR (Great Western Railway) is to be nationalised on 13th December. There was no surprise in this - it has been expected or even anticipated around that date. It means that the First Group will no longer be our train operator in Melksham - rather our trains will be operated by DfT Operator Limited - a public sector operating company. The "Great Western Railway" name will remain as it's a trading name that's actually been owned by the government and licensed to First. Our operating staff and their managers will be "TUPE"d (Transfer of Undertakings Protection of Employment) across to DFTO and we will initially see little change. It's unclear to me as to who will transfer at Director level, who will remain with First group, and whether some will chose to move on, start a new career or retire.
I have made some very good friends over the years in First Group (on the bus side too) though not always been in total agreement with their or their company's decisions. We have understood one another and co-operated in the promotion and improvement of the offering to passengers, explaining the apparently-perverse to the public where necessary, and pointing out to First elements which it's in the common interest to update. Of late, there has been a regrettable but natural drift for the team at a management level to tow the government line even where it's not fully considerate of the customer's needs, and a tendency for things to get lost in the treacle of bureaucracy or perhaps be put onto a back burner so they can be an early-win success story for DFTO to help show the benefits of nationalisation.
Crystal Ball time - what might we see under DFTO - or in future years "Great British Railways" - the newly integrated single public sector organisation combining tracks and passenger train operation (not, you will note, freight train operation nor ownership of the trains, which will remain largely in the private sector)?
There will be no big windfall income to the government. Profits to First Group on operations are only a couple of percent, and indeed there's a case for saying that this has been worth paying for their local skilled directors. There may be a saving on admin - things like delay attribution and planning with each train operator having its own team looking after its interests. Some of that will remain - there will still be a need to analyse issues, and to make payments back and forth when a freight or open access train interferes with, or is interfered by, a nationalised one, or where the nationalised operator has an accident or event that damages one of the trains owned privately by a RoSCo (Rolling Stock Company).
We expect the branding to stay; it was deliberate that the GWR name was only licensed to First, and indeed we may see more branding. HMG wants to move to "localisation" and we may see more rather than less of a postcode lottery on rail services; it's already notable that South Wales and the Bristol area have seen lots of new stations and improvements and lines, as has Devon, but in Wiltshire and Dorset the last brand new station opened was in 1937, with Melksham a sorta-new station in 1985 having been closed in overenthusiastic zeal 19 years earlier. Service is still far thinner than it should be.
The rail fare system has grown over the years to the extent it's considered over-complex and not fit for future purpose; the problem has been how to sort that out without creating too many losers who will complain far into the future. An element of the same can be said for certain service patterns. In both cases, some of the problems relate to multiple operators - it's been worthwhile searching fare databases for good deals set by different companies, for example, or to travel on one train operator rather than another. There is scope for change, but from the evidence I see "simplification" can often mean the elimination of cheaper and more practical customer options for the "operational convenience" and better overall stats as seen by the Department for Transport.
There is scope for improvement ... but risk of dumbing down to a basic standard. How does a nationalised railway operator justify on-train restaurant car catering for example, when the kitchen space could be used for more seats? And there is scope - governments seem to love it - for making things more complex. Will bicycles and dogs continue to travel for free? Or only be allowed on certain trains? The free reservation system sorta-works but it generates nothing to pay for its operation, and results in lots of unoccupied seats. Stations with low passenger numbers may be at risk - there are multiple closures proposed on the Bletchley to Bedford line at present and with - in the case of Bow Brickhill - no adequate replacement that I can see. The jury is out - a golden opportunity, but also an opportunity to reduce to a very basic provision. Not always a problem if modern technology does provide a friendly alternative.
South Western Railway was nationalised a year ago ... and on 20th May, Andrew Ardley of SWR will be talking to the West Wiltshire Rail User Group in Trowbridge. Easily reachable at the Bethesda Church Hall - 100 yards from Trowbridge Station, and timed for people arriving from and returning to other stations including Melksham and Chippenham. SWR still have a few services to Warminster and Westbury, though they have "rationalised" away their services at Trowbridge and Bradford-on-Avon leaving those stations without any through trains from London. It will be very interesting to hear what Andrew - a good friend over may years - has to tell us, including an update on what they are doing on their core line in the south of the county.
In amongst the "don't know" elements is the passenger voice and I worry if and how that will get due weight into the future. We have good friends at Transport Focus which, however, has lacked authority. Marketing words suggest a positive future for them, but from what I have seen the toothlessness may still remain. We will see; as an advocate of public transport I really hope for a mainstream strong and informed passenger voice / advocate.
No conclusions here - an explanation, a look ahead into a rather foggy crystal ball, and an encouragement to come along on 20th May. Join me on the 18:10 train from Melksham; return on the 21:22 from Trowbridge.
