Posted by TaplowGreen at 16:06, 20th July 2026
Due to a fault with the signalling system between Reading and Newbury fewer trains are able to run.
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 16:30 20/07.
Posted by TaplowGreen at 19:37, 15th July 2026
Delays to services between Reading and Oxford via Didcot Parkway
Following a points failure at Didcot Parkway all lines are now open. Disruption is expected until 20:00 15/07.
Train services between Reading and Oxford via Didcot Parkway are returning to normal but some services have been delayed.
Posted by ChrisB at 15:24, 14th July 2026
Track temperatures can be double that
Posted by TaplowGreen at 15:09, 14th July 2026
Hmmmmmm. London/Thames Valley mostly peaking at 28/29 degrees today.......does thst really constitute "severe" weather for mid July?
Due to severe weather between London Paddington and Reading fewer trains are able to run.
Train services running to and from these stations may be delayed or revised. Disruption is expected until 20:00 14/07.
Posted by TaplowGreen at 16:14, 10th July 2026
Err..........the explanation we've received for GWR trains running non stop to/from Reading to Paddington was that it was largely due to the likelihood of points (such as those at Dolphin Junction) falling over due to hot weather.
So customers who use Twyford/Maidenhead/Slough and smaller stations fall back to the Elizabeth Line, but if that fallback did not exist, what options would they have?
If that option didn't exist then the GWR services would be able to run on the relief lines all the way from Reading to Paddington making the normal stops.
Going back even further in time , before Turbos (165/6) with the all stations Padd - Slough and the Padd- Rdg semi fast (Ealing Bway, Slough Burnham Taplow Maidenhead Twyford) the default in hot weather was to run all stops Padd - Rdg that was torture especially as more often than not it was a 3 car air-con had not been invented
Sounds like a pretty miserable experience......nowadays things have moved on somewhat and there's mass "more trains than usual needing repair at the same time" cancellations and alterations of more modern trains due to lack of adequate air-conditioning in the driver's cab. Quite ironic.
Posted by Electric train at 15:32, 10th July 2026
Posted by IndustryInsider at 10:43, 10th July 2026
Posted by BBM at 09:40, 10th July 2026
As far as Twyford is concerned, GWR has said a few times this week on their X that passengers can take a fast train to Reading and then double-back on Elizabeth Line services. That happened to me a few times when I used to commute in pre-EL days but then of course all stoppers were operated by GWR.
Posted by grahame at 09:04, 10th July 2026
Hypothetical, perhaps to the extent of being of academic interest only?
I am noting today, in amongst missed stops, there are a number of extra stops at Maidenhead
18:08 London Paddington to Frome due 20:00
18:08 London Paddington to Frome due 20:00 will call additionally at Maidenhead.
This is due to severe weather.
which I suspect is a main line platform call.  And that train calls at Twyford too ...
Posted by TaplowGreen at 08:59, 10th July 2026
Err...surely the only difference sharing the relief lines east of Reading with the  Elizabeth Line makes to GWR when disruption occurs is to reduce the available capacity for them to use these lines when the OHL on the main lines only fails?
The "get out of jail" (odd expression for coping with disruption to their business) remains the slower alternative of taking Waterloo trains from Reading.
Posted by eightonedee at 08:03, 10th July 2026
Posted by TaplowGreen at 07:40, 10th July 2026
I guess the GWR masterplan of shove everyone to the Elizabeth Line and forget about them wasn’t so full proof after all.
The Elizabeth Line is a huge "Get out of Jail Free" card for GWR in this context - what on Earth would they have done if it wasn't there to save their bacon?
Posted by grahame at 18:26, 9th July 2026
Due to damage to the overhead electric wires between London Paddington and Reading the Reading bound high speed line is blocked.
We have had a report of a fault with the Overhead Line Equipment (OLE) between Reading and Paddington. OLE is the name given to the overhead wires and other equipment on electrified railway lines that provides power to the trains.
We are working with Network Rail to be able to return to running our normal timetable as soon as possible.
Posted by NickB at 18:21, 9th July 2026
Posted by Mark A at 18:05, 9th July 2026
Has there just been a report that all lines from Paddington are closed?
[Edit] Ah. https://bsky.app/profile/gwr.com/post/3mqa3vg7sno2l
⚠ Travel Update - 09/07 ⚠
Due to damage to the overhead electric wires between London Paddington and Reading all lines are blocked.
Posted by TaplowGreen at 10:19, 9th July 2026
Delays to services between Hungerford and Newbury
Due to a fault with the signalling system between Hungerford and Newbury trains have to run at reduced speed.
Train services running through these stations may be delayed by up to 15 minutes. Disruption is expected until the end of the day.
There is a fault with the signalling system in the Hungerford area, affecting trains towards Newbury, Reading and London Paddington.
This one is still ongoing, and now we also have;
Delays to services between Reading and Slough
Due to a problem with line-side equipment between Reading and Slough the line towards London Paddington bound high speed is disrupted.
Train services running to and from these stations may be delayed. Disruption is expected until 11:00 09/07.
Posted by TaplowGreen at 11:33, 7th July 2026
Posted by TaplowGreen at 15:15, 6th July 2026
We are sorry for the disruption to your journey.
The extreme heat that is forecast for today can lead to an increase in points failures.
Points are the moving pieces of metal that enable trains to change tracks.
To reduce the risk of this happening, a number of points will be set for one route and not moved, protecting the route to and from London Paddington.
....................plenty more standard paras follow re: explanations/alternatives, and of course "you may wish to consider postponing your journey until our service returns to normal"
Posted by GBM at 09:12, 6th July 2026
Alterations to services between Westbury and Reading
Due to a fault with the signalling system between Westbury and Reading fewer trains are able to run on some lines.
Train services running to and from these stations may be delayed or diverted. Some stations between Westbury and Reading will not be served. Disruption is expected until 08:00 04/07.
"Disruption is expected until the end of the day on 06/07/26" (!)
Train services running to and from these stations may be delayed by up to 20 minutes or diverted. Some stations between Westbury and Reading will not be served. Disruption is expected until the end of the day on 06/07/26.
There is a fault with the signalling system in the Hungerford area.
true to their word -
Delays to services between Westbury and Reading
Train services running to and from these stations may be delayed by up to 20 minutes. Disruption is expected until the end of the day on 06/07/26.
Some difficult fault this one!
Posted by NickB at 08:03, 6th July 2026
Looks like the paper mache signalling system has failed despite cancelling most of the GWR services for the Thames valley.
Posted by NickB at 08:01, 6th July 2026
Due to a fault with the signalling system between London Paddington and Slough some lines are blocked.
Train services running to and from these stations may be delayed. Disruption is expected until 09:30 06/07.
We are sorry for the disruption to your journey today.
Some axle counters, part of the signalling system, have stopped working in the Paddington area. Axle counters tell the signalling system if a section of track has a train on it. If an axle counter stops working, trains need to stop at the affected signal so that the Driver can speak to the Signaller to confirm if the track ahead is clear.
Posted by TaplowGreen at 07:48, 6th July 2026
...............just as the warm weather mass cancellations start again.
Posted by GBM at 08:11, 5th July 2026
We can run our trains via an alternative route between Melksham and Hullavington. This will extend journey times.
Last Updated:04/07/2026 16:04
((Issued yesterday!))
Posted by TaplowGreen at 18:09, 4th July 2026
Posted by TaplowGreen at 07:39, 4th July 2026
Posted by ChrisB at 14:09, 1st July 2026
Sensible rule of thumb is to take the first available train to the station of your connection & wait there rather than at your origin
Posted by grahame at 13:33, 1st July 2026
..........can't blame the weather today!
Due to a points failure between Reading and London Paddington fewer trains are able to run on some lines.
Disruption is expected until 13:15 01/07.
Disruption now pushed out to 1515..............if it starts disrupting people's plans to watch England play at 1700, the railway's reputation, already subterranean, is likely to sink even lower.
Yeah - got caught up in that.  09:48 off Paddington on time, 25 minutes down by Reading, 22 down (with a 25 minute connection) at Swindon, so I made Melksham on time.
Interesting, the GWR journey planner had suggested the 10:00 train and shorter change; had I followed their advice, I would have missed the connection ... next train 2 hours later.   Good job I know who things work and took the first available train off Paddington in an abundance of caution.
Posted by TaplowGreen at 13:19, 1st July 2026
Posted by TaplowGreen at 11:27, 1st July 2026
Posted by TaplowGreen at 08:14, 23rd June 2026
Elizabeth Line has fallen over due to a points failure - so that options now gone for those travelling from Twyford/Maidenhead/Slough etc this morning if they wish to get to London.
No service between Heathrow Terminals 2&3 and Heathrow Terminal 4 due to flooding caused by heavy rain and SEVERE DELAYS on the rest of the line due to a points failure at Southall. Tickets are being accepted on London Underground via any reasonable route.
Update
Between London Paddington and Heathrow Terminals / Reading
Severe weather at Heathrow Terminal 4 means that all lines are blocked to / from this station. As a result, trains running to / from Heathrow Terminals may be cancelled, delayed or revised.
Lines have now reopened following an earlier points failure at Southall. Trains running between London Paddington and Reading may continue to be cancelled, delayed by up to to 25 minutes or revised.
Posted by TaplowGreen at 07:07, 23rd June 2026
Posted by Chris from Nailsea at 17:37, 22nd June 2026
Fair point.
Posted by IndustryInsider at 17:04, 22nd June 2026
Quite a lot of freight loops will also be booked out for the same reason.  The loops at Milton, Wootton Bassett, Hullavington and Chipping Sodbury being five examples.
That's four.
Four locations but five loops as Hullavington has two.
Posted by ChrisB at 16:17, 22nd June 2026
Probably coinciding with the HS2 work & the Xmas closure.
Posted by TaplowGreen at 16:09, 22nd June 2026
The western section of Dolphin Junction was completely replaced at Christmas.  There was talk of the eastern section (which is the bit these particular trains use) being replaced and upgraded from 40mph to 70mph…not sure when though.
Just seen a comment on another forum suggesting that the outstanding work on Dolphin Junction is scheduled for the end of this year - clearly can't come soon enough.
Posted by Chris from Nailsea at 15:18, 22nd June 2026
That's four.
Posted by IndustryInsider at 14:31, 22nd June 2026
Posted by TaplowGreen at 14:18, 22nd June 2026
GWR relying on TfL/Elizabeth Line to bail them out between Reading-Paddington it would seem.
Indeed, a proactive and preventative strategy often used during extreme heat, and far better than the points at Dolphin Junction failing in 'reverse' and four operational lines becoming two.
Given that the frequency of these extreme weather events have been on the rise for the last decade or so, what has/is being done to make this and other key pieces of infrastructure more resilient?
Dolphin Junction would seem to be a well known and hugely disruptive single point of failure.
Posted by IndustryInsider at 13:31, 22nd June 2026
Posted by TaplowGreen at 12:43, 22nd June 2026
Posted by Chris from Nailsea at 12:10, 22nd June 2026
Yes, KRS (Key Route Strategy) measures will be in place all week to try and minimise the risk of S&C failures.
With thanks for your post, IndustryInsider, I have now added KRS to our 'abbreviations and acronyms' page.
Posted by TaplowGreen at 11:53, 22nd June 2026
Due to severe weather between Reading and London Paddington fewer trains are able to run on all lines.
Train services running to and from these stations will be cancelled or revised. Slough, Maidenhead and Twyford will not be served. Disruption is expected until the end of the day on 25/06/26.
Posted by eightonedee at 11:50, 22nd June 2026
Looks like all Paddington to Didcot services have been proactively cancelled today.
Actually - No!
What has happened is that the "usual" fallback of either terminating the stopping trains from Didcot at Reading or running then non-stop between Reading and Paddington is being implemented. I assume this reduces the potential for problems when the trains might otherwise have to switch from the main to the relief lines after Slough (and before Slough on the way back).
This has been clearly explained on Journey Check.
Posted by IndustryInsider at 10:32, 22nd June 2026
Posted by NickB at 10:26, 22nd June 2026
Posted by TaplowGreen at 17:40, 21st June 2026
Due to damage to the overhead electric wires between Slough and London Paddington fewer trains are able to run on some lines.
Posted by TaplowGreen at 08:54, 21st June 2026
Delays to services at London Paddington
Due to damage to the overhead electric wires at London Paddington trains have to run at reduced speed on the line.
Train services running to and from this station may be delayed. Disruption is expected until 10:00 21/06.
Posted by TaplowGreen at 17:09, 19th June 2026
At Didcot apparently.......feels almost inevitable doesn't it?
Cancellations to services between Reading and Swindon
Due to a fault with the signalling system between Reading and Swindon all lines are blocked.
Train services running to and from these stations may be cancelled, delayed or diverted between Reading and Bath Spa. Didcot Parkway, Swindon and Chippenham will not be served. Disruption is expected until 17:30 19/06.
Posted by Electric train at 11:27, 17th June 2026
Blimey what was it? An albatross?
Delays to services between Newbury and Bedwyn
Following a broken down train earlier today at Kintbury all lines towards Taunton have now reopened. Disruption is expected until 16:15 15/06.
Train services between Newbury and Bedwyn are returning to normal.
A train had broken down near Kintbury, after striking a bird.
Birds have always been an issue with overhead line electrification.   The first generation (Mk1) used on the WCML and GE had places that allowed birds to build nest, the dropping caused corrosion also the blighters shorted the system.
Large birds such as swans and geese will occasionally fly into the OLE insulators etc, they are also know to fly into pantographs even on moving trains which causes a short usually with a big bang, a dead bird and lots of singed feathers.
Posted by Chris from Nailsea at 21:18, 16th June 2026
To be fair, geese can take down an aircraft: see https://en.wikipedia.org/wiki/US_Airways_Flight_1549
Posted by TaplowGreen at 15:39, 15th June 2026
Posted by grahame at 06:42, 15th June 2026
......another week begins.....
Due to damage to the overhead electric wires between London Paddington and Reading the line towards London Paddington bound local stopping is closed.
Train services running to and from these stations may be cancelled or revised. Disruption is expected until 13:00 15/06.
At 06:03 (that's the update time) JourneyCheck is telling us
Due to some damage to the overhead wires in the Southall / Ealing area one of the lines has had to be closed. As a result, fewer trains are able to operate over the section of line between London Paddington and Reading.
Trains will still operate between those points but to a reduced frequency so they will be much busier than normal. Please accept our apologies for any inconvenience this may cause to your journey today.
Train services between London Paddington / Reading / Swindon and Bristol Parkway / Newport / Cardiff Central will operate to a reduced frequency.
Train services between London Paddington - Reading - Oxford will operate to a reduced frequency. Those services which operate to / from Worcester stations via Oxford will continue to do so. Customers at Oxford requiring London where there is no immediate service may utilise Chiltern Railways services at no additional cost between Oxford and London Marylebone and London Underground services Marylebone to Paddington. Similarly, customers in London wishing to travel to Oxford may utilise Chiltern railways services, at no additional cost, between London Marylebone and Oxford. In addition, GWR ticket holders may utilise CrossCountry services, at no additional cost, between Reading and Oxford (in both directions) in order to assist with their journeys.
Train services which normally operate between Didcot Parkway and London Paddington (calling at local stations via Pangbourne) will only operate between Didcot Parkway and Reading in both directions. Passengers to or from stations to London Paddington will be required to change trains at Reading.
Train services which normally operate between Newbury and London Paddington (calling at local stations via Thatcham) will only operate between Newbury and Reading in both directions. Passengers to or from stations to London Paddington will be required to change trains at Reading.
In addition to the reduced Great Western Railway service operating between Reading and London Paddington customers may use, at no additional cost, Elizabeth line services between Reading and London Paddington but kindly note that these services will also be operating to a reduced frequency and likely to very busy. Kindly note that at Paddington the Elizabeth line services call at platforms A and B which may be accessed via the entrances alongside platform 1 of the main terminal station. Great Western Railway ticket holders may also utilise, at no additional cost, South Western Railway services between Reading and Waterloo (in both directions) and London Underground services across London between Waterloo and Paddington.
Good information - and everyone can travel if a bit delayed, congested, and perhaps with an extra change ...  What a pity that this feels so routine!
Posted by TaplowGreen at 04:28, 15th June 2026
Posted by TaplowGreen at 15:53, 9th June 2026
Second of the day..................
Due to a fault with the signalling system at West Ealing fewer trains are able to run on some lines. Disruption is expected until 18:15 09/06.
Train services between Reading and London Paddington may be cancelled or delayed.
Due to a fault with the signal system in the West Ealing area, we are amending our train service between Reading and London Paddington this afternoon.
Posted by TaplowGreen at 06:46, 9th June 2026
From National Rail - causing a lot of cancellations
Between Abbey Wood and Heathrow Terminal 4 / Maidenhead / Reading, between Gidea Park and Heathrow Terminal 4, between London Paddington and Heathrow Terminal 4 / Heathrow Terminal 5 / Reading, and also between Shenfield and Heathrow Terminal 5
An earlier fault with the signalling system at London Paddington is causing disruption to Elizabeth line services through London Paddington. Trains running through this station may still be cancelled or revised whilst service recovers.
Disruption is expected until 08:00.
Posted by charles_uk at 17:48, 2nd June 2026
And just like London buses...
Train services running to and from these stations may be delayed by up to 20 minutes. Disruption is expected until 19:15 02/06.
Some axle counters, part of the signalling system, have stopped working in the Ruscombe area. Axle counters tell the signalling system if a section of track has a train on it. If an axle counter stops working, trains need to stop at the affected signal so that the Driver can speak to the Signaller to confirm if the track ahead is clear.
Posted by TaplowGreen at 10:48, 2nd June 2026
And in a bit of comedy timing, whilst all the disruption continues, the regulator ORR has decided to issue a letter to Network Rail Western saying ORR is satisfied with their performance and improvement.
Even includes :
A major area of focus has been the Thames Valley and Network Rail has carried out a high volume of asset interventions concentrating on track, overhead line equipment, axle counters and points.
https://www.orr.gov.uk/sites/default/files/2026-06/2026-06-01-nr-wales-and-western-compliance.pdf
So apparently ORR thinks the interventions are good enough, even though failures are continuing.  Words fail me.
Genuinely couldn't make it up
https://www.railmagazine.com/news/network-rail-improvements-lead-to-end-of-enforcement-action-on-poor-performance
Posted by John D at 10:36, 2nd June 2026
Even includes :
Posted by TaplowGreen at 10:25, 2nd June 2026
Disruption pushed out till midday now - last couple of weeks have been shambolic on this line - with so many people relying on the Elizabeth Line thanks to the RMT Tube strike today it makes the situation even worse.
Posted by charles_uk at 09:54, 2nd June 2026
Due to a fault with the signalling system between London Paddington and Reading some lines are closed.
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 10:15 02/06.
There is a fault with the signalling system between Slough and Acton. The signalling system is how trains are kept a safe distance apart and directed onto the various lines along their journey. When there is a fault with the signalling system trains may need to stop at the affected signals so that the Driver can speak to the Signaller to confirm if the track ahead is clear.
The problem affects 2 of the four lines between London Paddington and Reading, so we are having to reduce the train service through the area to avoid congestion.
Some services between London Paddington and Oxford, and between London Paddington and Cardiff Central, will not run, in either direction.
Local stopping services between London Paddington and Didcot Parkway/Newbury will only run between Reading and Didcot Parkway/Newbury.
Most longer distance Intercity services will continue to run between London Paddington and Reading, but may be subject to delay.
Posted by bobm at 20:28, 1st June 2026
Network Rail are saying on X that today’s problems were caused by cable theft.
Posted by bobm at 16:11, 1st June 2026
Edward Burnett was formerly at the Swindon Advertiser and became noted for his restaurant reviews.
He is now at the Oxford Mail and I suspect filling in at fellow Newsquest title, the Reading Chronicle.
Posted by Marlburian at 15:16, 1st June 2026
A new reporter has joined the Reading Chronicle team, though this article does not make for a happy start: "Several trains to London trains and vice versa pass through Reading."
Posted by bobm at 09:16, 1st June 2026
Electrical failure affecting the points at Dolphin Junction near Slough and one signal in the area.
Hope to be resolved in the next hour.
Posted by TaplowGreen at 08:42, 1st June 2026
Normal weather - normal service
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 08:01 01/06.
Now going to take extra 7 hours to fix disruption
Disruption is expected until 15:00 01/06.
Now been expanded to "all routes".
Cancellations to services on all routes
Train services running across the whole Great Western Railway network may be cancelled, delayed or revised. Disruption is expected until 15:00 01/06.
There has been a points failure between Reading and London Paddington. A points failure is a fault with the movable pieces of track that enable trains to change tracks.
................I got to Taplow at around 0540 to find everything being cancelled in both directions, hung around for half an hour, advised to go to Maidenhead although there was very little moving from there either and no taxis available for at least half an hour, so am working from home - fortunately I am able to although there were other customers arriving at the station who clearly weren't, and were extremely concerned/frustrated about how they were going to get to work.
What a (woeful) mess.
Posted by John D at 08:10, 1st June 2026
Posted by Mark A at 08:07, 1st June 2026
Coffeeshop map's a mess, or rather, reflecting a mess, and a lot of cancellations from the likes of Oxford.
Posted by TaplowGreen at 05:20, 1st June 2026
Posted by TaplowGreen at 20:13, 27th May 2026
Due to a speed restriction because of high track temperatures between Reading and London Paddington fewer trains are able to run on all lines.
Train services running to and from these stations may be running non stop between Reading and London Paddington. Twyford, Maidenhead and Slough will not be served.
Posted by a-driver at 18:37, 26th May 2026
Still, we haven’t got long to wait and it’ll be nationalised and all the infrastructure faults will magically disappear overnight!
Isn't the infrastructure in public ownership already?
Yes,  but many people don’t realise that!  Many still think all the failings of the railway are down to the private companies….. and the DfT don’t want to change that thinking!
Previously, any franchised operator had to display its owning company, be it First, Stagecoach etc pretty much from day one.  The nationalised operations don’t.  I wonder why?!
Posted by IndustryInsider at 10:36, 26th May 2026
Seems to apply to the majority of the London - Didcot services today
09:08 London Paddington to Didcot Parkway due 10:22
09:08 London Paddington to Didcot Parkway due 10:22 will no longer call at Slough, Maidenhead and Twyford.
This is due to a speed restriction because of high track temperatures.
To avoid using the crossovers at Dolphin Junction and Stockley Bridge.  They are pretty much the only trains that use them and they are a higher risk point of failure during a heat wave, and if they stay set to the straight ahead route they can’t fail.
Posted by TaplowGreen at 06:44, 26th May 2026
Posted by TaplowGreen at 18:02, 25th May 2026
Posted by a-driver at 17:19, 25th May 2026
Posted by TaplowGreen at 10:48, 25th May 2026
................here we go again
Due to a fault with the signalling system between London Paddington and Reading trains have to run at reduced speed on some lines.
Train services running to and from these stations may be cancelled, delayed or revised. Disruption is expected until 15:00 25/05.
Posted by TaplowGreen at 16:49, 24th May 2026
Due to a fault with the signalling system between Reading and Newbury some lines are blocked.
Train services running to and from these stations will be cancelled or delayed.
Posted by TaplowGreen at 19:16, 23rd May 2026
Due to a fault with the signalling system between London Paddington and Reading fewer trains are able to run on some lines.
Posted by TaplowGreen at 15:11, 22nd May 2026
........and also the second one of the day a little further West in the Thames Valley.....I guess now it's a little warmer we have to expect the infrastructure/service to start melting down.......literally as well as figuratively
Still, cracking BBQ weather! Just in time for the Bank Holiday weekend!
Train services running to and from these stations may be cancelled, delayed or revised. Disruption is expected until 19:00 22/05.
Posted by NickB at 13:34, 22nd May 2026
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 15:15 22/05.
Posted by TaplowGreen at 09:11, 22nd May 2026
Due to a fault with the signalling system between Newbury and Reading trains have to run at reduced speed on some lines.
Train services running to and from these stations may be cancelled or delayed by up to 25 minutes. Disruption is expected until 11:45 22/05.
Posted by TaplowGreen at 07:31, 22nd May 2026
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 10:15 22/05.
Posted by Chris from Nailsea at 20:55, 17th May 2026
Network Rail have been carrying out planned engineering work in the London Paddington area. They have informed us that this will not be finished on time.
Don't panic: it will all go so much smoother when we have civil servants doing it.
Posted by TaplowGreen at 08:01, 17th May 2026
Cancellations to services at London Paddington
Due to engineering works not being finished on time at London Paddington all lines are blocked.
Train services running to and from this station may be cancelled or delayed. Disruption is expected until 08:30 17/05.
Posted by ChrisB at 16:22, 10th May 2026
Piccadilly Line was already shut owing to Engineering Work.
With no trains to Heathrow, it was Circle/District to Hammersmith & a bus this morning - or out from Waterloo to somewhere with a bus connection.
Posted by TaplowGreen at 09:07, 10th May 2026
Due to the emergency services dealing with an incident near the railway between London Paddington and Reading all lines are closed.
Train services running to and from these stations will be cancelled or delayed. Disruption is expected until 11:00 10/05.
Posted by TaplowGreen at 13:46, 5th May 2026
Due to a broken down train between London Paddington and Reading fewer trains are able to run on the line towards Reading.
Posted by NickB at 20:37, 2nd May 2026
And now, trespassers.
Posted by TaplowGreen at 11:43, 2nd May 2026
Cancellations to services between London and Reading
Due to a broken down train between London Paddington and Reading some lines are blocked.
Train services running to and from these stations may be cancelled, delayed by up to 15 minutes or revised. Disruption is expected until 14:00 02/05.
Posted by TaplowGreen at 14:30, 1st May 2026
There is a fault with the signalling systems between London Paddington to Reading
Posted by TaplowGreen at 14:16, 1st May 2026
From National Rail
Elizabeth line services between London Paddington and Slough
A fault with the signalling system between Langley and Slough means that some lines towards Reading are blocked. As a result, Elizabeth line services running between London Paddington and Slough may be delayed by up to 20 minutes or revised.
Disruption is expected until 16:00.
Posted by TaplowGreen at 17:34, 25th April 2026
From National Rail
Between Abbey Wood and Heathrow Terminal 4 / Maidenhead / Reading, and also between Shenfield and Heathrow Terminal 5
A fault with the signalling system at Hanwell means that all lines are blocked. As a result trains running between West Ealing and Heathrow Airport / Slough may be cancelled, delayed by up to 30 minutes or revised.
Disruption is expected until 18:00.
Posted by TaplowGreen at 07:38, 24th April 2026
Due to a points failure between Reading and Newbury fewer trains are able to run on some lines.
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 10:00 24/04.
Posted by TaplowGreen at 10:52, 21st April 2026
..............he's moved further West today!
Cancellations to services at Hungerford
Due to trespassers on the railway at Hungerford trains have to run at reduced speed on all lines.
Train services running through this station may be cancelled or delayed.
Disruption is expected until 11:30 21/04.
Posted by Bob_Blakey at 08:04, 21st April 2026
Taser.
Yes, if necessary. First option should always be physical removal of the miscreant as rapidly as possible by as many trained operatives as required. But if said trespasser resists.....
Negotiation should never be involved.
Posted by TaplowGreen at 21:29, 20th April 2026
Taser.
Trespassers had been reported on the railway in the London Paddington area.
The person has now been removed from the railway. Train services will be reinstated where possible, please check your journey.
Hooray!
Posted by plymothian at 18:42, 20th April 2026
Now there’s a new ‘railway emergency’ that has brought trains to a standstill at Burnham
This is a bridge strike at Langley.
Posted by NickB at 18:04, 20th April 2026
Posted by NickB at 16:36, 20th April 2026
Taser.
Posted by ray951 at 16:29, 20th April 2026
Due to trespassers on the railway between Reading and London Paddington fewer trains are able to run on all lines. Disruption is expected until 13:00 20/04.
Delays now until 6pm
"The person has been on the railway since the early hours, and despite Police negotiation they remain on the railway"
.............surely by now they could have been physically removed?
LNER faced a similar issue last week, reportedly someone climbed a gantry, and the resulting disruption affected train services for two days. I’m not sure what the solution is, but it seems wrong that a single individual can cause such widespread inconvenience to tens of thousands of people.
Posted by NickB at 16:11, 20th April 2026
This does seem to be rather ridiculous.
