Routing / Any Permitted / Easements
26.4.2025 (Saturday) 19:29 - All running AOK
Re: Routing / Any Permitted / Easements
Posted by Mark A at 07:39, 26th April 2025
**snip**
I would favour a return of the term "any reasonable route" and to define that carefully to reduce any confusion. To be clear, "any reasonable route" would start with any train scheduled to get you to your destination, with intermediate changes if need be, ahead of any other route.   And an "any reasonable route" ticket should be always available.
**snip**
That would be a big step forward, I'm thinking of one particular route that apparently isn't mapped as permitted but that for certain services offers the fastest journey between the end points. *Waves at Gloucester-and-points-north to Bath Spa via Swindon*
Posted by grahame at 07:10, 26th April 2025
Personal views ...
Many easements that I'm aware of have come into use because of a horrid infrequency of direct trains - journeys like from Cheltenham Spa and south thereof to Bromsgrove allowing double-backs, and journeys to and from Dilton Marsh doubling back st Westbury or Warminster.  Once direct hourly or better direct services are offered, the easement becomes developed out of making sense.   Open another platform at Pilning and the easement to double back to get there if arriving from / through Patchway (or noting the lines are bi-directional, run some services "wrong line") and you can clear away another easement.
"Any permitted" is a joke of a use of the English language.   It's a tautology and every ticket is permitted to be used on any route on which it is permitted - duh! ... Agreed that the permission may be "via Bath Spa" on a particular ticket but even when that's added to the ticket, it is still permitted to be used by any route on which it is permitted to be used!
That "any reasonable route" would overcome - for example - those very silly suggestions from booking engines (clue - it's called a booking engine because people want to book tickets) that tell you of a travel opportunity but then tell you "no tickets available".  Try Melksham to Chepstow.    Or try (but the booking engine does not offer it) Melksham to Bristol Parkway where much the fastest is a usually a single change at Swindon.
A slower route with fewer (or no) changes should be allowed to, and a slower route which moves the interchange station (s) between services that are fit for the less able - that includes disabled, but also those with heavy luggage, babes in prams, arms or tummies who are less able but not classified as disabled - and indeed allow anyone to make those extended changes.
Posted by Ralph Ayres at 23:47, 25th April 2025
I don't think there has been a widespread change since the concept of permitted routes was brought in as part of rail privatisation, though there has been some tightening up such as various journeys now being only "VIA YORK" as part of the LNER single tickets-only change which previously had much greater flexibility.  Easements do change, but generally on a temporary basis to take account of engineering work.
It is I would say increasingly hard to spot useful alternatives to the obvious route, thanks to the National Rail Journey Planner being dumbed down to look pretty on a phone.  Even if you know an alternative route exists, it can be quite a battle to fool the algorithms to show the journey by using via points as just a few minutes extra on the journey time can render alternatives invisible.  In fairness most people would just be confused or irritated by being shown times they don't need, but perhaps a "show me everything however ludicrous" option should be offered.  Otherwise it can be a case of wading through the whole Routing Guide documentation, now held at https://www.nationalrail.co.uk/travel-information/routeing-guide/.
Posted by Trowres at 23:36, 25th April 2025
Well, services were improving to hourly or better and clockface in BR days, long before "any reasonable route" became "any permitted route" and the Routeing Guide came into existence.
The thread https://www.railforums.co.uk/threads/national-routeing-guide-update.99396/ starts in 2014, and the oldest I can find on the forum is from 2007: https://www.railforums.co.uk/threads/routeing-guide-easements.14305/
While these cover at-the-time changes, I don't know of any record of the cumulative effect of all the changes. I suspect that it would be difficult to research, especially as there are non-Guide changes that affect the choice of permitted routes. For example:
  • Timetable changes that add or remove through services
  • Some journeys not having an "any permitted" route option (only fares for specified routes)
Posted by ChrisB at 10:34, 25th April 2025
KI'm not sure routing easements are removed are they? Do we have any examples?
Posted by Mark A at 10:20, 25th April 2025
Does anyone know of a source for how routing has evolved over the last... well, I'm not sure. Perhaps since the railway moved from a pattern of infrequent services over a rather more extensive infrastructure and started to aspire to, say, hourly clockface patterns of services on the network we use today.
Is guidance for passengers to the effect: 'If the National Rail site won't sell a ticket for it, then it's not a permitted route'?
An issue is that the National Rail site can give the impression that for some journeys that had an alternative that was rather longer than the arbitrary 'Up to 3 miles longer is a permitted route and anything else needs an explicit easement' rule, routing easements have somewhat contracted, which is not to the benefit of the intending traveller.
