| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 11:40, 22nd December 2025 | ![]() ![]() ![]() |
16:23 Westbury to Swindon due 17:06 will be cancelled.
and
How the **** do they expect trains to be used when they are so often cancelled on the day? People will some other way to get around or not get around at all, and that is not good for the finances / business of the railway.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by TaplowGreen at 10:21, 22nd December 2025 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 14:39, 20th December 2025 | ![]() ![]() ![]() |
20:08 Westbury to Swindon due 20:54
Facilities on the 20:08 Westbury to Swindon due 20:54.
21:10 Swindon to Westbury due 21:52
Facilities on the 21:10 Swindon to Westbury due 21:52.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 19:19, 19th December 2025 | ![]() ![]() ![]() |
20:06 Westbury to Cheltenham Spa due 22:06 will be terminated at Gloucester.
It will no longer call at Cheltenham Spa.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 15:04, 19th December 2025 | ![]() ![]() ![]() |
I suspect if a member of crew can operate a number of routes including the TransWilts and there are two services which need operating, the TransWilts will be the one to fall away.
Nothing to do with passenger numbers but for operational reasons. [snip]
Whether it is passenger numbers or operational constraints, the end result is the same for travellers but I suspect it is the latter that leads to cancellations when there is a crew shortage. More importantly we need to keep pressing for sufficient crew and in the short term the need to arrange and publicise alternative road replacement when services are cancelled.
Agreed, Bobm, and there are other specific operational reasons for that particular train to be in trouble - "Rumour Mill" stuff because it's not confirmed.
I have highlighted your alternatives statement. Totally agreed, and those services need to be reasonably close to the time that the train was due too - waiting for a bus or taxi which is so late (when it turns up) that it's only going to get to destination after the next train - and that's over a hour on the 17:35 from Swindon is a good way to turn passengers off. These days, when I talk to people about the service it's not so much "good to have" but much more "don't use it - it's unreliable".
But yet, while campaigning, I'm desparately trying not to rubbish the operator / service to the extend I p*ss them off, and with publcitty that's so bad it puts people off too. A fine balances. I remember past concerns at the campaigning style of SHRUG - https://www.passenger.chat/r4949.html and their Hogrider which veered far to much on the negative side for my liking.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by bobm at 14:31, 19th December 2025 | ![]() ![]() ![]() |
Nothing to do with passenger numbers but for operational reasons. It is much easier to deal with a service which doesn't leave the sidings to make a return trip than cut, for example, a Cardiff-Portsmouth service. Depending when the cancellation is decided the train in question may already be on its way, but even if not you are still left with a train clogging up Westbury after terminating short. If you don't have the staff to shunt it out of the way, it is going to block a platform for a few hours until it can pick up the return working.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 12:46, 19th December 2025 | ![]() ![]() ![]() |
I very much doubt that the DfT (or even GWR when presenting to DfT) singles out any particular line of service, unless the MP(s) in question take the DfT to task) - so overall at drivers depot level, yours are likely the least used of services that Westbury drivers drive. So you catch the short straw to disadvantage the fewest customers at drivers depot level.
Thank you, Chris - so it is down to GWR. Who, however, deny the short straw stuff. I am of the somewhat-informed opinion that the imbalance of cancellations has other planning factors involved and - in school report terms - "could do better"
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by ChrisB at 12:40, 19th December 2025 | ![]() ![]() ![]() |
I very much doubt that the DfT (or even GWR when presenting to DfT) singles out any particular line of service, (unless the MP(s) in question take the DfT to task) - so overall at drivers depot level, yours are likely the least used of services that Westbury drivers drive. So you catch the short straw to disadvantage the fewest customers at drivers depot level.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 12:13, 19th December 2025 | ![]() ![]() ![]() |
One of the items that GWR consider when short-staffed is which services should we run, and which are our most popular services of those that will be affected in the time-slots that we are short?
I suspect that your services carry the fewest of trains in those time periods, and thus cancelling yours is affecting the fewest number of overall travellers wanting to travel at those times.
Hmmm ... busiest train of the day (I take it you are referring to passenger not trains?) ... and the only evening peak train home when there are two morning peak trains ...
Do the Dft dictate shift patterns - not only numbers of staff, but also which hours they are to work? Sorry to repeat my original question but in another form, Chris.
I would also suggest that cancelling a train disproportionatley on the day when the next one's over an hour later puts people off rising the opposite and reliable two train commute in the morning, whereas pulling one of the (say) six peak hour trains from a frequent services and having a sixth of the customers delayed by 20 minutes does far less damage in the evening, and virtually no damage to the morning.
"I don't use the train any more - too unreliable" - (former) customer this morning.. The train operator is failing us, whether through his own company's doing, or those who provide the backup / backroom environment. The liability is with GWR, just as when I buy something in a shop the liability if it's not delivered or doesn't work is with them and it's legally up to them to sort in out with their source.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by ChrisB at 11:46, 19th December 2025 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 11:42, 19th December 2025 | ![]() ![]() ![]() |
Staffing levels are down to the DfT....as is recruitment over & above the 'agreed' number of operatives.
So you have crew taking time of year - possibly using up annual leave if the leave year end equates to the calendar year-end, and no change of 'borrowing' drivers from another depot as they are unlikely to have the route knowledge.
So yes, long-term & short-term, its the DfT
Not sure how that DfT stuff controls which trains are the ones dubiously staff diagrammed and so keep failing though. You have done a good job, ChrisB, of addressing a different issue to the one I raised.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by ChrisB at 11:35, 19th December 2025 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 10:22, 19th December 2025 | ![]() ![]() ![]() |
Well Done, GWR. What's the excuse for still not having enough staff for this train over 10% of the time?
I am so glad you added the "?" there. That's the line I've heard quoted so many times and there's truth in it many times. But I think there are other key issues within the realm of GWR which are perhaps dominant in this case.
Here is the ontimetrains graphic for weekdays for the last four weeks (top) and last six months (lower)
and you'll note that there's no consistency through the day - some trains are pretty reliable and then others have a black armband at the top of their columns. Either the sort of panning needed to sort our specifics can be being done by GWR, or why do they have managers to look after these things and fix issues if such managers aren't able to be effective? Does the DfT really sign off daily crewing rotas and decide that the 17:35 from Swindon will be cancelled today? Where the DfT does get involved, and I accept, is the overall staffing levels ...
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by GBM at 09:34, 19th December 2025 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 06:23, 19th December 2025 | ![]() ![]() ![]() |
Busiest train of the day ... on what's expected to be the busiest day of the month. From the BBC
Britain's roads, railways and airports are set to be thronged by festive travellers on what is is anticipated to be the busiest day for Christmas trips.
The AA has warned of gridlock on Friday as 24.4 million cars are expected to hit the roads.
It is also expected to be the busiest day of the Christmas period for airports, with 460,000 journeys planned.
Network Rail has also advised travellers to check their journeys and book a seat if possible.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 05:48, 19th December 2025 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 19:29, 18th December 2025 | ![]() ![]() ![]() |
This is due to heavy rain flooding the railway.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 14:53, 18th December 2025 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by TaplowGreen at 18:00, 16th December 2025 | ![]() ![]() ![]() |
Facilities on the 20:06 Westbury to Cheltenham Spa due 22:06.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 15:02, 14th December 2025 | ![]() ![]() ![]() |
14:05 Frome to Swindon due 14:58
14:05 Frome to Swindon due 14:58 was terminated at Westbury.
It will no longer call at Trowbridge, Melksham, Chippenham and Swindon.
15:44 Swindon to Frome due 16:38 will be started from Westbury.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by TaplowGreen at 15:22, 13th December 2025 | ![]() ![]() ![]() |
Yep, deep clean required! No ability to do that at Westbury seems a bit mad?
For want of a bucket (+ hot water, bleach and a sponge!) the train was lost!
In some circumstances there is more to it than that. Human material can be infectious to other humans in ways that animal material is not.
I wasn't being entirely serious.
Looks like there is a bus replacement in place for at least one or two of the cancelled trips now.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 15:13, 13th December 2025 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by TaplowGreen at 15:09, 13th December 2025 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by IndustryInsider at 12:58, 13th December 2025 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 12:55, 13th December 2025 | ![]() ![]() ![]() |
So there's passengers taken ill, crew shortage, and now to complete the set....
We also have an "unknown cause" on the later trains. Now up to ten out of 14 cancelled.
Public post on Great Western Enthusiasts on Facebook ... here are the comments.
My guess too that it needs a deep clean. Must have been a sudden incident - nothing awry ad it left Melksham at 09:10
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by GBM at 12:51, 13th December 2025 | ![]() ![]() ![]() |
Plotted out from JourneyCheck - ALL cancellations across the GWR area are mapped. I have screen captured just the central area - there's also a round trip cancelled between Newquay and Par
Possibly more to come!
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by TaplowGreen at 12:35, 13th December 2025 | ![]() ![]() ![]() |
14:19 Westbury to Swindon due 15:01
14:19 Westbury to Swindon due 15:01 will be cancelled.
15:14 Swindon to Westbury due 15:58
15:14 Swindon to Westbury due 15:58 will be cancelled.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 12:28, 13th December 2025 | ![]() ![]() ![]() |
When I woke this morning and checked train times, everything was shown as running. I was down there to hand out Melksham printed bus and train timetables to anyone who wanted them
There were 18 Melksham passengers using the 08:02 this morning and a further 20 or so gathered at the station at a couple of minutes after 10, when the 10:10 slipped back to 10:12 then was shown "Cancelled" but perversely still showing "Calling at Chippenham and Swindon". The reason for the cancellation was only communicated when we enquired via the help point. This is the log thread - I will write up a "what should we learn" thread - although much should have been learned already - when I've sorted out a few other things.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 11:19, 13th December 2025 | ![]() ![]() ![]() |
09:53 Westbury to Swindon due 10:36 has been cancelled.
This is due to a passenger being taken ill on this train.
11:05 Swindon to Westbury due 11:48 will be cancelled.
12:17 Westbury to Swindon due 13:01 will be cancelled.
13:13 Swindon to Westbury due 13:55 will be cancelled.
5M15 ECS on it’s way from Westbury to Bristol….
Will a replacement train be sourced?
Im just back from the station ... writeup to follow when thawed and coffee ...
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by brooklea at 10:22, 13th December 2025 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by TaplowGreen at 08:54, 13th December 2025 | ![]() ![]() ![]() |
16:23 Westbury to Swindon due 17:05 will be cancelled.
17:44 Swindon to Westbury due 18:25
17:44 Swindon to Westbury due 18:25 will be cancelled.
18:38 Westbury to Swindon due 19:22
18:38 Westbury to Swindon due 19:22 will be cancelled.
19:44 Swindon to Westbury due 20:29
19:44 Swindon to Westbury due 20:29 will be cancelled.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 08:51, 12th December 2025 | ![]() ![]() ![]() |
05:11 Gloucester to Southampton Central due 08:09 will be terminated at Salisbury.
It will no longer call at Romsey and Southampton Central.
It has been delayed at Westbury and is now 35 minutes late.
Sat in Westbury for 40 minutes ... an educated guest suggests that it was awaiting crew off the first train up from Fratton which was running very late for reasons not apparent.
Through passengers from north of Trowbridge (yes, there are some!) will have been royally p*ssed at the delay, followed by the termination at Salisbury AFTER the South Western train onward to Southampton which could have provided an onward connection had left.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by TaplowGreen at 08:21, 12th December 2025 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 20:10, 11th December 2025 | ![]() ![]() ![]() |
But I don't remember seeing this previously (before Monday); is it a new service?
The normal route is closed between Castle Cary and Taunton and it's diverted this week
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by matth1j at 19:57, 11th December 2025 | ![]() ![]() ![]() |
While waiting for that at Chippenham (due 17:50) an empty IET passed through heading west at full tilt. I thought it might have been the reason for the delay, but the 17:35 was still parked at Swindon for a while after that.
Same happened this evening, except it looked like there were a few passengers on board. So I checked RTT, and in fact it's the Paddington-Penzance service, which has no stops between Reading and Bristol, and is scheduled to pass through Chippenham at 17:41:
https://www.realtimetrains.co.uk/service/gb-nr:V59505/2025-12-11/detailed#allox_id=0
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 18:03, 11th December 2025 | ![]() ![]() ![]() |
18:37 Westbury to Swindon due 19:21 will be cancelled.
If you are at Westbury and Trowbridge travelling to Chippenham or Swindon you should travel on the 18:41 Bristol Temple Meads service (18:48 from Trowbridge) and change at Bath Spa for the 19:43 London Paddington service which calls at Chippenham (19:55) and Swindon (20:09). However, if you are at Westbury or Trowbridge earlier, you may take the first available service via Bath Spa, via Melksham tickets will be accepted via Bath Spa at no additional cost.
If you are at Westbury or Trowbridge and travelling to Melksham, road transport is being arranged, you should contact station staff or use the Customer Help-Point.
If you are at Melksham we will provide road transport to Chippenham from the station car park.
20:12 Swindon to Westbury due 20:56
20:12 Swindon to Westbury due 20:56 will be cancelled.
If you are at Swindon or Chippenham travelling to Trowbridge or Westbury you should travel on the 20:26 Weston-super-Mare service from Swindon (20:38 from Chippenham) and change at Bath Spa for the 21:08 Portsmouth Harbour service which calls at Trowbridge (21:31) and Westbury (21:38). However, if you are at Swindon or Chippenham earlier, you may take the first available service via Bath Spa, via Melksham tickets will be accepted via Bath Spa at no additional cost.
If you are travelling to Melksham you should change at Chippenham and speak to station staff.
If you are at Melksham we will provide road transport to Trowbridge and Westbury from the station car park.
If you require further information please speak to our staff at the station or on the train, use the Customer Help Point, message us on X @GWRHelp or call National Rail Enquiries on 03457 484 950.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by TaplowGreen at 12:40, 11th December 2025 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 10:19, 11th December 2025 | ![]() ![]() ![]() |
15:15 Swindon to Westbury due 15:59 will be cancelled.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 19:07, 10th December 2025 | ![]() ![]() ![]() |
18:37 Westbury to Swindon due 19:21 has been delayed at Westbury and is now 14 minutes late.
This is due to train crew being delayed.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by matth1j at 15:24, 10th December 2025 | ![]() ![]() ![]() |
BTW the 15:37 Chippenham-Melksham is also showing as cancelled in National Rail.
which is actually the Chippenham-Bath-Trowbridge-Melksham option (I was looking on the 'plan your journey' tab); it's the 16:29 Trowbridge-Melksham leg that's (still) cancelled.| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by matth1j at 14:02, 10th December 2025 | ![]() ![]() ![]() |
Keep an eye open for the next couple of hours - 1 in 3 cancellations get re-instated.
Will do. BTW the 15:37 Chippenham-Melksham is also showing as cancelled in National Rail.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 13:59, 10th December 2025 | ![]() ![]() ![]() |
Drat. That'll be the 271 Bath-Melksham bus for me then.
To be fair that service is usually ok (in TransWilts terms
). I've used it 17 times since 13/10 for my Chippenham-Melksham hop and that's the first cancellation, with 4 delays >5 mins (range 9-17).
). I've used it 17 times since 13/10 for my Chippenham-Melksham hop and that's the first cancellation, with 4 delays >5 mins (range 9-17).Keep an eye open for the next couple of hours - 1 in 3 cancellations get re-instated.
Since 17th November - a checkpoint at which we had a significant meeting with GWR - cancellations are measurably less. I am not quoting the measurements yet - too soon to have a reliable sample over a reasonable time period. The request to GWR was not a request for perfection - it was a request to bring cancellations down to the same rate (percentage wise) as we see across the region - 3% at many stations, but 9% at Dilton Marsh and 11% at Melksham in the periods leading up to to that meeting - stats there for the last 6 months, 12 weeks and 4 weeks all similar.
So - there will, and we expect, there to still be be occasional issues.
Of course, as the cancellations drop to about a quarter of what they were, that should allow GWR to concentrate of getting the passenger experience of people being let down far more. Easier to deal with one cancellation than four, and even if they spend twice as much on replacement services, that's still only half the spend of the higher historic cancelation rate.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by matth1j at 13:45, 10th December 2025 | ![]() ![]() ![]() |
Oh dear - here we go again.
). I've used it 17 times since 13/10 for my Chippenham-Melksham hop and that's the first cancellation, with 4 delays >5 mins (range 9-17).| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 13:07, 10th December 2025 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 13:04, 10th December 2025 | ![]() ![]() ![]() |
Oh dear - here we go again. Busiest southbound train of the day. No alternatives on offer. It was due off Chippenham at 10 to six - quarter of an hour AFTER the last bus to Melksham and Trowbridge has left ... next train 70 minutes later.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by Mark A at 12:27, 10th December 2025 | ![]() ![]() ![]() |
That charter reached Victoria at a quarter to one in the morning. The train recovered an hour in one go as it was booked to wait an hour at Salisbury, which put me in mind of something, I can't quite put my thumb on it.
Running two hours late, it missed out on the opportunity to, oh yes, that was it, pay homage to the current evening connections Waterloo to Bristol there by waiting for an hour at Salisbury, and set off straightaway on its circuitous route back via Hampshire and Surrey and up to London.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by Mark A at 20:23, 9th December 2025 | ![]() ![]() ![]() |
Today's charter train seems to have had a complicated start to its return trip back to London Victoria. The set left Bristol roughly on time but then called at Bath and departed two hours and nine minutes late, very quietly, under diesel power. As it was booked to allow six hours between Bath and London Victoria perhaps it'll have an on-time arrival. Where the passengers were tucked during the delay I don't know.
https://www.realtimetrains.co.uk/service/gb-nr:U72587/2025-12-09/detailed
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by Oxonhutch at 20:08, 9th December 2025 | ![]() ![]() ![]() |
With all the diversions through Chippenham going on, Thingley Junction has indigestion.
I think you should change your strap line to "Two tracks now!"
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 19:46, 9th December 2025 | ![]() ![]() ![]() |
17:50 Gloucester to Salisbury due 20:06 has been delayed between Chippenham and Trowbridge and is now 9 minutes late.
Main line (at Chippenham) congestion- waiting for the train from Westbury to come off the branch, which in turn was waiting for a mainline opening towards Swindon. With all the diversions through Chippenham going on, Thingley Junction has indigestion.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 16:02, 9th December 2025 | ![]() ![]() ![]() |
Tuesdays and Fridays are my days off (AKA working from home) fortunately
It does look pretty grim outside at the moment, a good day to not be commuting.
It does look pretty grim outside at the moment, a good day to not be commuting.Surpisingly, only one issue so far
15:15 Swindon to Westbury due 15:59 is being delayed between Chippenham and Melksham and is now expected to be 12 minutes late.
Aggregate empties from Appleford to Whatley running 23 minutes late as it passed though Melksham. The passenger trains had to wait at Thingley Junction for the freight to clear Bradford Junction because there are no intermediate signals. Gone are the days of signals and boxes at Lacock, Beanacre, Melksham, Holt and Staverton.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by matth1j at 11:08, 9th December 2025 | ![]() ![]() ![]() |
This morning looks interesting. There are three services into one - with Castle Cary to Taunton closed for engineering, with Swindon to Parkway closed for flooding, three major main lines are all being funnelled through Chippenham and Bath. If the 17:35 off Chippenham is held back / misses its path, it may be a bit of a wait for the next path
It does look pretty grim outside at the moment, a good day to not be commuting.| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by matth1j at 08:41, 9th December 2025 | ![]() ![]() ![]() |
Is this a glitch? As well as the 1900 Salisbury service from Chippenham, National Rail are also showing one at 1910, albeit cancelled:
National Rail link: https://www.nationalrail.co.uk/journey-planner/?type=single&origin=CPM&destination=MKM&leavingType=departing&leavingDate=091225&leavingHour=17&leavingMin=45&adults=1&extraTime=0#O
EDIT: of course, that's just the (somewhat circuitous) Bath/Trowbridge route
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by Timmer at 08:28, 9th December 2025 | ![]() ![]() ![]() |
This morning looks interesting. There are three services into one - with Castle Cary to Taunton closed for engineering, with Swindon to Parkway closed for flooding, three major main lines are all being funnelled through Chippenham and Bath. If the 17:35 off Chippenham is held back / misses its path, it may be a bit of a wait for the next path, whether or not it's actually had to wait for passengers off the train from London, and irrespective of whether there's some diverted express running in its path so it has to be held back anyway.
To help the situation of all trains having to travel via Bath, GWR have cancelled all the hourly Cardiff to Paddington services and one of the two half hourly Bristol to London services.Might be interesting at Bath today with the Christmas market on, though I suspect the poor weather may put some people off.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 08:12, 9th December 2025 | ![]() ![]() ![]() |
17:35 Swindon to Westbury due 18:19 is being delayed at Swindon.
This is due to the train departing late to maintain customer connections.
I don't think too many 17:35 passengers decided to give up and make alternative arrangements when the announcement was made (more than once) that the fastest way to Melksham and beyond was going to be the 19:00 Salisbury service...
The announcement system is incorrect and confusing. If a train misses a calling or departure point by more than a couple of minutes, an assumption is made that it's not running - the station displays say "delayed" which is correct but so vague it is not helpful, and the announcements chime in with telling you about the next train even if it's an hour or more away. And that's even if the train can be seen on various feeds waiting for ... a late running connection, or a path over a busy line, and human and knowledgeable logic suggests that the train will turn up.
At Chippenham if the 17:50 does not "show", the next alternative is the 19:00 to Salisbury from the same platform anyway. The last bus to Melksham and Trowbridge left quarter of an hour ago, by the time a rail replacement bus is arranged it would be even later than the 19:09 into Melksham.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by matth1j at 06:18, 9th December 2025 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 18:55, 8th December 2025 | ![]() ![]() ![]() |
18:37 Westbury to Swindon due 19:21 is being delayed at Westbury.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 18:10, 8th December 2025 | ![]() ![]() ![]() |
17 minutes late off Swindon - however things like this can make sense given how infrequent the service is
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 21:45, 6th December 2025 | ![]() ![]() ![]() |
21:10 Swindon to Westbury due 21:52 will be cancelled.
Customers are requested to check the stations Onward Travel Information poster and wait for replacement road transport at the designated stop. Customers are advised that the replacement road transport may run later than the advertised train times owing to the additional time taken by road between stations and the time required for loading and unloading at each stop.
Due to the cancelled Swindon to Westbury.
Rail replacement transport has been requested for passengers travelling from Chippenham towards Westbury.
Last Updated:06/12/2025 17:15
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by TaplowGreen at 18:34, 6th December 2025 | ![]() ![]() ![]() |
20:08 Westbury to Swindon due 20:54 will be cancelled.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by bobm at 12:21, 6th December 2025 | ![]() ![]() ![]() |
09:28 Cardiff Central to Portsmouth Harbour due 12:51
09:28 Cardiff Central to Portsmouth Harbour due 12:51 will be diverted between Bath Spa and Trowbridge.
It will no longer call at Bradford-On-Avon.
It is being delayed between Bath Spa and Trowbridge and is now expected to be 12 minutes late.
This is due to a tree blocking the railway.
10:30 Cardiff Central to Portsmouth Harbour due 13:51
10:30 Cardiff Central to Portsmouth Harbour due 13:51 will be diverted between Bath Spa and Trowbridge.
It will be delayed due to the diversion and is expected to be 11 minutes late.
11:30 Cardiff Central to Portsmouth Harbour due 14:51
11:30 Cardiff Central to Portsmouth Harbour due 14:51 will be diverted between Bath Spa and Trowbridge.
It will no longer call at Bradford-On-Avon but will call additionally at Chippenham and Melksham.
12:30 Cardiff Central to Portsmouth Harbour due 15:51
12:30 Cardiff Central to Portsmouth Harbour due 15:51 will be diverted between Bath Spa and Trowbridge.
It will no longer call at Bradford-On-Avon but will call additionally at Chippenham.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 12:12, 6th December 2025 | ![]() ![]() ![]() |
Cancellations to services between Bath Spa and Westbury
Due to a tree blocking the railway at Avoncliff the line towards Westbury is blocked. Disruption is expected until 14:00 06/12.
Train services between Bath Spa and Westbury may be cancelled, delayed or diverted. Freshford, Avoncliff and Bradford-On-Avon will not be served.
Due to a tree blocking the railway line near Avoncliff, our train service is suspended whilst our teams make it safe to run.
Is this the same tree?
If so, has our Melksham-calling service been culled in order for GWR to run other trains through? Two tracks now!!
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 12:09, 6th December 2025 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 11:55, 6th December 2025 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 10:48, 5th December 2025 | ![]() ![]() ![]() |
Both reinstated at 06:49.
Thank you - and noted ... we have been very concerned and noted trains cancelled and then re-instated in the past - indeed it happens most weeks. From a very small sample of such cancelled-then-reinstated trains I have caught, passenger numbers can be decimated, though I don't have enough data to correlate the length of time a service was cancelled for with the passenger drops. Good this came back so quickly - would be really useful if the green signal of a running train didn't get slammed back to a red one, with messages going out to tell people that it won't be running - rather with a "check back in two hours" message - sort of single yellow.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by IndustryInsider at 10:41, 5th December 2025 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 07:18, 5th December 2025 | ![]() ![]() ![]() |
Facilities on the 05:11 Gloucester to Southampton Central due 08:09.
Toilet facilities are reduced.
No accessible toilet available.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by TaplowGreen at 06:25, 5th December 2025 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 21:54, 4th December 2025 | ![]() ![]() ![]() |
I see GWR are advertising an additional 21 services for Bath Christmas Market on Saturday.......I wonder if this will impact the Transwilts service?
So do I ...
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by TaplowGreen at 18:12, 4th December 2025 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 19:53, 1st December 2025 | ![]() ![]() ![]() |
17:50 Gloucester to Salisbury due 20:06 will be terminated at Warminster.
It will no longer call at Salisbury.
It is being delayed between Chippenham and Melksham.
6C54 - Oxford Banbury Road (Flhh) to Whatley Quarry F Liner Hh
due to pass Melksham at 18:36 but didn't pass until 19:16
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 06:39, 1st December 2025 | ![]() ![]() ![]() |
06:35 Salisbury to Worcester Foregate Street due 09:47 will call additionally at Dilton Marsh.
This is due to the train making extra stops because a train was cancelled.
I would need to look at what it's replacing, but in the whole picture of things, it would be sensible for this train to routinely call at Dilton Marsh.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 21:17, 29th November 2025 | ![]() ![]() ![]() |
After a few better days, here we go (or don't go) again. I wake to 4 cancellations, with no alternative travel plans offered or suggestsetd. Two successive trains each way, leaving a six hour gap inn the schedule.
Three words: Bath Christmas Market.25 specials calling as Bath. Wow ... I have commented on that thread but it needs recoding here as a record of what GWR think of their bread and butter customers.
It strikes me that GWR have taken on more than they can reasonably have coped either - but then are they under an obligation of some sort to do so? What they have absolutely got wrong is to sacrifice their everyday every week customers from Westbury to Swindon on the day.. I emphasise "on the day". Had they announced changes well ahead of time - as they do with things like the Cheltenham Gold Cup or Glastonbury - there would have been some disappointment. But to schedule it knowing all the extras were planned, build up passenger expectations and then crash out on the day - defies belief. What a ****up!
This is what JourneyCheck fed me earlier - cancellations as viewed across the whole GWR area
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by Timmer at 07:31, 29th November 2025 | ![]() ![]() ![]() |
I have left the 16:27 Exeter to Penzance in the whole GWR area cancellation list - the only other train they have cancelled in this period across their entire patch. Next train Exeter to Penzance is at 17:14. After the 16:23 from Westbury to Swindon, the next train is at 20:08. The GWR website will offer you travel via Bath if you are going to Chippenham and beyond, for which their website cheekily charged £19.80 rather that £9.80 (single) and if you have mobility issues "
The lifts are out of order between platform 1 and the subway at Bath Spa station."
Three words: Bath Christmas Market.I have left the 16:27 Exeter to Penzance in the whole GWR area cancellation list - the only other train they have cancelled in this period across their entire patch. Next train Exeter to Penzance is at 17:14. After the 16:23 from Westbury to Swindon, the next train is at 20:08. The GWR website will offer you travel via Bath if you are going to Chippenham and beyond, for which their website cheekily charged £19.80 rather that £9.80 (single) and if you have mobility issues "
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 07:11, 29th November 2025 | ![]() ![]() ![]() |
Thank you for that string of reports and your consistent help - really useful. I have woken and left my double post following yours, exceptionally, because it gave me a chance to explain the alternatives and what they mean - which GWR haven't done on JourneyCheck ...
I am in the Leekes superstore today and tomorrow with members of the Melksham Transport User Group handing out printed December to May timetables that came from the printers yesterday. I hope we have made a wise decision to encourage users along.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 07:07, 29th November 2025 | ![]() ![]() ![]() |
16:27 Exeter St Davids to Penzance due 19:40
17:35 Swindon to Westbury due 18:18
18:35 Westbury to Swindon due 19:17
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by TaplowGreen at 06:58, 29th November 2025 | ![]() ![]() ![]() |
17:35 Swindon to Westbury due 18:18 will be cancelled.
18:35 Westbury to Swindon due 19:17 will be cancelled.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by brooklea at 18:40, 28th November 2025 | ![]() ![]() ![]() |
Updated to show now starting from Westbury.17:50 Gloucester to Salisbury due 20:06 will be cancelled.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by TaplowGreen at 17:12, 28th November 2025 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by IndustryInsider at 10:46, 28th November 2025 | ![]() ![]() ![]() |
Facilities on the 17:50 Gloucester to Salisbury due 20:06.
Will be formed of 3 coaches instead of 5. First class reduced.
Gobsmacked - was that schedule to be an IET? No reason why not, of course, as far as Westbury but the idea of holding a hand out to stop an IET at Dilton Marsh is surreal
A possible explanation as to why an entry was made by mistake is that the set that forms that train (2V68, 13:28 WEY-GCR) is booked with 5-cars (166 and a 165) between Bristoland Gloucester with the 165 locked out of use and detaching at Gloucester.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 08:02, 28th November 2025 | ![]() ![]() ![]() |
Are IETs even cleared for travel south of Westbury to Salisbury? They may be for getting to Eastleigh for repairs to their yaw damper brackets. (Yes I had to look that up
)As far as I am aware they are NOT cleared to Salisbury. I have certainly not seen any of the IET stop boards south of Westbury.
The JourneyCheck and Real Time Trains we echo here are supremely useful in looking and learning about serious problems - cancellations, service short runs and delays, to inform in the "here and now" and look back and see what and why at later dates. Mixed in with those superbly useful reports are a sprinkling of frivolous ones where the systems have reported something that really does not matter to the passengers (3 cars rather than 2, delayed by a minute) or is plain wrong (5 cars with first class to Salisbury) - they lighten the message and help maintain the humour and humanity but can dilute the serious message. Case in point, this report here ...
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by Timmer at 21:42, 27th November 2025 | ![]() ![]() ![]() |
)| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 19:44, 27th November 2025 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 11:43, 27th November 2025 | ![]() ![]() ![]() |
What's your suggestion then? Don't cancel it until being sure around an hour from time of service?
No
Don't mention it at all (until it doesn't set off from origin, just to be ultra-sure?
No
(Don't cancel it in the first place would be obvious suggestion, but sometimes it has to happen)
No - none of the above. For all my negative responses, good serious discussions with GWR 10 days ago on how to deal with these circumstances. I do agree that cancellations shouldn't happen in the first place. If on-the-day announced cancellations including "false" ones could be reduced from the 14% they were early this month prior to the GWR meeting, the problem would be far less. Better to treat the disease rather than the symptoms, though the worst effects of the symptoms need to be looked after.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by ChrisB at 09:42, 27th November 2025 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 08:03, 27th November 2025 | ![]() ![]() ![]() |
Last night I travelled on the 21:22 from Trowbridge to Melksham after the West Wiltshire Rail User Group meeting. That was the same train that I caught home from the previous meeting which was in September, but that night the train had been announced as cancelled on JourneyCheck and other systems and only re-instated late on. 15 passengers when we left Trowbridge last night - not a lot, but three times the five passengers on that day in September. So evidence confirming that JourneyCheck and the various electronic systems do reach people and send them away, and that phantom cancellations really do damage the customer base. I understand that trains cancelled and re-instated do not show up on industry stats so presumably the TOC is not sanctioned for poor performance in any way.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 07:51, 27th November 2025 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 13:30, 25th November 2025 | ![]() ![]() ![]() |
If you are at Swindon or Chippenham travelling to Trowbridge or Westbury you should travel on the 13:25 Weston-super-Mare service from Swindon (13:38 from Chippenham) and change at Bath Spa for the 14:03 Warminster service which calls at Trowbridge (14:25) and Westbury (12:32). However, if you are at Swindon or Chippenham earlier, you may take the first available service via Bath Spa, via Melksham tickets will be accepted via Bath Spa at no additional cost.
13:43 Chippenham to Westbury due 14:26
An additional bus service has been planned to operate as shown 13:43 Chippenham to Westbury due 14:26.
Please check the stations Onward Travel Information poster and wait for the replacement road transport at the designated stop.
The road transport is taxis, operated by Bath Taxis. Before getting in any taxi vehicle please check with the driver that they are working on behalf of GWR, the driver should not ask for payment.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by TaplowGreen at 22:40, 21st November 2025 | ![]() ![]() ![]() |
20:12 Swindon to Westbury due 20:56 will be starting late from Swindon and is expected to be 10 minutes late.
This is due to passengers causing a disturbance on a train.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 20:13, 21st November 2025 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 19:57, 21st November 2025 | ![]() ![]() ![]() |
20:12 Swindon to Westbury due 20:56 will be reinstated and will now run as scheduled.
Wasn't even aware that one had been cancelled ...
and now ...
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 19:49, 21st November 2025 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 18:51, 20th November 2025 | ![]() ![]() ![]() |
Increasingly as we move to "One Railway" and to avoid finger pointing, they are just identified as "trains" rather than freight or passenger.
The failure being a freight train - presumably on the line northwards from Trowbridge - explains multiple cancellations at that time - I had wondered at the apparent co-incidence of 2 trains failing at the same time. In some ways it's good that the finger pointing / buck passing is to be avoided but in other ways in unlinks immediate local / company responsibility. But hang on - are freight train operations being nationalised or not??
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by bobm at 18:08, 20th November 2025 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by Phil at 10:50, 20th November 2025 | ![]() ![]() ![]() |
Last Updated:19/11/2025 14:17
I was caught up in this. What it doesn't mention is that the train was only cancelled at 14:17.5, by which time it was already standing on platform 1 in WSB, nicely warmed up and chugging away with the driver trying to explain to people that they couldn't get on because it might go to a different platform before going to Swindon. After half an hour or so of this it was shunted off into a siding, presumably in the hope that it could be used to provide the next scheduled service two and a half hours (!) later. I believe the next Trowbridge service didn't run until 4pm or so due to the goods train blocking the line (or do we call them freight trains now? I'm old; forgive me. "Freight" sounds so American somehow). I must confess I had already caught the 3.15 bus to Trowbridge by then.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 14:38, 19th November 2025 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by IndustryInsider at 11:45, 18th November 2025 | ![]() ![]() ![]() |
According to Real Time Trains an Oxford to Westbury feright was held at Bradford Junction waiting for a path, not departing until 1800
One of the benefits of our new berthmaps system is that I can run replays anywhere, not just on a TMIS at work, and having done that I can see nothing obvious that caused the delay - so, no sign of the above freight, or anything coming the other way.
That suggests it could have been a minor signalling issue, or a temporary block due to trespassers and so on (though nothing was entered into any of the signal berths to indicate that).
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 11:38, 18th November 2025 | ![]() ![]() ![]() |
I thought I saw that - BUT it was a "Q" - runs as required - path but hadn't been switched on which suggested to me it had not been run. In hindsight, makes sense that it WAS run. Intermediate signal or better needed!
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by rogerw at 11:13, 18th November 2025 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by grahame at 08:51, 18th November 2025 | ![]() ![]() ![]() |
I was on the 1750 Chippenham to Melksham yesterday evening, which stopped for no obvious reason on the main line before turning off into the single track section. The train manager announced that we were waiting for another train, but the only one that came past was an IET on its way to Paddington, which AFAIK shouldn't have held us up. We departed Chippenham one minute late, but were 11 minutes late arriving at Melksham.
Graham - I saw you on the platform at Melksham and assumed you'd also been on board; any ideas? (Sorry, had to dash off - band rehearsal in Bristol on Monday evenings and it's already a bit tight without an 11 minute delay.)
I must have missed you as I walked though - mind you, there were nearly 70 people on that train ( [72/18] ) . I was with a retired driver and a current senior member of the Westbury platform team, and they were a bit puzzled too. Might have been a freight train ahead of us on the single line so waiting for it to clear at Bradford junction - or is it possible that the IET had come through wrong line from the Corsham direction and had to cross to right line ahead of us? Mystery ...
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025 Posted by matth1j at 08:11, 18th November 2025 | ![]() ![]() ![]() |
