31.5.2025 (Saturday) 06:05 - All running AOK
Posted by grahame at 05:48, 31st May 2025
... . I guess it works on paper. ...
I guess it does.  Problem is ... railways don't run on paper ... they run on people, and engineering, and trains and rails, all of which have less continuous availability than a sheet of paper which remains a miracle that can be written on and still read years later.
Posted by grahame at 05:08, 31st May 2025
12:17 Westbury to Swindon due 13:01
12:17 Westbury to Swindon due 13:01 will be cancelled.
The change only happened last weekend!
So as of last night it was 50% of the days since the change that the peak evening train was declared cancelled then re-instated.  Unclever - very unclever.
Time flies - it's been two weeks not one, hasn't it, ChrisB?   And I fell for that without doing a fact check ... I have not looked back at the first week after the changes; that record commented on is for the second week as they should be bedding in.
Posted by Wizard at 21:58, 30th May 2025
I understand that Gloucester drivers have had Melksham work removed with the change of timetable. Along with Bristol drivers losing Weymouth, it would appear Westbury depot are too thin to cover all the gaps.
There are ... times ... I wish I had provided an "amazed" button answer as well as a "like" button. If you have understood correctly (and I have no reason to doubt it) it looks to be rather backward step in terms of providing a reliable service, doesn't it?
Has the new timetable change sorted out the lunchtime problem where a crew arriving off the semi-fast London to Exeter service do a round trip to Swindon ... notorious for being cancelled, turned at Chippenham or delayed if anything goes wrong (does it ever?) between London and Reading,  delaying the Exeter.
Almost all depots have lost routes with the May timetable. I guess it works on paper. Believe Oxford are the odd ones out who’ve actually gained a new route.
Posted by grahame at 15:01, 30th May 2025
Let's hope that THIS crew shortage issue (or the way of reporting it in a way that scares the customers away) is shortlived - teething troubles.  Sadly, I am not holding my breath as prior experience of staff shortages is that they go on. And on. And on.
Posted by TaplowGreen at 14:33, 30th May 2025
20:06 Westbury to Cheltenham Spa due 22:06 will be started from Swindon.
It will no longer call at Westbury, Trowbridge, Melksham and Chippenham.
Posted by RA at 12:48, 30th May 2025
The lunchtime train is still booked with an Exeter guard who arrives on the London to Exeter service.  The 1623 Westbury to Swindon and 1735 Swindon to Westbury services are now booked to have a driver who travels up from Exeter! I think Westbury have covered it (when possible) every time it has run since the timetable change though.
The evening 1750 Gloucester to Salisbury service is now booked from Swindon for a driver from Reading depot who is then booked to bring back the 2006 Westbury to Cheltenham service as far as Swindon.
Posted by ChrisB at 08:50, 30th May 2025
Posted by Timmer at 08:44, 30th May 2025
Explains why Weymouth trains often end up terminating at Westbury in both directions if Bristol drivers no longer sign the route down to Weymouth. Might be good for operators but not good for passengers.
Posted by grahame at 07:12, 30th May 2025
Posted by Wizard at 07:03, 30th May 2025
Posted by TaplowGreen at 19:40, 29th May 2025
The 16:23 from Westbury and the 17:35 from Swindon now re-instated.
However
20:06 Westbury to Swindon due 21:21
An additional bus service has been planned to operate as shown 20:06 Westbury to Swindon due 21:21.
Four people carriers from Bath Taxis. Before getting in any taxi vehicle please check with the driver that they are working on behalf of GWR, the driver should not ask for payment.
Posted by grahame at 15:49, 29th May 2025
17:50 Gloucester to Salisbury due 20:06 will be terminated at Swindon.
It will no longer call at Chippenham, Melksham, Trowbridge, Westbury, Dilton Marsh, Warminster and Salisbury.
And now cancelled throughout ... no real difference on the TransWilts section where it was cancelled anyway!
Posted by grahame at 11:42, 29th May 2025
Just looking at options for my usual commute home Bristol-Melksham (on the National Rail website) and of 9 options between 13:00 and 19:25, 4 are currently showing as "This service is cancelled". 2 cancellations are for the Chippenham-Melksham leg, 2 for Trowbridge-Melksham.
It is a "joke" ... a humeourless joke ... today. Goodness knows what has been cancelled and what has been re-instated and what ends up running in the end.    It  may feel OK to the folks who run the trains to chop and change during the day depending on staff availability - after all, a driver coming in to work at X O'clock doesn't need to know where he's going to be until a few minutes before.   However, for passengers (customers) rather more planning is needed, especially on services which are infrequent in the first place.  Perhaps more thought should be given to customers and the effect on them of all these "will-it, won't-it" flip-flops.
Posted by matth1j at 11:31, 29th May 2025
Posted by bobm at 10:23, 29th May 2025
However
Posted by grahame at 07:45, 29th May 2025
Depressing ... and it feels it's getting even worse again.
Gap at Melksham ...
12:32 to 18:53 northbound
13:39 to 20:38 southbound
... and that's for a town of around 25,000 where an appropriate service would be running hourly each way; the timetable is thinner (just one every 2 hours) and the sort of thing being offered today has six hour gaps. Sadly, this is not unusual - it's ongoing.   The trains MAY end up being re-instated later but that's cold comfort to people who need to have their days planned.
Things WILL go wrong occasionally ... but this is an ongoing problem and it is NOT occasional. It's difficult to see anything being done to provide a reliable service ... words are spoken, actions being taken explained and promised and there are even good patches for a while with it running a bit better, but it falls over again. Sad.
Posted by TaplowGreen at 05:40, 29th May 2025
15:15 Swindon to Westbury due 15:59 will be cancelled.
16:23 Westbury to Swindon due 17:06 will be cancelled.
Posted by grahame at 19:45, 28th May 2025
Followed, as sure as night follows day, by
Posted by TaplowGreen at 19:20, 28th May 2025
Posted by bobm at 13:54, 28th May 2025
Both now re-instated.
Posted by matth1j at 11:10, 28th May 2025
...and if I search for Bristol Temple Meads - Melksham on the National Rail app it also shows the earlier 1545 option as cancelled as well, although I can't be bothered to check which of the 2 trains on that route aren't running.
Posted by matth1j at 11:06, 28th May 2025
That would have been the last leg of my commute home. Looks like another £3 on the buses
Posted by grahame at 09:40, 28th May 2025
Posted by grahame at 07:33, 28th May 2025
Argh! First commute in over 2 weeks and the trains...
When I left the house, it was looking good. But then the 0632 Southampton service I catch from Melksham to Trowbridge got delayed and was showing as 20 mins late, ....
Yeah ...
05:11 Gloucester to Southampton Central due 08:09 has been delayed between Kemble and Swindon and is now 16 minutes late.
... it appears to have arrived on time in Swindon but spent 30 minutes rather than 10 there.  Looks like it will be on time from Salisbury, in spite of Journey Check assuming "once delayed, delayed all the way". Guessing it was some sort of issue the crew on local staff at Swindon were able to sort out.
Posted by matth1j at 07:15, 28th May 2025
When I left the house, it was looking good. But then the 0632 Southampton service I catch from Melksham to Trowbridge got delayed and was showing as 20 mins late, meaning I'd miss the 0646 Trowbridge Bristol. And the next option, the 0705 Cardiff service, was also showing as delayed, with the following Filton Abbey Wood cancelled.
So I'm on the bus to Bath, where I should be able to catch the 0747 Weston service. What's even more annoying is that the 0705 Trowbridge Bristol that was showing as delayed ended up being on time - it just started from Westbury instead of Frome.
Try again tomorrow...
Posted by grahame at 15:42, 27th May 2025
15:15 Swindon to Westbury due 15:59 is being delayed at Swindon.
Posted by grahame at 14:47, 27th May 2025
14:18 Westbury to Swindon due 15:00 will be starting late from Westbury and is expected to be 20 minutes late.
Portsmouth to Cardiff running 50 minutes late ... now arrives in Westbury at 14:02 and I suspect the crew is transferring and is progammed to take a personal needs break.
All a very long way from Mockava I'm travelling on, which is supposed to pause at Trakiszki for 8 minutes but but was there for more like 30 ... couple of Polish border guards going through and checking passengers. Not sure whether it was just the two who got on, but the two who came to all compartments in uniform left with two others not in uniform.
Posted by TaplowGreen at 21:21, 26th May 2025
Posted by grahame at 05:39, 26th May 2025
26/05/25 06:35 Salisbury to Worcester Foregate Street due 09:47 will be started from Westbury.
Posted by TaplowGreen at 06:41, 20th May 2025
Posted by TaplowGreen at 09:44, 18th May 2025
18:10 Castle Cary to Swindon due 19:34
18:10 Castle Cary to Swindon due 19:34 will be started from Westbury.
It will no longer call at Castle Cary, Bruton and Frome.
With crew shortages all over the place, so far the Westbury to Swindon service is doing far better than most today, having said which even a single cancellation on that line leaves a huge gap.   I have to personally wonder at why, after so many years, crew shortages seem to be almost routine and look to the management and direction (from inside and outside the TOC) for having failed to avoid such issues being so frequent, or to cynically have passed them off as an acceptable lack-of-service level.
Succinctly, because those at the upper reaches of GWR tend to be Managers rather than Leaders, and there are few better examples than this long running issue.
Posted by grahame at 07:12, 18th May 2025
Posted by grahame at 11:51, 17th May 2025
11:05 Swindon to Westbury due 11:48
Can't get the train out of platform 2??
Greetings from the Dutch traveller where I have proof that connections don't always work here.  I have just HAD TO DROP BACK to a train 7 minutes later that I planned.  It's a DIS-GRACE
Posted by grahame at 11:48, 17th May 2025
Due to a points failure at Swindon trains have to run at reduced speed on some lines. Disruption is expected until 13:00 17/05.
Train services between Swindon and Westbury via Melksham may be cancelled.
Due to a points failure west of Swindon, we have had to cancel our Swindon to Westbury service.
Customers at Westbury can still travel to Trowbridge, but any customers for Swindon are advised to travel to Bristol Temple Meads and change.
We are arranging road transport for customers travelling to and from Melksham and Chippenham.
If boarding at an unstaffed station, please make use of the Help Point for more information.
Posted by Bob_Blakey at 09:49, 17th May 2025
.....17:50 Gloucester to Salisbury due 20:06 has been delayed between Gloucester and Stonehouse and is now 15 minutes late.
I am interested in the reasons why trains are often delayed for, apparently, no obvious reason and in the explanations provided to passengers.
In this particular instance the journey check text should have read '17:50 Gloucester to Salisbury due 20:06 departed Gloucester 8 minutes having returned to Platform 1 from it's waiting point 10 minutes later than scheduled, because the platform was occupied by the late running 2T49 WOF>BRI service until 1748, and has been further delayed on the approach to Stonehouse.'
Too much information obviously but I think the majority of people understand what is meant by the term 'depot' and I doubt the Gloucester Loco Spur qualifies.
And I can't figure out why the service lost another c. 8 mins between Standish Junction and Stonehouse.
Posted by grahame at 20:14, 16th May 2025
Posted by grahame at 09:40, 13th May 2025
06:35 Salisbury to Worcester Foregate Street due 09:47 was terminated at Gloucester.
It will no longer call at Cheltenham Spa, Ashchurch For Tewkesbury, Worcester Shrub Hill and Worcester Foregate Street.
Posted by grahame at 11:02, 11th May 2025
I am getting confused ... and not risking any trains today!
13:32 Swindon to Weymouth due 15:46
13:32 Swindon to Weymouth due 15:46 will be started from Westbury.
Last Updated:11/05/2025 10:21
Posted by grahame at 10:09, 11th May 2025
12:17 Westbury to Swindon due 13:32
13:32 Swindon to Westbury due 14:48
Additional 13:32 Swindon to Westbury due 14:48 will be cancelled.
The additional bus will no longer run as the train is now reinstated.
Posted by grahame at 09:51, 11th May 2025
An additional bus service has been planned to operate as shown 13:32 Swindon to Westbury due 14:48.
For customers travelling between Swindon and Westbury taxis have been arranged to run from Swindon to Westbury at 13:32 calling Chippenham, Melksham and Trowbridge. For customers at these stations intending to travel beyond Westbury, the taxis will set you down at the station you require between Westbury and Weymouth, please inform the taxi driver. The taxis are from Bath Taxis Limited. Before getting in any taxi vehicle please check with the driver that they are working on behalf of GWR, the driver should not ask for payment.
Posted by grahame at 07:56, 11th May 2025
10:38 Weymouth to Swindon due 13:03
13:32 Swindon to Weymouth due 15:46 will be cancelled.
Now changed to
13:32 Swindon to Weymouth due 15:46 will be reinstated.
It will be started from Westbury.
Still cancelled for my station, then ...
Posted by grahame at 06:06, 11th May 2025
Posted by GBM at 12:34, 10th May 2025
This is NOT the right forum section BUT.
10:45 London Paddington to Weston-Super-Mare due 12:35
10:45 London Paddington to Weston-Super-Mare due 12:35 will be cancelled.
11:12 Salisbury to Bristol Temple Meads due 12:31
11:12 Salisbury to Bristol Temple Meads due 12:31 will be cancelled.
15:00 Cardiff Central to Penzance due 20:42
15:00 Cardiff Central to Penzance due 20:42 will be cancelled.
One unit breaks down and three services cancelled?
Posted by grahame at 10:07, 10th May 2025
08:44 Swindon to Westbury due 09:25 is being delayed between Swindon and Chippenham.
20 minutes late into Westbury and no significant connections missed, return train left on time.   This turned out to be a pinprick of a delay compared to yesterday's major rupture when the train broke down which lead to the complete cancellation of six services.
Posted by TaplowGreen at 09:23, 10th May 2025
Posted by grahame at 20:13, 9th May 2025
Would someone please fix the bl**dy thing or split a couple of carriages off another train?    You could even split 5 cars off a London to Plymouth evening service now as they get quieter when they get past Westbury.
I've taken the liberty and had a look in a couple of directions ... not ideal, but here are some multiple units passing through Westbury.  16:08, 17:06 and 18:03 could all drop 2 carriages on their way to Portsmouth.  The first one would get a bit crowded further south, but the latter 2 with 3 and 2 carriages
What heads west - 10 carriages just after 6 p.m. and I'm sure only 5 are needed beyond Westbury. And there's that 9 car that goes out of service at Frome ;-)
Posted by grahame at 18:28, 9th May 2025
16:23 Westbury to Swindon due 17:05 has been cancelled.
I have a funny (peculiar, not haha) feeling that trains get swapped around and "fault on this train" is reported because an old crock or a train someone was doubtful about was assigned to the service.  The feeling is boosted by the reaction when I made a comment at Westbury about waiting for / catching the Swindon train (I forget the comment exactly) and eyes were rolled in such a way that indicated the staff see it as the flakiest that runs from there.
And now ...
20:14 Swindon to Westbury due 20:57
Posted by grahame at 17:19, 9th May 2025
Posted by TaplowGreen at 17:11, 9th May 2025
Posted by grahame at 19:35, 8th May 2025
Posted by bobm at 15:47, 8th May 2025
12:17 left Westbury on time but was stopped outside Trowbridge for 20 minutes as the preceding train to Cardiff had come to a stand due to a fault with the driver vigilance device.  It got on the move after systems were isolated and terminated at Bath Spa.
The Swindon service didn't make up any lost time and arrived in Swindon 20 minutes late before leaving 12 down on the return journey.
Posted by grahame at 13:16, 8th May 2025
12:17 Westbury to Swindon due 12:59 is being delayed between Westbury and Trowbridge and is now expected to be 21 minutes late.
13:14 Swindon to Westbury due 13:57 will be starting late from Swindon.
Posted by matth1j at 08:39, 8th May 2025
The 07:21/07:23 did call in the end, and the quick connection into Bristol that sometimes worked appears to have done so ... not sure how many people got put off and looked at other alternatives such as the bus or waiting (with fingers crossed) for the 08:02.
I was put off, but happy to take the less stressful 08:02 option
Posted by grahame at 08:21, 8th May 2025
The Salisbury-Worcester service now showing as running (on National Rail app), due Melksham 07:23
(started from Westbury I think)
In summary ... the 06:32 call didn't happen at Melksham and a taxi at 06:35 from Chippenham was added at some point.  Useful for those headed towards Southampton though it would have arrived at Trowbridge / Westbury well after the diverted train had passed there, so passengers for Salisbury who joined at Melksham and normally carry on at 06:55 would drop back to the 07:40 as far as Salisbury, or the 08:01 if headed for Southampton (yes, there is a commuter flow)
Personally I was trying my luck with a sub-5-minute change at Westbury onto the Weymouth train which runs every 2 hours and of course that would have failed.  With the taxi added, I would have left Westbury 2 hours after plan, and without the taxi (on the 09:10 from Melksham) 4 hours late. For a day trip, a 4 hours delay kills the day and I didn't try it once the cancellation came up (decision made before the taxi got added).  Had I been required to travel, I could have caught a bus to Frome and picked up the train there 2 hours after my plan.
For Bristol, the 06:32 connects into Bristol with an arrival at 07:28.   That would have failed this morning as taxis are slower.  Arrivals into Bristol at 07:48 or (more likely) 08:11 depending on how long the taxi too.
There are some slight but noticeable improvements in how issues are handled, but the rail industry seems to be intensely unreliable, with shortages of crew, trains breaking down, signalling failures. Short term cancellation rates are 5% at present and that's 3 times what "Which?" described as "dreadful" for an airline - it means that if you commute from Melksham Station for a fortnight, 5 days a week, you can expect one journey to be cancelled.  For passengers on the 07:21 to Chippenham or Swindon, that's "just" a 40 minute delay - with almost all other trains, especially with connections, it's far worse.   With a proper (every 30 minutes or better) service, a 5% cancellation rate could perhaps be shrugged off, but with a 120 minute frequency, every one hurts and damages the public confidence.
There IS a "thank you" due to the people who fixed the line, to the people who arranged the taxis.  But [they/you] should not be put into a position of having to do that so often, and they should have tools to give better feedback to the customers.  To some extent, they are victims of a skimping on maintenance and a reduction of available staff below sensible limits, just as the passengers are.  Here's looking to you - management and controllers ...
Posted by matth1j at 07:12, 8th May 2025
Posted by GBM at 06:43, 8th May 2025
Cancellations to services between Trowbridge and Chippenham
Due to a fault with the signalling system between Trowbridge and Chippenham the line towards Melksham is closed.
Train services running through these stations may be cancelled or delayed. Disruption is expected until 08:00 08/05.
Taxis have been sourced as below:
Bath Taxis - 06.35 Chippenham calling Melksham, Trowbridge and Westbury. Please wait for the taxis at the rail replacement bus tops.
Bath Taxis- 07.11 Trowbridge calling at Melksham and Chippenham. Please wait for the taxis at the rail replacement bus tops. Passengers can use any London Paddington train from Chippenham to Swindon.
Posted by TaplowGreen at 06:32, 8th May 2025
Posted by grahame at 06:11, 8th May 2025
05:11 Gloucester to Southampton Central due 08:09 will be diverted between Chippenham and Trowbridge.
It will no longer call at Melksham.
It will be delayed due to the diversion and is expected to be 7 minutes late.
This is due to a fault with the signalling system
To confirm to anyone who might be reading this in GWR - these are not just "7 minute delay"s - they are cancellations as far as Melksham (population 25,000) is concerned
Posted by matth1j at 06:06, 8th May 2025
Yeah and the 06:35 Salisbury to Worcester Foregate Street, which I would have caught at Melksham at 07:21 instead, is also showing as cancelled due to a signalling problem. Will wait for the 07:45 Westbury - Swindon (Melksham 08:02) and hope they've fixed things by then - I'm not buying a ticket, yet...
Posted by TaplowGreen at 05:50, 8th May 2025
06:35 Salisbury to Worcester Foregate Street due 09:47 will be started from Westbury and diverted between Trowbridge and Chippenham.
It will no longer call at Salisbury, Warminster and Melksham.
It will be delayed due to the diversion and is expected to be 10 minutes late.
Posted by grahame at 04:41, 8th May 2025
Posted by grahame at 19:51, 7th May 2025
Posted by matth1j at 13:59, 7th May 2025
It stopped to pick up a lucky few - looked like they were in for a very nice breakfast
Well it flippin should be for £425
https://saphostrains.com/journey/the-golden-arrow-07-05-2025/
"The day starts as you settle into your seat with a glass of chilled bucks’ fizz..." - before 7am...
Posted by grahame at 11:54, 7th May 2025
Golden Arrow - diesel (47) from Bristol to West London (Hanwell)  then Brittania London to Canterbury.
Posted by matth1j at 10:48, 7th May 2025
Looks like a special train went though Trowbridge while you were waiting?
Yes - there was an announcement that a charter service was due at 0653, and I wondered whether it might be worth leaving the waiting room if it was going to be steam powered. I didn't, and it wasn't - a diesel of some sort, obviously old and 'special', but not a Deltic. It stopped to pick up a lucky few - looked like they were in for a very nice breakfast
Posted by grahame at 09:35, 7th May 2025
The 06:32 service from Melksham to Southampton was uncharacteristically late this morning - departed at 06:38, which meant I just missed the (official) connection with the 06:46 Bristol service at Trowbridge. Don't know what caused the delay to the Melksham train - it left Chippenham on time, and was just described as 'running late'. Not a disaster though - caught the 07:05 Cardiff train.
First time there's been any sort of problem taking this route to Bristol for quite a few weeks. It's so much more reliable than the alternative via Chippenham, and is worth the very early start.
No obvious reason - it seems to have left Chippenham on time and then been stuck for 5 minutes at Thingley - however that was NOT waiting for something else to clear the single line.
Next train from Trowbridge was only a 19 minute wait ... next train from Chippenham when the unofficial connection fails is a 34 minute wait (it did connect this morning). Because it's official you can claim delay / repay for an 07:28 expected arrival to an 07:48 actual arrival into Bristol whereas you have no claim via Chippenham.  Only negatives about the Trowbridge change are the earlier start and the need to cross the footbridge which if you have heavy luggage or are in a wheelchair is not clever.
Posted by matth1j at 08:55, 7th May 2025
Posted by TaplowGreen at 14:51, 4th May 2025
Reinstated.
Thank you.  I wonder, sadly, just how much damage cancellation and re-instatement of services does on a line where waiting for the next service will be a significant change to plans.
I think most people would check to see if the service is running and if it isn't, they will make other plans - realistically, no-one is going to keep checking back on the off chance of a reinstatement.
Posted by grahame at 13:30, 4th May 2025
It is a question asked many times.  Unfortunately I suspect we will only ever have anecdotal answers.
It would require considerable data logging and analysis and work to try to remove other factors from the results.
It is probably a fair assumption that it makes SOME difference, with their being some people who don't book / make other plans when a train is recorded as cancelled.    An on that basis is worth pointing out to the people who cancel and then re-instate services that this practise reduced the number of passengers carried and p***es off quite a number too, and is a practise they should avoid.. If something is bad, it's not necessary to put a number on exactly how bad it is before you fix it!
Posted by bobm at 13:17, 4th May 2025
Posted by grahame at 12:22, 4th May 2025
Reinstated.
Posted by IndustryInsider at 09:57, 4th May 2025
Reinstated.
Posted by grahame at 06:30, 4th May 2025
Facilities on the 13:32 Swindon to Weymouth due 15:46.
Posted by grahame at 05:56, 4th May 2025
Let's record a day when it all worked - Saturday, 3rd May.
Back to a familiar scene this morning
09:26 Chippenham to Westbury due 09:51
09:26 Chippenham to Westbury due 09:51 will be cancelled.
Posted by grahame at 02:48, 3rd May 2025
A summary from yesterday - of 18 calls planned, just 7 happened.
Southbound at 06:32, 20:39 and 23:12
Northbound at 07:21, 08:02, 18:52 and 21:31
Early evening calls at 19:09 and 20:22 were cancelled, even though the line had been re-opened by that time.
Posted by TaplowGreen at 19:41, 2nd May 2025
I have to ask ... why does it take so LONG to get a failed locomotive out of the way?  Is it part of a more general set of things that seem for whatever reason to take fare longer to sort out when things go wrong?  No backup plans?  No spares/staff around?  Extra Health and safety requirements? Everyone a specialist?
I'd point that question at Hopwood if I were you, after all it's his trains that are being cancelled and his customers inconvenienced.  Given that, I'm sure he's all over those responsible and should be able to address your points.
Posted by grahame at 19:35, 2nd May 2025
"Short" runs this evening too - the 17:50 Gloucester to Salisbury and the 20:06 Westbury to Cheltenham Spa both missing out Melksham.  Makes sense to be reversing TransWilts trains at Bathampton - remembering that 2 out of 3 passengers along the single line on a normal day are going through (not from or too Melksham) and so this is the best solution for them.
Oops - and sadly that's not what they have done with the evening trains after all
20:06 Westbury to Cheltenham Spa due 22:05
20:06 Westbury to Cheltenham Spa due 22:05 will be started from Swindon.
So "disruption until 20:00" is the operational description.  Anyone who hopes to head from Melksham to Cheltenham Spa (agreed not a huge flow) at 20:25 won't get there until - what - 11 p.m. or later?  [Edit - looked it up - 23:31!]
Posted by grahame at 19:23, 2nd May 2025
Cancellations to services between Westbury and Swindon via Melksham
Following a broken down train earlier today between Trowbridge and Chippenham the line has now reopened. Disruption is expected until 20:00 02/05.
Train services between Westbury and Swindon via Melksham are returning to normal but some services may still be cancelled, delayed or diverted.
A freight train locomotive had broken down on the line between Trowbridge and Chippenham. Engineers from the freight company fixed the locomotive and it has now been able to move clear of the line.
We are now able to re-instate our train service, the first service from Westbury will be the 18:37 Westbury to Swindon and the first train from Swindon the 20:14 Swindon to Westbury.
For the trains that are not running we have requested replacement road transport to run between Chippenham and Westbury via Melksham and Trowbridge. Please check the stations Onward Travel Information poster and wait for the replacement road transport at the designated stop. Before getting in any taxi vehicle please check with the driver that they are working on behalf of GWR, the driver should not ask for payment.
Posted by grahame at 18:31, 2nd May 2025
Posted by TaplowGreen at 17:11, 2nd May 2025
20:14 Swindon to Westbury due 20:57 will be cancelled.
Posted by grahame at 16:45, 2nd May 2025
At least there is a replacement bus in place (scheduled to arrive Westbury 40 minutes after the train, but better than telling people to wait hours) ... not a clever day today.
Posted by grahame at 16:06, 2nd May 2025
The problem is with the freight loco itself and fitters are having difficulty isolating components on it before it can be moved.    A rescue loco is on site ready to move it once that becomes possible.
Thanks for that, Bob ....
18:13 Chippenham to Westbury due 18:56
An additional bus service has been planned to operate as shown 18:13 Chippenham to Westbury due 18:56.
Please check the stations Onward Travel Information poster and wait for the replacement road transport at the designated stop. The coach is operated by Chandlers Coach Travel.
16:23 Westbury to Chippenham due 17:04
An additional bus service has been planned to operate as shown 16:23 Westbury to Chippenham due 17:04.
There will be three MPV taxis from Bath Taxis. Before getting in any taxi vehicle please check with the driver that they are working on behalf of GWR, the driver should not ask for payment. Please check the stations Onward Travel Information poster and wait for the replacement road transport at the designated stop.
If you require further information please speak to our staff at the station or on the train, use the Customer Help Point, message us on X @GWRHelp or call National Rail Enquiries on 03457 484 950.
Posted by bobm at 15:58, 2nd May 2025
Posted by grahame at 14:54, 2nd May 2025
15:15 Swindon to Westbury due 15:59 will be diverted between Chippenham and Trowbridge.
Posted by rogerw at 12:36, 2nd May 2025
Just knock the faulty vehicle out of the train and drop it onto the North Loop to await attention from C&W.  Nothing booked to run over that today.  Oh.  Wait.
I know, I know.  If only
Guessing on what's wrong with the train - but there IS a siding still at Thingley Junction.
Although the siding is not easily accessible from the Melksham line
Posted by grahame at 12:19, 2nd May 2025
Posted by grahame at 12:09, 2nd May 2025
12:17 Westbury to Swindon due 12:59 will be starting late from Westbury.
Posted by Witham Bobby at 12:01, 2nd May 2025
Has 6A16 (Whatley Quarry to Oxford) sat down?
According to Traksy, 6A16 is still somewhere between Bradford Junctions and Melksham, at 1040
Without inside information, we can only guess.  JourneyCheck was telling us about problems until the end of the day, and I speculate that a skate might be needed to get something with wheel problems out of the way.   With lack of bypass loops and sidings, perhaps they are waiting for the more important lines between Chippenham and Swindon, and between Trowbridge and Westbury to become clear after service?
Posted by grahame at 11:17, 2nd May 2025
Posted by Witham Bobby at 10:42, 2nd May 2025
Posted by grahame at 09:32, 2nd May 2025
Too late to do anything about it today, but a proper integrated transport system should offer an alternative when you look up your train and try to book.  Rather that cancelled and a note that the next train is 151 minutes later, if the 09:52 id cancelled what not suggest that people catch the 09:55 bus from the top of the Trowbridge station approach - 10:29 in Melksham Town Centre and about 10:33 at the top of the Melksham Station Approach?   The fact that the bus goes past Melksham Station Approach and does not actually stop there is another issue ...
Posted by grahame at 09:10, 2nd May 2025
Looks like it ...
Due to a broken down train between Swindon and Westbury all lines towards Westbury are blocked.
Due to a train fault at Melksham, the line is blocked between Swindon to Westbury.
Road transport will operate between Melksham to Westbury/ Melksham to Chippenham.
Posted by grahame at 09:00, 2nd May 2025
Posted by grahame at 08:51, 2nd May 2025
08:45 Swindon to Westbury due 09:26
08:45 Swindon to Westbury due 09:26 will be diverted between Chippenham and Trowbridge.
Last Updated:02/05/2025 08:38
No suggested alternative ... late notice cancellation.  There may be operational reasons but it's the very late changes without an (it could be automatic) passenger-focused advise line are highly damaging to customer morale.
Posted by bobm at 22:13, 1st May 2025
Hold it!
Opportunities if the train is running to time, you have ...
1 minute (no chance!) at Westbury
7 minutes at Swindon (*)
9 minutes at Gloucester (*)
17 minutes at Worcester Shrub Hill
* - Train calls at platform away from station building
Agreed at Swindon but the toilets are on the same island platform and I reckon, even at the speed I walk, you could get to the lavatory and back in the time allowed.
Posted by grahame at 15:58, 1st May 2025
This is due to a fault on this train
At least they've given is two hour's notice this time rather than cancelling it at 18:08 as they did on Easter Monday.   One of those "don't ask" days.
Interesting that it's the 17:50 to Salisbury that's cancelled rather than the 18:10 to Westbury, on a service with a far more frequent service where a gap might be less missed.
Posted by TaplowGreen at 15:54, 1st May 2025
Posted by grahame at 07:20, 1st May 2025
Hold it!
Posted by grahame at 18:04, 29th April 2025
It's in "Oh no - not AGAIN" territory ...  known as being a risky train. I will look at putting some numbers on it some time.
This train has run 89 times in the last six months, in which there have been 130 weekdays.  28 of those days it was cancelled because of planned engineering, 2 because it was Christmas / Boxing Day.   So 100 "should" have run. 11% cancellation rate - a very high percentage for a weekday.
Here's the proof, and comparison to other services:
Because of the very thin service, any cancellation is serious.
Posted by grahame at 17:52, 29th April 2025
