Thames Valley infrastructure problems causing disruption elsewhere - 2025
19.4.2025 (Saturday) 15:02 - All running AOK
A special treat for Easter!
Radley, unfortunately.
Appleford.
8178B - Southall East
8336 - Maidenhead East
8326 - Slough West
8296 - Dolphin Junction
8334 - Maidenhead East
8301 - Dolphin Junction
8335 - Maidenhead East
8027 - Royal Oak
Project Brunel anyone?
would be better as
Posted by grahame at 09:33, 19th March 2025
Owing to urgent repair work required on a small section of track in the Ealing Broadway area fewer train services are able to operate between London Paddington and Reading in both directions
Posted by GBM at 09:37, 17th March 2025
Alterations to services between Reading and Maidenhead
Due to a points failure between Reading and Maidenhead some lines are closed.
Train services running to and from these stations may be delayed or revised. Disruption is expected until 11:30 17/03.
A problem with some points (the means by which trains move from one track to another) in the Twyford area means that we have to reduce the number of train services operating over that section of line.
As a result, train services between London Paddington, Reading and Oxford will operate to a reduced frequency in both directions. Any customers travelling between London Paddington and Oxford (and vice versa) may utilise Chiltern Railways services between London Marylebone and Oxford (in both directions) as an alternative. GWR tickets will be accepted on those services and also on London Underground services between Paddington and Marylebone in order to facilitate this.
Train services between London Paddington and Newbury will not operate between London Paddington and Reading. Customers to / from these services will be required to change trains at Reading.
Please accept our apologies for any inconvenience this may cause.
Posted by TaplowGreen at 06:19, 15th March 2025
Due to a broken rail between Reading and London Paddington some lines are blocked.
Posted by TaplowGreen at 20:36, 11th March 2025
......and again.....
Following a points failure at Twyford the line will be reopened shortly. Disruption is expected until 21:30 11/03.
Train services between London Paddington and Reading may be delayed by up to 40 minutes or terminated at Reading.
Problems caused by a points failure near Twyford have now been resolved, and trains can run normally again. However this has caused significant delays and will take a while for the train service to recover.
Posted by a-driver at 19:59, 10th March 2025
TfL have publicly stated how un8mpressed they are with Network Rail previously.
Their public statement of unhappiness clearly achieved a lot!
It achieved a fair bit in securing additional resource, acknowledgement of shortcomings and undertakings that there would be improvements, but unfortunately this has yet to be delivered.
https://www.theguardian.com/uk-news/2024/feb/27/140m-rail-plan-to-tackle-elizabeth-line-and-great-western-problems
And 12 months on from that article there’s been no improvement.  It was all predictably bluff and bluster from Network Rail.
Posted by Ollie at 01:49, 10th March 2025
I’m on the 19:04 EL train from TWY (I’m going to Hayes) which left from P2 (which I was fortunate to aim for as according to RTT the previous one ran 13 minutes late and didn’t call there). This particular train is non-stopping Taplow and Burnham as indeed all EL trains are doing this evening with no advice that I’ve seen or heard so I don’t know what passengers to and from those stations are meant to do.
Burnham and Taplow was still able to be served by the Elizabeth line services that start/terminate at Maidenhead. It was only those to/from Reading that were unable to call.
Posted by BBM at 19:22, 9th March 2025
Also all the GWR trains on the PAD-DID route are shown on the screens at TWY as cancelled - from RTT it looks like they’re running but not stopping at TWY or MAI as in the message posted above.
Posted by grahame at 18:49, 9th March 2025
How would you describe that piece of hard-coded text then?
* An apology.
* An expression of care in acknowledging it is not as it should be.
I'm not sure it even needs a title though
Posted by ChrisB at 18:45, 9th March 2025
Posted by grahame at 18:42, 9th March 2025
Is it just me - or is that really NOT customer advice?
I would expect "Customer advice" to be something like "People who normally use GWR trains to Maidenhead or Telford should allow an extra  half hour and will need to change at Reading if coming from further west" . It actually advises the customers what to do!
Posted by grahame at 18:34, 9th March 2025
Alterations to services between Reading and Slough
Due to a points failure between Reading and Slough some lines are blocked.
Train services running to and from these stations may be delayed or revised. Twyford and Maidenhead will not be served. Disruption is expected until 21:00 09/03.
Due to a points failure at Twyford, GWR services cannot call at Twyford and Maidenhead. Elizabeth line services can still call at these stations.
Posted by TaplowGreen at 07:09, 9th March 2025
Posted by a-driver at 17:50, 8th March 2025
Posted by ChrisB at 15:03, 7th March 2025
TfL are a direct customer of Network Rail
GWR are a customer of the DfT, and a secondary customer of Network Rail of which Network Rail is a get-out clause within their DfT contract.
Posted by TaplowGreen at 14:37, 7th March 2025
Reading elsewhere that TfL are seriously unimpressed with the constant failures between Paddington and Reading (points, signal, track etc) which are affecting the Elizabeth Line and are taking a robust line with NR at a senior level, asking for details to be set out as to what is being done to address it.
A refreshing contrast with the apparently rather more quiescent GWR it would seem.
Whether it'll have any effect of course remains to be seen!
Posted by nickswift99 at 09:12, 6th March 2025
Except passengers struggled to go that way either. Passenger taken ill (which was unfortunate) meant that there were no trains to Waterloo from 0609 until 0728. I was lucky yesterday - didn't need to be in London until later so was able to get one of the first fasts from Reading at about 0835 - Reading station was pretty much deserted.
Posted by Wizard at 04:29, 6th March 2025
The Evening Standard reported that
Some trains were re-routed to London Waterloo.
Did that really happen?
Not a chance. Passengers were via SWR, the trains themselves weren’t.
Posted by ChrisB at 19:46, 5th March 2025
Check Real Time Trains?
Posted by Surrey 455 at 19:44, 5th March 2025
Posted by TaplowGreen at 05:15, 5th March 2025
Breathtakingly hopeless...............
Due to a fault with the signalling system between Slough and Twyford all lines are blocked. Disruption is expected until 09:00 05/03.
Train services between London Paddington and Reading will be cancelled.
Due to a fault on the signalling system between Slough and Twyford, the trains that run from London Paddington to Reading in both directions are unable to leave the depot. This means we have had to suspend the train service.
Posted by TaplowGreen at 04:46, 5th March 2025
Cancellations to services between Slough and Twyford
Train services running through these stations may be cancelled or delayed. Disruption is expected until 05:00 05/03.
Due to a complete loss of signalling between Slough and Twyford no trains can run.
Posted by TaplowGreen at 07:41, 2nd March 2025
From National Rail - Journeycheck still asleep.
between Ealing Broadway and Slough
Overrunning engineering works between Ealing Broadway and Hayes & Harlington means that some lines between between these stations are blocked. As a result, trains running through these stations will be cancelled or delayed by up to 10 minutes.
Trains are currently unable to run between Ealing Broadway and London Paddington.
Disruption is expected until 08:15.
Posted by TaplowGreen at 09:05, 1st March 2025
Hard to believe I know but yep, here we go again (from National Rail this time)
Services at Slough
A points failure at Slough means that some lines are blocked.
As a result, services at this station may be cancelled, delayed or revised.
Disruption is expected until 11:00.
Posted by TaplowGreen at 07:36, 28th February 2025
Points failure at Slough this morning.
From the rerouting I suspect it’s on the main line
Yep..........
Train services running to and from these stations will be cancelled, delayed or terminated at and started back from Reading. Disruption is expected until 11:00 28/02.
We are sorry for the disruption to your journey today, due to a points failure in the Slough area, the high speed lines are blocked. This means our high speed long distance trains and other operators local stopping trains are having to share the same lines.
Posted by NickB at 07:14, 28th February 2025
Posted by Oxonhutch at 20:11, 25th February 2025
I do wonder exactly keeps failing. There are many components associated with points that are not necessarily part of the mechanical points themselves. Is it detection? Track circuit sytems?
Posted by TaplowGreen at 14:14, 25th February 2025
Getting ridiculous now......time for the digit to be removed from the orifice and the root cause addressed.....
Due to a points failure between London Paddington and Reading some lines are blocked.
Train services running to and from these stations may be cancelled, delayed or revised. Disruption is expected until 15:30 25/02.
Posted by TaplowGreen at 06:04, 25th February 2025
And again.......
Delays to services between Slough and Reading
Due to a points failure between Slough and Reading some lines are blocked.
Train services running to and from these stations may be delayed by up to 15 minutes. Disruption is expected until 08:00 25/02.
A set of points on the high speed lines between Slough and Reading has failed.
Trains will need to be crossed over to other available lines to bypass the issue. This may mean you will encounter some delays to your journey this morning.
More information will follow as we have it.
Posted by TaplowGreen at 11:03, 22nd February 2025
Due to a points failure between Reading and Slough:
Train services running to and from these stations may be delayed by up to 20 minutes or revised. Disruption is expected until 11:30 22/02.
As consistent as Wales.
Posted by TaplowGreen at 06:02, 21st February 2025
Train services running to and from these stations may be delayed by up to 15 minutes. Disruption is expected until 10:00 21/02.
A set of points on one of the lines between Slough and Reading has failed.
Posted by NickB at 07:19, 19th February 2025
Bust track at both Hanwell and Ealing Broadway.
Everything is delayed. Yay.
Posted by TaplowGreen at 06:00, 19th February 2025
Train services running to and from these stations will be delayed or terminated at and started back from Reading. Disruption is expected until 09:00 19/02.
We are sorry for the delay to your journey today. Due to a section of faulty track in the Hanwell area, our trains have to run at a reduced speed over the fault. Network Rail are trying to fix the fault, but in the meantime we are going to have to cancel some of our trains between Reading and London Paddington. This is necessary to prevent a traffic jam of trains building up as they slow down over the faulty track.
Our trains that run between Newbury and London Paddington will only run between Newbury and Reading.
Posted by NickB at 22:30, 12th February 2025
Ah Southall was it?!
2hrs to get home to Maidenhead tonight via Elizabeth Line tonight including getting retrained at Slough so that the empty train could arrive at Reading faster.
Interesting to see how the timetabling and track priorities shift over the evening. During rush hour the Didcot services were running fine and the Elizabeth Line trains ran slow with 40min delays. Now, at the end of the day, Didcots are cancelled and tfl is running ok(ish)
Posted by TaplowGreen at 21:44, 12th February 2025
Delays due to defective track. Non-specific location.
Specifically Southall!
Cancellations to services between London Paddington and Newbury via Reading
Due to a broken rail at Southall fewer trains are able to run on some lines. Disruption is expected until the end of the day.
Train services between London Paddington and Newbury via Reading may be cancelled.
Due to a broken track in the Southhall area, only a limited number of trains are able to run on this line. As a result, some train services may be cancelled or delayed
.....also affecting Didcot services.
Posted by NickB at 18:11, 12th February 2025
Posted by UstiImmigrunt at 10:31, 9th February 2025
This may be due to a very late start to the engineering work as the stop board was placed on the wrong track and destroyed by an IET.
https://www.realtimetrains.co.uk/service/gb-nr:G68678/2025-02-08/detailed#allox_id=0
was the train involved I believe.
And some interesting decision making being done as well, the driver was happy to keep going but others decided he wasn't fit to continue.
Posted by TaplowGreen at 07:19, 9th February 2025
Cancellations to services between Ealing Broadway and London Paddington
Due to urgent repairs to the track between Ealing Broadway and London Paddington all lines are blocked.
Train services running to and from these stations will be cancelled or revised. Disruption is expected until 13:00 09/02.
We are sorry for the disruption to your journey today.
Network Rail have declared a possession overrun for this morning whilst carrying out essential track maintenance.
Owing to this, GWR services will not be able to run past Reading on journeys towards London Paddington and no services can depart London Paddington heading towards Reading. Some Elizabeth Line services will run but only as far as Ealing Broadway.
Posted by grahame at 23:04, 8th February 2025
Gonna be fun at Paddington ...
Sun, 9 February 08:44 London Paddington to Penzance due 14:06
Sun, 9 February 08:46 London Paddington to Great Malvern due 11:14
Sun, 9 February 09:00 London Paddington to Bristol Temple Meads due 10:43
Sun, 9 February 09:16 London Paddington to Oxford due 10:15
Sun, 9 February 09:28 London Paddington to Carmarthen due 13:17
09/02/25 09:28 London Paddington to Carmarthen due 13:17 will be cancelled.
This is due to urgent repairs to the track.
Sun, 9 February 07:36 London Paddington to Great Malvern due 10:15
Sun, 9 February 07:38 London Paddington to Didcot Parkway due 08:57
Sun, 9 February 07:47 London Paddington to Penzance due 13:32
Sun, 9 February 07:57 London Paddington to Exeter St Davids due 10:57
Sun, 9 February 08:28 London Paddington to Swansea due 11:22
Sun, 9 February 08:48 London Paddington to Didcot Parkway due 09:53
08:48 London Paddington to Didcot Parkway due 09:53 will be started from Reading.
It will no longer call at London Paddington, Slough, Maidenhead and Twyford.
Sun, 9 February 09:45 London Paddington to Penzance due 15:06
09/02/25 09:45 London Paddington to Penzance due 15:06 will be starting late from London Paddington and is expected to be 30 minutes late.
This is due to urgent repairs to the track earlier today.
Posted by Chris from Nailsea at 10:03, 8th February 2025
I'll prepare another new topic, ready for 2026.
Posted by TaplowGreen at 09:47, 8th February 2025
And again today - after a reasonably good start to the year, slipping back into the old routine
Due to a speed restriction over defective track between Reading and London Paddington fewer trains are able to run on all lines.
Posted by TaplowGreen at 16:35, 7th February 2025
Train services running to and from these stations will be cancelled, delayed or terminated at and started back from Reading. Some stations between Reading and London Paddington will not be served. Disruption is expected until the end of the day
Posted by TaplowGreen at 12:38, 5th February 2025
Alterations to services between London Paddington and Didcot Parkway via Reading
Due to a points failure between Slough and Hayes & Harlington some lines towards London Paddington are closed. Disruption is expected until 14:15 05/02.
Train services between London Paddington and Didcot Parkway via Reading will be suspended between Reading and London Paddington. All stations between Reading and London Paddington will not be served.
........also affecting services towards Newbury.
Posted by Marlburian at 20:07, 29th January 2025
From National Rail
Urgent repairs are needed to the track between London Paddington and Acton Main Line. Trains running between London Paddington and Heathrow Airport / Reading may be cancelled, revised or delayed by up to 20 minutes.
A friend of mine boarded the 1023 at Paddington which, she texted was "going nowhere" for 12 minutes,eventually she got to Reading and waited for the 1123 to Tilehurst/Didcot, which was progressively "delayed", eventually being announced as running fast to Didcot. By then I was waiting in the car at Tilehurst Station, where the concourse was jammed with vehicles of contractors working on the lists - and an ambulance making a rare appearance in its dedicated parking space; I was half-blocking the entrance and advised my friend to take a taxi and returned home. When I got there, I reflected that she might as well have waited for the next local service and she came to the same decision, opting to walk to my house. BTW nowadays the station car park seems almost as full as it was pre-Lockdown.
Posted by NickB at 19:18, 29th January 2025
And the Elizabeth Line was bust this evening too.
My gripe for this evening is with (one of) the gateline crew at Paddington. There must have been 1000 people queuing for the 18.20 to Didcot.  The gateline team were checking all paper tickets and turning away anyone with a TFL ticket. That included a woman ahead of me who had a 2/3 year old child in that throng.
Where is the sense or humanity in turning that woman and child away, who arguably had a valid ticket, and who then had to battle through the ongoing masses to wait god knows how long for a TFL service.
I’m off to complain to GWR on her behalf.
Posted by TaplowGreen at 07:33, 29th January 2025
From National Rail
Posted by TaplowGreen at 11:17, 28th January 2025
Due to failure of the electricity supply between London Paddington and Reading trains have to run at reduced speed on some lines.
Train services running to and from these stations will be delayed. Disruption is expected until 08:00 28/01.
Due to a fault with the overhead electric supply tripping affecting the UP and Down relief lines, trains in this location will be delaye
d.
Disruption now expected till 1600
Posted by TaplowGreen at 07:24, 28th January 2025
Due to a fault with the overhead electric supply tripping affecting the UP and Down relief lines, trains in this location will be delayed.
Posted by TaplowGreen at 08:45, 12th January 2025
From National Rail - Journeycheck having a lie-in.
Elizabeth line between London Paddington and Heathrow Airport / Reading
Great Western Railway services to / from London Paddington
Heathrow Express services to / from London Paddington
Overrunning engineering works between Ealing Broadway and Hayes & Harlington is causing disruption to services. This means that trains between London Paddington and Heathrow Airport / Reading may be cancelled, delayed by up to 40 minutes or revised.
Posted by Chris from Nailsea at 19:25, 10th January 2025
Sadly, yes.  From the Richmond & Twickenham Times:
Hanwell station Elizabeth line incident: Person dies
A person has died after an incident on the Elizabeth line at a busy west London train station.
A casualty on the tracks was reported at Hanwell station at around 1.15pm today (January 10).  Officers and London Ambulance Service crews attended, and the person was pronounced dead shortly after.  The incident is not being treated as suspicious and a file will be prepared for the coroner.
All lines between London Paddington and Reading have been closed as the incident is being dealt with.  Major disruption is expected until 4.30pm.
If you need someone to talk to, Samaritans are available to contact any time day or night on 116 123.
A spokesperson for British Transport Police said: “Officers were called to Hanwell railway station at around 1.15pm today (10 January) following reports of a casualty on the tracks.  Paramedics also attended, however sadly a person was pronounced dead at the scene.  The incident is not being treated as suspicious and a file will be prepared for the coroner.”
My highlighting - hopefully helpful.  Chris.
Posted by IndustryInsider at 14:30, 10th January 2025
Phew, thank goodness for that!  New Year, TG!
I think perhaps you tempted fate...................
Due to the emergency services dealing with an incident between Ealing Broadway and West Ealing all lines are blocked. Disruption is expected until 16:00 10/01.
Fatality at Hanwell by the looks of it.  The ultimate unhappy new year for somebody then.  Thoughts to friends, family and all involved.
Sadly, we are now ‘in the season’ for such incidents.
Posted by TaplowGreen at 14:19, 10th January 2025
Train services between Reading and London Paddington may be cancelled, delayed or revised.
Due to emergency services currently dealing with an incident in the Ealing Broadway area, all trains are temporarily on stop. We apologise for the disruption and any inconvenience this may cause.
Posted by IndustryInsider at 14:08, 10th January 2025
Posted by TaplowGreen at 07:42, 10th January 2025
TaplowGreen must be in hibernation.
My apologies - normal service resumed.
Cancellations to services at Slough
Due to a points failure at Slough fewer trains are able to run.
Train services running through this station may be cancelled or delayed. Disruption is expected until 08:30 10/01.
Posted by IndustryInsider at 15:39, 9th January 2025
Posted by UstiImmigrunt at 15:36, 9th January 2025
So what's gone wrong? January 9th and nothing reported!
Posted by IndustryInsider at 20:13, 19th December 2024
I'm merely preparing the ground here, ready for member TaplowGreen to develop this topic, in due course.
Let somebody else have a go, TG!
Posted by Chris from Nailsea at 18:50, 19th December 2024
No, I haven't lost the plot!
Rather, I'm sharing member ChrisB's view that this sort of problem won't suddenly go away on New Year's Eve:
And the first for 2025....New Thread please!
