Re: South Western Railways Waterloo - Bristol services axed
7.6.2025 (Saturday) 03:28 - All running AOK
Posted by TonyK at 17:17, 2nd June 2025
Now that GBR is responsible for the former franchise of SW[TR], is it time for them to be Great British and consider restoring the through services from London via the County Town of Wiltshire - the nearest county town to London without a through train from the capital.
I confess, I had to look it up, and was half-expecting it to be Melksham.
Posted by bradshaw at 14:18, 25th May 2025
If we could get a return to the NSE sub-divisions and give them some autonomy then there may be a chance. The WoE would look after the main line and perhaps Reading Basingstoke, along with Salisbury to Southampton. Their brief would be to develop the business, looking at other opportunities such as Bath and Bristol.
The Portsmouth Direct and Weymouth lines would return to Solent and Wessex.
Posted by Mark A at 10:30, 25th May 2025
That'll need a return to the likes of the pre-2018 SWR culture - in those times it was meeting people's travel needs, had a healthy set of destinations, passenger numbers on the service were trending upwards, with encouragement from the TOC and plans to grow the service.
Industrial relation woes, plus a change of franchise with a new MD with their heart in mass transit for big cities has left the SWR services west of Basingstoke in a curious situation and I wonder how (or if) they will be pulled together.
The road network isn't good, rail has plenty of potential and particularly to the South West there's a lot of suppressed demand, but without political pressure, will we just see the likes of 'Until the service improves we're not going to give you any breathing space to develop'? This at a time that Covid caused the service to contract along with the revenue - and at that time some of the seed corn went in the bin.
So, is there a mechanism up and running behind the scenes that takes a rail system that's essentially been nationalised for years albeit with a very curious model, can it quickly turn that into a system that's quick on its feet, hungry for growth and better able to serve people's need to travel? We'll soon find out.
Posted by TaplowGreen at 08:17, 25th May 2025
I think the message for this and all aspects of "renationalisation" should be "manage your expectations".
https://www.independent.co.uk/travel/news-and-advice/great-british-railways-south-western-london-waterloo-b2756798.html
Posted by IndustryInsider at 08:00, 25th May 2025
GBR isn’t responsible for SWR.  The DfT are.  And wasn’t it them that mandated their removal in the first place?
Posted by grahame at 05:01, 25th May 2025
Posted by Mark A at 11:38, 9th April 2025
Thanks for this, thought it was me. Now I know this I've just run the searches again and it's easier to see what's going on.
The issue with the cost seems to be SWR as the fare setter, and the off-peak/super off-peak structure that they introduced in the years since the through trains ran, which has put the prices up.
The £48.35 day return fare allows a 10:20 am arrival at Waterloo and return travel in the evening peak.
Later in the day, that day return fare is undercut by the super off-peak period return at £37.60 (with the return half valid for a month but unlike the off peak day return not valid in the evening peak).
Posted by grahame at 22:16, 8th April 2025
By the way - the web site ignoring "via" is not limited to "via Salisbury".   Also had problems getting Melksham to Newcastle via a single change in Cheltenham Spa - single change off the 07:21  and with limited mobility much better than via Paddington and Kings Cross.  When I asked "not via Reading", the Cheltenham Spa route came up.
Posted by grahame at 22:08, 8th April 2025
The plot thickens. Thinking to check Bath Spa - Paddington to compare current costs vs via Salisbury, neither the National Rail site nor GWR will list the super off peak return fare. This might be me: I'll have another look on... another day. (Off peak Bath Spa to Paddington with a railcard comes up at £69.70, the super off peak fare is listed on brfares.com as £50.50).
I have found that the GWR ticket purchase system is failing to honour "via" requests but has been honouring "avoid" so you're likely to find that it's missing if you do "via Saisbury" but offered if you do "avoid Reading".  May be that has been fixed and I'm not around long enough to check just at the moment
Yep ... "Avoid Reading" gives it
Posted by grahame at 21:18, 8th April 2025
Posted by ChrisB at 20:35, 8th April 2025
Have you checked brfares.com?
If it’s still there, then it’s in the fares manual & the TOC(s) are suppressing it….if they aren’t listed, then the fare has been withdrawn
Posted by Mark A at 19:48, 8th April 2025
Posted by Mark A at 18:14, 8th April 2025
Graham posting observations on train fares in January '24 in another thread:
The Bristol / Bath to London day return fare, it's been withdrawn, yes?
There are still two off peak day return fares Bath Spa to London via Salisbury and Warminster there - first class and standard class - according to BRfares. Still there from 2nd January too. Price is £66.20 (adult, no railcard)
If you want something a bit different, try an anytime day return from Portway Park and Ride to London via Warminster and Salisbury at £43.40 - it's restricted in that you may not arrive into Waterloo before 10:00, but there are no restrictions on the return time.
Checking this again, April 2025 and the Bath Spa - Waterloo off-peak day return is still on the system (using the National Rail web site, I can't find it on the GWR site which appears to ignore 'Via Salisbury'). It's now priced at £72.60, so, a nearly 10% increase on the January 2024 figure. A railcard brings that down to £48.35.
Back in 2022, in the last days of the through trains, the 'With railcard' fare... was it around £33? In which case the present day fare is a 46% increase on the 2022 fare. While the connections at Salisbury are rather improved on those at the time the through trains disappeared, it still 'Won't do'™.
Oh and the Severn Beach maneuvre still applies.
While checking this, the journey I was actually after was Bath Spa to Basingstoke in a day, and the best value for that is a day return at ~£21 for a mid-day arrival.
It always surprises me how far Basingstoke is from London. Even farther now given the state of the up main east of Woking, but perhaps that's been fixed.
Posted by ChrisB at 19:30, 23rd September 2024
So even fewer days diverted to Euston then. About 2 (1 weekend) a year on average, the worst year being 3 weekends (6 days)
Posted by Mark A at 16:52, 23rd September 2024
Now look at it again from the POV of someone who's tied up weekdays and uses trains at weekends.
Posted by ChrisB at 16:46, 23rd September 2024
Given the years of diversions east of Reading to Euston looming large,
Eh??
A few days a year - 18 at most for one year. Might all add up to a month in total.
Posted by Mark A at 15:46, 23rd September 2024
A quick reflection at the weekend that we're still in the month that, three years back and mid-pandemic, saw the last Saturday Bristol to Waterloo services, at a time when the Saturday services in particular were rapidly rebuilding their passenger numbers.
Given the years of diversions east of Reading to Euston looming large, cutting these really does now look to have been one of the less inspired moves by the DfT. If I never see that advertising screen again it'll be too soon.
Here's that photo of the last Saturday morning service at Bath Spa. I revisited the station the following Saturday at the time it would have run, place was dead.
Posted by grahame at 10:26, 5th July 2024
Fast forward to July 2024: not saying that the loss of the service affected any if the outcomes as there are far greater forces at play* but happy to see the backs of a couple of the transport secretaries who oversaw those times.
*HS2 phase 2a being a consideration asfar as the rail network is concerned.
I am getting some sleep ... running a wind-down environmental hustings meeting this afternoon and I will be working on transport futures for the area.    Yes, I have read Labour's ideas, and listened to our new Lib Dem MP's views and look to see how we can ask them to move things along appropriate lines for passengers but also in line with their policies, requirments, dogmas.
Posted by Mark A at 09:50, 5th July 2024
Posted by paul7575 at 14:05, 29th April 2024
The eventual aim is a direct Kings Cross - Middlesbrough via Northallerton service every 2 hours. AFAICT that might take passengers off Grand Central’s Sunderland open access which doesn’t directly connect with Middlesbrough, but picks up passengers from the area at Eaglescliffe.
The Middlesbrough trains are and will be completely separate to the once a day Sunderland service.  The relatively short lived Sunderland runs in marginal time via Newcastle, ie the early up train leaves Heaton depot and runs empty to Sunderland through Newcastle, then back to Newcastle in service, presumably it then heads off in the normal timings for a Newcastle starter.  Same for the late down train, it runs to Sunderland from Newcastle, then empty back to Heaton depot via Newcastle.  So effectively the Sunderland service doesn’t require additional rolling stock.
Coincidentally, the empty stock for the first Middlesbrough up service runs empty through Sunderland, and vice versa at end of the day.  (It does make you wonder if those services could serve Sunderland instead.)
Posted by Mark A at 21:26, 28th April 2024
I remembered this thread touched on through services in the North East when I saw this news from The BBC
A train company is planning to scrap one of its train services to London due to low passenger numbers and a lack of trains.
LNER said it would no longer run from Sunderland to London Kings Cross from December, with the service instead starting in Newcastle.
The operator said the service had low passenger numbers since it was introduced in 2015 and passengers could still travel to London using other companies.
or am I getting confuse with this daily service
07:08 Middlesbrough
07:15 Thornaby
08:13 York
10:20 Kings Cross
15:27 Kings Cross
17:21 York
18:08 Thornaby
18:18 Middlesbrough
The morning train's arrival from Sunderland at Kings Cross being just after 9am, is very peak-timey, with fares to match. A Sunderland resident is looking at £550 for a return to London first class on the LNER through train, or £275 standard.
Book in advance, and that brings rail travel costs down to £217 there and back, advance 1sts available for ~£350. Return tickets aren't sold.
And indeed, the Sunderland LNER service is a separate train to the one from Middlesbrough (and turning to Middlesbrough, this looks to be peak time in both directions, so... 1st Class both ways is £616 or £387 standard class, though there does seem to be rather more availability of advance fares).
A quick dip into National Express coach prices from either Sunderland or Middlesbrough looks to be about £15-£25 each way with a journey time of around 7 hours.
Posted by grahame at 13:08, 28th April 2024
Middlesbrough has an hourly service to York and a half hourly service to Darlington, both of which have services to London at least every 30 minutes. The proposed London service duplicates the existing service to York. Double standards?
So you could leave Middlesbrough on Northern or TransPennine Express and change to either LNER or Great Central, and in addition you can now travel direct with LNER too.
Other than the fact this service started at the same time the SWR trains were withdrawn, I'm not sure it makes for a good comparison.  Just the one direct train a day from Middlesbrough, also calling at Thornaby, which have a combined population of more than four times Bradford-On-Avon and Trowbridge.
07:08 Middlesbrough
07:15 Thornaby
08:13 York
10:20 Kings Cross
15:27 Kings Cross
17:21 York
18:08 Thornaby
18:18 Middlesbrough
Posted by Mark A at 12:15, 9th December 2023
As Graham mentions upthread, from tomorrow, Bristol to Salisbury trains connect far better with Salisbury to Waterloo services - to the extent that ticketing sites such as National Rail once again offer through tickets on many services that the site previously didn't recognise as connections.
This reinstates a semi-useable train service not only between Bristol and London but the likes of Trowbridge and London - or between the many pairs of intermediate stations, which will be appreciated by a young guy on the train yesterday travelling from Andover to Bristol and who had apparently been given a link to a travel survey as long as your arm along with a substantial bribe for completing it.
The good: some connections at Salisbury are actually less than 20 minutes. Also there's now a useable service from Bristol to London with walk-up anytime return ticket prices from Bath of £66 (railcard) or a walk-up option of £80.80 (full fare, no railcard). Also good, many people find they like Salisbury's class 159 trains - clean windows and interiors, cosy seats and one of the morning connections in particular is a 'Change at Westbury' which works well from the point of view of the quality of the journey.
The less good: a journey which at one point took two hours and ten minutes from Bath (it stopped at major stations save for Salisbury and Westbury, both of which it ran through without stopping) currently takes around 3 hours, no buffet etc and of course the TOCs not being permitted to rebuild the popular through service. Yet...
Overall, such a step change in quality of service that the railway needs to be promoting it. This isn't something that happens very often in Wiltshire and the South West. If it was a new service such as that to Okehampton people would be swooning - and it *is* effectively a new service, especially considering that the evening connections were previously so dire that ticketing web sites either just shrugged or when pressed attempted to sell a meagre provision of advance tickets routed via... Southampton.
Posted by anthony215 at 22:14, 25th October 2023
With grand union proposing a Cardiff to Edinburgh service wish they'd propose a Carmarthen to London Waterloo service
Posted by grahame at 16:51, 24th October 2023
Two years on, my Facebook memories came up with this:
Ironic that with extra (GWR) trains now running to Salisbury, and more Salisbury <-> Basingstoke trains extended to Waterloo from December, the awful connections have become far less awful.  All it needs is stuff terminating from the Bristol direction and stuff terminating from the London direction to carry on as though services.
Perhaps when its all one great GBR enterprise, they can provide a joined up service and contract First to run it.  Anyone fancy a word in the ear of Andrew Haines?
Posted by Mark A at 15:23, 13th October 2023
Improvements to the SWR December 2023 timetable at Salisbury mean that most connections to and from Bristol, Bath will be around 20 minutes, both outward and return.
The first walk up off-peak ticketed connection from Bath Spa is going to be the 7:35, offering an arrival into Waterloo at 10:20. Not as user friendly or marketable as the through service that ceased in 2021, but an improvement as the last two years offerings have been a bit dire.
SWR's train up from Westbury at 7:42 has a connection into it from Bristol and Bath Spa - but is at Anytime prices which is a shame as when I've been on it, it was carrying mainly fresh air for a good part of its journey. It would be far more useful to run it up from Bristol and Bath... at 9:07, say. (On the other hand it does sometimes get an allocation of advance fares).
Posted by grahame at 15:06, 11th September 2023
1. The extra GWR trains you mention (to Salisbury) only run during the "quiet" part of the day - during the morning and evening busy periods you are back to 1 hourly service and the 58 minute wait at Salisbury for a train to Warminster.
I don't disagree.
When we campaigning for addition services through Melksham, potentially we could have had them during the day a couple of years earlier, but we stuck out for a service to meet the anticipated flow requirement which was a commuter service.
Now - north of Westbury to east of Salisbury is not a commuter flow - or at least to the same extent.   I agree with you that it still remains a horrid wait at certain times - however there's potential there for a handful of the services to be joined up and for the target customer base the tradiitona; peak may not be (so) important.
Posted by Clan Line at 09:52, 11th September 2023
Here comes the irony.  GWR are now running an extra train every hour from Bristol to Westbury, and quite a few of them beyond - five of them to (and terminating at) Salisbury.  From what I've seen they're a mixture of turbos and 158s. And they question has be be asked where the joined up thinking has gone.   It would make so much sense for these units to provide the strengthener units that are added to the Exeter to Waterloo trains routinely at Salisbury and once again provide a through service.  I expect SWR have noticed this internally!
A couple of extra points about the present "service" on this line.
2. It would appear that the rolling stock for these additional GWR trains has been obtained by reducing the length of the Cardiff - Portsmouth trains throughout the day.
The so called improvements on this line are very much a smoke and mirrors box ticking exercise !! Lots of extra trains/seats (say GWR) - but at entirely the wrong time of day...................
(I put my daughter on the SWR 1051 to Waterloo at Warminster yesterday - it seemed well populated. I noticed that the GWR service was down to its usually dire state with a later train already showing as cancelled - one of 6 cancellations according to RTT today)
Posted by Mark A at 13:25, 10th September 2023
It probably has been good in driving people who are travelling to London from Bristol, Bath and West Wilts onto the more expensive routes via Reading.
A few, yes, but I suspect that rail has simply lost the majority of the passengers that used the through service, some to car, while others travel less or travel elsewhere. All there to be regained of course, and likely in these changed times to rebuild above 100% of what it was.
Posted by grahame at 10:10, 10th September 2023
From another source I hear that when the Bristol - Waterloo trains were canned, there was internal rumbling within SWR as it really wasn't a direction people wanted to take, and those rumblings have not subsided.
I wouldn’t be surprised that there were rumblings. The service was well used and very successful, sometimes a bit too successful based on past experience.
This would not surprise me either.  The decision to take off the service was a poor one in my view, and I felt at the time and still do that it was more a political one than anything else, with the fact of the case bent to ensure they met the required outcome. No consultation, and little or no input from experts who knew and underststood the flows and service served. It probably has been good in driving people who are travelling to London from Bristol, Bath and West Wilts onto the more expensive routes via Reading.  From an accountants viewpoint, the extra income for the IETs already running to London probably outweighs the loss of income on the 158 to Waterloo and the saving on staff and fuel for that is probably the icing on the cake.
Posted by Timmer at 18:51, 9th September 2023
Posted by Mark A at 11:33, 9th September 2023
Just filled in a customer survey for South Western Railway, the survey exploring past / current / future use of their network.
My responses possibly didn't directly expose why I expect income to them from me having dropped to a tenth of what it was pre-covid, to stay at that level through to 2024 - but intriguingly the survey was headed up by a map of their system that included Bristol (though no services) and the pick-list of station names for a 'Home' station included Bath Spa.
Posted by Mark A at 15:09, 31st July 2023
Ah, a source for that 41,000,000 figure here - it's 2021-22 hence on the low side. (The page has figures from the previous years too.)
https://www.railwaydata.co.uk/stations/overview/?TLC=WAT
Posted by grahame at 12:41, 31st July 2023
Affectionate article on Waterloo Station in 'Country Life' magazine
Includes this: "Fewer people are travelling by train since covid. In 2019, Waterloo welcomed 98 million passengers, but that has now fallen to about 41 million per annum."
I'm wondering if that statistic is current...
https://www.countrylife.co.uk/news/175-years-of-london-waterloo-the-gateway-to-everything-thats-wonderful-258047
Very interesting to hear the Secretary of State - Mark Harper - talking today about the new importance of leisure traffic and thanking people for encouraging it, but how it's vital for the railways that commuters and business traffic also returns.
Had it been. person to person talk and not a speech to the masses, I might have asked him how some of the cutting back such as (this thread's topic) helps leisure traffic, and with the changing world whether it's realistic to expect all the "vital" commuters and business traffic back.  PreCovid, I thought nothing of s journey to a business meeting, but these days that's the exception and meetings are done online for th most part.   Is Mark setting objectives that will probably fail?  Does he know that?
Posted by Mark A at 11:49, 31st July 2023
Posted by Worcester_Passenger at 18:09, 20th July 2023
I seem to remember that, when the Birmingham - Cheltenham route via Kings Norton was closed for engineering work on Sundays, and CrossCountry had to go round via Kidderminster, then their trains would stop at Kidderminster to offer an easy day out on the Severn Valley Railway. Alas, by the time you were going home, they were back on the main line.
Posted by Mark A at 17:12, 20th July 2023
With the 2023 tennis at Wimbledon receding into the past like a recently slipped coach viewed via a rearward glance from aboard the train of passing time*... a moment's pause to reflect that the Bristol to Waterloo through trains, when the tennis was on, would call at Wimbledon station to help make the journey seamless for passengers with that destination. It's the sort of thing that Scotrail would do.
Fast forward to today and with very few through trains to Warminster, even 'Imberbus' when it comes to rail travel from stations east of Salisbury, is out in the cold.
*Apologies, been out in the sun earlier.
Posted by JayMac at 09:47, 9th June 2023
SWR's current onboard network map:
Posted by Mark A at 18:44, 29th May 2023
What a world we live in. I asked Google's 'Bard' about these trains.
The withdrawal of the direct services has made it more difficult for passengers to travel between Bristol and London. Passengers now have to change trains at Reading, Salisbury, or Winchester, which can add significant time to their journey.
That's not strictly true though is it, because they can travel from Bristol to London via Paddington with GWR, which is much faster and more frequent than the SWR service to Waterloo, and a direct service, so they don't have to change?
OK they still have to change at Paddington and use the Underground if they want to get to Waterloo, so in that respect you could stretch a point and say it's "more difficult" but that still represents a considerable time saving from the old Bristol - Waterloo service?
Indeed, Bard's response for that question is a salad of edible green leaves, chopped onions and daffodil bulbs. It hasn't pulled in network benefits, the qualities of through trains, and the contribution to the quality of service for people travelling from intermediate stations. Perhaps the DfT provided the salad dressing.
Posted by grahame at 17:48, 29th May 2023
The article is a load of tosh - real facts mixed in with inaccuracies, false conclusions and things that are downright incorrect - but some things are spot on.
I cannot imagine a journey from Bristol to London that requires a change at Winchester.
Spot on?   Things like this ...
The decision to withdraw the direct services is a clear example of how the government's focus on austerity is having a negative impact on public services. The government needs to do more to support the railways, so that passengers can continue to travel easily and sustainably."
The removal of the through service was ... IMHO ... DafT ...
I notice we now have 5 Bristol Metro services from Bristol that terminate at Salisbury ... and 22 trains each day that run from Salisbury to London (Waterloo).  It is common practise for those trains at Salisbury to have extra carriages added for the busier part of that route into London.  Has anyone suggested that the carriages coming into Salisbury on the Bristol Metro be added, rather than ones from the depot?
Posted by TaplowGreen at 15:18, 29th May 2023
Posted by Mark A at 09:50, 29th May 2023
https://bard.google.com/
Me: "Can you tell me about the Bristol to Waterloo direct train services run by South Western Railway that ceased to run in December 2021?"
Holding up a mirror to its sources, Bard responded:
Bard: "Sure. In December 2021, South Western Railway (SWR) ceased to run direct train services between Bristol Temple Meads and London Waterloo. This was due to a number of factors, including:
    The COVID-19 pandemic had a significant impact on passenger numbers, and SWR was not able to make the services financially viable.
    The route was not as popular as other routes operated by SWR, such as the service between London Waterloo and Southampton.
    The route was not as profitable as other routes operated by SWR, such as the service between London Waterloo and Bournemouth.
The decision to withdraw the services was met with anger by many passengers, who argued that the services were essential for connecting Bristol and London. However, SWR defended the decision, arguing that it was necessary to make the company's finances sustainable.
In addition to the inconvenience, the withdrawal of the direct services has also had a negative impact on the environment. The longer journey times mean that more trains are needed, which in turn produces more pollution.
Posted by Mark A at 13:41, 10th May 2023
It has to be said that the National Rail site routes an evening connection or two via Southampton - but it's no longer a permitted route, hence, advance fares only. SWR didn't take up my suggestion that 'Via Southampton' should be reinstated as a permitted route.
Posted by grahame at 13:23, 10th May 2023
Serpell ( http://www.passenger.chat/17797 ) proposal C3 above,
Checking possibilities for a Bath Spa - Woking via Salisbury return trip I was inspired to imagine a world where the onward Salisbury to Southampton route didn't exist, and nor did the line west to Exeter, leaving Salisbury as a through station on a Bristol - Trowbridge - Warminster - Salisbury - Basingstoke - Waterloo line. If you recall that the Beeching era may have seen Salisbury to Exeter shut, at least part of this filght of the imagination is not so fanciful.
If the railway through Salisbury had been reduced to this single route, the likelihood is that it wouldn't have been subject to the frequent poor connections available there.
Single route would have been Westbury - Salisbury - Southampton, I'm afraid ... change at Southampton for London?
Posted by Mark A at 13:07, 10th May 2023
Or perhaps it would... elsewhere, it's surprising to find end-to-end rail lines built, sometimes with difficulty, over which neither through trains nor connecting services were run, usually as a result of a border between the services of two rail companies - echoing the culture revealed by some thoroughly coruscating examples on the canal system.
Posted by Mark A at 21:28, 22nd December 2022
Just one year from the last Bristol to Waterloo trains, courtesy of an order from the DfT that they cease to run.
Now, an article from 'Railway Gazette' with talk of Serpell and more, on the emerging threat to the network from that same DfT. There's a bit of a screenshot from the article on this Twitter thread:
https://twitter.com/HanneyDP/status/1606032263182950401
The article itself, on registration, is available here:
https://www.railwaygazette.com/uk/rail-leaders-frustrated-as-dft-tightens-grip-and-cuts-loom/63216.article
Posted by Mark A at 08:40, 13th October 2022
Around ten months out from the last of the well used Bristol Waterloo direct trains now, and SWR have just surveyed some of their customer base and good to see that 'Bath Spa' was still in the options for the list of stations served by SWR in the timeframe for which they were surveying.
Answered honestly, the brief survey didn't quite capture that with the loss of the trains, my use of their network has fallen off a cliff (and my use of Wiltshire's roads somewhat increased). Job done, DfT. (Wrong job of course...)
Posted by Mark A at 16:19, 23rd September 2022
Coffee at a cafe in town yesterday, and I was pleased to hear that this is still a live issue with the public. A young guy got into a conversation with staff about having been caught up in OHLE-related delay shenanigans both Monday and Tuesday. On the Tuesday he returned via Salisbury - and both participants in the conversation were aware of the relatively recent loss of the direct trains to Waterloo and what a PITA* that was.
*Acronym is indelicate and not suitable for inclusion in this forum's lovely mouseover info.
Posted by Mark A at 14:34, 17th September 2022
I'm reflecting that it's a bit under 11 months since that meeting in Trowbridge, listening to a representative from the DfT talking rather indistinctly about the lack of justification to fund the Bristol to Waterloo through services - that ceased last December.
His low key delivery provoked two members of the public to leave the meeting there and then as they could clearly see that the DfT was not in listening mode on this one.
This was a train service that would have made a growing contribution to transport provision across that part of Wiltshire, particularly at the time of the death of a monarch, but also into the future, as the nature of rail travel changes, with use of the railways not-for-commuting becoming more popular
Trowbridge, Warminster, in particular are now stuck with such poor evening connections from London that the likes of the national rail website directs passengers via Southampton despite it no longer being a valid route for through ticketing. At Salisbury, there's a tangible hole in the rail network from both the point of view of the travelling public and the online ticketing system. This at a time when Highways England are very keen to push through improvements to the A303.
Posted by Mark A at 09:17, 14th August 2022
Hmm, in a probably heat related incident, a bit of Salisbury Station's glazed roof has shed panes of glass onto the platform and track. No one injured, though there's also been an injury accident to a passenger there this weekend. (Person versus wheelybag, been a victim myself a couple of years ago though luckly didn't faceplant.)
Posted by Mark A at 09:49, 7th August 2022
Do any of the ticket selling sites allow a deep link to a particular journey / fare search?
Evening connections at Salisbury remain so bad that eg the national rail site, fed a search for a via Salisbury return journey from say Bristol to Blackheath... now finds only a single evening service for which it is prepared to return a fare.
(All other services it identifies are routed via Southampton, against which the site lists 'No fares available for this journey'.)
A trip which last year, off-peak with a railcard, cost I think £33.00 from Bath - Blackheath is now £47.50 return via Paddington and anything via Salisbury entails travel into the late evening as the only connection which is half decent is off the last one of the day and an arrival time after midnight.
Posted by Mark A at 11:41, 6th August 2022
From the GWR Customer and Stakeholder report 2021/22 published August 2022, grateful to one Chris Irwin for this:
"It was, therefore, of regret that GWR seemed unable to find ways of ameliorating the very poor connection times for passengers at Salisbury from Bristol, Bath and west Wiltshire to the southern home counties and London Waterloo caused by SWR’s withdrawal of through service between Waterloo, Salisbury, and Bristol."
It would have been lovely if it had been a bit of a theme from everyone though. Mark Hopwood in his introduction states, quite correctly:
"Rail is not about trains, it is about connecting people and places and we do that best when we work together"
With regards to current Bristol - Waterloo service provision, that report is a case of 'Talk the talk' at a time that they need to get down and fix something that, starting with the arrival of the new SWR franchise, the industry conspicuously broke.
Posted by grahame at 08:52, 22nd July 2022
https://www.southwesternrailway.com/other/about-us/our-plan
(No sign of them reinstating the chunk of the December '21 timetable change on which they didn't consult of course...)
No direct reference.   But I hope that
We will modernise and simplify the customer offer, taking into account the full end to end journey experience to improve our customers’ on-train and at station experience.
means that clockface connections at Salisbury will be sorted out
We will deliver a punctual and reliable train service that meets the needs of our customers through matching capacity to demand
means that demand from WECA and West Wiltshire will be met with punctual and reliable trains
We will maximise and sustain the recovery and growth of our own and whole industry revenues following the pandemic
means, again, that they will look for growth
Sadly, most the quotes above are sandwiched with weasel words and phrases ... and I could find some very negative things that could be done within the plan's apparently positive design.   I note that the ultimate way to simplify something is to withdraw it, and one approach to raising revenue is to increase the price - directly or by limiting the usefulness of lower priced options.
Posted by Mark A at 13:52, 21st July 2022
South Western Railway has published its 2022-23 business plan. Among other things, changes arising from the December '22 timetable consultation have been put back 'till is it May '23.
Posted by oldshire at 19:52, 9th July 2022
It's very sweet of her to give her payout to charity but the money belongs to the taxpayer!
Posted by TonyK at 16:53, 9th July 2022
Michelle Donelan, the MP for Chippenham has been appointed Secretary of State for Education.
It's surprising that there are Tory MPs out there prepared to join a sinking ship.
She's resigned. That has to be a record for the shortest tenure as a minister of state.
36 hours, with a payoff of £17,000. Although she left without making any big mistakes, like Sam Allardyce, the only England manager never to lose a game.
Posted by JayMac at 10:46, 7th July 2022
Posted by GBM at 07:24, 7th July 2022
Our local (Conservative) M.P has recently spoken against the Prime Minister.
Prior to that, he's kept his personal views quiet, only speaking about current agenda issues.
He's the only Cornish one to do so.
Steve Double has said as he's a Whip, he's supporting the party line.
George Eustice has said he's remaining in post.
The other three MP's haven't said anything.
I know, I know, politics will divide us and this is nothing to do with Waterloo to Bristol
Posted by JayMac at 15:11, 6th July 2022
Posted by grahame at 13:51, 6th July 2022
Andrew Murrison has resigned from a government post, here's his letter.
We have gotten to know Andrew well over the years and he's certainly been a good friend on the public transport side - an unassuming man who you could quite easily pass on Westbury station, and I feel that he's put his principles ahead of his career or his popularity with his colleagues and ministers at times. His support at the tail of last year was notably strong and genuine - he really asked the questions with a view to getting concrete local consideration and change, going rather beyond just meeting with ministers to let us know he had put our case.
I don't always agree with Andrew's views but I have a repect for him. Sad to see him resign, but in the funny world of politics and the Conservative party ...
Posted by Mark A at 12:18, 6th July 2022
https://twitter.com/AWMurrison/status/1544385269138350081
(He's the Conservative MP for South West Wiltshire. Circa 2004, when the Waterloo trains were previously threatened at a change of franchise, he did much to ensure the well used service was retained. Fast forward to the recent campaign, was it the case that he was supportive but with the current DfT decision makers found he had no influence on the issue?)
Michelle Donelan, the MP for Chippenham has been appointed Secretary of State for Education. A fair percentage of her constituents signed Graham's lovely petition in support of the service, just trying to recall exactly what percentage... ah, here it is: https://petition.parliament.uk/petitions/598397
Posted by paul7575 at 22:46, 28th June 2022
South Western Railway's web site on the topic of Wimbledon tennis championships.
They don't seem to be going as far as organising that additional trains call at Wimbledon to ease and encourage travel from further afield. Not sure the extent to which that was done in the past, but it *was* done, and very recently.
https://www.southwesternrailway.com/destinations-and-offers/sights-and-attractions/trains-to-wimbledon-tennis-championship
Granted there are no through trains from Bristol, Bath, Bradford-on-Avon or Trowbridge to Wimbledon this fortnight, but there are extra calls - I took a look on Saturday:
Arrivals from beyond Basingstoke (Weymouth, Yeovil Junction, etc) at 05:49, 10:32, 11:06, 11:32, 12:06, 12:09 and 12:32
Returning at 18:03, 18:20, 18:33 and throughout the evening until 23:51
I just did a drill down into RTT for a summary of this evenings (28/6) services, if you select passenger calls only, and subsequently calling at Woking, you get this:
https://www.realtimetrains.co.uk/search/detailed/gb-nr:WIM/to/gb-nr:WOK/2022-06-28/2142?stp=WVS&show=pax-calls&order=wtt&toc=SW
AIUI all the calls at P7 are tennis extras, as P7 is normally locked off to passengers.   It seems typical for the Wimbledon fortnight.  A similar exercise in the morning would involve looking for calls on P6.
Posted by Mark A at 20:50, 28th June 2022
Carrying on with the theme of bespoke train services for events, here's Iansvisits on the 2022 Imberbus day.
https://www.ianvisits.co.uk/articles/the-surreal-experience-that-is-imberbus-returns-in-august-55660/
for ticket suggestions from London, he's reduced to suggesting split ticketing the fare at Salisbury.
No enhanced train service to this, but there's a through train at 08:50 from Waterloo. Nothing in the opposite direction though apart from, if the light is right, the ghost of the old service from Bristol which presumably passed Warminster at a rather useful 5 o'clock(ish).
Looking at return trains, the fares are a bit all over the place - and into the evening, there's a couple of traditional looong connection times at Salisbury - with near three hour travel times, while the last train of the day involves a connection via Bath.
Posted by Mark A at 20:12, 28th June 2022
So they do, thanks for this. Be good to mention that on the event promotion page on the SWR web site, I'll drop 'em a line.
The services include e.g. Exeter at 07:25 arriving Wimbledon at 10:32 so 3 hours 7 minutes. And, currently 9 advance singles for tomorrow available at £37.80, (cf offpeak return at £95:40, mind...)
Return trip mostly involves a change at Woking, but there is a through train from Wimbledon to Exeter at 20:33 with similar AP fares, which is thoughtful.
Posted by grahame at 17:52, 28th June 2022
Posted by Mark A at 17:28, 28th June 2022
Posted by Mark A at 12:38, 21st June 2022
Transport Focus tweeting on the industrial action:
"Day 1 of #railstrikes. We’re keeping an eye on passenger experiences.
Last night we popped into Wool station (Dorset) to check on info for would-be travellers. We'll share our feedback with @SW_Help .
This morning we were at an almost-empty Brighton.
http://ow.ly/UONS50JCljL "
https://twitter.com/TransportFocus/status/1539171291130896385
Is it ok to feel a bit jaded with this? The campaign for the Bristol to Waterloo services left me with the impression that the days of any industry body to represent the travelling public were long past. If pressed, the issue was treated 'Pass the parcel' style between organisations in order to shield the people who make the decisions. One (small) aspect that has contributed to the low morale and unrest within the industry, something which is now several orders of magnitude more costly, and in several ways besides financial.
Posted by Mark A at 08:37, 19th June 2022
Cartoon from a Twitternaut, the two carriages along with the text made me think of the slant brought to the Trowbridge campaign meeting by the rather softly spoken chap from the DfT with his emphasis on 'We must save taxpayer money'.
The Waterloo trains are rather in my mind at the moment as, if they were running, in the next couple of weeks there would be three times that I'd use them for return trips (twice to Woking, once to Basingstoke) and as things are I'll probably not be travelling at all.
https://twitter.com/anotherJon/status/1538405745502441473
Posted by paul7575 at 22:44, 16th June 2022
That really is a good view. The disused nearest end of East Putney P3, this side of a barrier, seems in pretty good condition doesn’t it?  I’ve seen far worse on the wider national network…
I can’t remember exactly when, but I did the route on a Sunday Southampton to Waterloo service in the mid 2010s, maybe 7 or 8 years ago, they were diverted all day for engineering work, sufficient to have a reduced LU service for the day. I think it was a 10 car 444.
Posted by Mark A at 19:37, 16th June 2022
The East Putney route is used every day by SWR, pre-Covid there were over 20 movements daily, a bit less today, and mainly ECS but with just a few passenger services.
Thanks for this. Also, the following dates scraped from a deceased member of another forum:
"1. The Up flyover and connection with the Up Windsor Fast was closed on 4.4.87 (because of weak bridge) and subsequently removed. To replace it, the Down line was (eventually) made reversible from 11.2.91." Much of the track on the up line seems to survive despite being out of use for 35 years.
Here's a photo from a Twitternaut of East Putney station, close to the junction with the Windsor lines, from an uncommon vantage point. The two platforms on the left carry the lines to the junction, known as Point Pleasant. Platform 3 out of use, Platform 4 last saw a train in 1941, allegedly.
https://twitter.com/calsurv/status/1500031432571432960
Google satellite view shows that a lump of electrical equipment now occupies a vantage point high on the approach to the up viaduct over the Windsor lines. (There seems to have been an unwritten rule on the railways that if any are available, new equipment must be positioned if possible to obstruct former trackbeds.)
Posted by paul7575 at 15:10, 16th June 2022
Which has also reminded me that route knowledge was such that in the event of Wimbledon to Clapham Junction being unavailable, South West Trains would run services via the rather engineering-heavy surviving down spur at Putney, and now I'm wondering whether the spur is bi-directional, and whether the spur is still used in this way. But this is wandering far from GWR territory...
The East Putney route is used every day by SWR, pre-Covid there were over 20 movements daily, a bit less today, and mainly ECS but with just a few passenger services.  Somewhat less use at weekends but still used. The few passenger services provide route knowledge for drivers from country depots.
It’s still by far the best down direction access to Wimbledon Park depot, any trains to the depot via Vauxhall would have to cross the up slow and both fast lines.  Also yes the spur to the Windsor lines is bidirectional.
Here are tomorrow’s booked moves, you’ll see there’s one passenger WTT move in the late evening, but there’s a couple of passenger moves after midnight tonight:
https://www.realtimetrains.co.uk/search/detailed/gb-nr:ZPU/2022-06-17/0000-2359?stp=WVS&show=all&order=wtt&toc=SW
Posted by Mark A at 11:52, 16th June 2022
Mark ,I know Twitter can be an infuriating experience but I've never known Peter to bight anyone's head off ,in all my years of being there .
It was justified, and actually it was only a nip rather than a bite. At the time I was running out of road with the Bristol to Waterloo services and knew that people used them to travel to Imberbus - and those not on the through trains were liable to be bitten by the connection time at Salisbury - but I shouldn't have tried to drag him into it.
That aside, now thinking of rail services to events - and particularly that South West Trains, for the two weeks of the tennis, had the Bristol to Waterloo services make a special stop at Wimbledon. Wondering when was the last time *that* happened, but it's a good example of a TOC stepping up.
Posted by Western Pathfinder at 12:14, 1st June 2022
Posted by Mark A at 16:45, 31st May 2022
Didn't use this myself, but since we're a month away from July, the Bristol to Waterloo direct services, when the tennis was on, called at Wimbledon, yes?
Another event whose users probably miss these trains is the Imberbus operation, which possibly explains why Peter Hendy bit my head off when I tweeted something about it once.
Posted by paul7575 at 22:10, 9th May 2022
So now we see it’s a national survey, presumably we can wonder about why those other places are not on the SWR network, eg York, Cambridge, Norwich, Brighton…
Posted by Surrey 455 at 22:00, 9th May 2022
Alas, it wasn't around long enough for the internet archive to save a copy.
It's still there. Just looks as if Bristol Live got the beginning of the link wrong.
Try this - https://www.southwesternrailway.com/where-next/things-to-do/uk-independent-retailers
Posted by Mark A at 20:15, 7th May 2022
Posted by paul7575 at 19:59, 7th May 2022
Article on South Western Railway sponsored research in the Bristol Post.
https://www.bristolpost.co.uk/whats-on/shopping/bristol-named-fifth-best-place-7045951
Given that Bristol and Bath are No. 2 and 3 on their list for the South West, I'm looking forward to hearing that South Western Railway will reintroduce services to the two destinations which are still on their network map even if they do not at present serve either of them.
It seems perverse than a business that's looking to regrow on travel / tourism / leisure should cease to server the number 2 and 3 travel / tourism / leisure destinations.  Or are they pinning their hopes on promoting travel to such lovely sounding places as Redbridge and Rowlands Castle, Hilsea, Hedge End, Millbrook and Maldon Manor, Raynes Park, Syon Lane, Sunnymeads and Martins Heron.
Odd that the hyperlink to “South Western Railway” in the Bristol Post article doesn’t actually go anywhere?
But they do still go to Exeter, Bournemouth, Southampton, Poole, Portsmouth, Reading, London, I don’t think you need to bring in the minor halts just yet…
Posted by grahame at 19:45, 7th May 2022
Posted by ChrisB at 19:02, 7th May 2022
Fat chance, the DfT are saving money
Posted by Mark A at 18:24, 7th May 2022
Posted by Mark A at 19:03, 29th April 2022
Resource listing the top issue in all parliamentary constituencies. Too much to hope that for Chippenham, it's 'Economy' rather than 'Gis Trowbridge back its Waterloo trains'.
Press release
https://twitter.com/chrishanretty/status/1520057621109166080
Data (in a Google Doc)
https://docs.google.com/spreadsheets/d/1oGsSNopxoRwbG2sVJpAY4a8kKYVZxlmcfVVcyGdJUv4/edit#gid=0
Posted by Mark A at 17:49, 15th April 2022
In view of the often poor connections offered at Salisbury, I've asked South Western Railway to change the routeing guide to permit  travel from Waterloo to Bristol via Southampton. (Not sure when it ceased to be a valid route, does anyone know?)
SWR customer service have responded that the routing point calculator is broken with a technical issue, no timeframe to fix but will be reinstated on their web site once sorted.
Posted by paul7575 at 15:51, 13th April 2022
Is Waterloo to Bristol via Southampton quicker than the normal route?  Is the 2 tph Waterloo to Salisbury ever returning?
Thanks for this. Via Southampton is sometimes no slower. In the evening, there's a three hour slot from 18:20 to 21:20 when the connections at Salisbury are sufficiently dire that the National Rail journey planner advises travel via Southampton - but then if return fares are selected, states 'No fares available'. It's happy to sell an advance fare via Southampton - how an advance fare is available for connecting trains on a route that's supposidly not valid is another matter.
Also, did SWR previously have a blanket ban on the use of off peak return halves of tickets in the evening peak? The National Rail site seems to think this no longer applies & SWR's web site in the way it describes peak travel ticket restrictions... it could be better.
My understanding is that yes, advance fares do exist outside the routeing rules, and always have.
When SWR started they didn’t have any blanket evening restrictions on “Offpeak” fares, but they did initially continue with SWT’s evening restrictions on the “Super-Offpeak”.   The latter didn’t allow departure from Waterloo, Vauxhall or Clapham Jn between 1600 and 1900.
Posted by Mark A at 15:41, 13th April 2022
Posted by paul7575 at 12:02, 13th April 2022
It was quite a few years ago, (since found a 2013 discussion in railforums.co.uk).
IIRC a whole load of the routes and maps were “fixed” shortly after someone unwisely insisted to a train guard that according to the maps he could use a Basingstoke to Fareham ticket via Salisbury…
The NRES journey planner suggests Waterloo to Salisbury via Southampton is only permitted with a higher price “via Southampton” ticket.  Their info box says it can only be used via Southampton, which seems odd as it’s a higher price than the any permitted…
Posted by Mark A at 11:32, 13th April 2022
Posted by Mark A at 11:23, 13th April 2022
Very sorry that the petition wasn't enough to secure the Waterloo train service - and also very pleased that Graham was moved to create it in the first place as it has recorded data that's useful for the future.
Even in the few months that's elapsed since the service ceased, economic challenges, and people's economic circumstances have changed considerably and the need for these trains has if anything increased. It's a loss to individuals, to communities and to the rail industry that interchange at Salisbury is now so poor.
Posted by grahame at 20:46, 10th April 2022
Just to note for the record, the petition closed with 6,572 signatures.
Signatures by Constituency (this is the top of the list)
1,617 - Chippenham
1,496 - South West Wiltshire
469 - Bath
333 - North East Somerset
145 - Somerton and Frome
119 - Bristol West
103 - Devizes
98 - North Wiltshire
97 - North West Hampshire
88 - Salisbury
69 - Bristol South
67 - Kingswood
50 - Bristol North West
49 - Basingstoke
42 - Bristol East
30 - Woking
Signatures by Region (this is the top of the list)
5,025 - South West
553 - South East
395 - London
90 - East of England
59 - East Midlands
Posted by bobm at 19:49, 10th April 2022
Posted by REVUpminster at 07:13, 6th April 2022
In my attic I have a Graham Farish N gauge model of a 158 Alpha train that ran from Paignton-Southampton?? along the south coast. Who can remember this train and who operated it?
I did once due to Engineering works on a Saturday Waterloo- Paignton/Plymouth 159 service diverted via Southampton and it ran so late it was reversed early at Newton Abbot.
Posted by Mark A at 18:28, 4th April 2022
The linked article suggests that SWR has commissioned research to identify "The top literary hotspots in the UK" and rated them 1 to 9. It moved me to consider each with regards to through trains from Bristol / Bath.
While SWR does still serve London (Number 1 in the charts) the other two on the list that they *did* serve  -Bristol at number 9 and Bath at number 5 - the DfT pressured them into dropping those two from their network.
Turning to GWR, from Bristol, by direct trains they once served Oxford (Number 4) and in May will cease to serve Brighton (Number 3).
It's probably appropriate to give a nod to Wales and West's long vanished service to Liverpool (6 in the list)
And also perhaps, for Bath, Edinburgh (Number 2 in the list and pre-Covid, served by a single through train courtesy of Crosscountry). Also, an honourable mention to the Bristol - Edinburgh sleeper, lost at privatisation when it had a steady 50000 passengers a year.
https://www.bristolpost.co.uk/whats-on/whats-on-news/city-bridgerton-set-crowned-top-6885377
Posted by grahame at 07:43, 21st February 2022
South Western Railway having announced a date at which their services will return to 'Pre-omicron' levels 21st February ....
Unfair considering the weather issues, but it has been pointed out to me that this promise has not been kept ... services this morning are not at the level they were at the start of December, nor at the level they were at mid December ...
Cancellations to services on all routes
Due to severe weather some lines are blocked.
What's Going On:
Train services running across the whole South Western Railway network may be cancelled, delayed or revised. Disruption is expected until the end of the day.
What We're Doing About It:
Storm Franklin will cause severe disruption to our network today and we are urging you not to travel.
Storm Franklin expected to lead to high level of incidents across the network
50mph speed limit will cause delays and cancellations
Customer safety and welfare the top priority
Tickets booked for travel on Friday, Saturday, Sunday and Monday will be accepted on Tuesday.
Since Fridays winds of over 90mph, Network Rail have cleared more than 50 fallen trees from our network. We still face challenging weather conditions as the Met Office has issued a yellow weather warning for Storm Franklin until the end of today. With the wind direction expected to change it is very likely that more trees will come down during Storm Franklin, having been weakened over the last two days.
With strong winds forecast, there will be a 50mph speed restriction across the SWR network on Monday to protect the safety of our customers and colleagues, causing delays and cancellations to services. We also anticipate further line blockages due to fallen trees and we urge you not to travel as we regrettably are unable to guarantee replacement travel services will be provided during this challenging time.
We're sorry for the disruption that this is causing and thank you for your patience as we deal with the ongoing severe weather.
Tickets for travel on Friday 18th, Saturday 19th, Sunday 20th or Monday 21st February will be accepted for travel on Tuesday 22nd February. If you are travelling on an advanced ticket on Tuesday 22nd February, please try to travel at a similar time to your original booking.
If you wish to rebook your journey at another time you can do so with no administration fee. If you have tickets dated for travel on Friday 18th, Saturday 19th, Sunday 20th or Monday 21st February and decide not to travel, you will be able to obtain a refund with no administration fee. This may be able to be completed at your local Ticket Office but it depends on the type of ticket you purchased and where you originally purchased your ticket. You must apply for a refund within 28 days of the ticket's expiry date. More information on ticket refunds can be found here: www.southwesternrailway.com/contact-and-help/train-ticket-refunds
For the latest information visit https://www.journeycheck.com/swr/
For more information about how we work with Network Rail to combat delays caused by poor weather conditions, you can visit Network Rails Delays Explained here: https://www.networkrail.co.uk/running-the-railway/looking-after-the-railway/delays-explained/
Posted by grahame at 11:02, 14th February 2022
South Western Railway having announced a date at which their services will return to 'Pre-omicron' levels 21st February - aside from the fact that this feels as though it lags levels of returning passengers rather than anticipating them, I must set to one side that the first omicron cases turned up around the 24th November so on that basis they should really include other casualty of Covid, the Bristol to Waterloos. (OK, that's not First Group that's the government, and I'm really hoping that in due course, along with a couple of other things :-) it turns into an election issue.)
I put your point to the Regional Manager at South Western Railway, asking if the timetable being re-introduced was the one that was running pre-Omicron until (i.e. before 24th November) through to 10th December - which is how their statement read.
Sadly, the timetable being re-introduced is the one from mid December, well, well into Omicron (not pre-Omicron). He writes:
With regard to the pre-Omicron timetable I can confirm this is the one that applied from the timetable change in December 21, i.e. excluding Bristol.
Posted by Mark A at 10:54, 11th February 2022
Posted by grahame at 06:10, 17th January 2022
As from 17th January 2022, the hourly services from London (Waterloo) to Exeter are only running as far as Salisbury, where passengers from London and other stations east of Salisbury are required to change trains (20 minute wait) for the onward service which is reduced in frequency to once every 2 hours, though there are a couple of through trains in the "rush hour".
This is far too big a topic to have under the "Waterloo - Bristol services axed" thread, so I have split off posts from this thread - please see http://www.passenger.chat/25879
Yet having split the topic off anew, there are, surely, patterns to be noted and parallels considered in the activities of SWR in how they are treating passengers from west of Salisbury - be they from Trowbridge or Axminster, Bristol or Exeter, to London and to intermediate stations such as Clapham Junction and Basingstoke.
Posted by paul7575 at 21:17, 8th January 2022
Has Salisbury got a surplus of units now with the Bristol, Penzance, Plymouth and Paignton services all gone?
AFAICS there’s not much point combining things that happened almost 15 years apart, because Penzance, Plymouth and Paignton withdrawal was done primarily to provide the stock for the hourly service to Exeter, following the Axminster doubling.  The fleet size hardly changed subsequently, although a single 158 was eventually transferred permanently to EMT, now EMR.
Posted by grahame at 19:18, 8th January 2022
From my FOI enquiry, on 19th April 2021, a member of the SWR team who's name has been redacted wrote to Graham Stockbridge at the DfT:
Withdrawal of these services would allow the removal of route knowledge between Westbury and Bristol from both Drivers and Guards at both Salisbury and Yeovil Traincrew Depots. Given the limited number of trips this route knowledge is difficult and expensive to maintain, sometimes relying on rest day work. At least one Drivers and Guards turn would be saved each week day. Furthermore, there would be a reduction in fleet and fuel miles with an approximate value of [redacted]  p.a. as well as the avoidance of rail replacement services when engineering work applies. I am also aware that Northern Rail have enquired about the availability of Diesel trains and we also could consider released units for the start up of the Waterside Line.
The likely total saving is projected to be in the region of [redacted] p.a. (some of which is in future costs avoided rather than savings from our current costs).
However, take that with a pinch of salt because in the same letter (s)he also wrote:
Through journey opportunities from stations east of Salisbury to those north of Westbury will be removed; however, good connections and alternative services are available for passengers.
when the connections are typically as awful as they can be
GWR services between Salisbury and Bristol have been lengthened in recent years following the introduction of 5 car trains and turbo rolling stock.
which wrongly suggest that all trains that need it are now 5 cars
Further developments on this corridor are planned through Metro West and other schemes and given projected customer numbers there is little commercial need for SWR services which do not provide part of the regular clockface service on that route.
which overlooks the significant gap between the SWR services finishning and replacements starting
It was also pointed out to us in late November by SWR / DfT / GWR that there's less rolling stock available after a 158 and a 159 made a much closer connection than they should have done at the tunnel mouth at Fisherton.
Re: South Western Railways Waterloo - Bristol services axed
Posted by TonyK at 18:37, 8th January 2022
I did ask about priority seating for the executions but was told that we do not do this anymore.
Spent nearly two weeks on jury service and did not even get to watch a hanging.
So what's a hung jury?
A jury can reach the right verdict, or a jury can reach the wrong verdict. It is, however, the correct verdict. You can't say the same about transport ministers.
Posted by Oxonhutch at 17:23, 8th January 2022
Being a near-Wallingford man, Blackstone's Ratio comes to mind.
"It is better that ten guilty persons escape than that one innocent suffer."
Having done jury service only once - and quite distressing it was too - I console myself with the above regarding the subsequent verdict at my occasion.
