12:17 Westbury to Swindon due 13:05
12:17 Westbury to Swindon due 13:05 is being delayed at Westbury.
This is due to this train being late from the depot.
13:14 Swindon to Westbury due 13:57
13:14 Swindon to Westbury due 13:57 will be starting late from Swindon.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 In "Across the West" [377269/31163/26] Posted by TaplowGreen at 13:02, 21st July 2026 | ![]() |
Due to a safety inspection of the track between London Paddington and Reading fewer trains are able to run on some lines.
Train services running to and from these stations will be cancelled or delayed. Disruption is expected until 14:00 21/07.
We have had a report of a defect with the track between London Paddington and Reading. Trains may not be able to run over the affected line until it has been inspected or may have to run at reduced speed.
The problem affects two of the four lines between London Paddington and Reading, so we are having to reduce the train service through the area to avoid congestion.
Some services between London Paddington and Oxford, will not run, in either direction.
| Re: North Cotswold line delays and cancellations - 2026 In "London to the Cotswolds" [377268/31371/14] Posted by Witham Bobby at 12:43, 21st July 2026 | ![]() |
21/07/2026
More news from the crumbling edge of quality otherwise known as the London to Worcester and Hereford route
According to RTT:
1P26 1316 Worcester Shrub Hill to Paddington was cancelled between Worcester Shrub Hill and Moreton-in-Marsh due to the planned train being replaced with a slower train
The down working, 1W21 1053 Paddington to Worcester Shrub Hill is in trouble, at present 36 minutes late off Charlbury
| Re: Bridge hit - again "Freshford" = Limpley Stoke? In "Portsmouth to Cardiff" [377267/32077/20] Posted by John D at 12:43, 21st July 2026 Already liked by Witham Bobby | ![]() |
It's worth scrolling to the bottom of the councillors update and clicking on the two links (meeting minutes / meeting slides), they give a good insight to the saga.
Thanks for that - really informative and well spotted.
Also, I'd not reallsed that bridge heights and the fit beneath them were approached in a way that reminds me of... did anyone when very small have that child's puzzle that consisted of a plastic drum with a lid with various shaped holes in it - and a set of plastic shapes that needed to be pushed rather firmly through their respective apertures?
With those minimum clearance tolerances it rather sounds as though a combination of a vehicle that just passes beneath a bridge and a piece of debris on the road could precipitate a bridge strike. Now reading the notes and slides again to see if it's really the case that the notes say the clearance as signed is more than the bridge provides.
But to allow for suspension variation etc, traffic sign manual requires a minimum of 80mm and a round down to next 0.1m
However it seems because road is higher one end, should use 16m chord (basically length of HGV with 40foot container), and using this should be signed as 3.9m (or 12'9" as imperial rounds down in 3 inch increments), whereas some current signs show warning as 4.2m
Although Wiltshire seemed oblivious as to why more trucks were using it, they seem not to have noticed additional delays on A350 (they widen bits, but move problem delay along road, not remove it). Sat Nav's will usually route via quickest route (so regularly avoid A350) regardless of suitability of the road. Also Bath has also added weight restriction on the A36 bridge forcing big trucks to take alternative route. Unclear to me why Wiltshire Highways can't work that out.
Faresaver are running a shuttle bus between the site and Chippenham station, timetabled as 30 mins; £10 for a single:
https://womad.co.uk/wp-content/uploads/2026/06/WOMAD-W1-2026-PUBLIC.pdf
| Re: Station fire at Paignton. Footbridge? In "Shorter journeys in South and West Wales" [377265/32262/23] Posted by Phantom at 11:45, 21st July 2026 | ![]() |
https://www.devonlive.com/news/devon-news/paignton-fire-what-means-gwr-11069269
| Re: North Cotswold line delays and cancellations - 2026 In "London to the Cotswolds" [377264/31371/14] Posted by Witham Bobby at 11:42, 21st July 2026 | ![]() |
Tuesday 21/07/2026
Cancelled today, according to RTT:
1W11 0553 Paddington to Great Malvern cancelled from Oxford because of a fault with the traction equipment
so
1P18 0856 Great Malvern to Paddington did not run
and, from GW JourneyCheck:
16:58 London Paddington to Great Malvern due 19:25 will be cancelled.
Last Updated:21/07/2026 07:29
19:45 Great Malvern to London Paddington due 22:24 will be cancelled.
| Guyana - At least 27 dead and 83 missing after passenger ferry capsizes In "The Wider Picture Overseas" [377263/32263/52] Posted by Chris from Nailsea at 10:42, 21st July 2026 | ![]() |
At least 27 dead and 83 missing after passenger ferry capsizes off Guyana
A search and rescue operation for dozens of missing people continued on Sunday - Image © Prime Minister Mark Phillips / Facebook
At least 27 people have drowned after a passenger ferry capsized off the coast of Guyana on Saturday night local time.
Sixty-nine people aboard the MV Barima had been rescued, Prime Minister Mark Phillips told reporters on Monday, adding 83 more remained missing.
Divers continue to search the site where the vessel capsized and people who believe their loved ones may have been on board the stricken vessel have been asked to contact the authorities. "Our focus again is on finding people," said Phillips. "We still have hope."
An investigation into the tragedy had been launched, he said earlier. "Let me be absolutely clear: where negligence, misconduct or criminal wrongdoing is established, those responsible will face the full force of the law," he said.
Guyana's Public Works Minister, Juan Edghill, expressed his anger at a news conference on Sunday, accusing those who operated the ferry of trying to "cheat the system". The official registry had listed 133 as being on board the ferry, but Phillips said on Monday he was now "confident" there were 179 people. Edghill also said the ferry's captain and at least one crew member had tested positive for cannabis.
"We have zero tolerance for members of the crew drinking or smoking while at work. And for us to have positive tests from the captain... this is serious," the minister said. He added the captain and several of his crew had been taken into police custody.
| Re: Sssshh - don't tell the customers what's really going on ... In "Smoke and Mirrors" [377262/32258/3] Posted by Chris from Nailsea at 10:05, 21st July 2026 | ![]() |
And what is a TASC??
TASC is a Track And Service Car: A specialized on-track maintenance vehicle used for railway track work (such as the Plasser & Theurer TASC-45).
I'm adding it to our Coffee Shop forum 'abbreviations and acronyms' page.
| Re: Station fire at Paignton. Footbridge? In "Shorter journeys in South and West Wales" [377261/32262/23] Posted by bradshaw at 10:03, 21st July 2026 | ![]() |
Journey Check at 09.51 - Fire seems to be out but no trains until tomorrow
. A fire has broken out at Paignton Station, affecting signalling and surrounding infrastructure. Local news sources report that the fire is now out, but due to the nature of the damage, we will not be running trains on this route today. Please kindly note, Paignton station remains closed to the public.
| Re: Bridge hit - again "Freshford" = Limpley Stoke? In "Portsmouth to Cardiff" [377260/32077/20] Posted by Mark A at 09:41, 21st July 2026 | ![]() |
Starts on Thursday, although that's not a full day. The FAQs https://womad.co.uk/festival-information-faqs/ include "site map and getting here", with what3words locations for the entrances along the A365 Bath road on the Bath/Box side of Atworth. The main entrance is here:
https://what3words.com/addicted.disco.laughs
It's less than 2 miles from us, so it might be audible with the wind in the right(?) direction. Or as a 'local resident' I could purchase a 4 day ticket - reduced from £275 to £187
It would certainly be a chance to listen to something new - I don't recognise any of the names in the lineup...https://womad.co.uk/lineup-2026/
(apart from Barrington Levy, although not sure why)
| Station fire at Paignton. Footbridge? In "Shorter journeys in South and West Wales" [377258/32262/23] Posted by grahame at 09:16, 21st July 2026 | ![]() |
BBC - https://www.bbc.com/news/articles/cy8myezmlz5o
Firefighters are tackling a major fire at Paignton railway station, with train services cancelled and roads closed across the town centre.
Devon and Somerset Fire and Rescue Service was called to the station at about 05:45 BST, and seven fire crews are currently tackling the blaze.
Great Western Railway said the line was blocked due to the fire, and passengers should expect disruption to services.
The operator said trains had been cancelled or suspended between Newton Abbot and Paignton. It added Torre, Torquay and Paignton stations would not be served and that the disruption was expected to continue until at least 14:00 BST.
| Lost property - or abandonment? In "The Lighter Side" [377257/32261/30] Posted by grahame at 09:09, 21st July 2026 Already liked by Witham Bobby | ![]() |
From The BBC
A marmoset monkey has been rescued by animal welfare officers after being found abandoned inside a laundry bag on a bus in north-west London.
The female primate was discovered by a driver on the route 302 bus when it arrived at Kensal Rise on Friday morning, the RSPCA said.
I have posted in the lighter side though abandonment of an animal is a serious matter.
I was interested in the importance of this being on a route 302 bus. Is it routine and not newsworthy on other routes? Marmosets commonly found on 229s when they terminate in Croydon, perhaps?
| Re: Bridge hit - again "Freshford" = Limpley Stoke? In "Portsmouth to Cardiff" [377256/32077/20] Posted by chipbury at 08:39, 21st July 2026 Already liked by Mark A | ![]() |
Quick look on National Rail 'plan your journey' for Melksham-Bristol... currently Monday 12th Oct is latest you can plan, and it shows what is usually the 06:29 Melksham-Trowbridge becomes the 06:10 replacement bus. The 07:21 and 08:02 Melksham-Chippenham become the 07:26 (bus) and the 08:09 (train) respectively.
05:11 Gloucester to Southampton Central due 08:10
05:11 Gloucester to Southampton Central due 08:10 was terminated at Salisbury.
It will no longer call at Romsey and Southampton Central.
Oh dear ... whatever has happened to their ability to stop main line trains along the way instead? The suggestion for that is not to stop the precious Plymouth and Cornwall expresses, but just to call the trains that are already servicin the other intermediate stations prior to Taunton - i.e. Westbury and Castle Cary ...
There seems to be some conflict between the two sections as I read them, and what's that 17:36 off Swindon? Is it the train that now leaves at 17:44?
I would usually encourage GWR to additionally organise with Faresaver for ticket acceptance on the 271/2/3 between Melksham and Bath Spa Station. No note of that - perhaps it will come in detail, though I note that the 271/2/3 aren't serving Bath Station until November due to closed roads
Further follow up / learning needed ...
| Engineering works 10 - 16 October 2026 In "London to Kennet Valley" [377252/32260/8] Posted by John D at 07:08, 21st July 2026 | ![]() |
Engineering works and week long closure between Bedwyn and Pewsey/Westbury 10-16 October have been announced
Saturday to Friday:
No trains will run between Bedwyn and Pewsey / Westbury.
Long distance trains between London Paddington and Exeter St Davids / Paignton / Plymouth / Penzance will be diverted, and will either run via:
Bristol Temple Meads (calling to drop off only when running towards London Paddington, and picking up only when running from London Paddington)
Chippenham (some trains will additionally call at Swindon, Westbury and Castle Cary)
No trains will run to / from Pewsey. Replacement buses will run direct between Swindon and Pewsey.
Trains will continue to run between Reading and Bedwyn.
Some trains between Swindon and Westbury will be retimed to run up to 23 minutes earlier or later than usual, in order to accommodate the diverted services.
Monday to Friday:
An amended train service will run during morning / evening peak times between London Paddington and Newbury / Bedwyn.
Due to diversions, the vast majority of local trains between Swindon and Westbury will not run and will be replaced by road transport between Chippenham, Melksham, Trowbridge and Westbury.
However, the 17:36 Swindon to Westbury and 07:45 (amended to depart at 07:52) Westbury to Swindon trains will run.
At Trowbridge, buses towards Westbury will drop off only, and buses from Westbury will pick up only.
Monday to Friday:
https://www.nationalrail.co.uk/engineering-works/bedwyn-and-pewsey-westbury-20261010/
Engineering work for a week Bedwyn - Pewsey/Westbury Saturday 10th to Friday 16th October sees diversions via Melksham, with some buses doing set down only at Trowbridge
Saturday to Friday:
Monday to Friday:
Monday to Friday:
| Sssshh - don't tell the customers what's really going on ... In "Smoke and Mirrors" [377250/32258/3] Posted by grahame at 07:01, 21st July 2026 | ![]() |
Swindon Advertiser
Swindon and Cricklade Railway has said its Diesel Service to Farfield Lane could not go ahead on Sunday.
The company has said the “reduced service” took place, due to “unforeseen circumstances”.
"The Diesel Service to Farfield lane has been cancelled.
“A replacement Wickham Trolley service will be departing from Blunsdon and making regular trips to Swindon Mouldon Hill only. The TASC will also be available for rides."
From Station announcements at Dusseldorf Yesterday
We are sorry about this train being delayed. This is because the train is late
It strikes me that reasons given aren't reasons ... cop-outs to avoid admitting the issue.
Heidi Alexander remains as Secretary of State for Transport. ( reported BBC )
I'm not commenting on what / how she has done so far, but I admit to being of the opinion that we've had far too many changes over the years and there's an element of relief at the no-change stability.
| Re: Interrail trip 4 - the Home to Harwich to Hook experience In "Introductions and chat" [377248/32253/1] Posted by grahame at 06:30, 21st July 2026 Already liked by Mark A, Chris from Nailsea, GBM | ![]() |
But it is dark, so pictures from our base for the next couple of days will have to wait until the morning.
View from our window ...
| Trains not reaching Cheltenham Spa In "Swindon to Gloucester / Cheltenham" [377247/32257/38] Posted by grahame at 06:19, 21st July 2026 | ![]() |
From Max Wilkinson MP - via https://www.facebook.com/reel/1952559972119124
I asked Ministers why so many trains due to reach Cheltenham are instead terminating at Gloucester. After hearing concerns from local people, I’d already found out the facts from Ministers, which reveal a significant number of trains bound for our town don’t make it as far as Cheltenham Spa station.
Regular travellers on this route are all too aware of the frustrating turnaround time at Gloucester, but being ejected from the train entirely and told to wait for the next service or take a taxi is even worse.
While the Minister could not give me an immediate answer, I will be following up with the Department to find out what is going wrong and how it can be fixed.
| Re: Interrail trip 4 - the Home to Harwich to Hook experience In "Introductions and chat" [377246/32253/1] Posted by grahame at 22:25, 20th July 2026 Already liked by Mark A, JohnM, Witham Bobby | ![]() |
Nine electric main line trains, 2 diesel trains, 3 metro-ish trains, one Uber. 1 sloping lift and numerous vertical ones. A handful of escalators and travelators. 29 hours from Melksham. No flights.
Three planned trains were cancelled, each of them leading us to drop back a train. In the UK case, we had a substatial buffer and caught the ferry anyway, but each of the German train cancellations cost us an hour. No trains were late enough to cause us to miss a connection, but slower-than-previous immigration at Hoek, and a faulty lift at Beurs, each put us back one metro and caused a missed plan at Rotterdam Central. So we arrived in our destination town at 21:41 rather than the 18:39 suggested by the journey planner. Which, however, was no big deal. There were still two further trains in the hourly cycle had we needed them, and we had eaten on the way including a rather tasty chilli on the German ICE. And I had emailed the hotel to update our estimated time of arrival.
So in summary, in the Netherlands, the lifts don't work. In Germany, the timetable does not work. And in the UK the ticket gates and fare system don't work. All around, there are pockets of crowding and even extreme crowding, but the majority of trains are somewhere between comfortable and quiet.
| Security guard, 26, falls from 75mph train in Germany after 'brutal' attack In "The Wider Picture Overseas" [377245/32256/52] Posted by ChrisB at 21:49, 20th July 2026 | ![]() |
From the Mirror, via MSN
Security guard, 26, falls from 75mph train in Germany after 'brutal' attack by passenger during ticket check
A security guard has suffered serious injuries after he was allegedly "brutally" attacked by a passenger on a train during a ticket check.
The incident involved a 26-year-old man who fell from a train travelling at 120km/h (75mph), resulting in severe head injuries. The attack took place when the rail worker fell against a train door during a physical altercation with a 36-year-old passenger, Bild reports.
The incident took place near Ettlingen-Bruchhausen in the west of Germany on a regional train operated by Deutsche Bahn, the country's national rail company. The train was travelling between Offenburg to Karlsruhe when the fight occurred on Friday evening.
The altercation reportedly started after the passenger, a German national, was asked for his ticket. A verbal argument then started, which resulted in two security guards being called to assist the ticket inspectors.
A physical fight then occurred between the passenger, who was allegedly drunk, and the 26-year-old Bulgarian security guard, who fell through a door which opened when he was pushed into it. The security guard was pushed with such force against the door that a section of the entrance steps allegedly broke off.
It is understood that train drivers are normally notified when a door has opened while the train is running, immediately triggering an emergency stop. This is not believed to have happened on Friday.
An investigation has now been launched into the incident, which is being treated as high priority. The 36-year-old suspect was arrested onboard and charged, but it is unclear on suspicion of what offences.
The security worker was found by emergency services near the tracks, about 1.25miles from where the train eventually stopped. A similar incident took place in February, when a train conductor died after an attack by a fare evading passenger in Rhineland-Palatinate, also in western Germany.
The 26-year-old perpetrator was sentenced to 10 years in prison for manslaughter.
| Intercity rail passengers face summer disruption - slashed services and strikes In "The Wider Picture in the United Kingdom" [377244/32255/51] Posted by ChrisB at 21:44, 20th July 2026 | ![]() |
From the Guardian, via MSN
Intercity rail travellers face potential disruption this summer across Great Britain’s three north-south mainlines, with drivers voting on strike action on two lines and timetables slashed on the other owing to malfunctioning trains.
East Midlands Railway announced it will cancel hundreds of services in the coming weeks from its intercity timetable on the Midland mainline, because of continued problems with its fleet of Hitachi trains.
The train drivers’ union Aslef has called a strike ballot on LNER, which runs trains between London and Scotland, after a pay deal fell through. Drivers are already voting whether to strike over pay at Avanti West Coast.
EMR is cancelling about 20 fast trains a day between London, Sheffield and Nottingham, while others will also be short-formed and are likely to be crowded. Its new class 810 fleet, previously labelled Auroras when their launch was heralded less than a year ago, have suffered from what EMR has called “performance and reliability issues”.
The operator also criticised Hitachi’s maintenance of the existing fleet that the Auroras were due to replace, the class 222 trains, which it said had “significantly impacted upon EMR’s ability to run a consistent intercity service”.
Will Rogers, the managing director of EMR, said: “The performance of the class 810 fleet has fallen below the levels we and our customers expect, and it is necessary to introduce a temporary reduced timetable while we work with the manufacturer, Hitachi Rail, to improve consistency in service.
“We are sorry for the significant disruption and inconvenience these issues have caused our customers, and we are committed to restoring the reliable service they rightly expect.”
A Hitachi Rail spokesperson said it continued to “work closely with all industry partners ... implementing improvements and supporting the transition”.
The bi-mode trains, which run on diesel and electricity, have been introduced into service this year after a three-year delay.
Investigations into the fatal Bedford rail crash last month are still trying to ascertain what caused one of EMR’s new Aurora trains to stop on the mainline, apparently due to a fault with the automatic warning system, before being struck by another EMR train that had passed a red light.
Train drivers on the two other intercity mainlines running north from London could all be on strike by late August, after Aslef called a ballot on LNER on Friday.
Dave Calfe, the union’s general secretary, said: “The company’s failure to make a suitable offer is unacceptable and that’s why we are balloting our members for industrial action.”
The union said the Department for Transport had refused to sign off a pay deal agreed at the state-owned East Coast operator.
A DfT spokesperson said: “We have given LNER approval for a fair and affordable deal. We know how frustrating disruption can be for passengers and strongly encourage the union to continue engaging constructively with LNER to reach a solution.”
Two weeks ago Aslef announced a similar vote at Avanti West Coast over frustrated pay negotiations. The union has not renewed a rest-day working agreement, leading to some cancellations.
Sweepstake on the date of the first bridge bash?
| Re: Broken down train - an example of explanation and minimisation of issues In "Shorter journeys in Plymouth and Cornwall" [377242/32251/25] Posted by Chris from Nailsea at 21:27, 20th July 2026 | ![]() |
There is a large gap on school day afternoons from Truro though.
This should help out while the trains are unreliable.
Hopefully, those trains will be fixed during the next six weeks of school holidays?
All looking OK to my eyes. The new southern walk/cycle way is now open. Though no cycling yet unless you’re a VIP and ignore the signs, as the northern walkway is now being worked on…and is unlikely to make the end of August deadline as previously acknowledged. No major issue there IMHO.
When both are open I am guessing cyclists will be guided to use the northern walkway into Oxford and the southern walkway out towards Botley…but I’m sure many will stay on the road.
Works on the road look quite near completion now with the concrete flood protection finished so not much other than the road surface and associated furniture to lay.
I’m sure it’ll continue to look like a bit of a building site for a while to come, but I see no obvious reason why this latest, much delayed, deadline can’t be met.
