In "TransWilts line - Swindon, Chippenham, Melksham, Trowbridge, Westbury, Salisbury" [376058/31359/18]
Posted by grahame at 11:46, 17th June 2026
12:17 Westbury to Swindon due 13:01
13:14 Swindon to Westbury due 13:57
13:14 Swindon to Westbury due 13:57 will be cancelled.
This is due to a road vehicle colliding with a bridge.
Cancellations to services between Swindon and Westbury via Melksham
Due to a road vehicle colliding with a bridge at Freshford all lines are blocked. Disruption is expected until 14:15 17/06.
Train services between Swindon and Westbury via Melksham will be cancelled.
Due to a lorry hitting a bridge, it has been necessary to divert affected trains through Melksham. As a result, the regular Melksham service is suspended, however, where possible we will try and call additional trains at Melksham.
In "Across the West" [376057/31163/26]
Posted by Electric train at 11:27, 17th June 2026
Blimey what was it? An albatross?
Delays to services between Newbury and Bedwyn
Following a broken down train earlier today at Kintbury all lines towards Taunton have now reopened. Disruption is expected until 16:15 15/06.
Train services between Newbury and Bedwyn are returning to normal.
A train had broken down near Kintbury, after striking a bird.
Birds have always been an issue with overhead line electrification.   The first generation (Mk1) used on the WCML and GE had places that allowed birds to build nest, the dropping caused corrosion also the blighters shorted the system.
Large birds such as swans and geese will occasionally fly into the OLE insulators etc, they are also know to fly into pantographs even on moving trains which causes a short usually with a big bang, a dead bird and lots of singed feathers.
Re: Looe Branch Line - timetables, cancellations, engineering work, closures and incidents
In "Shorter journeys in Plymouth and Cornwall" [376056/569/25]
Posted by Andy at 10:37, 17th June 2026
Already liked by JohnM, REVUpminster
Due to a fault on this train between Liskeard and Looe the line is closed.
Train services running to and from these stations may be cancelled. Disruption is expected until 12:00 17/06.
More trains than usual are needing repairs at the same time. We have an insufficient number of trains to guarantee a reliable service. This means that we have no train to run this service.
We are working to repair this train and get it back into service as quickly as possible. We have done nothing to solve this underlying problem, which recurs frequently.
What are your options?
We are really really sorry, honestly [not] for the disruption to your journey today, these are the current options available to you but don't bother reading the copy-and-paste text which follows as it's unlikely to be relevant to the situation we've put you in. :
Option 1: If there are other rail companies or local public transport operators who may be able to help you make your journey, we will provide details here.
Option 2: We have requested local bus ticket acceptance and replacement road transport, once these are in place further details will be provided.
Option 3: If your train is cancelled, you may travel on either of the two services before, or two services after, your original train. If these are peak services or less flexible, you can still travel with your original ticket, at no extra cost.
Option 4: Consider postponing your journey until our service returns to normal.
Re: Service disruption
In "Bristol and Bath (WECA, now WEMCA)" [376055/32140/21]
Posted by JohnM at 09:02, 17th June 2026
Perhaps start this topic heading off with "Bristol"?
Please do - I just thought that the folder location would cover it, but I guess that's not always visible depending on the context. Bristol and Bath perhaps, or a separate topic for Bath-specific stuff?
In "Shorter journeys in Plymouth and Cornwall" [376054/569/25]
Posted by REVUpminster at 08:45, 17th June 2026
Today is a disaster for GWR in Devon and Cornwall.
150 taken from Paignton- Exmouth double unit; maybe for Looe?
0625 out of Barnstaple a 2 car 158 then cancelled as the 0935.
The 175 training train from Exeter-Paignton cancelled maybe to use elsewhere.
GWR has never had the interests of passengers in Devon and Cornwall unless someone else is paying for it. I'd include SWR as they are/were under they same umbrella.
In "Shorter journeys in Plymouth and Cornwall" [376053/569/25]
Posted by Mark A at 08:22, 17th June 2026
The poverty of the phrasing in the information that the industry has evolved in these comms is quite something, but I can't quite come up with an analogy that fits the root cause.
At our maintenance depot, a drain has blocked, resulting in a swamp and an influx of crocodiles on the trains brought into service.
We are working to remove the crocodiles as quickly as possible.
We are sorry if you were bitten today, these are the current options available to you:
Option 1: If there are helicopter companies who may be able to help you make your journey, we will provide details here.
Option 2: We have requested local hovercraft ticket acceptance, once these are in place further details will be provided.
Option 3: If your train has crocodiles on it, you may travel on (insert enormous long sentence describing complicated easement rules: hopefully staff on the ground would simply be pragmatic).
Option 4: Consider postponing your journey until the risk of crocodiles on the trains returns to normal.
Note: if you sit on a train seat and feel an uncomfortable bar beneath you, please report this to the train manager, who will arrange for the crocodile to be removed from beneath the seat cushion
In "Bristol and Bath (WECA, now WEMCA)" [376052/32140/21]
Posted by GBM at 08:08, 17th June 2026
In "Bristol and Bath (WECA, now WEMCA)" [376051/32140/21]
Bristol seems to be having several train incidents this morning.
07:03 Bristol Temple Meads to Taunton due 08:09
07:10 Bristol Temple Meads to Gloucester due 08:01
07:14 Bristol Temple Meads to Oxford due 08:32
07:40 Bristol Temple Meads to Westbury due 08:29
In "Shorter journeys in Plymouth and Cornwall" [376050/569/25]
Posted by GBM at 08:05, 17th June 2026
More trains than usual are needing repairs at the same time. This means that we have no train to run this service.
We are sorry for the disruption to your journey today, these are the current options available to you:
Exactly as member Mark A said on April 18th!
tools stolen from Clevedon minature railway
In "Heritage railways, Railtours, buses, canals, steamships and other public transport based attractions" [376049/30837/47]
Posted by infoman at 07:09, 17th June 2026
https://somersetleveller.co.uk/news/tools-and-equipment-stolen-from-clevedon-miniature-railway-site/
In "Bristol and Bath (WECA, now WEMCA)" [376048/32140/21]
Posted by JohnM at 06:18, 17th June 2026
...and the 5:58 Westbury to Cardiff is 'delayed'.
Now running, about 12 mins late.
In "Bristol and Bath (WECA, now WEMCA)" [376047/32140/21]
Posted by JohnM at 06:08, 17th June 2026
Service disruption
In "Bristol and Bath (WECA, now WEMCA)" [376046/32140/21]
Posted by JohnM at 05:43, 17th June 2026
The 4:50 Fratton to Bristol Temple Meads "is running late because of engineering works not being finished on time". So the 6:46 Trowbridge departure is currently showing as 7:04.
In "Shorter journeys in Plymouth and Cornwall" [376045/569/25]
Posted by grahame at 05:23, 17th June 2026
In "Across the West" [376044/31163/26]
Posted by Chris from Nailsea at 21:18, 16th June 2026
To be fair, geese can take down an aircraft: see https://en.wikipedia.org/wiki/US_Airways_Flight_1549
Re: Railways Bill 2025: introducing and designing Great British Railways - general topic
In "Looking forward - the next 2, 5, 10 and 20 years" [376043/31038/40]
Posted by John D at 19:51, 16th June 2026
How does the new GBR livery work on units with odd numbers of vehicles as stripy triangular pointy bit faces the nearest end.  Which way will it point on middle vehicle ?
Clearly there are 3, 5, 7, 9, 11 vehicle units around network
Re: How would YOU solve CrossCountry ?
In "Across the West" [376042/32138/26]
Posted by IndustryInsider at 19:33, 16th June 2026
Already liked by Mark A, eightonedee
Are there any ex-Avanti 221s still in storage?
Yes, currently sets 101-106
Grand Central still has a pair too (units 142, 143), but has nine 5car tri-mode (class 820 ?) IETs on order, so shouldn't need them once these new trains arrive, as won't need so many spares.
I seem to recall XC have expressed an interest in those six sets, but it’s sitting with the DfT?
Get those on XC routes ASAP, then the two Grand Central ones in 2028 (and also the boost of however many sets are currently undergoing refurbishment at a time) and you’ll have enough to make a very noticeable impact and perhaps get you through to a replacement order for the Voyagers (and the XC 170 fleet) in the late 2030s.
An option that just might get the ok from the treasury?
In "Looking forward - the next 2, 5, 10 and 20 years" [376041/31038/40]
Posted by grahame at 18:11, 16th June 2026
On X there is a video of a class 387 painted in the new GBR livery leaving the shed  at the depot near Brighton.
Sorry that livery just doesnt look right
Here it is - in comparison to a couple of others - a few minutes ago.
None of the passengers seem outwardly concerned at the colour of their train, nor asking if this is the new public railway.  Doesn't feel much different.
P.S. I joined the Gatwick Express train.   It's not going to Gatwick and neither am I.  I understand that I do not have to pay a premium "Gatwick Express" fare.
In "Across the West" [376040/32138/26]
Posted by Sulis John at 16:12, 16th June 2026
Start the process of ordering a new fleet of 9 car bi-mode trains now for delivery at the slowest possible viable rate. As they slowly enter service use any displaced Voyagers to double up other services. Given the usual delays new trains gave in entering service, by the time you’ve doubled up everything (and coped with the growth arising from the journey experience becoming something to enjoy rather than endure), those 15 years will be nearly up.
Re: Update from Bedwyn - May 2026
In "London to Kennet Valley" [376039/32109/8]
Posted by John D at 16:10, 16th June 2026
Many passengers from Pewsey are concerned that these fast trains will no longer call at Pewsey if Devizes Gateway is built and/or Bedwyn trains are extended to Westbury which would result in longer journey times between Pewsey and Paddington (and vice versa)
It's about 15 miles that are unelectrified Newbury-Bedwyn.
Of course a battery EMU could do it as extension (but aren't any yet)
Of course an IET is overkill, and totally wasteful hauling diesel engines around for that distance, when so many other lines could benefit from bimodes to replace pure diesels.  But if it really need a 120-130mph electric commuter train, instead of 110mph one is different question.
So is electrification sensible, wouldn't need new power supplies (one has already been added near Reading West).  Although would really need to continue to Frome / Bruton area if serious about electric freight.
As for practicality, some over bridges might need raising, I think there are
3 over bridges Newbury - Hungerford
3 over bridges Hungerford - Bedwyn
1 between Bedwyn station and reversing siding
Even if assume worst and all need doing (unlikely) then not impossible in practical terms.   Although never going to be in logical queue ahead of other extensions like Didcot - Oxford
In "Across the West" [376038/32138/26]
Posted by John D at 15:50, 16th June 2026
Really it would be economically wasteful to scrap all the voyagers (likely to be in service about another 13-16 years), but there is a strong case for using just the intermediate cars and lengthening sets to 6cars.   Fewer vehicles to refurbish, and get a pool of spare parts, engines, bogies, seats, cab fittings etc.
I am not sure if having 4 or 5 or 6 car sets is best.
4car on their own are too short and crowded (except at fringes of route).  5car sets get far too crowded in the Midlands and less than ideal too.  6car would be better and less of a problem when run on their own.
But if start having doubled up sets of 10, 11, 12 cars do they become overkill, or cause problems at stations where platforms are under 285m (935 feet) long.  An 11car voyager is similar length to 2x5car IETs
In "Across the West" [376037/32138/26]
Posted by IndustryInsider at 12:29, 16th June 2026
Most of that could be fixed by replacing existing stock with well-furnished 10-car and 5-car variants of 80x stock. This could bring the offering closer to a TGV/AVE/ICE-standard whilst with more capacity, tickets could be reduced so the per-mile price is closer to the network.
In theory, yes.
In practice the Voyager fleet has around 10-15 years of life left in them and it would be very hard to make the sums work for a £1bn+ full replacement of them for a few years yet, as it would be difficult to find a home for them.
A small additional fleet of new trains to bolster the current fleet?  Maybe.
In "Across the West" [376036/32138/26]
Posted by Noggin at 12:15, 16th June 2026
The primary gripes of most users are smelly trains, unusable wi-fi/blocked mobile signal, overcrowding and high fares.
Most of that could be fixed by replacing existing stock with well-furnished 10-car and 5-car variants of 80x stock. This could bring the offering closer to a TGV/AVE/ICE-standard whilst with more capacity, tickets could be reduced so the per-mile price is closer to the network average.
As mentioned previously, much the core network is now electrified (with more in prospect), and at the very least a bi-mode fleet would offer better performance under the wires and the ability to catch up schedules, but also improve the business case for gaps like Derby to Birmingham and Bromsgrove to Bristol to be filled. Reliability is inevitably going to be difficult on complex and long routes, but I don't think it's the main gripe for most people.
An additional problem is that long-distance "Intercity" passengers doing multi-hour journeys are are mixed with those doing short commuter hops of as little as 10 minutes (e.g. Bristol TM to Bristol Parkway). This is to a certain extent being mitigated by new commuter services like TfWM's planned Birmingham to Bristol/Cardiff, but XC could also bring in "reservation only" carriages.
In "Across the West" [376035/32138/26]
Posted by IndustryInsider at 11:47, 16th June 2026
In "Across the West" [376034/32138/26]
Posted by Phantom at 09:55, 16th June 2026
I despise the Voyager train, there is something about the interior feeling cramped and chaos at every station that I avoid at all costs
Ironically I just had a weekend in Teignmouth and the cheapest trains by a long shot were using Cross Country.
I was due to travel with a friend, but she was unwell and pushed me to go on my own.
I got on the train at Weston to find people in my reserved seat - first two on the right in the carriage.
The quickly moved on request, but then an elderly lady sat in one of my reserved seats saying it was hers.
Her husband was sat in front of her, and had to move a lady into another seat.
Once I realised they were travelling together I explained they were both my seats and that they could sit there so they could travel together, so I sat in the seat in front.
As soon as I got comfortable a lady in the window seat said her sister had been sat there and was now on the left side, so I offered her sister my seat and sat in my third seat, even before the train had got to the main line
The thing about this, it wasn't just where I was sat there were people moving people from reserved seats all through the carriage and was absolute chaos.
I don't understand why people find the reservation system so difficult to read or take notice of.
The other problem, is why they are only ever 4 car sets, with one being an underused first class.
How 3 carriages has ever been deemed suitable for long distance is incredible.
The ironic end to this, I actually travelled back on Saturday night
The train I was booked on ended up being cancelled
In "London to Kennet Valley" [376033/32109/8]
Posted by grahame at 09:40, 16th June 2026
The other potential risk of extending the Bedwyn trains to Westbury (calling at Pewsey and Devizes Parkway) is that they could end up becoming Westbury to Newbury shuttles with 165's so Pewsey would lose it's direct IET trains to Reading and Paddington.
Bedwyn and Pewsey are both in the same constituency. With railways being nationalised, there's likely to be more political influence so you could have a word with your MP to help ensure the groundwork for a good outcome for all. In my previous times, Claire Perry was a great ally.
In "Across the West" [376032/32138/26]
Posted by Bob_Blakey at 08:57, 16th June 2026
The first thing I would do is run a comprehensive analysis of the ticketing data to establish how much of the loading of each service is split between shorter (e.g. Plymouth > Totnes or Newton Abbot) and longer (e.g. South West > Birmingham) journeys.
On the basis of the results I would then make sectors with a preponderance of longer journeys reservation only, preferably aided by a new 'smart' reservation app which, once the origin station has been specified, only displays selected destinations so that the 'swamping' of services by short distance travellers is significantly reduced.
Where such restrictions were implemented I would amend the timetable(s), if necessary, to ensure that an appropriate 'local' service was available to short distance passengers.
The aforementioned ticketing data could also be used to determine, on a 'train-by-train' basis, the number of carriages required for each service; present experience quite clearly shows that 4 or 5 coach trains frequently don't cut the mustard.
The new LNER timetable might show a different way forward; using their Azumas there are now only four 10-car trains each weekday with a corresponding increase in a half-hourly 5-car train service.
In "Across the West" [376031/28982/26]
Posted by ChrisB at 08:51, 16th June 2026
https://www.youtube.com/watch?v=S0YO9ZzSpZA
First 175 into Paignton.
I did not use hyperlink. May work now.
Still nope.
Owner must have changed permissions as this now works for me
Re: West Coast Railways and ‘Hogwarts Express’ trains - ongoing discussion
In "Heritage railways, Railtours, buses, canals, steamships and other public transport based attractions" [376030/24067/47]
Posted by ChrisB at 08:27, 16th June 2026
Derailed on Sunday, I think?
From Chris Dale on X
Jacobite has derailed. "Banavie north signaller reports the driver of West Coast Railways 5Y69 from 2Y68 engine was completing a move where the engine is rounded, the leading tender axle has derailed over 3B points ground frame."
Lasted 7 hours before being manually rerailed.
In "London to Kennet Valley" [376029/32109/8]
Posted by hoover50 at 08:07, 16th June 2026
where the business case really comes much more to life is with a service extension of the faster of the two trains an hour to Hungerford, Kintbury, Bedwyn, Pewsey, (new) Devizes Gateway and Westbury.  Whether that (perhaps alternate trains?) carries on beyond, or feeds into the existing 2-hourly semifast, is open for discussion.
As things currently stand, some of the fastest trains that run between Pewsey and Paddington (and vice versa) only call at Newbury / Reading giving a journey time of just under one hour. Many passengers from Pewsey are concerned that these fast trains will no longer call at Pewsey if Devizes Gateway is built and/or Bedwyn trains are extended to Westbury which would result in longer journey times between Pewsey and Paddington (and vice versa)
