Re: Manvers Street, Bath, disrupted for reconstruction works for 6 months from May.
In "Buses and other ways to travel" [375337/31887/5]
Posted by Mark A at 20:51, 21st May 2026
Re: Paddle Steamer Waverley - merged posts
In "Heritage railways, Railtours, buses, canals, steamships and other public transport based attractions" [375336/19566/47]
Posted by Chris from Nailsea at 18:25, 21st May 2026
Waverley paddle steamer helps out passengers after CalMac ferry breaks down
The crew of a 79-year-old paddle steamer offered passengers a lift from Mull to Oban after their CalMac ferry was hit by a fault.
The Waverley was headed down the Sound of Mull when MV Isle of Mull broke down on Tuesday.
Another CalMac ferry, the MV Loch Frisa, was available but not all the passengers could be accommodated on a 18:40 sailing and the Waverley's crew asked if it could help out.
Some 42 foot passengers were picked up at Craignure and returned to Oban.
Re: Person hit by train, Taunton 24/10/2025 - Harry Basham, age 17, walking to work
In "London to the West" [375335/30967/12]
Posted by Chris from Nailsea at 18:06, 21st May 2026
Teen's rail crossing death was accidental - coroner
The death of a teenager who was struck and killed by a train on a pedestrian railway crossing was an accident, a coroner has concluded.
Harry Basham, 17, was hit by the train in Taunton, Somerset, as he walked to work at about 07:00 BST on 24 October 2025.
Somerset senior coroner Samantha Marsh said there was no evidence he "intended to harm himself" but accepted why he was on the track remained "unanswered".
A Network Rail spokesperson said: "Our thoughts remain with Harry's family and friends and the local community following the tragic accident at the 5/13 railway crossing. We will continue our engagement with local authorities, stakeholders and the community on the future of the crossing."
Re: Wokingham station - improvements, resignalling and siding - merged posts
In "South Western services" [375334/11448/42]
Posted by bobm at 18:04, 21st May 2026
Or a second gang turn up intent on demolishing the box and find a pile of rubble.
Re: New Oxford - Bristol direct service, ongoing developments and discussion
In "Oxford, Didcot and Reading from the West" [375333/28355/22]
Posted by bobm at 17:45, 21st May 2026
Freight was held on the up line so reversible working was needed - which obviously does affect both lines.
Re: Level crossing waiting times
In "The Wider Picture in the United Kingdom" [375332/32049/51]
Posted by John D at 17:45, 21st May 2026
When I used to live Kingston -Richmond borders occasionally used the level crossing by Sheen station.    Have waited for 5 trains to pass.
Get a bit of late running and mix of stopper on Kingston loop, faster trains to Windsor or Reading trains can be just 2-4 minutes apart, get a train going other way between them and just insufficient time to put barriers up.
Before SWR thinned the timetable 6 years ago (and never fully restored it post covid), barriers could be down for around 35-40 minutes each hour in the peak
In "Oxford, Didcot and Reading from the West" [375331/28355/22]
Posted by grahame at 14:43, 21st May 2026
Already liked by IndustryInsider
Someone was asking how these would show up on our disruption map ... yep, they do ...
13:09 Bristol Temple Meads to Oxford due 14:29
13:09 Bristol Temple Meads to Oxford due 14:29 is being delayed between Bath Spa and Swindon and is now expected to be 17 minutes late.
This is due to a late running freight train
13:03 Oxford to Bristol Temple Meads due 14:15
13:03 Oxford to Bristol Temple Meads due 14:15 is being delayed between Swindon and Chippenham and is now expected to be 32 minutes late.
This is due to a late running freight train.
Very odd in effecting trains in both directions - shunt movement at Royal Wootton Bassett?
Re: Train hits tractor and trailer on level crossing, Leominster, 22 May 2025
In "The Wider Picture in the United Kingdom" [375330/30290/51]
Posted by stuving at 14:02, 21st May 2026
RAIB have published their report on this accident, with the main conclusions on the summary page. This says:
The accident happened because the signaller gave permission to the tractor’s driver to use the crossing, despite the proximity of the approaching train. The signaller had forgotten about the presence of the train when they gave permission and did not check signal box equipment which was indicating the presence of the train beforehand, as they had been trained to. The signaller’s actions may have been affected by an interruption to their established routine for giving users permission to use the crossing, an increase in their workload, distraction and the effects of fatigue.
As Nordan Farm level crossing is a passive user worked crossing, it has no engineered safeguards to warn or protect a crossing user of an approaching train and safe operation is solely reliant on the signaller’s decision as to whether it is safe to cross or not.
RAIB found that Network Rail’s level crossing risk assessment process did not effectively recognise nor control the higher risk present at some crossings during intensive seasonal use. This was an underlying factor. RAIB also found that Network Rail did not have a coherent process for deciding whether a vehicle using a user worked crossing should be considered as large, low or slow moving. This was a possible underlying factor.
The main recommendations are about Network rail's management processes, with some learning points for signallers and other staff too.
In "South Western services" [375329/11448/42]
Posted by stuving at 13:16, 21st May 2026
I just got back from a shopping trip, and I found another missive from NR in the door. It's essentially the same as the first, but with a different background/frame and header "metadata". Both are from Basingstoke Campus, and both sign off as from Community Relations. The second adds Wessex Route to that, and in the heading it says "Ref: ELR: RDG2 62, 02ch / MW/OCT-Wokingham Signal Box". The first is vaguer about it origin, and it is headed "Ref No: RDG_62.0002_STN_WSX_22412 / 20/5/2026 1:00:00 am". Both in the footer invite you to sign up for information about future works, but for services with different names and URLs!
Doesn't that look like a case of the left hand not knowing what the next finger on the same hand is doing? And maybe it's a reminder that just being part of the same legal entity does not guarantee good communications within an organisation. I wonder if we will see more or less of this kind of thing as GBR coagulates.
In "South Western services" [375328/11448/42]
Posted by Mark A at 12:58, 21st May 2026
Ah, and several more stills showing the crossing (as well as many more featuring suburban street scenes from the early 1960s) here:
https://www.reelstreets.com/films/wrong-arm-of-the-law-the/
In "South Western services" [375327/11448/42]
Posted by Mark A at 12:48, 21st May 2026
A still from the film, showing the crossing, here:
https://railwaymoviedatabase.com/the-wrong-arm-of-the-law/
In "South Western services" [375326/11448/42]
Posted by Mark A at 12:45, 21st May 2026
Yes - the site of the crossing actually in nearby Bushy Park Road, how it's been misnamed is lost in the mists etc etc.
In "South Western services" [375325/11448/42]
Posted by Witham Bobby at 11:22, 21st May 2026
That put me in mind of what might have been a previous Feltham resignalling programme. I never noticed the box at Teddington, but, crossing the footbridge on the Kingston end of the station, the sight and sound of the pair, home and distant signal arms, fairly close to the bridge, implied its existence, and there was also the signalbox for the keeper who operated the crossing gates for Bushy Park Road some way towards Hampton Hill - for good measure, there were gasholders close at hand there too. Think it was 1973 that all the signalling in the area was replaced with the colour light variety, the crossing replaced by a footbridge, and later the gasholders went, the site eventually used for a care home and slightly gasholder-shaped blocks of flats.
Famously, the signalbox and level crossing that features in the 1963 Ealing film "The Wrong Arm of the Law" was at Fairfax Road, Teddington.  Is that the one you mean?  Closed in 1973
Re: Five to nine…
In "London to the Cotswolds" [375324/32053/14]
Posted by Witham Bobby at 11:14, 21st May 2026
Sounds like good news
Maybe 9-cars will more reliably get to Hereford than 5-cars
The down service seems often to suffer a long wait at Moreton Cutting, held for an up fast or two to pass by, before crossing to the Down Relief and on towards Oxford.  Hit for four of five minutes there, and then loses time along the way.  Sometimes I think ARS (Automatic Route Setting) has a lot to answer for!
In "South Western services" [375323/11448/42]
Posted by Mark A at 11:10, 21st May 2026
In "The Wider Picture in the United Kingdom" [375322/32049/51]
Posted by Witham Bobby at 11:01, 21st May 2026
A related question.
On my cycle wanderings I regularly use the Stoke Canon Level Crossing. The crossing is CCTV-equipped and has split full width barriers.
On a number of occasions the barriers have been closed for up to 8 minutes - yes, I have timed it - for the passing of 3 services.
This is not, I think, what you would call an intensively worked section of line. Is this entirely down to the local signalling configuration (long track sections) or decisions made by the signallers (who I believe are based at the Exeter Box)?
If you have Train 1 on the Down Main, Train 2 on the Up Main, and Train 3 on the Down:
Barriers dropped, say two minutes before Train 1 arrives at the crossing, so the driver gets greens on the approach.  The first signal that could give a yellow could be 1,800m or so in rear of the crossing, and you don't want the driver to see that as yellow as the train approaches, you want the driver to see a green. At a line speed of 80mph, say, you really do need to start those barriers dropping two minutes before the train gets there.  There will probably be an annunciator in the signalbox, to give awareness that the train is approaching, at a certain distance in rear of the crossing - a track circuit or a treadle
Say it's 2 minutes 20 seconds before Train 1 has cleared the crossing.  By which time, Train 2 could be within three minutes of arrival.  You wont lift the barriers to drop them again in less than a minute.  So they stay down.
Train 2 clears the crossing 5 minutes 40 seconds after the barriers were dropped.  And now Train 3 is about, following  maybe four minutes behind Train 1 on the Down, and not much more than three minutes from the crossing.  Again, you don't want to lift the barriers.  Train 3 arrives at the crossing 8 minutes or more after the barriers were first dropped
This is a general explanation, not specific to Stoke Canon Crossing. It works for two-aspect signals.   But it does give you an idea of why you'd have to wait there for a while, sometimes.  With three aspect signals, when you wouldn't want to show the driver a double yellow even further in rear of the crossing, the barriers may need to be dropped earlier.  Just admire the Saxby and Farmer built signalbox.  A listed building, I believe, and disused for around 40 years now
Five to nine…
In "London to the Cotswolds" [375321/32053/14]
Posted by IndustryInsider at 10:51, 21st May 2026
Already liked by Witham Bobby
Welcome news in the new timetable that 1W01, 09:52 PAD-HFD and its return working  1P28, the 13:18 HFD-PAD are now booked for a 9-car unit instead of the previous 5-car set.
Not so much of an issue in the Cotswold Line, but between Paddington and Oxford both ways these trains had become very crowded as 5-car services.
In "South Western services" [375320/11448/42]
Posted by stuving at 09:36, 21st May 2026
Already liked by Mark A, Witham Bobby
I've just had a "dear neighbour" letter from Network Rail pushed through the door, about work at the level crossing at the end of May. It promises somewhat noisy work "which forms part of the close-out works for the Feltham Resignalling Programme". The activities listed include "machinery to demolish building" and "machinery to remove debris", which sounds like the removal of the signal box.
It's hard not to feel sorry for the poor little thing, sitting there doing no-one any harm. But if you make NR responsible for it, costing them money, and it has no identifiable value to them or anyone else, I guess this is the inevitable result.
In "The Wider Picture in the United Kingdom" [375319/32049/51]
Posted by Bob_Blakey at 08:06, 21st May 2026
A related question.
In "TransWilts line" [375318/31359/18]
Posted by bobm at 17:51, 20th May 2026
14:18 Westbury to Swindon due 15:01
14:18 Westbury to Swindon due 15:01 is being delayed at Westbury.
For the record this was eventually cancelled due to the problems at Westbury North junction.
In "London to the Cotswolds" [375317/31371/14]
Posted by charles_uk at 15:43, 20th May 2026
In addition to the earlier PAD:WOF and return cancellation, we now have:
17:04 Didcot Parkway to Evesham due 18:23 will be cancelled.
This is due to more trains than usual needing repairs at the same time
18:51 Evesham to Oxford due 19:50 will be cancelled.
Hanborough in particular suffers because the Oxford bound service preceding the two cancellations, the 17:26 WOF:PAD, misses out the station.
In "TransWilts line" [375316/31359/18]
Posted by grahame at 15:14, 20th May 2026
15:14 Swindon to Westbury due 15:58 will be cancelled.
In "London to the Cotswolds" [375315/31371/14]
Posted by Witham Bobby at 15:01, 20th May 2026
15:23 London Paddington to Worcester Foregate Street due 17:47 will be cancelled.
This is due to a problem in the depot.
Last Updated:20/05/2026 12:00
18:02 Worcester Foregate Street to London Paddington due 20:29 will be cancelled.
Last Updated:20/05/2026 15:33
Re: HS2 and Northern Powerhouse Rail (NPR) - Government proposals, alternative routes, discussion
In "The Wider Picture in the United Kingdom" [375314/5138/51]
Posted by Witham Bobby at 14:34, 20th May 2026
And all to get from Birmingham to the outskirts of London quarter of an hour or so quicker.  If you didn't laugh, you'd cry
How many times does it need repeating that the WCML is full & no more paths exist. That was the original plan for HS" to provide additional paths for both passenger & freight. One might argue that their biggest fault was in naming the project Hi-Speed 2.
I am completely confident that additional capacity could have been built without a project that will take far too long to be completed and has dug very deeply into taxpayers pockets (£100bn is a huge amount of wonga)  and would have provided a lot more "connectivity" than a shuttle route between the capital and our second city
I don't argue that the capacity is needed.  But the project is a farce, and, beyond the capacity that it might produce, has very little benefit (unless you're a consultant or civil engineering contractor.  In which case you're right royally coining it)
In "London to the Cotswolds" [375313/31371/14]
Posted by charles_uk at 14:34, 20th May 2026
From yesterday (19 May):
1W25 1252 London Paddington to Worcester Foregate Street cancelled between Worcester Shrub Hill and Worcester Foregate Street due to a problem with train communications (J0). It ran non-stop from Oxford arriving at Shrub Hill 19 minutes late.
The 15:23 London Paddington to Worcester Foregate Street and return run were also both cancelled.
And today:
In "TransWilts line" [375312/31359/18]
Posted by grahame at 14:30, 20th May 2026
In "The Wider Picture in the United Kingdom" [375311/5138/51]
Posted by grahame at 13:03, 20th May 2026
Reply no. 1937 on a thread that originates back in 2009 ...
The naming is certainly something that has given rise to a false narrative, but may I suggest that the implication from that naming is an even bigger fault - the heavy engineering and extra expense of a brand new line on an alignment fit for a speed that will save a few minutes.
Here are two images I have grabbed this morning - that on the left if the DfT's crowing about progress - none of which will actually be in use for, what, another decade, and on the right is a railway map showing North West London.
Now - it's too late to look at the parallel universe through retrospective glasses - but I find myself musing that had a decision been taken to restore / retain the old Great Central route north of Aylesbury, various other routes that are not at WCML capacity would have opened up. The old GC route crossed the West Coast main line at Rugby, and from the right hand side map here you'll see how close the various lines come to each other in the lead into London.
The parallel universe offered some really interesting prospects, such as express trains from the North West and Midlands (and beyond there from North Wales, the North East and Scotland) routing onto the Midland line and rather than turning right at Kentish Town carrying on along the chord across onto HS1.  With the UK joining Schengen ...
* Manchester - Stoke-on-Trent - Nuneaton - London Kentish Town - Ashford - Calais - Lille - Brussels - Koln - Frankfurt
* Leeds - Sheffield - Nottingham - Leicester - Rugby - London Kentish Town - Stratford International - Paris
* Holyhead - Bangor - Crewe - Rugby - London Kentish Town - Brussels - Hannover - Berlin - Warsaw
and they would be up and running already!  The engineering needed being only a fraction of that which the DfT boasts of being proudly completed on social media this morning.
In "The Wider Picture in the United Kingdom" [375310/5138/51]
Posted by ChrisB at 12:29, 20th May 2026
Already liked by Oxonhutch
In "The Wider Picture in the United Kingdom" [375309/32049/51]
Posted by Witham Bobby at 12:12, 20th May 2026
Barriers (well, certainly most of them) that are locally or CCTV supervised in track-circuited areas are default-set to auto raise as soon as the circuit over the level crossing goes clear.  Obviously that doesn't happen if the barriers are down for a train passing over the crossing on another line
Some crossing keepers/signalmen used to switch off this setting so that their action would initiate the raising of the barriers.  They were either bloody minded antagonistic people, or they had too much time on their hands
In "The Wider Picture in the United Kingdom" [375308/32049/51]
Posted by stuving at 11:15, 20th May 2026
Both were on Saturday afternoon, probably about 2.30pm and then about 4.30pm.
In that case I got the wrong day - if anything the trains were running too regularly. There are 12 tph, and if they arrive spaced close to 5 minutes apart there are none of the longer gaps. On that Saturday there were several trains a minute or two early or late and that's all it takes. The other factor is the personal style of the operator - some are more inclined to whip the barriers up whenever possible, others more cautious.
I'm not sure where the operators sit for that one, and whether they are crossings-only operators or signallers. It was quite noticeable when Wokingham went over from local operation by the signaller to specialsed operators at Basingstoke ROC that the barriers were raised much sooner after a train had passed.
