Re: Plus bus plus Rover
In "Fare's Fair" [372410/13019/4]
Posted by grahame at 08:44, 15th February 2026
https://tfw.wales/ways-to-travel/rail/ticket-types/rovers-and-rangers/explore-wales seems to be fairly comprehensive. The 'Our bus partners' section shows the following:
Here is a list of the bus operators in Wales that will accept the 'Explore Wales Pass':
    All TrawsCymru services (Excluding T7, T12, X43, 460)
so it appears the M&H Coaches drivers were correct.
Except the map shows the T8, and it's a TransCymru service not in the excluded list ...
Fun!
I'm sure the drivers were correct.  I should probably ask my sales outlet - GWR - as I stated I wanted to go to Ruthin on the ticket and what I was sold was not valid for that
In "Fare's Fair" [372409/13019/4]
Posted by Bob_Blakey at 08:19, 15th February 2026
    Arriva Wales
    Cardiff Bus
    First Cymru
    Stagecoach South Wales
If this mirrors the situation in Devon bus services which are run on an entirely commercial basis i.e. without Local Authority support cannot be required to accept 'discounted' tickets. I could not find any information regarding this issue on the M&H Coaches website.
In "Fare's Fair" [372408/13019/4]
Posted by grahame at 05:49, 15th February 2026
The Explore Wales Rovers include bus travel with most scheduled service operators.
Grand theory (and I know I am following up an old post).    We used the T8 yesterday - or tried to - on an "Explore Wales" ticket purchased at Bath Spa Station on Friday.   The sales blurb said we could, the chap there sold it to us for use on trains and buses, but we were denied its use on the T8 service - once each way - by different drivers.  According to one of them, it is (now?) only valid on buses run by Arriva ... and this service is run by M&H Coaches.
I am - disinclined - to complain.   Both bus drivers were very nice about it, and the rides out and back from Chester into Wales were good, but it was a challenge that we felt we should not have faced, and being told that our tickets weren't acceptable when we had paid quite a bit for them ...
So - if I were to raise this, who would it be with?   M&H Coaches who refused the tickets?  TfW who put out the misleading information and map?  Arriva because they have the concession for TransCymru services and may have subcontracted this route?  GWR who sold me the ticket and I stated to the booking clerk that we needed to get to Chester and then on to the bus part of the pass?
Lisa and I are relatively hardened to the challenges of public transport travel, but various challenges yesterday on getting the T8 (not showing on bus stops, for example, running late ... not accepting the tickets we had chosen to include use of that bus) must, surely, put off the timid newcomer.
Re: Itchy feet - where have they taken me?
In "The Lighter Side" [372407/31622/30]
Posted by grahame at 18:07, 14th February 2026
A reminder if you are coming back through Bath Spa.   The lift from Platform 2 is out of use until next month.
https://transwilts.org/2026/02/04/lift-works-at-bath-spa/
Yeah ... thanks ... we had planned around that  .    Will post follows ups as they happen.
In "The Lighter Side" [372406/31622/30]
Posted by Mark A at 17:15, 14th February 2026
*Breathes sigh of contentment*
In "Across the West" [372405/31163/26]
Posted by TaplowGreen at 15:07, 14th February 2026
Due to a fault with the signalling system between Newbury and Reading trains have to run at reduced speed on the line towards Reading.
Train services running to and from these stations may be delayed by up to 15 minutes. Disruption is expected until 18:00 14/02.
Apologies to customers, due to a fault with the signalling system in the Thatcham area trains on eastbound line have to run at a reduced speed thus incurring delays.
Some semi-fast trains between Newbury and Reading will be cancelled, but all stations will still receive a train service.
In "The Lighter Side" [372404/31622/30]
Posted by bobm at 14:22, 14th February 2026
Re: Night Riviera Sleeper train - between Paddington and Penzance
In "London to the West" [372403/489/12]
Posted by bobm at 14:17, 14th February 2026
Part of the apparent discrepancy may be down to a change of route.   After leaving Taunton it was scheduled to go via Box and Swindon but instead went up the Berks & Hants line.
When it passed Cogload Junction it was 194 minutes late.  By the time it got back on route west of Reading it had reigned that in to 157 minutes late.
As the service was replaced by a five car IET at Taunton, it also saved 20 minutes with the Reading stop as it didn't pause to attach the second loco to the rear.
In "The Lighter Side" [372402/31622/30]
Posted by grahame at 13:20, 14th February 2026
Tickets - Melksham to Severn Tunnel Junction then on to an Explore Wales 4 or 8, which wasn't easily found by the ticket clerk, and we nearly ended up with an Explore SOUTH Wales.  Relatively expensive for what we are doing but it gives us the flexibility.  "On the Buses" today.
Was this bought at Bath Spa? Did they issue the coupon with it, to record the days you travel?
Yes, and yes
In "London to the West" [372401/489/12]
Posted by TaplowGreen at 11:24, 14th February 2026
I hope that they were all l;eft in their cabins until the IET was ready & waiting at TAU?
A rude awakening indeed!
In "London to the West" [372400/489/12]
Posted by ChrisB at 10:47, 14th February 2026
In "London to the West" [372399/489/12]
Posted by Andy E at 10:27, 14th February 2026
It seems that the train was declared a failure at Taunton where it had arrived at 01.38. An 802 IET was sent from Exeter to continue the service leaving Taunton at 05.05.
In "London to the West" [372398/489/12]
Posted by ChrisB at 09:36, 14th February 2026
21:45 Penzance to London Paddington due 05:07
13/02/26 21:45 Penzance to London Paddington due 05:07 is being delayed at Taunton and is now expected to be 200 minutes late.
Goodness - how the information system is so wonderful at getting it wrong.   Due into Paddington at 05:07, actually in at 07:04 - only 117 late
That's a result of timing the run at a sedate pace to allow sleep. Of course, once late, the train can & does go faster & catch up.
I'm sure it was 200 late when that warning was posted - why would it not be?
Lumo even post that their delays can be caught up further down/up the line.....
In "Across the West" [372397/28982/26]
Posted by REVUpminster at 09:19, 14th February 2026
Already liked by Western Pathfinder
5Z13 shows 175011 allocated from Par, and RTT has reports of it from Par to (so far) St Germans. How it got to Par, and why it's not showing on Traksy, is another matter.
It has just popped up at Wivelscombe on Traksy. But how it's already got past Saltash on camera, I have no idea.
Just to tidy up, and correct my mistakes:
-  REVUpminster's webcam of 175011picture was on 5Z33, 1100 Plymouth-Par, coming off the bridge at 11:13.
- so that answers my question about how it got to Par
- it was also seen in the Saltash webcam on 5Z13 at 12:51, on the way back to Plymouth (arr. 1259).
Which leaves outstanding the question of when it first got back from its enforced holiday at Liskeard to Plymouth. If I had to guess (which I don't, obviously) I'd say it was coupled to 175007, but not mentioned in despatches.
or did come back with 175002 and not mentioned.
An interesting signal problem is how. On London Underground signalling; as the points cannot be guaranteed, because a train is occupying the approach section, to be locked they would have to be scotched and clipped and hand signalled into the platform or the trains moved towards Liskard past signal LD20, the points on the branch scotched and clipped then the normal signal interlocking can take effect and the trains moved onto the main line.
In "The Lighter Side" [372396/31622/30]
Posted by Mark A at 08:35, 14th February 2026
In "London to the West" [372395/489/12]
Posted by TaplowGreen at 08:35, 14th February 2026
Goodness - how the information system is so wonderful at getting it wrong.   Due into Paddington at 05:07, actually in at 07:04 - only 117 late - and for many passengers, I suspect that's a far better arrival time anyway.  And - question - how does delay/repay work with the sleeper - fare, berth fees, ...
"Only" 2 hours late
In "The Lighter Side" [372394/31622/30]
Posted by Mark A at 08:34, 14th February 2026
A police dog took exception to me there and had a little bit of a go at me. Its handler was less than impressed and communicated this to the dog in surprisingly forthright terms. To be honest, I wouldn't like to repeat the experience either.
Ah, that's Newport. The police dog that was less than ok was on the footbridge at Waterloo, I'm sure all the police dogs in Wales are lovely. This from Dyfed police's web site.
https://www.dyfed-powys.police.uk/police-forces/dyfed-powys-police/areas/about-us/about-us/dog-section/
In "London to the West" [372393/489/12]
Posted by grahame at 08:31, 14th February 2026
In "The Lighter Side" [372392/31622/30]
Posted by grahame at 08:20, 14th February 2026
Melksham (station) to collect the gent who's house sitting, Bus to Bath, train to Temple Meads, train to Newport, train to Chester.  All on time.   We made a connection that wasn't at Temple Meads - arrived at 15, left 6 minutes later from 3 and with a mobility aid that meant lifts not stairs too.   Arrived at 1 into Newport (not common?) and headed up north from 3.   Loved the 197 on what was classified as "Standard Plus".
Love the whole atmosphere / friendliness of public transport travel - both the Bath to Bristol local and and Marches line service too ... oh, and the bus.  Bit of a randomness about that; personally helped by being a frequent traveller in our very local area and so knowing a lot of people.
In "London to the West" [372391/489/12]
Posted by TaplowGreen at 08:13, 14th February 2026
Re: Yeovil - Weymouth closure Feb-March 2026
In "Heart of Wessex" [372390/31620/19]
Posted by JayMac at 05:31, 14th February 2026
Proactive rather than reactive maintenance it would seem. Bravo.
Re: A379 at Slapton Sands in south Devon - sea related incidents
In "The West - but NOT trains in the West" [372389/31569/31]
Posted by johnneyw at 22:39, 13th February 2026
Already liked by Chris from Nailsea, Andy E, rogerw, chuffed
It's a very sorry sight indeed.  I've been down the Slapton Line many times over the last half century, whether by foot, car, bus or coach.
The local MP Caroline Voaden made an appeal in parliament to the PM pointing out how the local community had twice served the nation to their cost last century.  Firstly with the offshore dredging to help build the Plymouth breakwater for the Royal Navy which resulted in the eventual destruction of Hallsands (and arguably contributed to this year's damage at Torcross).  Secondly with the wartime evacuation of the communities to facilitate D-Day training in The Second Word War.
The Slapton Line repair could, in this context, be seen as a much delayed and meaningful act of gratitude and recognition.
In "Across the West" [372388/28982/26]
Posted by stuving at 22:26, 13th February 2026
In "The Lighter Side" [372387/31622/30]
Posted by grahame at 21:39, 13th February 2026
I'm thinking that 2 might be Newport.
And I think that 4 is Newport, too!
Yep, they both are.    There are only so many places we were at today!
In "The Lighter Side" [372386/31622/30]
Posted by johnneyw at 21:10, 13th February 2026
1. has been guessed correctly as Chester
Ah yes, so it seems.  It was still quite fresh in my memory despite the unfamiliar view from that hotel.  I liked Chester and found a decent hotel by the canal near the town centre.
Re: Mousehole, Cornwall: a bus route change (for the worse)
In "Buses and other ways to travel" [372385/31600/5]
Posted by Mark A at 21:00, 13th February 2026
Good to hear. Never stayed there, mind, but their lawn and its outlook could hardly be better.
In "The Lighter Side" [372384/31622/30]
Posted by Mark A at 20:41, 13th February 2026
Re: Buying Tickets for Four Seniors
In "Fare's Fair" [372383/31623/4]
Posted by John D at 20:16, 13th February 2026
Yes you can buy for May, the ticket office clerk will probably remind you that all need senior railcards valid at date of travel.
One of your party might have a railcard that expires before travel date, so showing it now doesn't prove they will have renewed it, or will remember it on the day.
It's also a bit daft if you get refused at a ticket office, but can then go online and buy it anyway.  If this happened it's sort of indirectly recommending no reason to keep ticket offices open.
In "Fare's Fair" [372382/31623/4]
Posted by bobm at 19:59, 13th February 2026
You can book seat reservations via a GWR account on their website.  It asks what type of tickets you have but doesn’t actually need the proof.
Incidentally you can reserve a seat on any reservable service with any TOC from the GWR website.
In "The Lighter Side" [372381/31622/30]
Posted by ChrisB at 19:57, 13th February 2026
Looking at this again, yes, I think so too.
I'm pretty sure that I know the first one
