29.5.2025 (Thursday) 02:09 - All running AOK
In "TransWilts line" [361809/29726/18]
Posted by grahame at 19:45, 28th May 2025
21:16 Westbury to Swindon due 21:58 will be cancelled.
Followed, as sure as night follows day, by
In "TransWilts line" [361808/29726/18]
Posted by TaplowGreen at 19:20, 28th May 2025
Re: Northumberland Line to open on Sun 15 December
In "Campaigns for new and improved services" [361807/29569/28]
Posted by Noggin at 19:07, 28th May 2025
It is great that people are using this service but the tickets are really cheap i.e. an anytime single Newcastle to Ashington (about 13 miles) is £2.60; in comparison a Didcot to Oxford (10 miles) anytime single is £8.70. 20p a mile compared with 87p a mile.
Northern is the English TOC with the highest subsidy so not sure how this is affordable, of course ideally we would like all services to be as highly subsidised.
Lets hope that as the fares rise the service continues to be used.
And I do wonder with EWR whether 2 car trains are going to be big enough.
If you think that's cheap, I'm currently in Spain's Basque country. They seem to have some kind of special economic crisis pricing going on. If I'm not mistaken I just did the 12 miles by train from Hendaye in France to San Sebastian for 49c
Re: Taking Train Operation into public ownership - Govt planning from 4.12.2024
In "The Wider Picture in the United Kingdom" [361806/29571/51]
Posted by Sixty3Closure at 18:33, 28th May 2025
Unless I missed it I didn't see any mention of simplifying tickets which I thought would be one benefit of bringing everything under one roof?
In "Across the West" [361805/29650/26]
In "Across the West" [361804/29650/26]
In "Across the West" [361803/29650/26]
In "Across the West" [361802/29650/26]
In "Across the West" [361801/29650/26]
In "TransWilts line" [361800/29726/18]
Posted by bobm at 13:54, 28th May 2025
Already liked by matth1j
17:35 Swindon to Westbury due 18:19
17:35 Swindon to Westbury due 18:19 will be cancelled.
Both now re-instated.
Re: Night Riviera Sleeper train - between Paddington and Penzance
In "London to the West" [361799/489/12]
Posted by bobm at 13:44, 28th May 2025
Sleeper loco suffered a fuel leak.   Now been rescued by a Castle Class set and on its way, empty, to Long Rock in Penzance.
In the end it went to Laira, Plymouth, for repairs.   Due to head to Penzance this afternoon.
In "Across the West" [361798/29650/26]
In "Across the West" [361797/29650/26]
In "Across the West" [361796/29650/26]
In "TransWilts line" [361795/29726/18]
Posted by matth1j at 11:10, 28th May 2025
...and if I search for Bristol Temple Meads - Melksham on the National Rail app it also shows the earlier 1545 option as cancelled as well, although I can't be bothered to check which of the 2 trains on that route aren't running.
In "TransWilts line" [361794/29726/18]
Posted by matth1j at 11:06, 28th May 2025
That would have been the last leg of my commute home. Looks like another £3 on the buses
In "London to the Cotswolds" [361793/29711/14]
Posted by Worcester_Passenger at 10:42, 28th May 2025
and
1W11 05:53 London Paddington to Great Malvern was delayed at Shrub Hill. Arrived Worcester Foregate Street +22 and cancelled thereafter.
08:18 Worcester Shrub Hill to London Paddington due 10:25 has been delayed at Worcester Shrub Hill and is now 36 minutes late.
This is due to a fault on a train in front of this one.
Last Updated:28/05/2025 09:14
Indeed so - I'm on it. And the "train in front" was the 05:53.
08:56 Great Malvern to London Paddington due 11:27 will be started from Worcester Foregate Street.
Last Updated:28/05/2025 08:58
In "TransWilts line" [361792/29726/18]
Posted by grahame at 09:40, 28th May 2025
In "London to the West" [361791/489/12]
Posted by RobT at 09:07, 28th May 2025
Looks like set GW08 43156/43186 was used for the rescue, as 2C00 was cancelled and 2E06 was partially cancelled.
In "London to the West" [361790/489/12]
Posted by GBM at 08:51, 28th May 2025
23:45 London Paddington to Penzance due 07:55
27/05/25 23:45 London Paddington to Penzance due 07:55 was terminated at Exeter St Davids.
It will no longer call at Newton Abbot, Plymouth, Liskeard, Bodmin Parkway, Lostwithiel, Par, St Austell, Truro, Redruth, Camborne, Hayle, St Erth and Penzance.
.....all lines currently blocked at Exeter St Davids as a result.
Looking at RTT, it was a 3 carriage train from London to Exeter!
In "Campaigns for new and improved services" [361789/29569/28]
Posted by RichardB at 08:47, 28th May 2025
Already liked by ray951
The fares issue is partly down to the Ashington line only having Single tickets and no returns (Single leg pricing).  The £2.60 is actually Off Peak, the Anytime Single being £3.00 (www.brfares.com) - your point about the fares being cheap still holds but, taking that Didcot - Oxford example, the Off Peak Day Return for that is £8.70, just 10p more than the Off Peak Day Single.
Okehampton was opened in 2021 with fares of £4.00 Single, £8.00 Return (both Anytime, no Off Peak fares) Exeter - Okehampton and that's 30 miles.   Now £4.60 and £9.20 respectively.  In both cases, the railway is being introduced in areas where generations have grown up without it so attractive fares clearly have an important role.  I know the great care that was taken with Okehampton.
In "London to the West" [361788/489/12]
Posted by grahame at 08:37, 28th May 2025
What are they going to do without "Thunderbird" Castles??
Re: Bristol Temple Meads - station, facilities, incidents and events (merged posts)
In "Bristol (WECA) Commuters" [361787/10737/21]
Posted by Red Squirrel at 08:15, 28th May 2025
All in the master plan, discussed upthread or here: https://www.networkrail.co.uk/running-the-railway/our-routes/western/bristol-rail-regeneration/
In "TransWilts line" [361786/29726/18]
Posted by grahame at 07:33, 28th May 2025
Argh! First commute in over 2 weeks and the trains...
When I left the house, it was looking good. But then the 0632 Southampton service I catch from Melksham to Trowbridge got delayed and was showing as 20 mins late, ....
Yeah ...
05:11 Gloucester to Southampton Central due 08:09
05:11 Gloucester to Southampton Central due 08:09 has been delayed between Kemble and Swindon and is now 16 minutes late.
... it appears to have arrived on time in Swindon but spent 30 minutes rather than 10 there.  Looks like it will be on time from Salisbury, in spite of Journey Check assuming "once delayed, delayed all the way". Guessing it was some sort of issue the crew on local staff at Swindon were able to sort out.
In "London to the West" [361785/489/12]
Posted by bobm at 07:22, 28th May 2025
In "TransWilts line" [361784/29726/18]
Posted by matth1j at 07:15, 28th May 2025
When I left the house, it was looking good. But then the 0632 Southampton service I catch from Melksham to Trowbridge got delayed and was showing as 20 mins late, meaning I'd miss the 0646 Trowbridge Bristol. And the next option, the 0705 Cardiff service, was also showing as delayed, with the following Filton Abbey Wood cancelled.
So I'm on the bus to Bath, where I should be able to catch the 0747 Weston service. What's even more annoying is that the 0705 Trowbridge Bristol that was showing as delayed ended up being on time - it just started from Westbury instead of Frome.
Try again tomorrow...
In "London to the West" [361783/489/12]
Posted by TaplowGreen at 06:08, 28th May 2025
In "Across the West" [361782/29650/26]
In "London to the Cotswolds" [361781/29711/14]
Posted by Worcester_Passenger at 04:33, 28th May 2025
Wednesday May 28
20:52 London Paddington to Great Malvern due 23:13 will be cancelled.
Last Updated:28/05/2025 02:47
In "Campaigns for new and improved services" [361780/29569/28]
Posted by IndustryInsider at 23:41, 27th May 2025
Already liked by Mark A, ray951, Witham Bobby, Timmer
That's an easy one.  NO they won't be anywhere near long enough!
