12.7.2025 (Saturday) 03:34 - All running AOK
Re: HS2 - Government proposals, alternative routes and general discussion
In "The Wider Picture in the United Kingdom" [363129/5138/51]
Posted by Chris from Nailsea at 01:14, 12th July 2025
The government has made the demise of domestic air travel an explicit policy target for the first time by aiming to replace short-haul flights with a new 250mph high-speed rail network.
I was reminded of the original post in our previously merged topic on the subject of HS2 - so I've now merged the latest discussion into this one, in the interest of continuity.
Re: Air India flight to London Gatwick crashed in Ahmedabad - 12 June 2025
In "The Wider Picture Overseas" [363128/30350/52]
Posted by JayMac at 00:33, 12th July 2025
We now know how the plane crashed. Whether we get the 'why' remains to be seen.
I've attached the interim report to this post. It is compressed so the embedded images may not be clear. Alternatively it can be downloaded from India's Aircraft Accident Investigation Bureau.
https://aaib.gov.in/What's%20New%20Assets/Preliminary%20Report%20VT-ANB.pdf
In "The Wider Picture Overseas" [363127/30350/52]
Posted by TonyK at 22:51, 11th July 2025
Reported elsewhere too. From the MSN extract from the Telegraph:
Initial findings from the investigation into the crash indicate switches controlling fuel flow to the jet’s two engines were turned off leading to a catastrophic loss of thrust at take-off.
Amid the confusion, one of the pilots is heard asking the other why he “did the cut-off” to the fuel supply in the recovered cockpit voice recording.  The other pilot responded that he did not do so, according to the report released on Friday night by Indian authorities.
The switches were then moved back to their normal position, which automatically started the process of relighting the engines.
One of the engines was in the process of regaining power at the time the aircraft crashed. The other was relit but was not yet regaining thrust.
“At this stage of investigation, there are no recommended actions to B787-8 and/or GE GEnx-1B engine operators and manufacturers, suggesting that no significant fault has been found with the plane or its engines,” the report reads.
In "The Wider Picture Overseas" [363126/30350/52]
Posted by broadgage at 22:17, 11th July 2025
BREAKING NEWS.
No significant faults found with the aircraft or the engines.
Both fuel controls found to be shut off. (according to flight data recorder)
One of the pilots can be heard asking the other pilot why were the switches turned off ? (according to cockpit voice recorder)
Source was BBC TV news at 22-00, Friday evening.
Re: Shortage of train crews on Great Western Railway - ongoing discussion
In "Across the West" [363125/18719/26]
Posted by Timmer at 21:36, 11th July 2025
https://www.gwr.com/sunday-disruption
Travelling by train this Sunday? Important information
We expect disruption on some routes this Sunday because of crew availability. 
No services will operate on the following routes on Sunday 13 July and customers should not attempt to travel between:
Westbury and Weymouth (No bus replacement able to operate)
Swindon and Westbury (A very limited bus replacement will operate)
A reduced, amended timetable will also be in place for trains between: 
Westbury and Bristol Temple Meads
On this route, customers should change their plans if possible and only travel if necessary. Fewer trains will run, and those that do will be extremely busy. Some further services may also be cancelled or delayed at short notice. 
Because of the late-notice changes, and the complexity of updating timetable systems, journey planners will not show changes correctly before Sunday morning.
With high temperatures expected, we’re reminding all customers to plan ahead and travel prepared:
Stay hydrated – bring a refillable water bottle
Check before you travel – services may be busier or subject to change
Allow extra time – especially during the hottest parts of the day
Your comfort and safety are our priority. Please check live updates before setting off and take care in the heat.
If you have already bought tickets between Westbury and Weymouth for this Sunday 13 July, these will be valid on Saturday 12 or Monday 14 July, or if you do not travel you can claim a full refund at GWR.com/refunds – subject to the terms and conditions of your ticket type.  
In "TransWilts line" [363124/29726/18]
Posted by Timmer at 21:29, 11th July 2025
I know it’s a bit off the Transwilts, but the service at Dilton Marsh since 4pm onwards has been next to non existent with cancellations in both directions with Warminster/Salisbury services being cancelled.
There are supposed to be automatically added stop orders - that may only be on certain trains though - have extra stops happened?
If there have been, they haven’t appeared on the Tiger Departure Board this afternoon/evening or Journeycheck saying Cardiff-Portsmouths making additional stops.
In "TransWilts line" [363123/29726/18]
Posted by grahame at 21:14, 11th July 2025
In "Across the West" [363122/29650/26]
Posted by a-driver at 21:07, 11th July 2025
Re: West Somerset Railway - Bishops Lydeard to Minehead (merged posts)
In "Heritage railways, Railtours, buses, canals, steamships and other public transport based attractions" [363121/2688/47]
Posted by Chris from Nailsea at 20:52, 11th July 2025
As ever, in the interests of continuity and ease of future reference, I have merged two topics here.
Re: Disruption 10/07/2025
In "Portsmouth to Cardiff" [363120/30443/20]
Posted by Clan Line at 20:38, 11th July 2025
*Sits on hands*
*Fails, hands escape and fly to the keyboard*. The utility and value to passengers and to the industry of that Waterloo-Bristol through service that ceased to run only a few years ago. Class 159, three carriages, well timed departures from Waterloo that didn't impose a peak fares massacre (as well as an easier-to-understand fares structure, and, often, advance fares available). Oh, and comfy seats and, though busy, spare seats every trip plus a trolley service for drinks and a bite.
..............you forgot the noisy, but working, air-con !    My daughter travelled from Kent to Warminster today. WAT to SAL - 3 car 159, everything worked, busy but comfortable. SAL to WMN (middle of the afternoon !!) - 3 car 166, full and standing, absolutely sweltering .......
At least on Sunday morning she will have a 159 all the way from WMN to Clapham
Re: west somerset railway cancels all day time services Friday 11 July 2025
In "Heritage railways, Railtours, buses, canals, steamships and other public transport based attractions" [363119/2688/47]
Posted by TaplowGreen at 20:37, 11th July 2025
What other trains? Only Scotsman and one home fleet loco operating. Out from Bishops Lydeard by one, back by t'other.
Mum and I did the journey last Wednesday. Lovely day out. We did see evidence of lineside fires. Later that week and earlier this week the WSR were using diesels for their running days and for the other leg of Scotsman services. They pressed the former GWR HST Castle set into service that is currently residing on the WSR
Given recent incidents such as this, the lineside fires you mention and the ongoing tinder dry conditions steam trains shouldn't be running at all.
The Fire Brigade are likely to be busy enough dealing with wildfires without having to cover totally avoidable risks such as this.
https://www.oxfordmail.co.uk/news/25277018.oxfordshire-historic-steam-train-caused-1-5-miles-fires/
In "Across the West" [363118/29650/26]
Posted by TaplowGreen at 20:21, 11th July 2025
In "TransWilts line" [363117/29726/18]
Posted by bobm at 20:11, 11th July 2025
https://transwilts.org/2025/07/11/no-transwilts-trains-on-sunday-13th-july/
GWR are warning of disruption on some routes this Sunday (13 July) because of crew availability.
No services will operate on the following routes this Sunday and customers should not attempt to travel between Westbury and Weymouth (No bus replacement able to operate), and between Swindon and Westbury (A very limited bus replacement will operate).
A reduced, amended timetable will also be in place for trains between Westbury and Bristol Temple Meads. On this route, customers should change their plans if possible and only travel if necessary. Fewer trains will run, and those that do will be extremely busy. Some further services may also be cancelled or delayed at short notice.
Customers who had already bought tickets between Westbury and Weymouth for this Sunday 13 July will be able to use them on Saturday 12, or Monday 14 July, or if they do not travel they can claim a full refund at www.GWR.com/refunds.
Further information will be available on our webpage at www.gwr.com and customers can check before they travel at www.gwr.com/check.
In "The Wider Picture Overseas" [363116/30350/52]
Posted by Clan Line at 19:44, 11th July 2025
https://www.standard.co.uk/news/world/air-india-plane-crash-report-investigation-pilot-error-switches-london-gatwick-b1237753.html
In "TransWilts line" [363115/29726/18]
Posted by Timmer at 19:10, 11th July 2025
In "Across the West" [363114/18719/26]
Posted by Timmer at 19:05, 11th July 2025
Do not travel to be issued this Sunday 13 July between Westbury - Weymouth & Westbury - Swindon and an emergency timetable in operation Westbury - Bristol due to crew availability.
Limited RRB will run Westbury - Swindon.
Customers who have already bought tickets for travel between Westbury and Weymouth this Sunday will be able to use them this Saturday 12, or Monday 14 July.
Must be a lot of Westbury based crew are tennis fans with the men’s final on Sunday.
In "Across the West" [363113/18719/26]
Posted by plymothian at 18:51, 11th July 2025
Re: West Somerset Railway cancels all day time services Friday 11 July 2025
In "Heritage railways, Railtours, buses, canals, steamships and other public transport based attractions" [363112/2688/47]
Posted by bobm at 18:41, 11th July 2025
Latest on their website.
Due to operational issues the West Somerset Railway had to cancel all planned services on Friday 11th July 2025.
Jonathan Jones – Pratt, Chairman said ‘’Unfortunately the decision was made to suspend operations due to a trackwork incident yesterday. There have also been concerns with staff welfare and ensuring they are working in safe conditions given the extreme weather temperatures. This was a difficult decision to make and I am aware there are disappointed customers at this special time of operations on the line. Our team has been working extremely hard to overcome the challenges but given the excessive heat currently being experienced it has meant no work can be undertaken to the rail during daytime hours, causing the operational issues to be prolonged. Our teams are working exceptionally hard to try to resolve the issues and will be working overnight this evening, when temperatures will have dropped, to fix the current issues.  We expect services to operate as planned tomorrow and will be offering additional operational services with Flying Scotsman on Sunday 13th to allow those who missed out on Friday the opportunity to still travel.
In "TransWilts line" [363111/29726/18]
Posted by bobm at 18:36, 11th July 2025
12:17 Westbury to Swindon due 13:05
12:17 Westbury to Swindon due 13:05 is being delayed at Westbury.
This is due to train crew being delayed.
Let me guess ... because the crew are coming in on a delayed Berks and Hants semi-fast .... this arrangement does not seem to be robust.
In the end it departed 12 minutes late - four minutes after the West of England service arrived.  At least it ran.
In "TransWilts line" [363110/29726/18]
Posted by John D at 18:07, 11th July 2025
seems to be an epidemic affecting Turbos today - or maybe the warm weather.
Warm weather doesn't create faults, but it does reduce the ability to use worn or poorly fitted components without problems.
In a way any poor / shoddy maintenance tends to show up as problems and faults more quickly.  The old adage a stitch in time saves nine applies, and if get lots of breakdowns, run out of usable trains short term.
In "TransWilts line" [363109/29726/18]
Posted by grahame at 18:03, 11th July 2025
And 4 more gone ...
20:14 Swindon to Westbury due 20:56
... it was 158769 on earlier services so perhaps not a turbo failure this time
In "TransWilts line" [363108/29726/18]
Posted by TaplowGreen at 18:02, 11th July 2025
20:14 Swindon to Westbury due 20:56 will be cancelled.
This is due to a fault on this train
21:16 Westbury to Swindon due 21:58 will be cancelled.
In "Across the West" [363107/29650/26]
Posted by TaplowGreen at 18:00, 11th July 2025
Re: Seagulls, particularly in Cornwall - ongoing discussion
In "The West - but NOT trains in the West" [363106/29073/31]
Posted by JayMac at 17:55, 11th July 2025
Already liked by Timmer
The fewer we have around our residents parking area, the better, as far as I'm concerned.
The b*st*rd sh*t*hawks seem to delight in congregating on the cars and sh*tting all over them.
In "Heritage railways, Railtours, buses, canals, steamships and other public transport based attractions" [363105/2688/47]
Posted by JayMac at 17:51, 11th July 2025
In "The West - but NOT trains in the West" [363104/29073/31]
Posted by broadgage at 17:48, 11th July 2025
Press report regarding gulls dying after gorging on flying ants https://www.wsfp.co.uk/news/seagulls-die-after-gorging-on-flying-ants-495683
That was some years ago, but it seems that similar conditions are now occurring.
In "London to the Cotswolds" [363103/29711/14]
Posted by Worcester_Passenger at 17:29, 11th July 2025
Friday July 11 : problems near Hereford
1W02 11:52 London Paddington to Hereford (14:44) : delayed Oxford (+16), held Great Malvern (+31) and Ledbury (+53), arrived +66.
In consequence:
15:18 Hereford to London Paddington due 18:29 will be terminated at Reading.
It will no longer call at Didcot Parkway and London Paddington.
This is due to a fault with the signalling system earlier today.
Last Updated:11/07/2025 17:13
This train departed +56.
18:57 London Paddington to Great Malvern due 21:18 will be started from Reading.
Later:
1W27 13:50 London Paddington to Great Malvern (16:15) : departed +19, arrived +28.
1P38 16:32 Great Malvern to London Paddington (19:29) : departed +29, held Norton, currently +47 at Honeybourne.
In "The West - but NOT trains in the West" [363102/29073/31]
Posted by TaplowGreen at 16:49, 11th July 2025
Already liked by Chris from Nailsea, broadgage, matth1j, PrestburyRoad
Numerous dead gulls have been seen locally. Reported as being due to gorging on flying ants. Some claim that these insects are toxic if eaten in large numbers, others claim that the birds overeat to such an extent that they become too heavy to fly, and expire of heat stress.
Note to self: go easy on flying ant consumption, particularly if intending to fly.
In "The West - but NOT trains in the West" [363101/29073/31]
Posted by broadgage at 16:47, 11th July 2025
In "TransWilts line" [363100/29726/18]
Posted by TaplowGreen at 16:47, 11th July 2025
17:35 Swindon to Westbury due 18:19
17:35 Swindon to Westbury due 18:19 will be cancelled.
