In "TransWilts line" [375575/31359/18]
Posted by TaplowGreen at 20:15, 27th May 2026
Cancellations to services between Westbury and Swindon
Due to more trains than usual needing repairs at the same time between Westbury and Swindon fewer trains are able to run on the line.
Train services running through these stations have been cancelled. Disruption is expected until the end of the day.
Due to a shortage of trains this evening, we have unfortunately had to suspend our Westbury to Swindon service, meaning Melksham station will not be served.
In "TransWilts line" [375574/31359/18]
Posted by grahame at 20:14, 27th May 2026
20:06 Westbury to Cheltenham Spa due 21:46
20:06 Westbury to Cheltenham Spa due 21:46 will be cancelled.
In "Across the West" [375573/31163/26]
Posted by TaplowGreen at 20:13, 27th May 2026
Due to a speed restriction because of high track temperatures between Reading and London Paddington fewer trains are able to run on all lines.
Train services running to and from these stations may be running non stop between Reading and London Paddington. Twyford, Maidenhead and Slough will not be served.
Re: New Oxford - Bristol direct service, ongoing developments and discussion
In "Oxford, Didcot and Reading from the West" [375572/28355/22]
Posted by JohnM at 17:52, 27th May 2026
Hopefully catch 18:45 from Swindon, Melksham 19:09. Although the speed we're going at the moment I'm not sure whether that's likely either...
In "Oxford, Didcot and Reading from the West" [375571/28355/22]
Posted by JohnM at 17:48, 27th May 2026
Ha if only - broken down freight train between Bristol and Bath. So 17:29 first stop is Swindon - that's the only option really I think, and come back from there. Just departed Bristol.
In "Oxford, Didcot and Reading from the West" [375570/28355/22]
Posted by TaplowGreen at 17:46, 27th May 2026
Confirmed along with its return running......
17:12 Bristol Temple Meads to Oxford due 18:29
17:12 Bristol Temple Meads to Oxford due 18:29 has been cancelled.
This is due to more trains than usual needing repairs at the same time
19:04 Oxford to Bristol Temple Meads due 20:16
19:04 Oxford to Bristol Temple Meads due 20:16 will be cancelled.
In "Oxford, Didcot and Reading from the West" [375569/28355/22]
Posted by JohnM at 17:38, 27th May 2026
Catching 17:12 from Bristol for first time today - well I was, but it's been cancelled (showing 'on time' at 17:12). Now on the 17:29 Paddington, was originally hoping to continue to Chippenham to still connect with the 18:00 Melksham service (just), but it's now 17:35 and we're not moving - 'delayed'.
So looks like plan C - get off at Bath, assuming we ever get there, and catch 18:15 Melksham bus, after walking/running up to the Hilton to catch it.
Re: Bridge hit - again "Freshford" = Limpley Stoke?
In "Portsmouth to Cardiff" [375568/32077/20]
Posted by chipbury at 17:28, 27th May 2026
Being a resident of the Limpley Stoke area I was reading the most recent parish council meeting minutes and saw this:
Unitary Councillor for Winsley and Westwood Report- Mr Nigel White (NW)
NW is still in discussion with Network Rail, Wiltshire Highways and
National Highways regarding the railway bridge problems. Signage on
the A36 needs to be bigger as vegetation is covering the very small
HGV warning sign.
Hopefully if enough people raise the issue with Network Rail they may act.
Re: Campaign for Tavistock reopening
In "Campaigns for new and improved services" [375567/804/28]
Posted by Andy at 17:23, 27th May 2026
Sorry - post deleted
Re: More 4 car 158s for Portsmouth services
In "Portsmouth to Cardiff" [375566/27229/20]
Posted by bobm at 17:13, 27th May 2026
Already liked by MVR S&T
It is hard to get accurate figures for many stations on the route.   Looking back to Graham's post a few months back, Warminster is also served by trains to Gloucester.   Those services also call at Bradford-on-Avon alongside those to and from Weymouth.
Based on ticket sales the Cardiff/Portsmouth line as a whole is attracting around 57 to 61,000 passengers a month.    Since the turn of the year it has failed to reach pre-Covid levels.    Easy to speculate on reasons while sitting at a keyboard but are people put off by the prospect of standing?   We saw that in the days of the class 153s on the TransWilts.
Re: The People's Emergency - film, free, 27.5.2026
In "Diary - what's happening when?" [375565/32079/34]
Posted by Chris from Nailsea at 17:06, 27th May 2026
Already liked by broadgage, grahame
For some strange and inexplicable reason, I do indeed happen to be in Melksham this evening.
I'll be at the film viewing, dispensing some excellently produced public transport related timetable brochures to anyone else who is there, as well as watching the film.
Melksham Assembly Hall is just behind the Town Hall, on Market Place.
Chris from Melksham.
In "Diary - what's happening when?" [375564/32079/34]
Posted by broadgage at 17:04, 27th May 2026
sounds a worthwhile cause. Do they propose any sensible solutions to the many problems we face.
In "Oxford, Didcot and Reading from the West" [375563/28355/22]
Posted by ChrisB at 16:46, 27th May 2026
Agreed - but would *still* be well below the previous highest customer number on other routes....
In "Portsmouth to Cardiff" [375561/27229/20]
Posted by John D at 16:32, 27th May 2026
Although shortened to just Bristol Parkway to Fareham due to engineering work at both Severn tunnel and Portsmouth area, seem to be struggling to find sufficient units.
1F06 started with 165137, had to be swapped to a 158
1F09 just a 2 coach 158 (158747)
2F12 Bristol-Warminster cancelled due to unit being swapped
1F15 and 1F22 just a single 2 coach 158 (158766)
Roll on getting decent number of 175s in service, so some extra stock can be moved to Bristol area
In "Oxford, Didcot and Reading from the West" [375560/28355/22]
Posted by bobm at 16:31, 27th May 2026
Agreed although my somewhat unspoken point was that if the service is reliable people will use it.   There were less than 20 cancellations in April (with eight on one day).  This was preceded by a reasonable February and March where barring a car on the line and several attempts to demolish the bridge at Limpley Stoke, the reliability was markedly better than pre-Christmas.
In "Oxford, Didcot and Reading from the West" [375558/28355/22]
Posted by ChrisB at 16:15, 27th May 2026
That is still *way* down on total customers mentioned by Graham on other routes - and the operators WILL take number of customers affected into account when cancelling/altering services. Of course those services carrying the fewest customers will suffer the biggest brunt of cancellations
In "Oxford, Didcot and Reading from the West" [375557/28355/22]
Posted by bobm at 16:12, 27th May 2026
"We're short of a driver from Bristol to Oxford and that's a High Vis service"
"OK - let's take George off the Bristol to Salisbury - he can drive an IET and knows the road"
"But who will drive the Salisbury train"
"We can take Gillian off the Westbury to Swindon shuttle for that"
"So who will drive the TransWilts train"
"Oh - we'll cancel that ... it's no longer a high vis service with ministerial interest"
Dangerous to read too much into one month's figures - but in April TransWilts passenger numbers were up on April last year and April 2019.   I think that is the first time it has got above pre-pandemic levels.
In "London to the Cotswolds" [375556/31371/14]
Posted by Witham Bobby at 15:43, 27th May 2026
And now:
16:58 London Paddington to Great Malvern due 19:25 will be cancelled.
Last Updated:27/05/2026 14:14
19:45 Great Malvern to London Paddington due 22:24 will be cancelled.
In "TransWilts line" [375555/31359/18]
Posted by TaplowGreen at 15:43, 27th May 2026
In "Oxford, Didcot and Reading from the West" [375554/28355/22]
Posted by IndustryInsider at 15:37, 27th May 2026
Oh - I agree with you ... I was imagining the cascading that might go on ...
Believe me, they're neither that devious...nor that clever!
In "Oxford, Didcot and Reading from the West" [375553/28355/22]
Posted by grahame at 15:24, 27th May 2026
Already liked by Witham Bobby, Mark A
It also carries at least half of the number of customers of te other routes mentioned.
With 26% cancellations and nothing else for a number of hours, are we surprised that passenger numbers are so low - though they are typically way, way above the target numbers when the service was introduced  .
Not looking for the lowest common denominator.   Looking for an operation that runs well over 95% of the services it promises in the timetable rather than 74%
In "Oxford, Didcot and Reading from the West" [375552/28355/22]
Posted by ChrisB at 15:10, 27th May 2026
Re: [otd] 24th May 2002 - opening of Falkirk Wheel
In "Heritage railways, Railtours, buses, canals, steamships and other public transport based attractions" [375549/32062/47]
Posted by rogerw at 14:10, 27th May 2026
Already liked by Oxonhutch
... Knowing that the Falkirk Wheel has attracted a number of our members to take a look (has anyone here ridden it?) and it's talked about on our member's area - yes - I'm posting.  My own picture (probably one of my worst pictures of any time) is via https://www.wellho.info/share/falkirk.html
I have taken a full revolution of said structure not long after it opened visiting family in that part of the world. We used the touring narrowboat, with half a turn up; through the tunnel and return finishing with a half a turn back down. A wonderful piece of engineering.
I did the same thing last month. Highly recommended
In "Oxford, Didcot and Reading from the West" [375548/28355/22]
Posted by grahame at 13:44, 27th May 2026
In terms of comparisons with the TransWilts I don't think there is any interface with either the trains or the staff that work each route, so the only impact they might have on each other is the shared tracks between Thingly Junction and Swindon...and obviously more trains running over a route increases the chances of knock-on delays.
In "Oxford, Didcot and Reading from the West" [375547/28355/22]
Posted by IndustryInsider at 13:17, 27th May 2026
It might be (very) hot for May, but late July / early August is on average the hottest time of year.   We are not in the high 30s
Does ask a big question though, what temperature should be the stress point.  I would argue that anything failing at the moment is either not maintained well, or was under specified.
Have to accept that temperatures in low to mid 30s are not uncommon in recent years, and really should be able to be handled without failing.
GWR territory is not like somewhere like Chicago or Vienna where temperatures vary from about -25-20c to +40-45c.   So why our equipment is allowed to be so fragile is not clear to me.
It's a good question.   I would argue that the ability to handle extreme heat is actually better than it was 5-15 years ago, despite that heat arriving more often.  I don't recall any really major issues* over this heatwave so far, and my memory of 5-15 years ago was that whenever the temperature hit 30 degrees there was a high likelihood the service would collapse completely.
You could spend a whole heap of money replacing things with higher tolerances, but does that offer good value for two to three spells over 30 degrees each summer?
And is Chicago or Vienna much more immune to weather related incidents?  Or do we just not hear about them?
I don't have much experience of either, other than a visit to Vienna in the early 1990s, but a quick Google brought up the following...
https://metra.com/Service-disruptions
https://www.visahq.com/news/2026-01-13/at/bb-issues-nationwide-travel-warning-as-ice-storm-knocks-out-inter-city-rail-links/
* By which I mean complete cessastion of services on the trunk GWR routes
With so many problems on other services that show resources stretched, reasons like "not enough working trains" and "not enough working staff" for cancellations of the service that's just ten days old brings something of a wry smile.   Issues which are hightened by extreme weather are more forgiven.
But yet ... the Bristol <-> Oxford service has been doing very well compared to certain others ...
... and I can't help wondering if some of those cancellations which were cause by lack of a working train or lack of working staff would have actually been cancellation if GWR wasn't so stretched to make the new service reasonably reliable. Are they trying to spread things too thinly?
Much too early to draw any conclusions either way.
In "Oxford, Didcot and Reading from the West" [375546/28355/22]
Posted by grahame at 13:01, 27th May 2026
Oh dear ... teething troubles for the new service, or is GWR / NR locally in meltdown?  Journeycheck is reporting 40 cancellations across the GWR operated services this morning, and a further  21 updates which look like they're largely short runs (cancellations for some).
Is that ten days into the new service before the first cancellation?  After the hottest ever temperatures recorded in May and easily the hottest Bank Holiday Monday on record (including the August one)?
With exceptional heat comes all sorts of additional stresses on the GWR service which as we know is already fragile.
Literally a meltdown I would say!
