In "London to the Cotswolds" [372855/31371/14]
Posted by charles_uk at 10:13, 27th February 2026
From Realtime Trains:
0713 Great Malvern to London Paddington - this service was cancelled between Worcester Shrub Hill and London Paddington due to a points failure (IB).
Re: Rail replacement buses while River Plym bridge work carried out
In "Shorter journeys in Devon - Central, North and South" [372854/31637/24]
Posted by GBM at 09:15, 27th February 2026
Blimey!  It's nearly 3 hours by road from Walsall to Tiverton, and the same back: that doesn't leave much time for the coach driver to also go to Plymouth.
They must be staying overnight somewhere in Devon.
Drivers and vehicles are usually employed for the duration of the rail replacement works, rather than just a day.
So a coach is brought down (or up from Cornwall) to where the operations centre is (probably Exeter, or Plymouth).
Drivers stay in a hotel there, and arrangements are in hand for vehicles to be cleaned and fuelled locally as well.
When the rail replacement ends, drivers and vehicles return to their respective depots.
In "Across the West" [372853/28982/26]
Posted by grahame at 08:57, 27th February 2026
All cancelled due to "more trains than usual needing repairs at the same time" - more problems with these "new" trains?
With Barnstaple, Okehampton and Exmouth all running again ... and I suspect this week that in these days of specialisation there are trains in Plymouth that need to get to Exeter for repair but can't because the line from Totnes to Plymouth is closed for engineering works, and the old alternative from Bere Alston to Okehampton has been closed for much longer.
Re: Petition for double track on Cotswold line...
In "London to the Cotswolds" [372852/1129/14]
Posted by grahame at 08:52, 27th February 2026
I have come back to a very old thread ... though it may be ripe for a split. Picking up a discussion on making proper use of facilities at some lesser used stations,
I am - noting - the Green byelection success at Gorton and Denton last night, and congratulate Hannah Spencer on her victory.  I celebrate the wide range of views to be expressed in parliament, and the thoughts expressed in her victory speech are good, though elements are of concern. And yet, the Green Party comes from environmental roots and references to that have faded away.
In the early days of "Save the Train", Denton station was one we compared Melksham to - a sleeping resource, hanging on to life by its finger tips. It still does; it still waits for an opportunity to be re-woken. That needs (and they have been suggested) purpose and flows - the trains, or trams, going somewhere people want to usefully go.    Last time I went through Denton by train, it was on the Aberystwyth to York service, long since gone.  I visited the station a number of years ago too - situated off a main road bridge and what a contrast between the busyness of the road and the lack of trains.
In "Across the West" [372851/28982/26]
Posted by GBM at 08:30, 27th February 2026
07:12 Plymouth to Penzance due 09:19
09:50 Penzance to Plymouth due 11:47
12:18 Plymouth to Penzance due 14:14
14:50 Penzance to Plymouth due 16:45
17:00 Plymouth to Liskeard due 17:37
RTT not showing a 175, but 150'type.
In "TransWilts line" [372850/31359/18]
Posted by grahame at 08:17, 27th February 2026
06:35 Salisbury to Worcester Foregate Street due 09:47
06:35 Salisbury to Worcester Foregate Street due 09:47 will be terminated at Gloucester.
It will no longer call at Cheltenham Spa, Ashchurch For Tewkesbury, Worcester Shrub Hill and Worcester Foregate Street.
In "Across the West" [372849/28982/26]
Posted by TaplowGreen at 08:00, 27th February 2026
Re: Go-Op Cooperative - proposals for additional rail services
In "Campaigns for new and improved services" [372848/11010/28]
Posted by grahame at 06:54, 27th February 2026
Also in the Co-op news
https://www.thenews.coop/one-last-chance-for-go-op-passenger-train-co-operative/
The wider economic case for an Oxford - Swindon - Westbury - Frome - Taunton service makes sense.   The financial case, making it into a business operation, is a problem. That problem is compounded where a new business model - a co-operative - is to be used, and as a matter of so-far unbent principle. And the problem is compounded further where incumbent industry players may not be taking a "let's help you get this going" stance - perhaps the reverse. Final problems that the industry and structures are so s-l-o-w in picking up ideas and are hard to work with, and having tried for over a decade, Go-op finds itself considered a "that won't happen" laughing stock based on passed and failed projections.
The economic cases for Oxford - Swindon, Swindon - Westbury and Frome - Taunton all remain. You'll note that the first two have those have been improved under the auspices of First and the DfT since the formation of Go-op, and with further improvements to the first of those from May. Extra trains are running (calling) now Westbury - Castle Cary - Taunton, and Westbury - Frome, and to me these improvements confirm that Go-op does / did have a sensible analysis of where a service should / could run.
Now - if they were willing to tear up their principles, could the Go-op team sell / transfer their access rights to a commercial company?  Who runs open access trains under commercial or open access rights?   There are two other companies running trains from Taunton ... and a service from (say) Paignton to Marylebone or to Milton Keynes ... I wonder what the timing would be; what a joyous selection of journeys and for longer distance passengers the attraction of through services might be a factor that brought them on board.
In "Shorter journeys in Devon - Central, North and South" [372847/31637/24]
Posted by grahame at 06:28, 27th February 2026
Always a very telling sign of the state of the U.K. coach industry and how difficult it is to source coaches for any rail replacement work, there’s coaches operating between Plymouth and Tiverton that are based as far away as Walsall!!
With the closure of their public bus operation in the far west, my social media feed has been stuffed with reports of First shipping / driving buses out of Cornwall to all sorts of other far flung places in Great Britain.
In "Shorter journeys in Devon - Central, North and South" [372846/31637/24]
Posted by Chris from Nailsea at 06:27, 27th February 2026
Re: Accessability at Bath Spa - the Garibaldi Bridge
In "Railway History and related topics" [372845/31680/55]
Posted by grahame at 06:24, 27th February 2026
I don't know if the hotel has a lift ...
Apparently, the Royal Hotel in Bath does have a lift - a very small one, not suitable for modern disabled access - as an alternative to the spiral staircase:
Wheelchair Accessibility
Regretfully our bedrooms are not suitable for wheelchair users, and our lift is not large enough to accommodate both a wheelchair and a passenger. This is due to the fact that the property was built in 1846, and is also Grade Two listed, which restricts us from making major structural alterations.
Yep - we found similar at The Queen in Chester a couple of weekends ago ... and we had similar constraints from in accessability access at our old (listed) home and business premises;  "don't even ask!" was the message from the heritage officer when we made tentative enquiries.
Booking-dot-com does have a "elevator/lift to upper floors" that we look for when booking.  We have learned that it does not guarantee that a disability aid will fit into the lift,  that you can get into and out of the lobby without going upon and down steps, or there won't be steps along the way from the hotel's lift to the hotel room.
In "Railway History and related topics" [372844/31680/55]
Posted by Chris from Nailsea at 06:07, 27th February 2026
In "Shorter journeys in Devon - Central, North and South" [372843/31637/24]
Posted by a-driver at 05:22, 27th February 2026
Already liked by Timmer
In "Railway History and related topics" [372842/31680/55]
Posted by Chris from Nailsea at 05:06, 27th February 2026
In "Railway History and related topics" [372840/31680/55]
Posted by grahame at 03:29, 27th February 2026
Already liked by matth1j
A reminder if you are coming back through Bath Spa.   The lift from Platform 2 is out of use until next month.
https://transwilts.org/2026/02/04/lift-works-at-bath-spa/
I came across this old picture from Bath showing a bridge across from the Royal Hotel to the station and it struck me as a level access ... all be it from the upper floors of the hotel.    I don't know if the hotel has a lift, but this "Garibaldi" bridge as I believe it was called might have provided a temporary ... or even a permanent solutions to the problems there seem to be of accessibility at Bath Spa
Bath Spa: Lifts out of order
The lifts will be out of order between platform 2 and the subway from now until 13/03/2026 at Bath Spa station.
Additional Information
Until Friday 13th March, the lift on platform 2 at Bath Spa will be closed for essential upgrade work. Before 09:00, please speak to staff, use a station help point or call us on 0800 197 1329. After 09:00, the station will have staff to help with luggage and another lift will be available to/ from platform 2 via the Ludo Sports Bar.
Where is the Ludo Sports Bar??
Re: Auschwitz anniversary, 27 February 1942 - merged posts
In "Railway History and related topics" [372838/15281/55]
Posted by Chris from Nailsea at 00:13, 27th February 2026
Already liked by Timmer, GBM
All of the above makes for some very sombre reading again, on this sad anniversary.
Lest we forget.
Chris.
Re: Near miss involving child closes Knaresborough level crossing - Feb 2026
In "The Wider Picture in the United Kingdom" [372837/31679/51]
Posted by Mark A at 22:24, 26th February 2026
Already liked by GBM, Oxonhutch
"...concerns about visibility for pedestrians..." "... vegetation growth on a steep embankment."
Re: Baby alpacas born at Suffolk farm who 'look like ET' need names - Feb 2026
In "The Lighter Side" [372836/31678/30]
Posted by Oxonhutch at 22:03, 26th February 2026
Already liked by Chris from Nailsea, chuffed, GBM
Pity it wasn't Wales.
He could have been Dai the Lamma
In "The Wider Picture in the United Kingdom" [372835/31679/51]
Posted by Chris from Nailsea at 22:01, 26th February 2026
Near miss involving child closes level crossing
An emergency order has closed Frogmire Lane level crossing for at least 21 days
An emergency order has closed a railway level crossing following a "near miss" incident involving a child.
Network Rail said it had a "number of serious safety concerns" about Frogmire Lane level crossing in Knaresborough and had already starting gauging public opinion about closing it permanently.
The crossing, which is used by school-aged children, has long-standing problems with misuse and vandalism. There are also concerns about visibility for pedestrians, which is limited by the curved railway alignment and vegetation growth on a steep embankment. Network Rail added that trains would coast along this section of the line, making them harder to hear when approaching.
The emergency closure order would see the crossing shut for 21 days, with option to extend it by six months while long-term options are explored.
Dave Smith, Network Rail route level crossing manager, apologised for the inconvenience caused to crossing users. "Our view is that Frogmire Lane level crossing presents an unacceptable level of risk, and our application for an emergency closure on safety grounds has been accepted by the local authority," he said. "Decisions like this are not taken lightly, but our priority is always to keep the public safe, and the combination of poor sight lines, high levels of misuse and the number of vulnerable users means urgent action was needed."
In "The Lighter Side" [372834/31678/30]
Posted by Chris from Nailsea at 21:47, 26th February 2026
Baby alpacas who 'look like ET' need naming
Baylham House Rare Breeds Farm manager Kate Ockleton said a lot of people had commented on the babies' appearance
Two baby alpacas and a set of goat triplets have all been born at the same time at a Suffolk farm, creating a bit of a naming dilemma.
The newborn crias are only the third and fourth baby alpacas to be born at Baylham House Rare Breeds Farm near Ipswich.
Farm manager Kate Ockleton said it was hard to think of enough new names for them all, although there had been a lot of comments from visitors which may provide some inspiration. "Any suggestions for names would be very welcome," she said. "But a lot of people have been saying they look like [the fictional extraterrestrial] ET!"
The two crias - a boy and a girl - were born to their mothers Iris and Alina this week. "They have very long legs and are very sweet," said Ockleton.
"Alina is very protective - there has been a little bit of spitting and headbutting going on to keep us away from her baby, which is totally fine! Iris used to be a little bit nervous of us but after I wrapped her baby in my coat to keep her warm, we have bonded a little."
Alina gave birth to a brown-furred male
Ockleton said it had been a bit difficult to get the crias to feed at first so they were given a bottle provided by some of the farm's ewes.
The babies will stay with their mum for about seven months until weaning happens naturally.
All the animals born on the farm will remain there, Ockleton added.
'Alpaca MacAlpacaFace' probably isn't going to work.
Re: OTD - 26th February (2022) - On this day nothing rail has happened?
In "News, Help and Assistance" [372833/26088/29]
Posted by Oxonhutch at 21:43, 26th February 2026
Already liked by Chris from Nailsea, GBM
Well, that's all water under the bridge now.
I thought the problem was that it's all bridge under the water, now.
In "News, Help and Assistance" [372832/26088/29]
Posted by Chris from Nailsea at 21:23, 26th February 2026
In "News, Help and Assistance" [372831/26088/29]
Posted by bobm at 21:13, 26th February 2026
Following up "Midwinter Lull" On This Day - I have noted on our disruption map "nothing to report" a couple of times in recent days, and JourneyCheck reporting merely 7 lifts out of action.   This morning, all we have is a three car diagram on the Reading to Basingstoke reduced to two cars - hardly the end of the earth. Nothing on the Looe line, I note - back in action, or gone so long it doesn't even make JourneyCheck?
I suspect the Looe branch is not mentioned as it was planned to be closed this week due to engineering work.  That has been in journey planners for a few months.
Man in court after Stagecoach bus driver taken to hospital - Aberdeen, 25 Feb 26
In "Buses and other ways to travel" [372830/31677/5]
Posted by Chris from Nailsea at 19:49, 26th February 2026
Man in court after bus driver taken to hospital
The incident happened at Aberdeen Bus Station on Wednesday
A man has appeared in court charged after a Stagecoach bus driver was taken to hospital following an incident at Aberdeen Bus Station.
Police Scotland said officers were called to reports of an assault on a bus at the station on Wednesday morning.
Robert Whyte, aged 45 of Aberdeen, faces charges including assault to injury and permanent disfigurement and threatening or abusing behaviour.
He made no plea at the city's sheriff court, was committed for further examination and remanded in custody.
Flooding causes disruption at Glasgow Central Station - 26 Feb 2026
In "The Wider Picture in the United Kingdom" [372829/31676/51]
Posted by Chris from Nailsea at 19:38, 26th February 2026
Glasgow Central Station's low-level platform is likely to remain closed for the rest of the day due to flooding.
Pictures from the scene show several inches of water in the corridor with the automatic ticket gates, sandbags next to doorways and flooding on Argyle Street.
Network Rail Scotland said trains can still run through platforms 16 and 17 at the station, but they are not stopping.
Trains are still calling at Anderston and Argyle Street as normal and anyone travelling is urged to use those stations instead.
The low-level line is likely to remain closed for the rest of Thursday
There is also flooding outside the station on Argyle Street
In a post on social media, Network Rail Scotland said: "Glasgow Central low-level is likely to remain closed for the rest of the day, though trains are still running on the Argyle Line, calling at other stations. We're on site with Scottish Water and other partners to establish the cause.
A spokesperson for the water company said they were responding to a burst water main at Argyle Street which is causing a loss of water supply for some customers in the area. "Our teams are on-site to isolate the damaged section of main and assess the required repair," the spokesperson added.
They are liaising with Network Rail to restore the station to "normal conditions" as soon as possible.
