3.6.2025 (Tuesday) 09:38 - All running AOK
In "London to the Cotswolds" [361906/29711/14]
Posted by Worcester_Passenger at 08:16, 3rd June 2025
Tuesday June 3
A points failure at Cheltenham Spa has meant that train 1G01 0632 Swindon to Shrub Hill was terminated at Gloucester.
This train forms 1P20 08:18 Shrub Hill to London Paddington. But:
08:18 Worcester Shrub Hill to London Paddington due 10:25 will be started from Oxford.
Will be formed of 5 coaches.
Last Updated:03/06/2025 07:50
In "TransWilts line" [361905/29726/18]
Posted by grahame at 06:36, 3rd June 2025
06:35 Salisbury to Worcester Foregate Street due 09:47
06:35 Salisbury to Worcester Foregate Street due 09:47 will be cancelled.
Just noticed ...
06:50 Westbury to Weymouth due 08:25
06:50 Westbury to Weymouth due 08:25 will be reinstated.
It will be starting late from Westbury.
So is that 2 trains with faults at Westbury this morning, or a fault on the train planned to run to Weymouth and then a decision to use the one planned for the TransWilts service for the Weymouth instead?
Re: German experience - not quite as punctual as its old reputation would suggest
In "The Wider Picture Overseas" [361904/30313/52]
Posted by grahame at 06:16, 3rd June 2025
We spend a lot of time on the Coffee Shop logging delays and cancellations and we spend very little time logging trains that are on time. Although that's natural, and the news, and it's important to highlight issues to be fixed, it's never the less a biased picture that's out of proportion to the number of trains that [should] run.
There's a bit of a message in my original post that says "look, folks - we know there are problems in the UK but there's no magic wand to fix them and other countrys struggle too.
The advise from Mark Smith to allow 45 minute connections makes sense. My own approach would, rather, be to allow 15 minutes PLUS having a fall back plan to the next train.  Arriving into Warnamunde / Kiel we had dropped back - in fact we had taken the view that we would get to Hamburg and when we got there decide on what was the next train onwards, and whether we were hungry and wanted a food break.
Here are three samplings of the departure boards at Berlin Hbf on three different days - not photographed really to show the delays, so a bit random.  And of course for long distance trains starting from that region, the picture painted in rosier than the overall picture with so many delayed, yes, by engineering works, on the way.
Now in France, and I had a series of trains planned from 09:23 ... which however was cancelled at short notice.  Blew the whole plan as some of the trains here have even longer gaps than I am used to from home. They seem to run in the peak hours with a reasonable service and then have long gaps during the day.
In "TransWilts line" [361903/29726/18]
Posted by grahame at 05:29, 3rd June 2025
In "The Wider Picture Overseas" [361902/30313/52]
Posted by Surrey 455 at 23:10, 2nd June 2025
In 2024, DW also reports:
The German rail network company Deutsche Bahn (DB) has once again smashed the myth of German trains running on time, according to statistics published by the company on Friday.
Just 64% of long-distance trains reached their destination on time — meaning less than six minutes late — last year. This was a similar share to 2022 when 65.2% could be considered punctual.
For regional trains, the rate of punctuality was much higher, with 91% reaching their destination on time.
Why are so many trains delayed in Germany?
DB said that the reason for the widespread delays was the increasing number of short-term works and repairs on the rails.
According to the rail operator's own data, around 75% of all long-distance trains had to slow down for construction sites by the end of the year.
The prospects for 2024 don't look much better, with works on the tracks continuing and even ramping up.
By 2030, Germany aims to have renovated dozens of routes into high-speed corridors that should eventually speed up journeys across the country. It has however warned that this could lead to things getting worse before they get better.
https://www.dw.com/en/germany-a-third-of-long-distance-trains-delayed-in-2023/a-67964403
That article is dated 01/12/2024 (US format) and when I cut and paste it, I get 01/12/2024 January 12, 2024.
In "The Wider Picture Overseas" [361901/30313/52]
Posted by Surrey 455 at 22:58, 2nd June 2025
The German rail network has been in a bad way for some time.
From The Independent in 2024:
https://www.independent.co.uk/travel/news-and-advice/german-rail-delays-connections-frankfurt-b2593820.html
But even without the latest shutdowns, rail passengers in Germany are encountering a wide range of problems this summer:
  • Missed connections due to late-running trains
  • Sudden cancellations or re-routings
  • Inadequate or incoherent information
Now, a leading expert has warned against assuming standard train connection times will work.
During his latest trip across Germany, Mark Smith – known as The Man In Seat 61 – recommended allowing extra time to change trains when planning trips online because so many services run behind schedule.
“Always change ‘Transfer time’ from ‘normal’ to 45 minutes when using bahn.de,” he wrote on X.
Almost half of German long-distance trains were at least six minutes late at some point in their journey in June 2024.
Deutsche Bahn blames outdated track infrastructure, intensive engineering work and sheer traffic density at key hubs including Frankfurt, Cologne and Stuttgart.
Re: ITV West feature on West Somerset railway
In "Heritage railways, Railtours, buses, canals, steamships and other public transport based attractions" [361900/30311/47]
Posted by grahame at 20:25, 2nd June 2025
Already liked by Timmer
And they are still waiting…
Minehead ... Portishead ... Go-op ... Corsham ... Tavistock ... threre are so many schemes that would benefit form a JFDI approach.  Thinking as applied at Workington North and for rail-road interchange at Tiverton Parkway.
Re: Railway Benefit Fund - auction of experiences (now until 7 July 2025)
In "Heritage railways, Railtours, buses, canals, steamships and other public transport based attractions" [361899/30314/47]
Posted by ChrisB at 19:43, 2nd June 2025
One for you here.....
Guided Tour of Knorr-Bremse UK Headquarters – Melksham, Wiltshire
Available (1) Bids (0)
STARTING BID
£50
Go behind the scenes at Knorr-Bremse’s UK rail headquarters in Melksham, home to its RailServices operations. This facility plays a vital role in the maintenance, overhaul, and support of rail vehicle systems that help keep trains running safely and efficiently across the UK and Ireland.
Knorr-Bremse is a global leader in rail systems, supporting technologies such as braking, HVAC, door systems, and sanitary solutions.
The tour is for a maximum of 6 guests. To be arranged on a mutually convenient date within a year of purchase.
Kindly donated by Knorr-Bremse.
In "Heritage railways, Railtours, buses, canals, steamships and other public transport based attractions" [361898/30314/47]
Posted by grahame at 19:31, 2nd June 2025
https://go.eventgroovefundraising.com/auction2025/Campaign/Details
RBF Auction of Rail Experiences
RBF's virtual Auction of Rail Experiences features a range of amazing money-can’t-buy rail experiences.
The auction is key event in our fundraising calendar with a target of £25,000 to raise.
Bidding in our auction helps us to support railway people and their families facing hardship across the UK.
In "Heritage railways, Railtours, buses, canals, steamships and other public transport based attractions" [361897/30311/47]
Posted by Timmer at 17:48, 2nd June 2025
Already liked by Chris from Nailsea, broadgage
Days I remember very well indeed.  When the WSR had the purpose of being a useful public transport link for the people of West Somerset, and remembered all those people who queued for hours at Minehead station a couple of years earlier to buy shares that they'd been told would bring their Taunton trains back.
Re: Bristol Temple Meads - station, facilities, incidents and events (merged posts)
In "Bristol (WECA) Commuters" [361896/10737/21]
Posted by TonyK at 17:20, 2nd June 2025
Already liked by johnneyw, GBM, Red Squirrel, chuffed
The new Temple Meads canopy continues to be slowly revealed with even some of the scaffolding being dismantled.  I took those pictures this afternoon.
What a difference! Reminds me of when I had the cataracts removed, and realised my living room walls weren't the colour I thought they were.
Re: Driving licences and tests - ongoing discussion
In "The Wider Picture in the United Kingdom" [361895/19893/51]
Posted by stuving at 17:19, 2nd June 2025
On the matter of bots and tests, is it beyond the wit of man to amend the booking system to start with "Enter your driver number here" then allow changes only via DVSA. A system could be added to allow registered driving schools, such as those doing intensive courses, to book separately, but that would be the answer, wouldn't it?
DVSA have started a consultation about changes similar to those. The consultation started on 28 May 2025 and will close at 11:59pm on 23 July 2025. There's an online form in the explanation page for the consulation.
In "South Western services" [361894/25368/42]
Posted by TonyK at 17:17, 2nd June 2025
Already liked by TaplowGreen, Surrey 455, chuffed
Now that GBR is responsible for the former franchise of SW[TR], is it time for them to be Great British and consider restoring the through services from London via the County Town of Wiltshire - the nearest county town to London without a through train from the capital.
I confess, I had to look it up, and was half-expecting it to be Melksham.
In "The Wider Picture in the United Kingdom" [361893/19893/51]
Posted by TonyK at 16:55, 2nd June 2025
Already liked by Witham Bobby, Timmer, Mark A
Just reading this from the start.
My first visit to India in 2004 I was met at the airport with a car from our office. Mid way into Chennai I asked the driver whether they drove on the left or the right (it certainly wasn't obvious to me). He said "yes".
I asked him if he knew what the white lines were for. "Just some nonsense the British left in 1947, he said.
Then, nor in all my subsequent visits, did I have the courage nor skill to get behind the wheel of a car.
Having been a passenger in India, I can't imagine how I could ever be a driver. Cars, trucks, motorbikes with a family of five on board, all turned onto the main road from the left without slowing, at places where in England there would be traffic lights or a roundabout. It scared my wife. I think though that nobody would ever get anywhere if they didn't drive like that.
In my teens when learning, people from Newcastle would head 35 miles up the road to Alnwick for their test.  They got the same licence, but there were no traffic lights or roundabouts to navigate.
My cousin emigrated to the USA in the 80s before taking her first test somewhere in the deep south. It consisted of something like driving a loop around a residential block and then reversing successfully into a side road. She reckoned it was far easier than a British cycling proficiency test…
Minehead was popular at one time, especially on Butlins changeover days. I don't think they do tests there any more.
In "London to the Cotswolds" [361892/29711/14]
Posted by Worcester_Passenger at 14:31, 2nd June 2025
And the halts train will be cancelled this afternoon:
17:04 Didcot Parkway to Evesham due 18:23 will be cancelled.
Last Updated:02/06/2025 14:06
18:51 Evesham to Oxford due 19:50 will be cancelled.
Later:
20:52 London Paddington to Great Malvern due 23:13 will be terminated at Oxford.
This is due to the train manager being taken ill.
Last Updated:02/06/2025 18:06
But...
22:58 Worcester Shrub Hill to Great Malvern due 23:12
An additional train service has been planned to operate as shown 22:58 Worcester Shrub Hill to Great Malvern due 23:12.
Last Updated:02/06/2025 18:13
In "Heritage railways, Railtours, buses, canals, steamships and other public transport based attractions" [361891/30311/47]
Posted by Witham Bobby at 12:14, 2nd June 2025
ITV West to celebrate 70 years of ITV,
had an item on the West Somerset railway from 1978 on the local news at 6pm on Friday 30 May 2025,enjoyable.
Was this the archive item about the 1978 blizzard?
The blizzard that very nearly killed me at the age of not yet 23
In "London to the Cotswolds" [361890/29711/14]
Posted by Worcester_Passenger at 11:00, 2nd June 2025
Monday June 2
07:50 London Paddington to Great Malvern due 10:14 will be terminated at Oxford.
Last Updated:02/06/2025 01:07
10:59 Great Malvern to London Paddington due 13:25 will be started from Oxford.
Last Updated:02/06/2025 01:13
In the end, both of these journeys operated normally.
But:
2E77 05:10 Oxford to Worcester Shrub Hill was cancelled throughout (train crew)
2E80 07:00 Worcester Shrub Hill to Didcot Parkway was cancelled throughout.
08:18 Worcester Shrub Hill to London Paddington due 10:25 has been cancelled.
Last Updated:02/06/2025 08:20
Stock has run empty from Shrub Hill to Paddington.
1W11 0553 London Paddington to Great Malvern arrived Shrub Hill +24 (blocked by the 08:18 perhaps), Worcester Foregate Street +35 and was cancelled thereafter.
08:56 Great Malvern to London Paddington due 11:27 will be started from Worcester Foregate Street.
This is due to congestion.
Last Updated:02/06/2025 08:57
Re: Diary Of A Reasonably Frequent Rail User
In "The Wider Picture in the United Kingdom" [361889/17250/51]
Posted by Bob_Blakey at 09:55, 2nd June 2025
Already liked by RichardB, PrestburyRoad, GBM
01/06/2025 - A Day Out In Paignton For The Riviera Airshow
Pretty good work from GWR despite challenging circumstances
Tickets
2 x Senior Railcard Off-Peak Day Returns DIG>PGN» £15.40 (£7.70 each)
Outward - 01/06/25
DIG 1013 (1015)>PGN 1125 (1147): 2T11 EXM>PGN : 1 x 166/2 (3 Cars)
We arrived at DIG to the sight of some 40-50 pax waiting to board the train. The shape of things to come - the service was essentially full departing EXC, lost time to some extent at each stop due to the expected boarding issues, and eventually arrived at PGN 22 mins down. I noted that GWR staff were present at the normally unmanned DWW.
On arrival at PGN all pax had to walk to the southern end of P2 and then back along the station car park - to avoid platform crowding - into the clutches of GWR Revenue Protection. All tickets & railcards / passes were checked by a 1st line team and passengers presenting with issues were directed to a separate team for a chat.
Although we didn’t use the option - being comfortably ensconced in our seats on the stopper - it would have been possible to change at EXD onto 1C75 PAD>PNZ and then swap at NTA to 2Z31 - a 9-Car IET - for the run down to PGN.
The airshow was very busy, well organised, and the sun was (mainly) shining. Happy days!
Return - 01/06/25
PGN 1631 (OT)>NTA 1645 (OT) : 2Z40 PGN>NTA : 1 x 802/0 (5 Cars)
NTA 1654 (1657)>EXD 1713 (1716) : 1A90 PNZ>PAD : 2 x 800/0 (10 Cars)
(We had planned to catch 2F20 back to DIG but decided instead to use the buses to get home - free with our ‘Crusties’ passes - just in case that service was full)
At PGN all the normal entrances to P2, save one fully staffed for the use of disabled passengers, were locked shut and all pax were directed to the queueing corral at the south end of the car park. We were counted onto the platform when the train was ready and, once again, all tickets & passes were checked.
On departure 2Z40 was full with a small number of standees.
In "The Wider Picture Overseas" [361888/30313/52]
Posted by grahame at 07:32, 2nd June 2025
Already liked by PrestburyRoad
Another day - another delayed German arrival.  For all the past reputation of German efficiency, I/we have had a whole series of late arrivals in Germany and indeed that reputation of being on time hasn't been the case. However I/we (2 of us on some journeys - me alone on some) have always easily know about out options when we arrive at final or connecting stations, and we never had a lack of information nor very much extended waits for connections.
Part 1 - from 18th May 2025
(Amsterdam) to Osnabrück
Osnabrück to Hamburg (-10 thoughout (note 7))
Hamburg to Rostock (-8 into Rostock (note 6))
Rostock to Warnemünde (-15 into Warnemünde (note 1))
Warnemünde to Rostock (whole day on time)
Rostock to Tessin
Tessin to Rostock
Rostock to Bad Doberan
+ Bad Doberan to Heiligendamm
(Heiligendamm to Rostock by bus)
Rostock to Wismar
Wismar to Bad Kleinen
Bad Kleinen to Rostock
Rostock to Hamburg
Hamburg to Kiel
Part 2 - from 29th May 2025
[Prague] to Berlin Hbf (-70 late into Berlin (note 2))
Berlin to Magdeburg
Magdeburg to Quedlinburg
+ Quedlinburg to Alexisbad
+ Alexisbad to Eisfelder Talmühle
+ Eisfelder Talmühl to Nordhausen Nord
Nordhausen to Halle (-6 into Halle (note 3))
Halle to Berlin (-10 late from Halle, -25 into Berlin (note 4))
Berlin to Potsdam Hbf (-5 into Potsdam (note 5))
Potsdam to Berlin (-15 into Berlin (note 5))
Berlin to Offenburg (-95 into Offenburg (note 8))
Offenburg to [Strasbourg]
Notes
+ - Not a train on the Interrail pass network
[place] - outside Gernany - this was an international train
1. Inbound conenction missed (just) so we were half an hour down and then the train to Warnemünde left on time but had to wait for the single line section for a delayed train coming the other way. This line is normally double tracked all the way but active engineering works replacing the second track mean all trains are sharing the single line.
2. The train from Prague ran AOK to Rzepin but then the locomotive had to be replaced - don't know why - at such short notice it appeared to have taken them by surprise.
3. Reason not known; I think it was congestion.
4. Classic case of 2 wrongs making a right - because of delay (3) my short connection actually made - I don't know why the train was late when I joined it, but further time was lost as we went past engineering works "wrong line" - out of path and had to wait for the single section
5. Trains overloaded and extra station time needed, especially on the journey back into Berlin.  They would have been on time if it wasn't for those pesky customers.
6. We joined this train running a little late and no time was made up. Reason unknown
7. Reason unknown.  Just slipped back?
8. About 15 late into Mannheim - again due to engineering works. But we sat there for an extended period, and we then sat for an extended period at Karlsruhr too. Explanation - translated by fellow passengers for us - was that the train was overloaded and would some people please get off.  Sort of "Mexican stand off". Eventually enough people found alternatives / gave up and got off to allow us to proceed.
In "London to the Cotswolds" [361887/29711/14]
Posted by Worcester_Passenger at 01:53, 2nd June 2025
Monday June 2
Re: 25th May 2025 - SWR Franchise expires and services Nationalised
In "South Western services" [361886/29993/42]
Posted by ChrisB at 21:26, 1st June 2025
GBR doesn't actually exist yet, so there won't have been anyone from GBR present
GBR does very much exist, it is just not a fully established as yet, 2026 / 27 is the plan for the establishment of GBR
So it doesn’t yet exist (as a physical entity, employing people with an office). I think that is what I meant & I also think you know that
In "South Western services" [361885/29993/42]
Posted by TaplowGreen at 19:50, 1st June 2025
Over £100 million spent so far on something that "doesn't actually exist yet", well, this is the railway I guess..........one is almost tempted to ask "ooooooooos gonna pay for it?"
(The answer of course being straightforward......the taxpayer)
In "The Wider Picture in the United Kingdom" [361884/19893/51]
Posted by paul7575 at 19:16, 1st June 2025
Already liked by Witham Bobby, rogerw, Timmer
Jodie Johnston, a driving instructor in Exeter, likens booking a test to the infamous annual scramble to buy tickets for Glastonbury Festival - and says some learners in London, where demand can be even higher, are travelling 200 miles to take their tests in Devon. "It's easier to pass a test than book a test at the moment," adds Ali Slade, a driving instructor in Farnham.
My niece in Surrey found it quicker to get a test in Portsmouth. Apparently a few of her school friends have done the same.
In "South Western services" [361883/29993/42]
Posted by Electric train at 18:35, 1st June 2025
Re: Shortage of train crews on Great Western Railway - ongoing discussion
In "Across the West" [361882/18719/26]
Posted by IndustryInsider at 15:14, 1st June 2025
Not just GWR havjng the usual Sunday issues today...
From my own observations, Cross Country seem to be worse than GWR in terms of their percentage of cancellations on a typical Sunday.
In "Across the West" [361881/18719/26]
Posted by TaplowGreen at 15:08, 1st June 2025
Not just GWR havjng the usual Sunday issues today, although given the number of full & part cancellations from/to Devon/Cornwall today this won't help......
Between Birmingham New Street and Leicester / Nottingham / Stansted Airport, between Manchester Piccadilly and Bournemouth / Paignton, and also between Nottingham and Cardiff Central / Plymouth
A shortage of train drivers means that fewer CrossCountry trains will be able to run, and as a result, trains may be cancelled or revised on the following routes:
It is recommended that you check before you travel today, as other routes may be affected.
In "TransWilts line" [361880/29726/18]
Posted by grahame at 14:35, 1st June 2025
15:44 Swindon to Frome due 16:38
15:44 Swindon to Frome due 16:38 will be reinstated.
It will be started from Westbury.
It will no longer call at Swindon, Chippenham, Melksham and Trowbridge.
1 cheer not 3. Not "reinstated" as far as passengers wishing to join at Swindon, Chippenham, Melksham or Trowbridge are concerned ...
Somewhat better news (2 cheers not 3) that the following return trip is no longer on the cancellation report, so id probably re-instated throughout.
In "London to the Cotswolds" [361879/29711/14]
Posted by Worcester_Passenger at 12:38, 1st June 2025
Already liked by Timmer, Mark A
Sunday June 1
16:58 Great Malvern to London Paddington due 19:26 will be started from Reading.
Last Updated:01/06/2025 07:29
17:30 Hereford to London Paddington due 20:25 will be cancelled.
Last Updated:01/06/2025 08:02
Leaving a three-hour gap in the service towards London on Sunday evening!
13:50 London Paddington to Great Malvern due 16:16 will be terminated at Worcester Shrub Hill.
20:50 London Paddington to Worcester Shrub Hill due 23:00 will be cancelled.
All of these have now been removed from JourneyCheck, though the 19:58 will still terminate at Reading.
Later : and now the 19:58 has been removed from JourneyCheck.
In "TransWilts line" [361878/29726/18]
Posted by grahame at 12:07, 1st June 2025
14:05 Frome to Swindon due 14:58
16:43 Frome to Swindon due 17:34
17:44 Swindon to Salisbury due 18:55
17:44 Swindon to Salisbury due 18:55 will be cancelled.
Last Updated:01/06/2025 11:57
Re: Okehampton
In "Shorter journeys in Devon - Central, North and South" [361877/18334/24]
Posted by bobm at 11:44, 1st June 2025
Already liked by rogerw, PhilWakely, Chris from Nailsea, GBM, Witham Bobby, TonyK, trainbuff
Unless you are in coach 33 and have to walk through to coach 3 to exit the train....
