Thames Valley infrastructure problems causing disruption elsewhere - 2026
Posted by Chris from Nailsea at 17:43, 27th November 2025
I have been reminded of my original post, on another topic here - simply because of its ongoing topicality. Those major infrastructure problems won't go away with Great British Railways, nor any of Rachel Reeves' Budget announcements :
No, I haven't lost the plot!
I'm merely preparing the ground here, ready for member TaplowGreen to develop this topic, in due course.
This is clearly an area of concern (understatement?) to our members and readers of the Coffee Shop forum, in terms of their experiences of travelling on the railways in our wider area.
While starting this topic (in preparation), may I also reassure all of our members that their ongoing contributions to this, and indeed any other topic, will continue to be very welcome.
Posted by Chris from Nailsea at 17:44, 30th December 2025
TaplowGreen, the Coffee Shop forum is prepared for you.
Posted by Electric train at 17:49, 30th December 2025
That's a presuming that there will be infrastructure problems in the Thames Valley causing disruption elsewhere in 2026 ....................    I am a born optimist
Posted by TaplowGreen at 11:12, 1st January 2026
Didn't take long, did it?
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 12:00 01/01.
Due to a signal fault in the Slough area, trains departing London Paddington towards Reading will be subject to delays.
Posted by bobm at 12:53, 1st January 2026
Not helped by the fact the Up and Down mains are closed for planned engineering work in the Slough area.
Posted by Chris from Nailsea at 14:12, 1st January 2026
Nope! That's why I did such timely groundwork, ready for this new topic. CfN.
Posted by TaplowGreen at 06:47, 6th January 2026
Due to damage to the overhead electric wires between London Paddington and Reading fewer trains are able to run on all lines.
Train services running to and from these stations will be cancelled, delayed or revised. Disruption is expected until 12:00 06/01.
Posted by grahame at 09:15, 6th January 2026
Oh dear!
Damage has been found to the OLE in the Ladbroke Grove area. Overhead Line Equipment (OLE) is the name given to the overhead wires and other equipment on electrified railway lines that provides power to the trains.
Whilst engineers are fixing the damage, our train service will have to be reduced between London Paddington and Reading.
The problem affects all of the four lines between London Paddington and Reading, so we are having to reduce the train service through the area to avoid congestion. Local stopping services between London Paddington and Didcot Parkway/Newbury will only run between Reading and Didcot Parkway/Newbury. Most of our longer distance Intercity services will continue to run between London Paddington and Reading, but may be subject to delay and some services between London Paddington and Cardiff Central will not run.
One of my New Year's Day pictures showed diesel fumes - or was it steam - coming out of the pipes on an IET at Chippenham - no doubt just warming up has it come electric as far as Cocklebury Lane, and I mused sadly that it wasn't electric through to Bath, Bristol and beyond.   Seeing the problems that NR / GWR seem to have with the extra complexity of OLE, I wonder if I should be careful what I wish for.
Posted by TaplowGreen at 10:44, 6th January 2026
"Disruption is expected until the end of the day"
Posted by grahame at 10:57, 6th January 2026
From my inbox
Dear Graham,
We're getting in touch to advise about current disruption in West London impacting GWR services operating between London Paddington and Reading, as well as Elizabeth Line services.  This is due to an issue with overhead wires in the Ladbroke Grove area. Network Rail teams are working quickly to repair the overhead wires and as a result, services are likely to be impacted until the end of the day.
Local stopping services between London Paddington and Didcot Parkway/Newbury will only run between Reading and Didcot Parkway/Newbury. Most of our longer distance Intercity services will continue to run between London Paddington and Reading, but may be subject to delay and some services between London Paddington and Cardiff Central will be cancelled.
For the very latest please visit our dedicated webpage at www.gwr.com/check. Delay Repay compensation is available for customers using GWR services who arrive at their destination 15 minutes or more later than scheduled, and can be claimed at www.gwr.com/delayrepay.
We're very sorry for the disruption to passenger services today and would be grateful if you could share this information with your networks.
Please let us know if you have any questions.
Best wishes,
Olivia & Ahmed
Sharing done ...
Posted by IndustryInsider at 11:10, 6th January 2026
The newer sections of OHLE are generally very robust.  Problems nearly always occur in the legacy OHLE from the 1990s from Paddington out as far as Heathrow.  Though that fragile area is the most important unfortunately!
Posted by TaplowGreen at 12:15, 6th January 2026
You're only as strong as your weakest point.
What's the nature of today's problem? Too chilly?
Posted by TaplowGreen at 12:46, 6th January 2026
It gets better & better
Due to a broken down train between London Paddington and Reading all lines are blocked.
Train services running to and from these stations will be cancelled, delayed by up to 75 minutes or revised. Disruption is expected until the end of the day.
A freight train has failed just East of Reading station and blocked all lines. We are unable to services between London Paddington and Reading until the freight train has been rescued.
Posted by NickB at 19:26, 6th January 2026
TfL drivers this evening are telling passengers that the OLE won’t be fixed tonight and not to bother travelling tomorrow.
Posted by IndustryInsider at 12:04, 7th January 2026
Indeed.  That's kind of what I meant by..."Though that fragile area is the most important unfortunately!"
It was a broken bridle, which is part of the OHLE.
It was fixed overnight (the overnight services starting/turning back at Ealing Broadway) and all lines reopened just gone 6am, though there were knock-on delays and cancellations for a couple of hours after that, mostly on the Elizabeth Line.
Posted by TaplowGreen at 14:01, 13th January 2026
Due to trespassers on the railway at Reading all lines are blocked.
Train services running to and from this station may be delayed. Disruption is expected until 15:00 13/01.
Posted by TaplowGreen at 06:29, 14th January 2026
Due to a points failure between London Paddington and Reading fewer trains are able to run on all lines.
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 07:30 14/01.
.......also broken down trains at various TV locations blocking lines. Good luck if you're travelling today.
Posted by TaplowGreen at 09:01, 17th January 2026
2026 really off to a great start............
Due to a safety inspection of the track between Reading and London Paddington fewer trains are able to run on some lines.
(TfL are blaming an OLHE problem, could quite conceivably be both I guess given the state of the infrastructure)
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 11:30 17/01.
Posted by ChrisB at 11:04, 17th January 2026
Or the same, quite likely. Have you ever seen "safety inspection of the OHLE"....or similar. I suspect they include OHLE in 'track' for this purpose.
Posted by TaplowGreen at 12:47, 28th January 2026
Delays to services between Reading and Newbury
Due to a points failure at Reading West disruption is expected until 13:30 28/01.
Train services between Reading and Newbury may be delayed.
Posted by TaplowGreen at 15:36, 28th January 2026
Now ongoing until 1700
Posted by TaplowGreen at 08:03, 30th January 2026
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 11:15 30/01.
Posted by TaplowGreen at 06:29, 13th February 2026
Due to damage to the overhead electric wires between London Paddington and Reading fewer trains are able to run on some lines.
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 08:45 13/02.
Posted by TaplowGreen at 07:59, 13th February 2026
Updated:
Posted by TaplowGreen at 15:07, 14th February 2026
Due to a fault with the signalling system between Newbury and Reading trains have to run at reduced speed on the line towards Reading.
Train services running to and from these stations may be delayed by up to 15 minutes. Disruption is expected until 18:00 14/02.
Apologies to customers, due to a fault with the signalling system in the Thatcham area trains on eastbound line have to run at a reduced speed thus incurring delays.
Some semi-fast trains between Newbury and Reading will be cancelled, but all stations will still receive a train service.
Posted by TaplowGreen at 22:20, 18th February 2026
Due to urgent repairs to the track at Southall fewer trains are able to run on the line. Disruption is expected until the end of the day.
Due to short notice engineering works being done over night, we have had to reduce the number of trains running between Reading and London Paddington tonight. Until Midnight, a more limited train service is operating, although customers can still travel between the two stations. A change at Reading may be necessary for some customers travelling from or to further afield.
However, overnight train services between London Paddington and Reading are cancelled. Although some road transport has been arranged to cover, this is very limited, and so customers are advised to delay their journeys wherever possible.
Posted by Chris from Nailsea at 23:21, 18th February 2026
Posted by TaplowGreen at 12:18, 20th February 2026
Delays to services between Maidenhead and Slough
Due to a points failure between Maidenhead and Slough trains have to run at reduced speed on the line towards Slough.
Train services running through these stations may be delayed. Disruption is expected until 14:00 20/02.
Posted by TaplowGreen at 19:50, 22nd February 2026
GWR Journeycheck seems to have gone home for the day but this from National Rail.....
Elizabeth line between Abbey Wood / London Paddington and Reading
A fault with the signalling system between Maidenhead and Reading means all lines are blocked. Trains between Slough and Reading may be cancelled, revised or delayed by up to 30 minutes.
Disruption is expected until 22:00.
Elizabeth line customer advice:
At present services will not operate between Maidenhead and Reading, and therefore Twyford and Reading will not served.
Posted by TaplowGreen at 06:10, 23rd February 2026
Due to engineering works not being finished on time between Reading and London Paddington fewer trains are able to run on all lines.
Train services running to and from these stations may be cancelled, delayed or revised. Disruption is expected until 09:00 23/02.
We have been notified that engineering works between Twyford and Maidenhead scheduled to finish at 5am this morning are not going to be completed on time.
The below listed services will be terminating and starting from Reading:
Oxford to London Paddington
Newbury to London Paddington
Posted by TaplowGreen at 11:07, 1st March 2026
Following a fire next to the track between London Paddington and Reading all lines will be reopened shortly. Disruption is expected until 11:30 01/03.
Posted by bobm at 11:29, 1st March 2026
Bit more detail on Journeycheck.
The fire brigade have been responding to a fire at a train depot near London Paddington.
To allow the fire brigade to deal with the incident, power to the overhead electric wires which powers electric trains was switched off.
As a result, major disruption has occurred on this route this morning.
However, the fire has now been safely extinguished, and we are slowly starting to reintroduce the train service. However, delays and short notice cancellations should be expected as continue to restore the train service.
Posted by TaplowGreen at 08:35, 13th March 2026
Due to a fault on a train at Hayes & Harlington trains have to run at reduced speed on some lines. Disruption is expected until 09:00 13/03.
A safety inspection of the track in the Hayes & Harlington area is causing congestion to trains in and out of London Paddington. In order to reduce delays, some train services have been taken out of the timetable this morning; specifically:
Semi fast services between London Paddington and Reading, that would call at Slough, Maidenhead and Twyford, will not run. Customers can however use their tickets on the Elizabeth Line.
Posted by TaplowGreen at 10:47, 19th March 2026
From National Rail;
Lines have reopened following an earlier fault with the signalling system at Slough. Trains between London Paddington and Reading are returning to normal but may still be delayed by up to 25 minutes.
Disruption is expected until 12:00.
Posted by TaplowGreen at 17:27, 26th March 2026
Alterations to services between Newbury and Reading
Due to a fault with the signalling system between Newbury and Reading the line towards Reading is disrupted.
Train services running through these stations may be delayed or diverted between Westbury and Reading.
Disruption is expected until 18:15 26/03.
Posted by TaplowGreen at 17:22, 28th March 2026
Due to trespassers on the railway between Reading and London Paddington trains have to run at reduced speed on all lines.
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 17:45 28/03.
Posted by TaplowGreen at 08:06, 29th March 2026
Also impacting services further afield.......
Cancellations to services between Didcot Parkway and Reading
Due to engineering works not being finished on time at Didcot Parkway some lines are blocked. Disruption is expected until 09:45 29/03.
Train services between Didcot Parkway and Reading may be cancelled or delayed.
Posted by TaplowGreen at 11:42, 30th March 2026
Due to a points failure between Reading and Westbury all lines are blocked. Disruption is expected until 12:15 30/03.
Train services between Reading and Newbury may be cancelled or diverted.
Posted by TaplowGreen at 15:56, 31st March 2026
Due to a speed restriction over defective track between Hungerford and Newbury trains have to run at reduced speed on the line towards Newbury.
Posted by TaplowGreen at 19:54, 31st March 2026
Cancellations to services at Oxford
Due to a fault with the signalling system at Oxford some lines are blocked.
Train services running through this station may be cancelled, delayed by up to 30 minutes or diverted. Disruption is expected until 20:45 31/03.
Posted by NickB at 15:17, 2nd April 2026
Not infrastructure per se, unless you count trackside fencing, but…
Extensive disruption this afternoon at paddington with all lines blocked due to a trespasser at Southall.
To my recollection this is the 3rd such incident in the past fortnight.  Does the great western line have a track security problem?
Posted by TaplowGreen at 16:17, 2nd April 2026
Lines open again now but still extensive delays until 1800 according to National Rail on one of the busiest days of the year - also affecting local Elizabeth Line services.
This sort of moronic behaviour does indeed seem to be on the rise and not just in this area - saw some footage of a couple of people practically tap dancing on the third rail last week, narrowly avoided being turned into charcoal.
Posted by JohnM at 17:16, 2nd April 2026
It meant the 1630 Bristol-Paddington was cancelled, then the 1700 was only 5 coaches instead of 9 - possibly twice as many people on a train half the size (plus additional holiday traffic?). I should have been on it, but decided to leave early and return to Melksham via Trowbridge, which was fine despite a scheduled 5 min change.
Posted by IndustryInsider at 20:49, 2nd April 2026
Seems to have been an attempted suicide which when a driver saw the person with their head on the track, stopped their train and initiated a Railway Emergency Call to stop all other trains in the vicinity.
So the suicide was prevented…but then of course it became a trespass incident.
Mind you, general moronic behaviour as a whole is on the increase, yes.
Posted by Bob_Blakey at 08:06, 3rd April 2026
.....Does the great western line have a track security problem?
The volume of graffiti, AKA criminal damage, along the railway between Paddington & Acton, indicates the answer to that question is a resounding 'Yes'.
Posted by TaplowGreen at 09:18, 3rd April 2026
Ah but Bob that graffiti is "art", and yet another benefit of our increasingly progressive, diverse society (....or something!)
Posted by NickB at 17:00, 3rd April 2026
You forgot to mention ‘vibrant’
Posted by TaplowGreen at 22:24, 5th April 2026
Due to the emergency services dealing with an incident between Reading and London Paddington all lines are blocked.
A person has been struck by a train, leading to all lines being blocked. It is necessary to bring all trains in the affected area to an immediate stop.
Posted by Chris from Nailsea at 22:41, 5th April 2026
Person died, sadly: see https://www.london-now.co.uk/news/25996954.paddington-gwr-delays---person-hit-train-dies-swindon/
Posted by TaplowGreen at 05:59, 8th April 2026
Due to urgent repairs to the track between London Paddington and Reading fewer trains are able to run on some lines.
We have had a report of a defect with the track in the West Drayton area. Trains may not be able to run over the affected line until it has been inspected or may have to run at reduced speed.
Posted by TaplowGreen at 13:52, 8th April 2026
......and to add to the misery......
Due to a points failure between London Paddington and Reading some lines are closed.
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 16:15 08/04.
There has been a points failure in the Southall area. A points failure is a fault with the movable pieces of track that enable trains to change tracks.
There is also a defect with the track in the West Drayton area which means trains are having to run at reduced speed on one of the four lines towards London Paddington.
Posted by ray951 at 18:53, 8th April 2026
And even more misery, must be because the weather got a bit warm today.
Due to a fault with the signalling system between Oxford and Didcot Parkway all lines will be blocked.
Impact:
Train services running through these stations will be cancelled or delayed. Disruption is expected until 20:00 08/04.
Some axle counters, part of the signalling system, have stopped working in the Oxford area. Axle counters tell the signalling system if a section of track has a train on it. If an axle counter stops working, trains need to stop at the affected signal so that the Driver can speak to the Signaller to confirm if the track ahead is clear.
All lines are blocked for 30 minutes to allow Network Rail to access the site to resolve the issue.
Posted by TaplowGreen at 06:35, 9th April 2026
......and it continues into today......
Cancellations to services between Twyford and Slough
Due to a fault with the signalling system between Twyford and Slough fewer trains are able to run on some lines.
Train services running through these stations may be cancelled or delayed. Disruption is expected until 06:45 09/04.
Posted by TaplowGreen at 09:05, 9th April 2026
Now pushed out to 1100
"The problem affects 2 of the four lines between London Paddington and Reading, so we are having to reduce the train service through the area to avoid congestion. Local stopping services between London Paddington and Newbury will only run between Reading and Newbury. Most longer distance intercity services will continue to run between London Paddington and Reading, but may be subject to delay.
We are working with Network Rail to be able to return to running our normal timetable as soon as possible".
Posted by a-driver at 18:10, 9th April 2026
Confirmed as cable theft.
Posted by TaplowGreen at 14:31, 10th April 2026
Due to a broken down train between London Paddington and Reading fewer trains are able to run on some lines.
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 16:15 10/04.
A train has broken down near West Ealing Station.
The train is blocking one of the four lines between London Paddington and Reading, so we are having to reduce the train service through the area to avoid congestion.
Posted by TaplowGreen at 15:42, 10th April 2026
Truly dire few days on this line......
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 18:00 10/04.
A train had broken down near West Ealing Station but has now been cleared. Unfortunately there is now a points failure in the Hanwell area.
Posted by TaplowGreen at 06:46, 14th April 2026
Due to a points failure between Reading and Newbury the line is blocked.
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 08:00 14/04.
Posted by Witham Bobby at 08:56, 14th April 2026
Wasn't there to be a concerted effort from NR and contractors to fix the many long-term infrastructure issues on the Paddington the Reading main line?  What happened to that?  Failures seem to me to be as frequent as they ever were
Posted by TaplowGreen at 09:45, 15th April 2026
Yep, even our esteemed Mayor Khan chipped in with his opinions on Network Rail's performance and I believe he also chipped in with some cash, but pretty much to no avail it would seem judging by recent issues......
https://www.cityam.com/network-rail-must-improve-performance-after-elizabeth-line-and-paddington-disruption-says-sadiq-khan/
Posted by IndustryInsider at 10:25, 15th April 2026
Notwithstanding a bit of a dip over the last couple of weeks, it seems to have been better generally of late?
I'm hesitant in bringing statistics into the game as it's easy to make them fit whatever narrative you want, but pulling data from https://dataportal.orr.gov.uk/statistics/performance/passenger-rail-performance/table-3181a-delay-minutes-per-1-000-train-miles-total-by-network-rail-region-periodic-1/ the average delay minutes for Wales & Western per 1000 train miles works out at:
75.5 for 2023/24 (the year Sadiq chipped in)
63.5 for 2024/25
60.3 for 2025/26 (one period of data still to be added)
Still poor...but definitely improving.
Interestingly, during the main Covid year it was 24.5 proving once again that all these delays are the passengers fault!
Posted by TaplowGreen at 18:39, 16th April 2026
Cancellations to services between Bedwyn and Newbury
Due to a broken down train between Hungerford and Pewsey the line towards Westbury is blocked. Disruption is expected until the end of the day.
Train services between Bedwyn and Newbury will be cancelled.
Posted by Trowres at 20:29, 16th April 2026
Culprit seems to have been the 6V50 Wembley-Merehead.
Moving again after standing for >3 hours. (passed Kintbury 16:52 and Bedwyn 20:22).
What are the barriers to achieving a rescue in less time?
Posted by Witham Bobby at 09:45, 17th April 2026
Lack of spare locos and traincrew at depots
Lack of inter-operability between classes of loco
Few places where there are crossovers to enable rescue locos to reach a failed train conveniently
Lack of lay-by loops and refuge sidings where a train can be placed "out of the way"
Posted by TaplowGreen at 16:01, 17th April 2026
Apart from that, all good!
Posted by NickB at 20:14, 17th April 2026
Surprise!!!  It’s bust again.
Definitely reaching the point of ‘nope, I won’t bother going in case I can’t come back’ that we had in 2024 (and every other year since 2020 really)
Due to a points failure between Slough and Reading fewer trains are able to run on some lines.
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 22:45 17/04.
Posted by TaplowGreen at 08:11, 18th April 2026
If it's any comfort, (as we're told above) apparently it's "definitely improving"
Posted by IndustryInsider at 10:39, 18th April 2026
Yes, I think that's a fair statement...as long as you include the "Still poor" bit.
Posted by TaplowGreen at 11:22, 18th April 2026
Really, "still poor" goes without saying!
Posted by Chris from Nailsea at 11:33, 18th April 2026
You could also say, it's 'slightly less bad'.
Posted by IndustryInsider at 11:42, 18th April 2026
Yes, I like that!
Posted by NickB at 07:11, 20th April 2026
Due to trespassers on the railway between Reading and London Paddington fewer trains are able to run on all lines.
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 09:00 20/04.
Posted by TaplowGreen at 12:42, 20th April 2026
Due to trespassers on the railway between Reading and London Paddington fewer trains are able to run on all lines. Disruption is expected until 13:00 20/04.
Posted by TaplowGreen at 15:04, 20th April 2026
Delays now until 6pm
"The person has been on the railway since the early hours, and despite Police negotiation they remain on the railway"
.............surely by now they could have been physically removed?
Posted by NickB at 16:11, 20th April 2026
This does seem to be rather ridiculous.
Posted by ray951 at 16:29, 20th April 2026
LNER faced a similar issue last week, reportedly someone climbed a gantry, and the resulting disruption affected train services for two days. I’m not sure what the solution is, but it seems wrong that a single individual can cause such widespread inconvenience to tens of thousands of people.
Posted by NickB at 16:36, 20th April 2026
Taser.
Posted by NickB at 18:04, 20th April 2026
Now there’s a new ‘railway emergency’ that has brought trains to a standstill at Burnham
Posted by plymothian at 18:42, 20th April 2026
This is a bridge strike at Langley.
Posted by TaplowGreen at 21:29, 20th April 2026
Taser.
Trespassers had been reported on the railway in the London Paddington area.
The person has now been removed from the railway. Train services will be reinstated where possible, please check your journey.
Hooray!
Posted by Bob_Blakey at 08:04, 21st April 2026
Taser.
Yes, if necessary. First option should always be physical removal of the miscreant as rapidly as possible by as many trained operatives as required. But if said trespasser resists.....
Negotiation should never be involved.
Posted by TaplowGreen at 10:52, 21st April 2026
..............he's moved further West today!
Cancellations to services at Hungerford
Due to trespassers on the railway at Hungerford trains have to run at reduced speed on all lines.
Train services running through this station may be cancelled or delayed.
Disruption is expected until 11:30 21/04.
Posted by TaplowGreen at 07:38, 24th April 2026
Due to a points failure between Reading and Newbury fewer trains are able to run on some lines.
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 10:00 24/04.
Posted by TaplowGreen at 17:34, 25th April 2026
From National Rail
Between Abbey Wood and Heathrow Terminal 4 / Maidenhead / Reading, and also between Shenfield and Heathrow Terminal 5
A fault with the signalling system at Hanwell means that all lines are blocked. As a result trains running between West Ealing and Heathrow Airport / Slough may be cancelled, delayed by up to 30 minutes or revised.
Disruption is expected until 18:00.
Posted by TaplowGreen at 14:16, 1st May 2026
From National Rail
Elizabeth line services between London Paddington and Slough
A fault with the signalling system between Langley and Slough means that some lines towards Reading are blocked. As a result, Elizabeth line services running between London Paddington and Slough may be delayed by up to 20 minutes or revised.
Disruption is expected until 16:00.
Posted by TaplowGreen at 14:30, 1st May 2026
Due to a fault with the signalling system between London Paddington and Reading fewer trains are able to run on some lines.
There is a fault with the signalling systems between London Paddington to Reading
