Bus fare cap - ongoing issue, merged posts
13.6.2025 (Friday) 17:39 - All running AOK
Posted by infoman at 05:03, 16th August 2022
https://www.mirror.co.uk/news/politics/bus-fares-could-limited-2-27747026
Re: two pound maximum fare for the U.K.?
Posted by CyclingSid at 06:53, 16th August 2022
Good photo. looks as though he has just bitten the wrong sort of pickle!
Posted by Electric train at 07:16, 16th August 2022
The only problem with a 'one year cap' it only makes it worse once the cap runs out.  If he is serious about public transport, then he needs to put decent public spend into supporting it long term ...............
But then he is an opportunist like all politicians just looking after his own career
Posted by Bmblbzzz at 07:59, 16th August 2022
I get the impression that Shapps has been more active, verbally at least, since Johnson stepped down than in his previous three years as Minister of Transport. And for the same reason, does it matter what he says now? Whoever takes over as new PM will have their own preferred ministers.
Posted by grahame at 08:43, 16th August 2022
It may matter - it may influence whether he remains in post, is promoted, demoted or fired.  And that will affect not only him, but the departments involved, way into the future.   At this point, he 'needs' to play to Sunak, Truss and their teams of advisors.
Posted by jamestheredengine at 20:40, 16th August 2022
And of course this is not the UK, only England. Nice idea though.
Posted by Ralph Ayres at 23:48, 16th August 2022
This has been doing the rounds since early July (see https://busandtrainuser.com/2022/07/03/to-cap-it-all-a-2-limit/ for more).  Broadly it would mean a flat £2 fare for all journeys and might be simpler done like that; I can't remember the last time I paid less than £2 for a bus journey anywhere outside London. It does seem rather over-generous for longer journeys when something like a blanket 50% reduction on all journeys might achieve similar results with less subsidy.
I wonder if he has discussed any possible negative side-effects or alternative approaches with those in the industry or with passenger representatives?  On second thoughts I don't wonder at all. Of course he hasn't.
Posted by Hafren at 00:19, 17th August 2022
Swansea council has been providing free travel on local buses during certain periods (mostly school holidays and possibly some bank holiday periods etc). Generally it's been applied Fri-Mon, and applies to journeys starting before 7pm. Not sure how much the 7pm rule is enforced, and it's open to interpretation – "made a connection before 7pm, and it's a leg of the same journey" - in rail that would definitely form a journey under the contract, but I suspect each leg counts as a journey in the bus world. I think those who  use the bus for work (who may already have a weekly/monthly pass for the other days and therefore don't benefit, but might do if they are hybrid/part-time workers and able to flex their days) worry about crowding; the guidance is essentially to "plan" around buses being busy, i.e. "you're on your own if you don't fit on and there isn't a later option". I suspect the 7pm rule is partly about avoiding crowding out last buses/connections. It strictly applies to ordinary local buses (not P&R, long-distance etc) and to journeys entirely within the authority's area.
The advertised rationale is to encourage people to return to public transport post-Covid, but of course there are other benefits e.g. encouraging reduced car-use.
I'm wonder how the subsidy works – do the drivers count boarding passengers and the operator claim accordingly, or does the council provide a fixed subsidy based on the operator's expected usual income? Those with senior and other passes are expected to tap in as usual.
Some observations based on this, some of which would probably also apply to a subsidised low & flat fare:
• Certain buses (esp tourist routes) end up being crowded on key days, bearing in mind that there's no 'extra' provision, and probably insufficient resources to provide it. First, the dominant (but less than it was) local operator brought some routes back up to pre-Covid daytime levels, then reduced frequencies because of staffing issues (typically 4bph down to 3bph), and evening services have never returned to the old level.
• Dwell times are significantly reduced as most passengers are waved on.
• Many people aren't aware. I suspect most who are were aware before travelling knew because they already followed the council or a bus company on social media. The rest are surprised the first time they travel in the relevant offer period. And maybe then forget about it until the next time it happens, and are only reminded if they happen to travel then.
Perhaps with a low & flat fare, assuming the subsidy doesn't have some cap & collar arrangement, there would be enough additional demand generated to provide an improved service level to cater for the increased demand. Oh, dreaming again...
The dwell time improvement doesn't appear if people are paying a fixed fare. It would reduce some of the transaction time as the fare structure is significantly simplified, but if people would have bought a day ticket before, it could turn out that two singles now work out cheaper, so now they're paying on boarding both ways instead of once. On the other hand, if people just need to tap a debit card because they don't really need to specify a ticket in many cases (unless the day ticket still works out cheaper e.g. making several journeys that day) it's no slower than showing a day ticket.
I wonder how it would work for multi-leg journeys, especially where it's a long journey connecting with a short journey where most passengers are connecting. Would they have to pay twice, when the journey is no longer than some other journeys on the 'long journey' bus.
The awareness issue would probably have a different dynamic if the cheap fares last longer than one holiday period, and all days of the week – much more opportunity for the public to catch on, especially if nation-wide.
Posted by rogerw at 11:09, 17th August 2022
Many bus services are being cut in the autumn following the withdrawal of government support. A £2 maximum fare is no good if you no longer have a bus service. I think that if the Government wants to help bus services and encourage the use of public transport, using the money to maintain existing services would be a far better idea
Posted by grahame at 07:29, 3rd September 2022
From The BBC
Bus journeys in England will be capped at £2 from January to March next year in a bid to ease the rising cost of living, the government has said.
The £60m plan could see some passengers save more than £3 per single bus ticket, according to the Department for Transport (DfT).
Transport secretary Grant Shapps said the move will provide "direct help" to thousands of households.
But Labour said the plan "fails to match the scale of the crisis".
Meanwhile, from Sunday, single bus fares will be capped at £2 in the Greater Manchester and West Yorkshire regions as part of longer-term schemes.
Local bus fares in England, for the quarter January to March 2022, increased by 3.6% when compared to the same period in 2021..
An average bus fare for a three-mile journey currently stands at around £2.80, meaning the new price cap would save passengers 30% of the price each time they travel, according to the DfT.
Bus operators covering more than 90% of the network in England have signed up for the scheme, the DfT said.
The first time I have such official government comment.  If funded, I would love to see it.
Questions
1. Does "local bus service" mean all journeys on any registered local bus service, or is there a new milage definition bearing in mind all the urban examples being given?  Typical bus journeys here in Wiltshire are 6 to 10 miles between towns and priced much higher that the £2.80 average
2. Do we know which operators have and have not signed up, and is there time for the remaining 10% to do so?  Is there a financial encouragement for them to do so?   If the there is such a financial encourgment, is there funding for it, or could it lead to the loss of supported but routes as local transport authorities struggle to balance the books?
Posted by ellendune at 09:09, 3rd September 2022
A bus journey from here to Swindon Town Centre would be cheaper, but I hardly ever go there, so any journeys I do involve a change in the Town Centre so it would be 2 single journeys would it?
The 5 miles to the office would take 1 hour by bus with two buses  and a significant walk at the other end.  In the car I can do it in 10-15 minutes depending on the traffic.  I could actually walk it in 1.5 hours.
Yesterday I went to the hospital.  That would have been 2 bus journeys.  Although the bus journey is only 45-60 minutes, I would have had to leave half an hour earlier to get there on time due to the gaps in the timetable.  Similar problem on the way back.  So I would have to leave at 11:45 and get back at 2:46.  That's 3 hours for a 20 minute appointment.  By car I left at 12:45 and was back by 1:45. In addition to the fuel I had to pay £1.10 for the car park.
That is why I don't use the buses.
Posted by stuving at 17:14, 6th September 2022
This is DfT's news item about this, from 3/9/22. It doesn't have all the details in it, instead it says they are still working on that:
...Introducing the fare cap by January enables the government to work with operators and local authorities to implement a scheme that most effectively delivers real savings for passengers. Operators representing around 90% of the bus market have expressed support for the scheme and we hope that all bus operators will participate.
The fare cap builds on lots of offers around the country in areas with high bus demand, which include daily, weekly and monthly ticket options and promotional offers. Single fares which are already lower than £2 will not be affected by the cap.
The government will continue to work closely with bus operators and local authorities and consider future support to help passengers continue accessing reliable and affordable bus services after March.
A flat-rate bus pilot scheme, backed by £23.5 million of government funding, launched in Cornwall this January and has already seen an indicative 10% increase in passenger numbers. The ‘Any Ticket Any Bus’ scheme, running over 4 years, includes a £3 day ticket within towns or a £9 day ticket across all of Cornwall, which is valid across different bus operators...
Posted by FarWestJohn at 19:04, 6th September 2022
In Cornwall the any bus any operator anywhere adult all day ticket is £5 and family £10.
Posted by Mark A at 12:10, 4th October 2022
AKA Two pound minimum fare 'cos in Bath it killed the three stop hop fare.
Posted by infoman at 12:44, 19th December 2022
https://www.gov.uk/guidance/2-bus-fare-cap
Its a good idea,but can't find out if there are restrictions on the early morning bus's.
Re: Maximum two pound bus fare across most operators in England
Posted by bobm at 13:08, 19th December 2022
Looking at the Swindon Buses website, it says the offer is valid from start of service.
Posted by grahame at 13:17, 19th December 2022
I do not believe there are any time restrictions. It's just possible that there are limits on night buses, and on things like the airport services in Bristol.     I don't know you can get a £2 fare on the 02:46 from Bristol Airport to the city centre, for example.
Posted by Richard Fairhurst at 15:01, 19th December 2022
It's participating operators only, so although the big guys are all taking part, lots of the independents seem to have opted out - presumably, as with ENCTS, they're not being reimbursed the full amount by Government.
Locally both Stagecoach and Oxford Bus Co/Thames Travel are taking part, but I can't see any of the independents or CICs signed up. Stagecoach have (unsurprisingly!) excluded the Oxford Tube.
Posted by JayMac at 20:30, 19th December 2022
The list of participating operators is missing some independents.
In Somerset/Dorset South West Coaches are participating.
Its probably worth checking with independents if they are not listed.
Posted by MVR S&T at 22:15, 19th December 2022
More bus in east dorset west hampshire are participating, Yellowbuses are not as  they dont exist now!
Posted by grahame at 18:18, 20th December 2022
The £2 fare applies to all local bus services in Wiltshire.   That and much MUCH more in a Christmas update from "our Lee" who I am especially proud of ...
Links to http://option247.uk/christmas2022.html
Posted by Bmblbzzz at 19:13, 20th December 2022
I rarely travel by bus, but IMO one of the best aspects of this, as with the London bus fares, is that you don't need to ask. You just know it's going to be £2.
Posted by Ralph Ayres at 19:30, 20th December 2022
One of my local independents charges rather lower fares than the big outfits, and on the route I know best the fares don't get much above £2 anyway. Understandably they aren't taking part as the admin to reclaim the difference, and the overall benefit to passengers, really wouldn't be worth it.
Posted by Ralph Ayres at 19:38, 20th December 2022
...and talking of admin, I wonder if passengers will still have to state their destination and be issued with a ticket to the required fare point so the amount of reimbursement can be calculated, or if it will be done on some sort of average? I've failed to find anything online but presumably operators have been given details.
Posted by grahame at 13:21, 22nd December 2022
Full list at https://www.gov.uk/guidance/2-bus-fare-cap - good example of a nice simple list - NOT!
Posted by Oxonhutch at 16:44, 22nd December 2022
Thanks Graham, I did find two of my bus routes I use included in the list with nothing so far on the companies' web sites. Might induce another couple of trips into Oxford for an afternoon pint. Always very pleasant.
Posted by Trowres at 17:26, 22nd December 2022
Where in this list is the 49 from Trowbridge to Swindon? (Stagecoach)
Posted by grahame at 18:12, 22nd December 2022
Listed under "Cheltenham and Gloucester Omnibus Company Ltd" which is a Stagecoach operating company. Simples ;-)
Posted by grahame at 18:27, 22nd December 2022
Experience bus users may chuckle, but for newcomers here is some "how to use the bus" advice from Stagecoach
Buying your ticket on the bus
New to the bus
If you haven’t travelled by bus before, here are a few tips for a simple journey.
* Plan your journey so you know which bus and route are right for you.
* Make sure you take a note of the bus number.
* When your bus is approaching the bus stop, just put out your hand so the driver knows to stop and let you on board.
* When you get on the bus, ask the driver for a single ticket to your destination.
* Your fare will be automatically capped at £2 and you can pay by cash, contactless or Apple/Google Pay. Don’t forget to take your ticket from the machine and keep it for the whole journey.
* Once your payment is accepted, take your seat and enjoy the journey.
* When you’re approaching your destination bus stop, press any of the stop buttons located around the bus.
* When the bus comes to a stop, thank your driver as you get off.
Posted by Bmblbzzz at 17:53, 23rd December 2022
I think it's a missed opportunity having to still ask for a ticket to your destination, rather than adopting a proper flat fare.
Posted by ChrisB at 17:27, 24th December 2022
Prevents you from using it as a rover-type ticket
Posted by bobm at 12:48, 6th January 2023
Many will be aware that some long distance journeys are split in the timetable to comply with Traffic Commissioner requirements regarding local bus services.
An example is the X5 from Swindon to Salisbury which splits at Pewsey.   I have confirmed with Salisbury Reds that despite that the £2 applies end to end.
I assume the same will apply for the 49 from Swindon to Trowbridge (which splits at Devizes) and the S6 from Swindon to Oxford (Faringdon).
Posted by ChrisB at 11:15, 17th January 2023
If the bus continues to the end of route....if you have to change buses, it's down to the bus company's choice.
Posted by grahame at 11:31, 17th January 2023
Qualified "yes".  We also have a case locally where the route number changes too at the split point, and I don't know what the status is on that.    And where the journey and change is between bus companies, it would be rare for the £2 to carry over - journeys such as Melksham to our main hospital in Bath, and from Trowbridge and Westbury to Salisbury which was the D1 until last year, when the D1 was truncated to Warminster and the Beeline 24 hurriedly commissioned to ensure the key bus network isn't broken.
Posted by ChrisB at 11:36, 17th January 2023
Definitely NOT if between operators - two tickets required.
Same operator - of course every bus does more than one trip a aday, moving from one route to another. These tickets aren't rovers, so a change of route number is very likely to mean a new service and another £2 ticket.
Posted by Bmblbzzz at 11:58, 17th January 2023
I took a bus on Saturday and was pleased to discover that on First buses in Bristol at least, you don't need to state anything. Just tap on, tap off. I was told by a regular bus user later that you don't have to tap out, but it can affect the fare. If you tap out, then take another (First) bus that day, your daily fare is capped at £3.50. If you don't tap out, it's just another £2 fare for each bus with no daily or weekly limit.
Posted by JayMac at 17:10, 17th February 2023
The £2 fare cap scheme has been extended for another three months until the end of June 2023.
https://www.bbc.co.uk/news/business-64678990
Posted by ChrisB at 18:58, 17th February 2023
As well as £80million further funding for the Bus Recivery grant too
Posted by CyclingSid at 07:14, 5th April 2023
More people using the bus because of the £2 limit
https://www.bbc.co.uk/news/business-65177420
Posted by Fourbee at 11:54, 5th April 2023
It was nice to break the news to a regular Stagecoach user the other day that this had been extended to the end of June. He was delighted (uses it to get to work). I got an email from them about the extension well after I learnt about it on here.
Just shows what can be done. It would be good if the gov't could suspend/abolish the minimum fare on railcards to compete a bit with this promotion.
Posted by Fourbee at 11:57, 5th April 2023
Just to add I've been using the bus more as a result and agree with Bmblbzzz, it's nice to know the fare will be £2 and not some randomly high amount. I know some operators publish single fares on their websites, but at least this way you don't have to look it up or get a nasty surprise when the driver tells you. Also makes comparing singles with day/rover tickets a bit easier when weighing up what's best value.
Posted by JayMac at 00:59, 17th May 2023
The £2 bus fare cap scheme has been extended again. It will now run until the end of October 2023.
From 1st November 2023 the cap will rise to £2.50 for a further 13 months, to the end of November 2024.
https://www.bbc.co.uk/news/business-65616182
Posted by grahame at 07:11, 17th May 2023
What about an appropriate similar scheme for trains?   Sort out fares for the summer and keep extending?
Posted by TaplowGreen at 07:32, 17th May 2023
Ooooooooos gonna pay for it?
Posted by grahame at 07:43, 17th May 2023
1. Who is paying for the bus scheme?
2. Read me carefully - I said "appropriate" scheme not a £2.50 flat rail fare.  I would wonder if it may be more "who's going to guarantee it" that "who's going to pay for it", but then it could results in trains being overfilled, and cutbacks from 10 and 9 car to 5 car, etc, have reduced capacity and made for a system which is pruned towards reduced passenger levels.
Posted by grahame at 08:13, 17th May 2023
The next United Kingdom general election is scheduled to be held no later than 28 January 2025. It will determine the composition of the House of Commons.
I expect the £2.50 will extend until March 2025 if the election goes "to the wire".
Posted by Richard Fairhurst at 09:50, 26th June 2023
Very pleased to see that Pulhams are now joining the fare cap scheme following their acquisition by Go-Ahead/Oxford Bus Company.
Posted by ChrisB at 16:40, 26th June 2023
You reckon it'll go to the wire? Seriously??
Posted by CyclingSid at 06:54, 27th June 2023
Possibly the only good thing of being acqured by by Go-Ahead/Oxford Bus Company?
Posted by Richard Fairhurst at 14:03, 27th June 2023
I'd be more charitable than that! OBC have a knack for promotion and have shown they're willing to try and grow the business. Pulhams were lovely as independents, but I don't think I've ever seen a single piece of promotion for the X9 ("our" bus, Witney–Charlbury–Chipping Norton), and they only introduced card payment on it when OCC funded them to do so.
I'd pretty much resigned myself to the X9 being abandoned in a year or two and left for a community transport organisation to pick up. It may still happen but having the heft of OBC behind it gives it a fighting chance.
Posted by bobm at 14:09, 27th June 2023
In Swindon we have Go-Ahead and Stagecoach.   I know which I prefer.  A modern fleet v an ageing one.
Posted by JayMac at 15:44, 27th June 2023
Whenever I'm travelling around the UK I'm always glad when the local bus operator in a particular area is Go Ahead.
Miles *ahem* Ahead of First, Stagecoach or Arriva.
Posted by CyclingSid at 09:37, 26th September 2023
Bus fares in rural England drop 11% thanks to government's £2 fare cap
https://www.gov.uk/government/news/bus-fares-in-rural-england-drop-11-thanks-to-governments-2-fare-cap
How does this translate to the income of the companies who run the buses? I believe the number of rural bus routes has continued to decline this year.
Posted by Ralph Ayres at 10:52, 26th September 2023
I understood that the bus companies were being compensated for any lost revenue, though it's not clear to me how that is calculated.  Comparing with the previous year isn't realistic cos of the pandemic, changes to routes etc, and most drivers don't bother asking where you are going so it's not based on what price you would have paid which might have gone up by now anyway. No mention of how much the overall subsidy has cost in the press release, which actually raises more questions than it answers if you look at it in detail. The sentence about fares being comparable to 2007 particularly stands out. I would hope some of the media would ask for more background, but most will probably just copy and paste what amounts to a government promotional piece.
Posted by stuving at 11:12, 26th September 2023
I can't find the DfT's own version of the rules for the Bus Fare Cap Grant. This is from TransportXtra, who also reported the extension in May without any mention of alterations.
£2 bus fare cap operator payments to be fixed
Peter Stonham    29 November 2022
More details have been revealed on how operators will be reimbursed for offering a maximum £2 bus fare for three months starting in January. The Government's Bus Fare Cap Grant (BFCG) will distribute the £60m allocated to the £2 flat fare scheme planned in England outside London for January to March.
Participating operators look set to be offered a fixed funding allocation in early December, before they need to confirm whether they will take part.
Consultancy firm EY UK has been engaged by DfT to collect the data necessary to calculate allocations, which will be capped at £20m for each of the three months in question. Key questions being addressed in draft BFCG guidance relate to the treatment of losses or profits of those involved in the scheme, what services they agree to include – probably all their network – and the competitive consequences between those operators taking part and those not doing so
DfT issued the draft guidance in early November and made clear that terms within it are subject to change. Among other provisions are acceptance of concessionary passes and the impacts of established fare capping arrangements. On services that cross borders to Scotland or Wales, only journeys beginning in England will be eligible for the grant.
Calculation of the sum to be offered to each operator will be carried out via a four-stage process that first uses a baselining exercise to calculate average revenue loss per ticket, followed by forecasting of BFCG take-up and a generation factor to reflect expected growth in demand, including adjustment for passengers switching from other tickets to the £2 fare.
When it announced the cap in September Ministers said offering people support during the cost-of-living crisis was a key reason for its creation, though encouragement of post-Pandemic patronage return was another.
I'd guess that the amounts have been recalculated for any offer to operators for the extension.
Posted by JayMac at 15:18, 4th October 2023
The rise from £2 to £2.50 on 31st October will now not go ahead. To remain at £2 until December 2024.
Posted by Phantom at 12:39, 5th October 2023
Great to hear
I've actually use the local bus service more in the past two months that I did in the previous two years
Posted by JayMac at 21:47, 5th October 2023
Notwithstanding my bus woes today (as told elsewhere), I too have made considerably more bus journeys since the fare cap came in.
Posted by ChrisB at 19:27, 16th August 2024
I thought that the previous Government had committed to the bus fare cap at £2 until the end of this year, followed by another year at £2.50?
From The Independent, via MSN
Ministers are being urged to avoid imposing a “cliff edge” return to commercial bus fares on passengers in England after refusing to commit to extending the £2 cap.
Bus companies said it is vital the cost of using their services is kept low for young people to “enhance their access to education and jobs”.
Single bus fares in England have been capped at £2 since January last year, but the Labour Government has declined to say whether the policy will continue past the current end date of December 31.
Alison Edwards, director of policy and external relations at industry body the Confederation of Passenger Transport, said: “Bus operators are working closely with the Government so that together we can find a way to avoid a cliff edge return to commercial fares.
“Analysis has shown that supporting fares, which can be done in a range of different ways, is great value for money and can support many other Government objectives.
“For example, keeping fares low for young people would enhance their access to education and jobs while also encouraging them to develop sustainable travel habits to last a lifetime.”
Transport Secretary Louise Haigh said in a recent interview with the PA news agency that her officials were “looking at various options” in relation to the cap, including whether they could “target it better”.
In response to a parliamentary question on the issue last month, transport minister Simon Lightwood wrote that the Government was “urgently considering the most effective and affordable ways” of delivering “reliable and affordable public transport services”.
Passengers travelling long distances in rural areas or between towns and cities are likely to suffer the biggest fare rises if the cap is not extended.
When it introduced the policy, the Conservative government said routes with some of the biggest per journey savings were between Leeds and Scarborough (£13), Lancaster and Kendall (£12.50), and Plymouth and Exeter (£9.20).
Re: Ministers urged to extend £2 bus fare cap after refusing to commit to move
Posted by grahame at 19:40, 16th August 2024
I think it was to be £2 until (?) the end of 2023, then £2.50 through 2024.  But that might have been a bit of a vote looser, mightn't it?   It was another scheme which would / will be difficult to sustain long term unless someone at the top decides to grow public transport use by making it attractively cheap, even at cost to the treasury.
Posted by JayMac at 21:22, 16th August 2024
The plan was for the cap to rise to £2.50 from 1st November 2023. But that was scrapped and it was kept at £2 until 31st December 2024.
Posted by Fourbee at 09:22, 17th August 2024
I had an email from Stagecoach on 26th June announcing price increases which came into effect on 1st July, including some single and return fares. Obviously if the £2 scheme ends then customers will be exposed to the higher prices in the new year. I've got no idea what the nominal fares would be for the journeys I could make as when I look them up they obviously come up as £2 at the moment. I will certainly be using the bus less if the scheme ends as some of the fares were way too high for me even before the unknown price rise last July.
Rachel Reeves to scrap bus fare cap
Posted by ChrisB at 15:52, 13th October 2024
From The Telegraph, via MSN
Rural communities are at risk of losing vital bus routes as Rachel Reeves prepares to scrap a £2 cap on fares.
The cap, introduced to encourage people to use public transport post-Covid, is to be raised or abolished outright in this month’s Budget, according to industry and Whitehall sources.
Ms Reeves has already ordered government departments to find savings as she scrambles to fill what she claims to be a £22bn black hole in the public finances.
While the impact of removing the cap, which costs the Treasury £350m a year, would most likely be marginal on short routes within cities, rural fares could jump by £10 or more.
That could leave people unable to afford to get to work, college or hospital, and reduce passenger numbers to such an extent that the future of some routes is thrown in doubt.
Silviya Barrett, the director of policy and research at the Campaign for Better Transport, said the £2 cap had breathed new life into the bus sector and should be extended, not abolished.
She said: “Taking the bus shouldn’t be a financial burden and raising the cap or scrapping it entirely could leave passengers struggling to afford travel on lifeline services.”
The Rural Services Network, which campaigns on behalf of residents of Britain’s 6,000 villages and 200 market towns, said rural poverty has depressed car ownership and left people reliant on the bus, many of whom will be left isolated if fares jump or services are cut.
Bus operators are understood to be largely resigned to the £2 cap being abandoned when it expires in December, and are pressing for it to be raised to no more than £2.50.
That would have little impact on the affordability of urban routes, it is argued, as nationwide bus prices countrywide averaged £2.47 before the cap was introduced in January 2023.
However, industry sources believe the ceiling will most likely be kept at that level for six months before being raised to £3 and then scrapped at the end of 2025.
While the Department for Transport (DfT) is said to favour a staged withdrawal, there are also concerns the Treasury could insist on abolishing the cap outright in this month’s Budget.
The Confederation of Passenger Transport, which represents a UK bus sector that carries 10m passengers a day, said it is vital that such a cliff-edge scenario be avoided.
Alison Edwards, its policy director, said: “Removing the cap overnight would be catastrophic for passengers and would have a knock-on effect on bus services.”
Ms Edwards said that the removal of the cap would also weigh heavily on discretionary travel such as bus-based tourism to the countryside and coast, which has seen a huge resurgence since Covid.
In North Yorkshire, where bus travel jumped 11pc last year, the cap has been credited with maintaining the viability of a host of rural routes. They include the Coastliner 840 service from Leeds to Whitby, which has been voted the most scenic in the UK.
If the cap is to be removed, Ms Edwards said it should be replaced with other measures to ease the burden on passengers, such as support for fares for younger people.
The House of Lords debated the cap last week, with Labour transport spokeswoman Baroness Blake hinting that the Government may put the onus on councils to fund fares, just as authorities in cities including London and Manchester already do.
She said: “The money going to local authorities is not ring-fenced; they are able to look at different schemes for their particular localities.”
The Department for Transport declined to comment.
So, basically, they're guessing.
Edit note: ChrisB, I've added one additional character to the very first of your post, simply to make your link work.  CfN.
Re: Rachel Reeves to scrap bus fare cap
Posted by JayMac at 16:25, 13th October 2024
And that makes the thread title somewhat misleading. Perhaps add, "says The Telegraph"
Posted by grahame at 16:28, 13th October 2024
Yes, but it might appear to be a slightly educated guess reading the smoke.  The flat fare gives the greatest benefit on longer more rural routes so was perhaps well tuned to woo voters in what were blue shires, and it would be convenient to dump the ire of it finishing onto the local authorities there.   There is probably a need to refactor / restructure and I do hope we don't end up with a complex system that varies across bus companies and LTA boundaries.
Posted by Ralph Ayres at 20:17, 13th October 2024
The cap was never going to be sustainable long-term, as well as being a blunt tool not catering particularly well for example for people who had to use more than one bus for their journey. Cynically, I wonder if the implementers were fairly sure that withdrawing it would be someone else's problem.  I'm not convinced that it is maintaining the viability of a host of rural routes. There may well be more people travelling and it's helped people on lower incomes, but the overall revenue for the bus operators hasn't gone up significantly if at all; as I understand it that's pretty much how the reimbursement from the DfT is meant to work.
Ideally a cap of some sort needs to stay in place just long enough to allow a far better scheme to support and encourage bus use to be designed and implemented.
Posted by Electric train at 07:15, 14th October 2024
I agree that "the cap" was intended to be a temporary measure.  In this country there has been a fixation that public transport should be self financing ie without support from the public purse.
If we the UK public want to have effective public transport that supports rural areas drives car usage then public transport will need support from the public purse, there should be a move to private companies paid on a contract with service level obligations model and not a franchise model which only seems to fund the bubbly at share holders meetings
Posted by grahame at 09:37, 14th October 2024
The cap was never going to be sustainable long-term ...  [snip]
And there you have the problem - how do you translate the economic case for the area served and all the public good done by public transport into a financial case in which the balance sheet for operating the service including any renewal an maintenance covers its costs at the least.
With the £2 bus fare being questioned, and with the winter fuel allowance being means tested, do members feel that there is a risk of other schemes that help people who are above the safety net - such as the ENCTS scheme - being curtailed, dropped, means tested, having a fixed (£2  ) charge per journey added, being limited to journeys starting in your own authority, etc.
Posted by TaplowGreen at 09:46, 14th October 2024
I could certainly see the universal free bus pass being means tested in the same way as the Winter Fuel Payment.
Posted by ChrisB at 19:52, 14th October 2024
Don't forget that its also available to those with a disability, regardless of age.
Posted by infoman at 07:53, 15th October 2024
May the Government might fudge the issue and withdraw the cap in large populated areas.
But retain it in the country areas,just a thought.
Posted by grahame at 08:38, 15th October 2024
There was a suggestion at one point, wasn't there, that the cap was to go up to £2.50 but that was not done and I wonder if it's because a general election was coming up.
If I was Rachel Reeves (for clarity, I am NOT) and if she was to listen to me (I'm sure she has better things to do), I would consider stepping up the cap at (say) a pound a year until it reached £5, from that point perhaps leaving it in place rather like it being a "regulated fare" ... and giving some help to those who, with some contention I suspect, we could describe as the "rural poor".    The balancing act is between a poorly targeted subsidy and a cost so much higher / spiking upwards that people don't use the buses, and a 'take' of £3 or £4 is far better than an empty seat bringing in £0.
Posted by RichardB at 15:30, 15th October 2024
I think this is just mischief making by the Telegraph.  Buses ae a big priority for the new Government so I think it is extremely unlikely the cap would simply be scrapped.  I can see the previously announced increase to £2.50 happening but then I can also see them sticking to the £2 too.
We'll see soon enough in the Budget.
Posted by Fourbee at 12:12, 28th October 2024
Just announced that the cap will be £3 throughout 2025:
https://www.bbc.co.uk/news/live/c079nmk0rd5t
Starmer says new £3 cap on bus fares will be announced this week
The PM is now asked about scrapping a £2 cap on bus fares in England, rumoured to be included in the Budget.
Starmer says the Tories only funded this capped fare to the end of 2024.
He says he understands how reliant many people are on this cap, particularly in rural England and announces that there will be a new £3 cap fare until 2025 announced this week
(From a live BBC feed)
Posted by JayMac at 13:39, 28th October 2024
Excellent news. A sustainable increase for the government and not too great a price shock for bus users.
Posted by TaplowGreen at 16:20, 28th October 2024
I fear that the 50% rise in the bus fare cap may be the only good news to look forward to from the Government this week!
Posted by XPT at 17:18, 29th October 2024
I don't see what's good or excellent news about the bus fare cap rising to £3.  This will probably mean that even very short distance bus journeys now will rise from £2 to £3.  I expect it will be the case with First Bristol/First West of England buses anyway.  As all their single fares are a flat fare of £2.  I can't see them changing their fare structure to for example short distance journeys for £2 and longer distance journeys for £3.  Will their "Tap in Tap out" system be able to work out short distance and longer distance journeys to calculate the fare?  We'll have to see.  But I expect they'll probably just change their flat fare single journeys to £3 to keep it simple.  So this would even mean even very short distance journeys of up to a few stops or only about a mile or so in distance would be £3 now.  Which is pretty expensive!  Some people would probably decide to walk instead of forking out £3 for such a short distance journey.
Posted by bobm at 18:10, 29th October 2024
In Swindon the short hop fare with Swindon's Buses on Tap on, Tap off was £1.80 until recently when it rose by 10p.   I don't see that increasing to £3 in January.
Posted by JayMac at 19:19, 29th October 2024
Taunton's £150 flat fare is also not increasing as far as I'm aware. The park and ride service is just £1.
Posted by ray951 at 19:34, 29th October 2024
I would hope not
Posted by JayMac at 20:03, 29th October 2024
Aha ha ha. I of course meant £1.50.
Posted by infoman at 00:53, 30th October 2024
Ah Well,this is good news if your heading to Manchester for an event,
unless like most of us on here that have already got their senior citizen bus pass card.
https://www.bbc.co.uk/news/articles/cz6jlze96elo
Posted by grahame at 07:24, 30th October 2024
Thank you for bringing us that. Good on Manchester for retaining the £2 cap.  Environmentally, this is very encouraging and in an ideal world (or a better one?) I would have liked to have seen that nationwide - however, the temporary scheme that was in place was always going to be a challenge to maintain in areas where the typical bus journey is longer, such as the South West, whatever flavour the new government.
Posted by infoman at 08:53, 30th October 2024
Not sure if this in the correct section for the topic.
Andy Burnham metro Mayor for Manchester speaking on LIVE on BBC breakfast talking about various issues,
stated he/they were going to have a meeting with Northern rail today(Wednesday 30 October 2024) to discuss the high amount of cancellations.
Posted by grahame at 09:35, 30th October 2024
Not sure where is right for that really - but it continues the Manchester public transport theme that's topical this morning, so this looks fine.
Far from being just a Manchester / Northern issue though ... on my blog at https://grahamellis.uk/blog1399.html I wrote this morning about what happened at last night's Melksham Town Council meeting.
5. Railway - and a report back on the letter of concern we sent to GWR relating to the reliability of their train service at Melksham, in particular in relation to short notice cancellations. These are usually reported as being due to insufficient staff or working trains being available. The letter was sent a couple of months ago, and we still await a reply. We did hear back from our Community Rail Partnership, who explained why the trains are not reliable, but were unable to offer any substantive news on how the acknowledged problem will be fixed - they are in GWR's hands (and GWR's masters perhaps - the Department for transport who are the puppet masters in many ways). But I can report back on what may be things getting a bit better - hard to tell because the problems go up and down - and I can also report on a somewhat better provision of alternative road transport. On a (different) matter I have spoken with GWR managers twice earlier this month, and they have confirmed that their MD received the letter ... the fact that it has been copied around within the organisation is encouraging, as is the new Wiltshire Rail Strategy which I wrote about last week - you'll find that if you scroll down.
Posted by JayMac at 11:26, 30th October 2024
Are most of this forum's membership of senior bus pass age? I'd be interested to know the stats.
Posted by johnneyw at 18:26, 30th October 2024
I'm teetering on the brink of that particular addition to my wallet.  My application went in yesterday.
Posted by Chris from Nailsea at 18:38, 30th October 2024
I'm looking forward to applying for mine next year, when I will (hopefully) reach State pension age.
Posted by ChrisB at 21:08, 19th November 2024
From The Mirror, via MSN
Transport Secretary Louise Haigh gives update on future of £3 bus fare cap
The £3 cap on single bus fares could be targeted at younger people and rural areas from 2026, Louise Haigh has suggested.
The Transport Secretary hinted that rather than extending the overall cap once more the government will explore other options in the coming year. Last month it was confirmed at the Budget the cap would be extended - costing £150million.
But it was announced the cap will also go up from £2 to £3 at the start of next year through the end of December 2025. Fares less than £3 will only rise by inflation.
Ms Haigh told Sky News's Trevor Phillips: "The plans we inherited would have ended the cap completely on December 31. We've stepped in with funding to protect (the cap) at £3 until the 31st of December next year, and in that period, we'll look to establish more targeted approaches."
"We've, through evaluation of the £2 cap, found that the best approach is to target it at young people.
"So we want to look at ways in order to ensure more targeted ways, just like we do with the concessionary fare for older people, we think we can develop more targeted ways that will better encourage people onto buses."
Pressed on whether there will not be a single cap after December 2025 but subsidies will be targeted at certain groups of people, she replied: "That's what we're considering at the moment.
"As we go through this year, as we have that time, whilst the £3 cap is in place, because the evaluation that we had showed it hadn't represented good value for money, the previous cap."
It came as the Transport Secretary also revealed where £1 billion in funding will go to deliver London-style buses nationwide as part of a massive Budget boost. She confirmed £712 million in funding for local authorities to improve services, alongside a further £243 million for bus operators.
Areas receiving an "unprecedented" amount of funding include Peterborough, the Isle of Wight, Torbay, Cambridgeshire, Leicester and Torbay.
Speaking on Sunday, she said: "If you live in a lot of small towns or villages, you've not got a bus before 9am or after 5pm and that's what stops people catching the bus."
Posted by ChrisB at 21:16, 19th November 2024
From the Metro, via MSN
Full list of areas sharing £1,000,000,000 funding for London-style buses
Areas set to benefit from close to £1 billion investment in bus services have been revealed.
The government hopes to make bus travel more convenient and cheaper across the country, letting more regions benefit from a service similar to that in the capital, where you rarely go long without seeing a familiar double decker.
Unveiling more detail today, they said South Yorkshire would get £17 million; Liverpool City Region would get nearly £21 million; Lancashire would get £27 million; Kent would get £23 million; Essex would get £17 million; and Norfolk £15 million.
Areas receiving an ‘unprecedented’ amount of funding include Peterborough, the Isle of Wright, Torbay, Cambridgeshire, Leicester and Torbay.
Bus services are currently a ‘postcode lottery’, with many locations underserved particularly in rural areas, and the funding system inconsistent.
Transport Secretary Louise Haigh confirmed £712 million in funding for local authorities to improve services today, alongside a further £243 million for bus operators.
A reformed allocation model has been based on need – for example an area’s levels of deprivation and population – instead of making areas compete for funding as in previous years.
Ms Haigh said: ‘Buses are the lifeblood of communities, but the system is broken.
‘Too often, passengers are left waiting hours for buses that don’t turn up – and some have been cut off altogether.
‘That’s why we’re reforming funding to deliver better buses across the country and end the postcode lottery of bus services.’
Alongside this big Budget commitment, the Government will also set aside £150 million to cap fares at a maximum of £3 and an inflationary limit will also be set to ensure other fares are not automatically increased to £3. The cap will run until the end of 2025.
However, the news has not been universally welcomed because single bus fares in England have been capped at £2 outside London, where they are £1.75 per journey, for most routes since January 2023, so some fares may now increase.
Alison Edwards, of the Confederation of Passenger Transport said: ‘It is encouraging to see that the funding will be shared across every English region. Bus operators look forward to working with local authorities on plans to speed up services, improve coordination and enhance frequencies.
‘Bus passengers deserve a fair funding deal. Every pound of public money invested in buses delivers a return of more than £4 in benefits to the environment, to public health and to communities.’
Posted by JayMac at 22:28, 19th November 2024
That article says it is the 'full list' of Bus Service Improvement Plan spending. With its included map giving the impression large parts of the country are not getting any of the allocated money. With only a not very clear embedded link to the government's information on the BSIP.
Here is the full list of funding:
https://www.gov.uk/government/publications/bus-service-improvement-plans-local-transport-authority-allocations/bus-service-improvement-plans-local-transport-authority-final-allocations-2025-to-2026
Edit: Not shooting the messenger. Just criticising the journalism.
Re: Bus fare cap - ongoing issue, merged posts
Posted by JayMac at 20:48, 10th June 2025
According to The Mirror, the Chancellor Rachel Reeves will be announcing that the bus fare cap, currently at £3 for a single journey, will remain in place until March 2027.
www.mirror.co.uk/news/politics/bus-users-protected-price-hikes-35368949
Posted by grahame at 16:19, 11th June 2025
Update / confirmed and includes other announements - https://www.bbc.co.uk/news/articles/clyr170qm19o
Transport, energy and environment
£15.6bn allocated between 2027 and 2031 for transport projects in English city regions outside London
Additional £11.5bn committed towards the cost of building the Sizewell C nuclear power plant in Suffolk, which will also require private investment
£3 cap on single bus fares in England extended until March 2027
Rules used by Treasury officials to assess proposed infrastructure projects to be updated
Is that "Rules to be updated" a bit woolly but potentially a biggie?
Posted by ChrisB at 18:57, 11th June 2025
Relates to BCR figures not solely determining whether any project would get built....
