Vivarail chosen for fast charging trial on the Greenford branch
8.7.2025 (Tuesday) 11:49 - All running AOK
Posted by Celestial at 12:16, 15th February 2022
Great Western Railway has signed a deal with manufacturer Vivarail to trial new battery-charging technology on its network, paving the way for battery-only trains to run in regular passenger service in the future.
The trial, supported by Network Rail, will take place on the Greenford branch line later this year and test Vivarail’s trackside fast-charging equipment in an operational setting for the first time.
It is hoped that the project will demonstrate that the equipment works safely and reliably in a ‘real-world’ environment.
The use of batteries for extended operation has typically been constrained by their range and meant widespread implementation has, until now, not been feasible.
Fast Charge equipment will be installed at West Ealing Station later this year and tested with Vivarail’s battery-only Class 230 train, first showcased at COP26 last year.
The train has a range of up to 62 miles on battery power, recharging in only 10 minutes using the Fast Charge system in off-network tests.
https://news.gwr.com/news/gwr-fast-charging-trial-brings-regular-battery-only-rail-services-a-step-closer
Let's hope it's successful. It would seem appropriate technology for, say, some of the West Country branches.
Re: Vivarail chosen for fast charging trial on the Greenford branch
Posted by IndustryInsider at 13:39, 15th February 2022
Yes, and a good choice of route to trial it on.  Might release another Turbo or two to go west.
Posted by broadgage at 18:58, 15th February 2022
Charging in ten minutes is impressive, a battery range of only 62 miles less so but still useful.
Does anyone know how this charging energy is to be supplied ? Short length of OHLE ? Conductor rail ?
I would hope that something simple and reliable has been selected. It would n my view be preferable to also allow charging from a standard mains supply via a flexible lead. Not very practical for ten minute layovers, but handy if the train is ever required to visit some place not equipped with anything more sophisticated.
A 32 amp 3 phase supply would probably fully charge it overnight, and even a domestic type 13 amp supply would charge it in a few days.
Posted by IndustryInsider at 19:25, 15th February 2022
Details here:
https://vivarail.co.uk/wp-content/uploads/2020/12/Vivarail-Solar-Power-RCM-Web.pdf
Posted by Celestial at 20:14, 15th February 2022
Even better, use a four way extension lead and you could charge a small fleet all at the same time. Simples.
Posted by stuving at 20:19, 15th February 2022
If you look on Vivarail's website, there isn't anything very technical but there is a video about the trains and their "fast charge" system. That shows the progress since the note in the link above (dated December 2020).
Basically, there's a buffer store of batteries at the station housed in shipping containers, that only needs a low power mains supply. Connection is via short "ramps" of third and fourth rail that the train has to stop exactly over to get a high-current feed. Whether it can do all of this at DC isn't clear, nor is what kind of batteries they use (though didn't we have something on that earlier?).
Posted by Electric train at 21:14, 15th February 2022
I would suspect it will be at DC, most fast chargers are DC and match the battery voltage.  DC also saves the weight of having chargers on board.
The development of the rules of how these trains charge on the operational network has been in discussions involving NR, ORR, RSSB and Vivarail for quite a number of years
Posted by grahame at 07:54, 16th February 2022
My understanding is that a battery storage bank allows a reservoir of power to be built up off solar power, or perhaps off a limited mains supply, over a period of time for a short, sharp local charge.  Bit like a reservoir, but for power not water?
Could this technology also be applied (indeed, is it already applied?) to electric charging for road vehicles - could (for example) a couple of buses running a town service be fast-charged during the driver's personal needs break, even if the grid to the place that break is taken is pretty pathetic?
Posted by Timmer at 08:30, 16th February 2022
I have read that fast charging is not good for the life of a battery. Not going to be very environmentally friendly if you are having to swap batteries out every few years because they are knackered from the over use of fast charging. This applies to electric cars too of course.
Posted by Bmblbzzz at 08:56, 16th February 2022
Details here:
In Cancun the sun shines for an average
of 9 hours a day for 240 days per year*
Is that Cancun in Mexico, or Cancun the lesser known borough of West London?
Posted by grahame at 09:17, 16th February 2022
Details here:
That's 2160 hours
From:  https://www.climatestotravel.com/climate/england/london
In London, there are 1,675 sunshine hours per year. The sun is rarely seen from November to February, while from May to August, it shines for an acceptable number of hours, and in any case, it shines a bit more often than in the rest of Britain (excluding the southern coast).
So great for an intensive summer service of trains from the London suburb of Ealing to holiday and day trip destinations such as Castle Bar Park and Green Ford
Seriously - excellent line for the trial, me thinks.
Posted by stuving at 12:31, 16th February 2022
Yes - quite a few systems, notably trams (e.g. Nice) and local trains (e.g. using Furrer + Frey's Railbaar contact system). But it's hard to know if these are really fast, or just fast enough. From what I've seen, most traction batteries are still Li-ion, so they can't cope with very high charge rates. And you don't need the onshore buffer battery if you have a big enough supply.
Vivarail's previous announced work in this field, and the trains they have built, use batteries from Valence. There was a FOAK project unhelpfully called TRAIN on the same contact system being used at West Ealing. The buffer is described as using 'retired' batteries, presumably from cars, so it must rely on having a lot of them to reach the peak power needed (but then they are cheap).
I have seen reports of trails using other batteries, and the BPEMU used lithium iron magnesium phosphate ones from Valence and they were acquired by Vivarail afterwards. While there was a lot of technical detail from Vivarail around 2018, I can't see that on their site now. So what batteries they will be using for the Greenford trains is a bit of a mystery (I think Valence now call themselves Lithion, which may be a hint). And of course that's the main thing determining the peak charge rate and what that means for battery life.
Posted by broadgage at 15:29, 16th February 2022
Not certain that the intention is to charge the lineside battery from solar ? The publicity material seems to imply that this is an option.
In an urban area of the UK with substantial grid supplies, I am not convinced that the lineside battery is justified. This battery adds costs, complication, extra losses, and another point of failure.
Loads of up to about 1 MW can be supplied direct from the 11kv DNO network, if more than that is needed than a higher voltage supply is needed. This costs money, but is probably cheaper than the lineside battery.
Posted by paul7575 at 15:38, 16th February 2022
[…] While there was a lot of technical detail from Vivarail around 2018, I can't see that on their site now. So what batteries they will be using for the Greenford trains is a bit of a mystery (I think Valence now call themselves Lithion, which may be a hint). And of course that's the main thing determining the peak charge rate and what that means for battery life.
Regarding battery manufacturer, there’s an IMechE presentation about the trains that includes pictures of battery packs from the manufacturer “Hoppecke” about 35mins in:
https://youtu.be/5eNGAfm0Dl4
I couldn’t make out what he was saying originally…
Posted by stuving at 17:42, 16th February 2022
I do recall coming across the name Hoppecke in the context of a switch of battery supplier - I even thought I'd put it in a post, but if I did I spelled it wrong. The fast charging work did start with Valence, so the switch took place mid-stream. Hoppecke's announcement of their new friends says these are Li-ion batteries, rather than the old LiMP ones.
From the answer to a question in that IMechE talk, the main factor in how well Li-ion batteries cope with fast charging is the balancing the charge state of all the cells. This capability is built into the Hoppecke ones, but if it's not you can't really add it on afterwards. For small batteries, every Li-ion cell has to have a charge controller chip. For bigger ones, with strings of series cells, maybe they are not usually provided per cell?
Posted by JayMac at 21:06, 16th February 2022
Long enough flex with a spring winding system and you could leave the train plugged in.
Posted by eightonedee at 22:06, 16th February 2022
Quote from: Celestial on Yesterday at 08:14:27 pm
Quote from: broadgage on Yesterday at 06:58:32 pm
Not a bad idea BNM. But I have had another - how about suspending two conducting wires side by side above the track, put some kind of pick up apparatus on the roof of the train, and do away with those heavy (and expensive to produce from all kinds of rare materials whose extraction and processing is I understand not particularly environmentally friendly) batteries?
Posted by TonyN at 23:40, 16th February 2022
Why bother with the flex just use clockwork. Could have a motor at West Ealing and Greenford to wind it up before each trip.
Posted by grahame at 03:01, 17th February 2022
The irony - from Ian Visits
Former London Underground District line trains are returning to London.
This happens to means that during the trial, Greenford station, which is on the Central line, will also be served by ex-District line trains.
Posted by broadgage at 03:42, 17th February 2022
You would not even need two wires ! One wire will work fine with the steel rails forming forming the other side of the circuit.
Various voltages have been used, recent trends have been towards relatively low DC voltages of from 550 volts up to 1,500 volts for shorter lines in urban areas, and with 25 kv AC finding favour for longer routes.
Both are lethal if touched but reasonably safe as well out of reach.
Posted by oxviem at 08:23, 17th February 2022
Indeed it already is in the UK too - see the electric buses in Harrogate. https://en.wikipedia.org/wiki/Harrogate_Bus_Company
Posted by grahame at 08:51, 17th February 2022
Thanks for that link - really interesting to read into the Harrogate project (which I have been doing while supping my coffee!).   I can't see a note there of how the power gets to the rapid chargers.   Do they have a battery storage reservoir at the charging points (which is what I am especially interest in with the Ealing experiment) so they can be filled up with a pathetic mains connection while there's no bus on stand, or is there a thumping great substation behind the bus station?
Posted by stuving at 11:07, 17th February 2022
For the Volvo 7900e (as in harrogate) the rooftop connector and the rather clunky "socket" it plugs into are of a proto-standard design called OppCharge. This appears to be led by ABB, but who makes the bits is less clear. The idea of promoting it as a standard is obviously that buyers don't want to be limited to a single supplier for new buses to use their chargers.
The draft standard says rather cheekily that there is no upper limit to the current (presumably referring to the standard's text, not to any real equipment). The voltage is in the nominal range 500-800, typically 700 or 750, and at the moment the maximum current is 600 A. ABB say their chargers can offer 150, 300, or 450 kW (i.e. 750V x 600A), citing ones in Brussels that can fully recharge Volvo electric hybrid buses in three to six minutes. But that's electric hybrids - with a diesel engine, so presumably a smaller battery.
The 7900e data sheet says its capacity can be 198, 264 or 330 kWh, and when using OppCharge is can accept 300 kW (or 150 kW DC or 11 kW AC via a plug-in lead). Obviously that's not going to do a complete charge from empty in six minutes! 300 kW at 400 V is roughly the total capacity of a typical substation circuit like mine. So it's reasonably easy to provide if a substation is nearby, otherwise you'll need an 11 kV feed, which could give a higher peak power.
Essentially, at the moment local buffering is a non-standard extra, and that's probably how VivaRail justify their otherwise rather implausible claim that their kit is first-of and patentable.
Posted by Celestial at 11:30, 17th February 2022
https://www.bbc.co.uk/news/av/business-48764903
An interesting report from a couple of years ago in Guildford, where a storage facility is used to draw charge from the grid during the day to avoid putting too much pressure on the local supply overnight.  That's only for 9 buses as well.
Posted by stuving at 12:29, 17th February 2022
I suspect that should be seen as more of a supply-side storage battery. There are a lot pf places, especially (but not only) more rural ones, where there is no spare supply capacity further up the distribution chain. That's not just an issue with very short high-power peaks: you'd need to shift the load out of the main daytime high load periods into the night.
The supply industry (DNOs, mainly) are trying to work out how to interact with customers' own storage, but also looking at having their own. A few years ago there was a research project here (with SEPD as DNO) on storage distributed in the local network (i.e. street corners), to even out the load.
All of these general-purpose storage units interface to AC mains via an inverter/converter. This kind of local reinforcement is compatible with a "normal" charge rate, but with a high cost if required to supply a really high power peak for a very fast charge and/or a big battery.
Posted by Electric train at 13:11, 17th February 2022
There is an over generation of renewable (solar mainly) in parts of the country, the problems are the DNO's do not always have the infrastructure to get this back to a TNO site.
Its more complex than just feeding it backwards. The UK power network was designed and engineered bulk generating plants cascading power down to the end user, the DNO's and TNO are working to get the infrastructure in place but it takes time and money.
The lineside storage is a bit akin to the days of steam and the water tanks which had a trickle feed into them but had the ability to "charge" the tender of a locomotive quickly.
I believe the Vivarail will be a contact system in the four foot, the original concept was for a short length ( 3 or 4 metres) of standard type third or fourth rail, neither NR or the ORR were keen on that on safety grounds.   The collection contacts will only be energised when the train is stopped in the right place and the brakes applied.
Charging at 300kW should not be an issue, if the previously stated 60 miles on a single charge is correct the unit will only need charging once it arrives at West Ealing from Reading TCD and then before it returns back to Reading TCD at the end of the day.
Posted by Celestial at 13:59, 17th February 2022
How does that work? If it's a half hourly service on a 5 mile return trip then it would need recharging at least every 6 hours. And surely better to get used to topping up every time so that there are as many opportunities as possible to ensure that the process is robust and works every time, even if time constrained.
Posted by TonyK at 20:26, 17th February 2022
The publicity does indeed suggest that it can be charged from solar panels, as can any battery. It looks good, and impresses the green lobby more than saying that it will be charged by electricity produced by a mixture of solar, wind (not solar wind), nuclear, coal and predominantly gas. The Cancun 3-car model could be powered by a solar array spread over 3.4ha according to the leaflet, a space which would probably see about 250 homes built on it were it to become available. I assume therefore that not only is it sunny in Cancun, but that land is cheap. Given the weather here, you would probably need most of Greenford covered in panels if you were to rely on that.
A 3-car train uses 9 kWh per kilometre. Greenford to West Ealing and back is 8 km, so the charge at each turn at the charging station would be in the order of 72 kWh. To do that in 10 minutes is quite an accomplishment - would that need a >400 kW charge? That seems far too high, so I assume I misunderstand the maths and/or physics.
Posted by paul7575 at 21:41, 17th February 2022
Looks about right to me, but for an accurate calculation you’d also have to look at the time spent decelerating and hence regenerating.
But if you think about it another way, if the short relatively lightweight unit draws about 100A on average from its supply when moving, you’d have to expect many times that during the much shorter charging phase.  If you round up the typical DC line voltage to 800V, then 500A would give you your 400kW.  Of course with their shoreside battery bank they can use a voltage of their own choosing, within reason.
So I think you’re in the right ballpark.
Paul
Posted by broadgage at 03:56, 18th February 2022
400 kw is in theory just about doable at UK standard supply of 415/433 volt three phase. It would however be a very "disturbing" load to add to the ordinary LV distribution system.
A dedicated substation supplied at 11 kv would probably be required. In a built up area, providing an extra substation is routine and probably cheaper than a local battery. The substation transformer and other equipment should last at least 50 years.
Any local battery would almost certainly need replacing many times in 50 years.
Another advantage of a dedicated substation is that the transformer may be of a suitable voltage for the fast charger, rather than incurring the capital cost and the losses in transforming 415/433 volts up the charging voltage.
Ideally fast charging should be available at BOTH ends of the line, but the on board battery capacity should enable a normal service to be operated with charging only available at one end. In case of transformer failure or local power cut.
There is also the NIMBY factor, I and many other people would oppose a large lithium battery near my home in case of accident. A local substation would no problem.
Posted by TonyK at 11:36, 18th February 2022
I agree, broadgage, although NIMBYs aside, I doubt that a large lithium battery in a built up area would get the nod from the planning people on safety grounds.
Thank you, Paul, for checking my homework.
Posted by stuving at 11:47, 18th February 2022
For all those desperate for another fix of facts and numbers, there's some in a long railengineer article dated October 2020 and a US presentation from April 2019. So these data can be added to the knowns list:
The DC bus voltage is 750 V, as it was before conversion. It's a very hard thing to alter, even if they have changed pretty much everything that connects to it, and of course it's essential to allow the option of third rail power.
The one thing I can't source explicitly is whether the new batteries are around 100 kWh capacity, like the initial ones. I think they are; I just can't work out where I saw that. But that's not all used; they are operated between 20% and 80% charge by agreement with Hoppecke. The bottom 20% is "get you home" reserve, but how can the top 20% be used as a reserve? My guess is that as they get older the upper limit of charge is allowed to go up to keep the same working range of 60 kWh.
The planned and/or guaranteed life of the batteries in service is seven years, after which they are either recycled by the makers at once, or used in a trackside buffer store for ten years first.
The fast charging is done per vehicle, and for this train that's two batteries each end. It has room for three, and for COP26 the third one was said to be "for resilience". Given the nature of that one-off deployment away from its home depot, this makes most sense if it was a spare that could be swapped in in any siding by moving a few cables or borrowing a forklift.
Exactly how many batteries are attached could have been altered, and indeed it could still change. There is room for three under each motor vehicle, and five under the central trailer. It may well be that the arrangements for using all of those, and for fast charging them, don't exist yet.
These new batteries need built-in cooling to cope with the "in excess of 1000 A" charging current per battery. So each fast charger needs to supply nearly 2 MW. I think that's within the range of what third rails and shoes can manage, though they do say they are using ceramic carbon shoes. Being static on the rail for several minutes may make the heat build-up worse, perhaps.
The objective to "fully replenish" a battery in 10 minutes, taken literally, but for 120 kW working capacity, requires 720 kW (a little under 1000 A). That has to be doubled for the vehicle. Balancing does waste charging current, and liberate heat, but it would be surprising if it added 10% to the charge current. But the numbers do match, more or less. Note that charging a battery needs a higher voltage, but the extra power isn't recoverable, so without extra information the numbers may not mean exactly what you think.
The US presentation includes a figure of 2 kWh per vehicle mile, which is a lot less than 9 kWh per km for three vehicles (nearly 5 kWh per vehicle mile). I wonder which is right? Either way, an 8 km round trip to Greenford would not take 10 minutes to replace. That's just as well, since keeping the current 2 tph with one train (as suggested by GWR) only allow 6 minutes total for both ends.
If the highest figures apply, and it used 80 kWh per round trip, it needs to put back 20 kWh per battery. In two minutes that needs 600 kW - which can be done, according to the data above.
Posted by Electric train at 13:27, 18th February 2022
In reality a traction unit dose not draw full power 100% of its journey, it will coast or "throttle" back for a large portion of its journey.   It will sit on its charging point and the unit software will decide what charge rate to adopt.
The project team will almost certainly have talked to the local DNO for a supply.
Another method to derive the power would be a 25kV transformer in theory 6 MW is posible in reality an aux supply transformer of 1 or 2MW have been used on the National system the output voltage what every you chose, it could feed a SFC to produce 3 phase from the single phase input
Posted by eXPassenger at 18:29, 18th February 2022
I imagine the 80% is too allow for regenerative braking, if for example the unit has been charged at the top of a hill.
Posted by stuving at 19:07, 18th February 2022
I think a diesel hybrid might need to do that, but it seems a bit too much to allow for a pure electric train.
Going back to those numbers, 80 kWh 33 times per 24 hours averages out at 110 kW. That (plus a bit for losses - say 120-150 kW) is quite a chunky "trickle". It could be supplied at 400 V three phase from a large enough commercial installation. Whether a small station like West Ealing would have anything like that available is another matter. NR may be able to do things differently, especially at the carriage sidings. If the power used is the lower of those two figures, say 70 kW, it's obviously easier to source.
That does not make use of the full battery range, of course. If it can do five trips (or ten if that's right) without replacing that charge from the buffer store, that  much might instead be done overnight and from another supply.
Vivvarail's marketing emphasises not needing a lot of heavy infrastructure, and even the "pop-up" electric train service needing a big box of batteries dumped in each station car park and little else.
Posted by Celestial at 20:39, 18th February 2022
I would assume that is taken into account in coming up with the 62 mile range quoted, based on an assumed typical cycle of acceleration, braking and coasting.
Posted by Surrey 455 at 10:11, 19th February 2022
I see that the distance from West Ealing to Reading depot is approx 29 miles as the crow flies. If the train will be stored at Reading overnight, presumably it will need a top up before it departs for West Ealing in the morning otherwise it will be close to or over it's 62 mile range.
Posted by grahame at 10:18, 19th February 2022
Does the first run of the day still start from Paddington and the final run end there?
Posted by IndustryInsider at 10:27, 19th February 2022
I believe the unit is to be stabled and serviced in West Ealing sidings with light maintenance being carried out in the Plasser works next door, so no lengthy runs required.  Probably one of the reasons why the Greenford route was chosen for the trial.
Posted by ChrisB at 18:53, 10th March 2022
Update from a meeting with GWR this afternoon.
The unit will charge to full in just three minutes at West Ealing on each return there.
Posted by Electric train at 19:02, 10th March 2022
That's a lot of Joules (one kilowatt-hour is equivalent to 3.6 megajoule)
Posted by ChrisB at 19:09, 10th March 2022
That's what I thought & asked for confirmation that I'd heard correctly.
Posted by stuving at 19:19, 10th March 2022
Did they how empty that was from? My guesstimate upthread was that it would have used a sixth of a batteryfull, and replacing that would take a couple of minutes.
Posted by ChrisB at 19:22, 10th March 2022
no, that wasn't mentioned/asked
Posted by broadgage at 05:57, 11th March 2022
I doubt that charging from empty in three minutes would be possible.
I presume that they mean replacing the amount of charge used in the previous journey, which is still impressive.
Posted by Electric train at 06:42, 11th March 2022
Based on tests I have been involved in at IPH Berlin ( https://www.cesi.it/about-us/overview/iph-gmbh/ ) testing third rail shoe contact current capacity when static.   Once you get over about 4kA (4000A) at 750V DC arcing and burning starts which is not a problem for a train if it starts to move as the contact surfaces scrub.  To get over the 4kA DC limit the downward pressure of the shoe gear needs to be increased but you get to the point of the mechanical limit of the force required.
Of course the transfer may be AC not sure the ORR would be keen on an RMS Voltage above 750V AC.  Another option could be high frequency AC but then there are RFI issues and the risk of shock from exposed conductors.
It will be interesting to see what the charging system will be.
Posted by broadgage at 15:53, 12th March 2022
For fast charging, perhaps a short length of 25 KV overhead might be simpler.
Out of reach, so can be left live all the time.
Much lower current due to the higher voltage.
Can be of a cheap and simple design as not intended to be used at significant speed.
Multiple pantographs are possible, in order to pick up enough current.
Another advantage is that if needs change, the trains can re deployed to other routes that are partly electrified.
Posted by IndustryInsider at 15:59, 12th March 2022
Won’t they be using their modified D78 stock?  In other words no pantograph fitted, but fitted with DC shoe gear?
Posted by ChrisB at 17:45, 12th March 2022
I understand thst is so
Posted by stuving at 20:14, 12th March 2022
Of course it is - as announced by Vivarail! The relevant story on their Fast Charge system is hard to find, for want of links, and some the other details are elsewhere. But it does include:
With assistance from the UK’s Department for Transport and Network Rail, Fast Charge’s trial is due to start in early 2022 on the West Ealing-Greenford line in London, after that it will be fully approved for use on the network for all types of battery train.
According to Vivarail, the Fast Charge application is quite simple. Lengths of conductor rail sit between the running rails. Beside the track is a container full of batteries (the company aims to use second-hand batteries in power storage banks, possibly from the automotive industry). All the train has to do is pull to a stop in its normal place. At that point, and without any need for the driver to do anything, a high current shoegear connects to the conductor rail.
So they are trying to prove this Fast Charge approach and the hardware. They reckon the buffer battery at trackside is worthwhile to avoid a high-power mains feed. The fast transfer of energy from it to the onboard batteries is well above what a small train like this would normally need, by AC or DC. But clearly adding AC would cost a lot at any power level, while at DC the current goes straight into the batteries. The electronics to control it and match voltages can be offboard, apart from the cells' charge controllers that are built into the batteries.
They talk about current levels of 1 kA or a low multiple of that, and that agrees with what ET said above. They also mention ceramic shoes to cope with the heat, and I don't suppose they will use standard conductor rails either for the same reason.
So it's all been planned out and, apparently, ready to go ... soon. Of course getting it all up and running on schedule is the hard bit, and the suppliers of both new and rebuilt trains have now got a truly lousy reputation for that.
Posted by stuving at 09:54, 15th March 2022
There's now a youtube video of a presentation by Vivarail on Fast Charge, recorded at a PWI* on-line. It concentrates on the safety case, perhaps because of the audience, which leads to the impression it will have a lot of failures due to false alarms. But I can see that for their programme to do the Greenford trial, getting ORR and NR approvals was probably the biggest activity and highest identified risk.
The numbers are not quite the ones I got from their previous presentations: now 300 kWh of batteries per DM (and 1 MWh per Trackside Charge Unit). The transfer is of 1 kA at 800 V, and is expected to replace 30-50 kWh per train used in a 5-mile round trip in three minutes. So the control system design has dictated by the need to charge automatically for as long as possible during the turn-round, and without the driver stopping to do anything special.
One those numbers there is easily enough capacity to cope, but then there's no mention of "losses" or "efficiency". You just can't shovel all those kWh around at that rate without a lot of them escaping!
*Permanent Way Institution
Posted by IndustryInsider at 10:40, 15th March 2022
That's a relief.  I wouldn't want to be the driver who had his train cancelled because he forgot to plug it in the the charger...a headline makers dream!
Posted by Electric train at 09:26, 16th March 2022
The use of carbon ceramic make sense especially as it is static current collection also the shoe look larger than normal travelling shoes.  The key as always with electrical connections the greater the current the larger the surface area required the surface area can be reduced by contact pressure, there is a limit of when you start to lift the train
This has been in discussion with RSSB, ORR and NR for at least 5 years
Posted by grahame at 16:49, 5th July 2022
Any news on when the trial start?  Trains in public service?
Posted by stuving at 17:45, 5th July 2022
"Later this year", according to Vivarail. Were you expecting anything more specific?
Posted by stuving at 13:16, 16th July 2022
Eversholt have announced that they are getting Vivarail to add some batteries to their "Renatus" modernised Class 321 EMUs. From their news page:
Eversholt Rail and Vivarail to develop Class 321 BEMU
Eversholt Rail and Vivarail have signed an agreement aimed at developing battery power – and range extension – to the Class 321 ‘Renatus’ fleet.
The 30 unit ‘Renatus’ fleet is a product of £65m investment in AC traction, air conditioning and upgraded interior.  Completed in 2019, it provides a high-quality passenger experience, proven reliability in intensive operations and is widely compatible on the UK network. This fleet is currently operating on the Greater Anglia network until the introduction of their new trains is completed.
Eversholt Rail and Vivarail are committed to supporting the UK Government’s ambition to decarbonise its rail sector by 2050, and the Scottish Government’s objective of doing so by 2035. This proven and reliable fleet is an excellent fit in terms of characteristics, fleet size and availability for conversion to a Battery Electric Multiple Unit (BEMU). Vivarail, as the designers and manufacturers of the UK’s only battery and hybrid trains currently in passenger service are well positioned to progress this development.
We will be working together to develop a design to integrate battery technology to provide between 20 to 30 miles of self-propulsion. Enabling the fleet to operate on non-electrified or partly electrified routes would offer the opportunity to increase the range of modern, low-carbon options to accommodate passenger demand; to enable fleet cascades; to improve the passenger experience; and to bring air quality and decarbonisation benefits to local areas.
Through discussion with train operators, regional sponsors and DfT a number of opportunities have been identified across the network. The technical and safety case development will continue throughout 2022 and in parallel Eversholt Rail and Vivarail will be engaging with the market to assess the viability of potential routes. This will inform the decision on further investment in the fleet.
Since this is the same traction package as on the 455s, it must use 750V as its intermediate DC voltage. So the batteries and linking electronics can be the same as on the 230s, or a bit beefed up.
What applications do they have their eye on? Much the same as for the ones based on the D78s, I guess, but offering a real train?
Posted by stuving at 13:38, 16th July 2022
One thing that's implied, but not mentioned at all in that publicity, is that presumably this involves charging from on-board traction power. That would be a new bit of Vivarail's kit of parts, but one you could have guessed they'd be working on. It leaves open the question of whether shore power or a charger would be needed at the far end of the line.
Posted by bobm at 14:15, 16th July 2022
Don’t know if it’s connected but the Greenford Branch is closed over the August Bank Holiday weekend and the first two Saturdays in September.  (There are no Sunday services anyway).
Posted by ChrisB at 10:46, 17th February 2023
Bringing this thread back to life owing to new developments....
From Today's Railways, on twitter
The West Ealing-Greenford fast-charge trial is to go ahead after @GWRHelp agreed to buy “intellectual property, rolling stock & equipment” from the in-administration Vivarail. 230001 thus transfers to GWR ownership. GWR has also employed 9 former Vivarail staff to support the trials
Posted by broadgage at 12:05, 17th February 2023
Glad to hear that this project is still going ahead. Battery power is IMHO the future for lines that cant be electrified affordably.
I hope that the new trains enjoy greater success than some other new types.
Posted by johnneyw at 12:37, 17th February 2023
Encouraging, interesting and perhaps a little surprising given that I seem to recall Mark Hopwood being somewhat dismissive of the prospects of GWR using Vivarail D-Train a few years ago.  I suppose that it might have been because the battery power version was a less proven option then.
Posted by ChrisB at 12:39, 17th February 2023
Commercial opportunities with other TOCs for the supply of maintenance etc.?
Posted by paul7575 at 13:31, 17th February 2023
The biggest problem with the Bedford - Bletchley 230 units, and presumably the TfW version, was the diesel power pack reliability.  The DC only SWR class 484 version is already maintained in house, hopefully spares provision was included.
So although without any firm evidence, I’d expect that the diesel power packs are completely irrelevant to GWR’s aims for the trial and won’t have been included in the deal.
PS
Roger Ford has also summarised it in his e-mail preview that just arrived:
The good news, breaking just as I was about to send out e-Preview, is that GWR has agreed contracts to buy the intellectual property (IP), rolling stock and equipment for the high-performance battery and Fast-Charge technology which was due to be tested on the Greenford Branch.
GWR has also employed nine former Vivarail staff to support the trials and project development.
The IP acquired is essentially the patents protecting the Fast-Charge system.
Paul
Posted by TonyK at 15:03, 17th February 2023
Your view isn't shared by the authors of the Regional Traction Decarbonisation Strategy. They give amber to battery power for passenger transport to 75 mph, read for 100 mph, but green for hydrogen in both cases. That doesn't make sense to me unless they are happy with the steam reforming of hydrogen. Even then, battery would win because we already have an infrastructure for that. Like johnneyw, I am surprised, given Mark Hopwood's antipathy towards the idea in the past. Possibilities for his volte-face (should it be Volt here?) include an improvement in the technology since Vivarail dropped the viva, a Damascene conversion on the road to West Ealing, an opportunity to greenwash something else, or a jolly good price for something that might come in handy in the future.
I don't see either battery or hydrogen as having a big future on railways. It will be OHLE, diesel, or closure.
Posted by ChrisB at 15:17, 17th February 2023
Battery beats diesel though, right?
So a very reasonable way of removing diesel where costs of electrifying plus the time needed are deemed excessive?
Posted by TonyK at 16:24, 17th February 2023
Battery beats diesel. I have a nasty feeling that the laws of physics will beat battery in the real  world unless there is a diesel engine just in case. That will make it a hybrid, like the ones sold by the Indulgence Specialists, unbeloved by broadgage with good reason.
Posted by Bmblbzzz at 18:02, 17th February 2023
Battery technology is improving, and apparently there is hope for types based on iron, avoiding the problem of needing rare minerals. But that's still in the future...
Posted by eightonedee at 19:32, 17th February 2023
There also seems to be some encouraging developments in developing sodium-ion batteries instead of lithium-ion. However it seems still to be early days, and (if I understand what I have read so far correctly) advantages of not being reliant on China for lithium, fewer safety issues, faster charging and longer life are offset to a degree by lower energy storage.
There is however an issue that no-one seems to have addressed - a small fleet of battery units operating on a small number of branches surely reduces flexibility, and means that if a unit fails it is going to be difficult to procure a replacement from a limited pool of units. More cost-effective means of electrification of branch lines may well be more cost effective in the long run.
Posted by TonyK at 21:19, 17th February 2023
Jam tomorrow then, although that was probably said of the now ubiquitous Lithium ion battery for the first 30 years or so of development.
Early days indeed, although sodium ion batteries were being looked into some years ago, until it became clear that Lithium was going to be the winner in the rechargeable battery race. Sodium is back in contention because of cost and availability rather than any chance of replacing the usurper. From what little I have read, it looks like weight would preclude use for transport applications, although as a static power source it seems potentially useful. Not just iron and sodium  - I get emails announcing, with a fanfare of trumpets or roll of drums, some new idea involving aluminium or sulphur, both of which benefit on the electron count compared to lithium or sodium. All need a lot of playing with before any real result happens or the idea fades. Regime change in batteries can be as sudden and total as in the totalitarian wing of politics, or in matters like light bulbs. The new idea becomes affordable and safe with big advantages over the old, and old one is toast in the twinkling of an eye. The development is slow, though. The period between the start of serious research into a workable lithium ion battery and its near total domination over other small rechargeable types almost exactly mirrored the period from the introduction of VHS and Betamax to the almost complete demise of tape-based recording of video in the home.
That's a fascinating topic for deeper discussion on another thread, but does lead me nicely back to GWR's bargain purchase. Imagine that the research into how to optimise current battery technology continued under the aegis of GWR, with a select few of Vivarail's TUPE'd boffins working both in the laboratory and field, emerging with singed eyebrows and ticked boxes on worn clipboards occasionally. It is entirely possible than in a few years time they would come up with a workable solution that would become obsolete during the ceremony to roll out the 100th train produced to their design. For this reason, I can't see GWR pulling out every stop to bring the battery train into service. It may be worth carrying on slowly, maybe evaluating new developments to sort wheat from chaff rather than doing their own research. Intellectual property can sit quietly in a safe in case someone suddenly wants to buy or lease it. I hope I'm wrong, but there probably won't be much news here in the foreseeable.
Posted by Electric train at 07:43, 18th February 2023
I think its a bit wider than just the 'D' Stock. GWR has bought the intellectual property rights to the high-performance battery and fast charging technology, this is the part that is deployable to other rolling stock types, the 'D' Stock could be seen as the test bed.
I can seen GWR partnering with a train builder for new rolling stock and or train builders buying a licence to use the technology
Posted by TonyK at 09:52, 18th February 2023
I agree completely. Whatever battery technology is decided upon, they will still hopefully make a living from licensing the charger idea. They have, to paraphrase a music publisher, bought the real estate. That presupposes that there is something discrete about the design that couldn't be assembled by any Tom, Dick or Isambard from parts available already.
Posted by ellendune at 10:03, 18th February 2023
I wonder has First Group Bought it or is it a franchise asset - essentially DfT buying it?
Posted by stuving at 10:13, 18th February 2023
I was thinking that too. There was a press release from First group, which I think is exactly the text from Twitter quoted above - so it's explicitly GWR that will be the owner. DfT is mentioned, but then they always were a "partner" in the trails programme. As a TOC, GWR must have had DfT approval, but not necessarily any money, do do this. I guess there will be agreements between DfT, GWR, and First covering who ends up with what. Of course the "what" may not have any value by next year anyway.
Posted by Bmblbzzz at 10:45, 18th February 2023
Battery power might be useful as an addition to OHLE in two circumstances:
  • Providing limp-home traction and running heating, air conditioning and lighting on passenger trains in case of OHLE failure
  • For low-speed, short-distance freight manoeuvres in places where it's impractical to install OHLE for other reasons, such as ports and quarries, where waggons need to be loaded from above
Obviously only the first applies directly to GWR, and it might turn out that for the second, a small fleet of diesel shunters is more practical (but dirtier).
Posted by ChrisB at 11:15, 18th February 2023
The VivaRail staff won't have been TUPE-D, because VivaRail was already in administration & therefore those staff already made redundant.
Also, I don't see why GWR would have needed DfT approval to buy those assets. Surely a risk taken completely by GWR needs no approval. From *their* ultimate owners (FirstGroup) very likely though.
Posted by grahame at 12:34, 18th February 2023
As I read it, it could be a pretty complete purchase. I wonder if this means we might get D76 stock on the Severn Beach line.  Just imagine the political gains - "We have brought the underground to Bristol"
Posted by stuving at 12:43, 18th February 2023
DfT have huge powers over a TOC, so GWR will certainly need to agree this with them. The contract gives DfT explicit rights of approval when GWR (1) buy a train or (2) take on employees or workers. And despite this not being a franchise agreement, there is still a load of stuff about assets, franchise assets, primary franchise assets, etc. One clause gives the SoS the right to designate any asset as a franchise asset. Nanomanagement!
Posted by TonyK at 21:27, 18th February 2023
I am obliged.
I am between spectacles, and read that as "might get D76 stuck on the Severn Beach Line". A prophecy if I ever saw one coming.
Posted by johnneyw at 23:12, 8th April 2023
The ongoing Vivarail saga doesn't seem to have had an adverse impact on the introduction of hybrid Class 230s for Transport for Wales as the link below would seem to confirm.
https://news.tfw.wales/news/uks-first-hybrid-train-enters-service-on-borderlands-line
Posted by TonyK at 18:43, 10th April 2023
Bit odd though. RTT shows most services between Bidston and Wrexham as being bustituted. On 6 April, 230010 arrived at Wrexham 0658 from Birkenhead EMU depot, before forming 2F50, the 0731 to Bidston. The return 0833 to Bidston leaves 7L, and isn't shown as being 230010 like the earlier service is. Whatever ran the service arrived at Wrexham at 0941, 9L, and the return service is cancelled out of Central, starting from Wrexham General at 0942, presumably not the same train. It looks like the train that arrived at Wrexham at 0941 returned empty to Bidston, leaving at 1209. The coming week's actual trains on the route are marked as DMUs, then no service at all in w/c 17 April. Only from 25 April do the D-trains start to form the day's services. I can't tell whether it was issues with 230010 or other problems unrelated, but it doesn't seem to have been an entirely smooth entry into service, more like a tentative trip or two for the papers to start with.
Posted by grahame at 17:22, 15th April 2023
From The BBC
A train route suspended after a maintenance firm went into administration will not resume services until the autumn, a rail firm has said.
The Marston Vale Line, which has 12 stations between Bedford and Bletchley, has been out of action since December.
Operator, London Northwestern Railway (LNR) said new trains was expected in June but drivers needed training.
A rail replacement bus service, in place since Vivarail's collapse, will continue to operate in the meantime.
Posted by grahame at 15:38, 14th May 2023
The Daily Mail seems to think this is "Exclusive" ...
Mind the SCRAP! 1970s Tube trains are saved from the junkyard to be put back in service as London overground trains
EXCLUSIVE: Vivarail paid £2M for 150 District Line trains which were retired
Great Western Rail bought Vivarail out of liquidation to continue the plan
Posted by anthony215 at 09:28, 7th February 2024
230001 is now out testing on the mainline. Hopefully won't be too long before it moves to Reading.
https://youtu.be/dQ7EtCkGffc?si=gwgmE0teT1PLKNy6
Posted by PrestburyRoad at 09:47, 7th February 2024
Oh the nostalgic sound of those motors.  I'm used to hearing it in subterranean London and now my brain feels pleasantly disoriented when I hear it pictured in rural Gloucestershire.
I guess the higher-pitched sound is something to do with the new control equipment needed for the battery power source.
Posted by stuving at 10:59, 7th February 2024
It's the inverters or motor drives, now a part of all train designs. Some of them sing, some warble, these do rather scream in chorus.
Posted by anthony215 at 18:09, 7th February 2024
230001 to make its way to Reading on Friday 16th February.  Testing showing its managing 70 miles before needing charging although batteries Re still said to have plenty of energy lefy
Posted by DaveHarries at 00:03, 8th February 2024
230001 to make its way to Reading on Friday 16th February.  Testing showing its managing 70 miles before needing charging although batteries Re still said to have plenty of energy left
I would be surprised if it didn't have regenerative braking: if it doesn't then I wonder why not.
Dave
Posted by stuving at 00:29, 8th February 2024
Dave
You can hear it does. As the train slows for the stop, the inverters are running until the last few seconds, then cut out abruptly. From what I recall about it, running the inverters and supplying a field to the motors uses power, even if the field is in step with the motor and not driving nor braking it. At very low speeds the power available from regeneration is too low to make this worthwhile; also the braking force reduces with speed so friction braking has to be used right at the end anyway.
But the energy recovered isn't going to extend the battery life by much in any case.
Posted by johnneyw at 12:04, 8th February 2024
Railadvent have a bit about the battery train's testing in west London this spring.  Link below:
https://www-railadvent-co-uk.cdn.ampproject.org/v/s/www.railadvent.co.uk/2024/02/battery-trains-to-be-tested-in-west-london-this-spring.html/amp?amp_gsa=1&amp_js_v=a9&usqp=mq331AQGsAEggAID#amp_tf=From%20%251%24s&aoh=17073910041782&csi=0&referrer=https%3A%2F%2Fwww.google.com&ampshare=https%3A%2F%2Fwww.railadvent.co.uk%2F2024%2F02%2Fbattery-trains-to-be-tested-in-west-london-this-spring.html
Posted by anthony215 at 23:34, 15th February 2024
Paths on realtime trains for 230001 to make its way to Reading depot tomorrow.
https://www.realtimetrains.co.uk/servic ... 6/detailed
Theres a lot of eyes watching this trial.all going to plan batterybtrains could appear on a few of GWR's branch lines Chiltern are watching this trial too
Posted by GBM at 06:09, 16th February 2024
Link not working for me!
Posted by Ollie at 06:25, 16th February 2024
This is the one you want https://www.realtimetrains.co.uk/service/gb-nr:K00487/2024-02-16/detailed
Posted by BBM at 12:02, 16th February 2024
Tim Dunn is aboard and reporting live on X (link to thread):
https://twitter.com/MrTimDunn/status/1758447007469895732
Posted by johnneyw at 13:45, 16th February 2024
Theres a lot of eyes watching this trial.all going to plan batterybtrains could appear on a few of GWR's branch lines.....
I'm wondering if any of those are with Metrowest in mind.
Posted by Witham Bobby at 15:15, 16th February 2024
He's extremely fortunate to have found a workable 5G (or even 1G) signal in this neck of the woods, with which to post his video
Posted by grahame at 20:08, 16th February 2024
Remind my why the West Ealing to Greenford service is not overground?
Or perhaps The Siemens Line - https://www.siemens.com/global/en/company/about/history/stories/on-track.html
Posted by anthony215 at 21:00, 16th February 2024
I think it could go on Severn beach services if it just shuttled between Bristol TM and Severn Beach etc.
Certainly the figures from today have surprised everyone unit did the trip just using 45% of the  charge on the batteries the engineers saying it could have done 120 miles between charges. Well have to see how it performs on tje Greenford branch now. No doubt all going to plan well see more 230s on the other branches in the Thames Valley  possibly other areas too.
Wont be surprised to see other TOCs consider it
Posted by TonyK at 21:27, 16th February 2024
It was of course a trip with few passengers and no station stops, taking two hours to travel 70 miles. My own EV experience shows that more speed equals less range, and trundling along an empty M5 at 35 mph for 2 hours would probably give me half my car's claimed range again. It is hardly a real-life test in service conditions, but I am still impressed. The technology works, the train moved when asked, and if it only manages 70 miles between charges in real life, that isn't bad. Subject to the fast recharging kit doing what it says on the tin. I think we are still in the early days of battery development. You can't beat those pesky laws of physics, but I am sure big improvements will arrive before too long. This certainly looks a bright idea.
Posted by paul7575 at 21:50, 16th February 2024
It was looked at a few years ago in a route study, (I forget which one), with a view to LO or even Chiltern taking it over. Neither option made much sense, especially since with the GOB line being recently wired LO were not interested in reintroducing a couple of DMUs to their fleet. In Chiltern’s case it was apparently a possibility, but would still have meant awkward empty stock running with no real advantage over GWR operationally.
Paul
Posted by johnneyw at 23:25, 16th February 2024
Wasn't a Severn Beach - Portishead route once on the cards for Metrowest?  A charging point a each end would work nicely.
