Problems with IET trains from April 2021
24.4.2025 (Thursday) 11:59 - All running AOK
Posted by eightonedee at 18:32, 27th April 2021
Dipping into the BBC Local News revealed the following-
https://www.bbc.co.uk/news/uk-england-56902528
Perhaps some of our industry insiders have more information? It's just as well this has come to light (and hopefully will be resolved) in current circumstances when traffic is light.
Re: Problems with IET trains from April 2021
Posted by IndustryInsider at 18:58, 27th April 2021
It doesn't sound like anything more than you might expect from a new train.  A bit more detail here, with poster Clarence Yard explaining the situation very well (as always) on the second page...
https://www.railforums.co.uk/threads/gwr-withdraw-some-800s-due-to-cracks-in-yaw-damper-bolsters.216705/
Posted by broadgage at 20:19, 27th April 2021
If this was an isolated problem,  I would be at least somewhat forgiving.
However taken together with all the other faults and failures, these are starting to look pretty rubbish.
Failure to couple and uncouple reliably, despite this being an "essential requirement"
Failure to cope with the waves at Dawlish, also an "essential requirement"
Overheating in hot weather.
Poor ride.
Unreliable toilets.
Unreliable reservations.
Poor quality trim and fittings.
And a general failure to meet the required levels of availability that resulted in frequent short formations, forgotten about  with the reduced passenger numbers in the pandemic. But no doubt to return.
The poor standards of passenger comfort and facilities are arguably due to the TOC policy of "what downgrades can we get away with" and not Hitachi's fault, but still gives a poor impression.
Posted by Celestial at 20:58, 27th April 2021
Poor ride.
Unreliable toilets.
The poor standards of passenger comfort and facilities are arguably due to the TOC policy of "what...
For one moment I thought I was going to get through a broadgage post on IETs without the inevitable word appearing. You teased me until almost the end.
Posted by TonyN at 21:37, 27th April 2021
Having read the posts on railforums I am reminded that every time I travel over the Cotswold line on an IET there are some loud thumping noises while traversing the Paxford curves between Campden tunnel and Moreton in Marsh.
Posted by broadgage at 23:50, 27th April 2021
Which word ? I avoided calling them DMUs, out of deference to those who state that they are not REALLY DMUs despite being powered by underfloor engines.
Neither did I mention buffets, as the lack thereof is not really Hitachi's fault.
Did not even mention the failed trolley service which IS PARTLY Hitachi's fault, since they designed the sloping floors, and they made the "greatly improved" trolleys. The steeply sloping floors, and "wonky wheels" on the trolleys were frequently given as reasons for no trolley/static trolley/hidden trolley. Such factors do not help, but I feel that GWR are not serious about trolley provision, and regard this as a temporary or interim measure between a proper buffet and the longer term aim of nothing.(as on SWT, and others)
Did not even criticise the hard seats or lack of gangways.
Posted by TaplowGreen at 06:55, 28th April 2021
That's most of the broadgage bingo card ticked off and it's not yet 0700!  An omen for a productive day?
Posted by eightf48544 at 14:22, 28th April 2021
As the wellknown quote goes:
" 'To lose one set of yaw dampers (CAF) may be regarded as a misfortune, to lose two
(Hitachi) looks like carelessness."
Possibly a combination of inadequate design to cope with poor track as mentioned by TonyM
Posted by broadgage at 16:18, 28th April 2021
Also concerning in my view is that these failures have occurred on what are still relatively new trains.
Fatigue failures have two main causes, poor design and a certain inevitability after the planned service life.
Good design consists largely of avoiding "stress raisers" such as sudden changes of shape or cross section in highly stressed components. For this reason the windows in aircraft and ships are either circular, or rectangular with rounded corners. A rectangular design with sharp corners would be liable to stress fractures at the corners. Likewise highly stressed engine components are designed without sharp corners. A narrow piston rod is connected to the wide piston by a curved formation not a straight transition from rod to disc, which would be liable to stress fractures.
Hitachi engineers are no doubt aware of this, it is basic engineering.
The other part of good design is selection of the correct materials, strong but not too hard/brittle. This is a bit more complex, and it is possible that unsuitable material was used, either wrongly specified, or correctly specified but the actual material used was different, perhaps in some subtle way that was not obvious.
And of course good design includes designing for the stresses to which a component will be subjected in its life. That includes rather a lot of unknowns.
Eventual fatigue failure is almost inevitable in highly stressed components, that is why intensively used aircraft have a limited life, determined in either flight hours, or by number of take off cycles. Life could be extended almost indefinitely by stronger construction, but that would render the machine too heavy to fly economically.
Fatigue failure after say 35 years, on a train designed to last 27.5 years would be nothing remarkable.
Fatigue failure only about 10% into the design life is much more concerning.
It suggests either poor design, defective materials, or the stresses being so badly under estimated that failure occurred very early in the planned life.
Posted by Lee at 17:03, 28th April 2021
House!
Posted by Electric train at 17:16, 28th April 2021
The much exulted Mark 3 coach (Mk3) and High Speed Train (HST) power cars suffered from cracks in bogie components right from the early days in the mid 1970's.  The worse failure was the brake disks on the power cars.
Nothing new, remember these trains many more miles in a week than almost any other form of land vehicle,
Edit: VickiS - Clarifying Acronyms
Posted by IndustryInsider at 17:27, 28th April 2021
This sort of thing happens with most new train designs as I said.  In fact it was a similar problem on a new train from a different manufacturer which prompted the check that led to its discovery on a small number of units.
I expect regular inspections, maintenance and an eventual modification will mean this is soon forgotten about by everyone...except Broadgage.
Posted by broadgage at 18:08, 28th April 2021
Even I will forgive and maybe forget, provided this does not become a frequently recurring or long ongoing problem.
Posted by Incider at 07:05, 1st May 2021
Hitachi don’t make the trolleys…..
Posted by broadgage at 08:51, 1st May 2021
But presumably Hitachi specified or supplied the trolleys ? They have an Hitachi asset number affixed, or did when I last looked.
Posted by stuving at 09:41, 1st May 2021
I'm not sure they did. Both the Master Availability and Reliability Agreement  (MARA) and Train Availability and Reliability Agreement (TARA) as published (dated 2014) include "Level 4 catering trolley" in their definition of terms under catering equipment, but neither mentions therm in the text. At that stage (after Agility was given a contract, but before the interior design was fixed) "trolley storage facilities" was listed as one of the subjects to be dealt with by "consultation with the user population" under "progressive design assurance".
It looks as if it became clear later on that the trolleys could only be sensibly kept with the trains in the depots, so were best maintained by the Train Service Provider (TSP) (Agility). The way the contracts are set up that means the Train Service Provider(TSP) has to own them, but not necessarily decide their specification. However, they don't appear on the (very long) list of spares to be held by the Train Service Provider (TSP), so I assume this was a late change and covered by a contract change not in the public version.
Posted by Lee at 10:38, 1st May 2021
I'm not sure they did. Both the MARA and TARA as published (dated 2014) include "Level 4 catering trolley" in their definition of terms under catering equipment, but neither mentions therm in the text. At that stage (after Agility was given a contract, but before the interior design was fixed) "trolley storage facilities" was listed as one of the subjects to be dealt with by "consultation with the user population" under "progressive design assurance".
It looks as if it became clear later on that the trolleys could only be sensibly kept with the trains in the depots, so were best maintained by the TSP (Agility). The way the contracts are set up that means the TSP has to own them, but not necessarily decide their specification. However, they don't appear on the (very long) list of spares to be held by the TSP, so I assume this was a late change and covered by a contract change not in the public version.
Before VickiS has reads this and has a coronary, MARA stands for "Master Availability and Reliability Agreement", TARA stands for "Train Availability and Reliability Agreement" and TSP stands for "Train Service Provider"
Hope that clarifies things more than my Marsh Barton post did...although I must give them bonus points for the use of "consultation with the user population" under "progressive design assurance" - Outstanding!
Posted by stuving at 11:26, 1st May 2021
Of course the words chosen for the name of something, abbreviated or not, can be a poor guide to what it really is or does - as you hint there. The MARA is 731 pages of ... stuff (to be credited to Hogan Lovells International LLP), so there's plenty of room for things to hide until you search explicitly for them or stumble across them. For example:
Seats are included under progressive design assurance, with each mention worded as "seat design, including comfort". But there are more words about the "Seat Weight Model":
... the TSP will develop the seats for the Sets in a way that allows the Secretary of State to have full visibility of the weight issues relating to seats (which shall involve, as a minimum, the TSP providing the Secretary of State with a Seat Weight Model which shall be updated on a periodic basis as agreed by the parties to reflect the emerging Design), provided that in finalising the design of the seats, the TSP shall also comply with the other Requirements and the requirements of Applicable Laws and Standards and Applicable Derogations.
Seats also get a mention under "Glass Case Standards". What's one of them? (There is a definition provided, fortunately.)
Posted by TonyK at 14:37, 1st May 2021
Before we lose sight of the original matter, have they been fixed yet?
Posted by stuving at 16:50, 1st May 2021
I've not seen any news. perhaps a more important question now is how many others have been found on inspection across all fleets. But replacing a few bogies should have been quite possible.
The Master Availability and Reliability Agreement (MARA) lists "major incident spares", essentially parts of the carriage bodies only likely to be bent by a collision, and "damage and vandalism spares", essentially running gear, some of them  likely to be broken by hitting things on the track or by passenger misbehaviour. However, the list also covers items needed for routine maintenance, where performance is the Train Service Provider's (TSP)'s responsibility. It may be hard to split that list on a "who pays" basis.
Either way, the level of spares holding should be a good guide to how many such things can be found at once. The parts' names, on the other hand, are hard to interpret in some cases without a labelled diagram. The list is is no logical order, and names short, so where bits go is ambiguous (e.g. is the "Lateral Bump Stop Rubber" part of a toilet door or a bogie?). These look relevant, or in some cases obvious things that may give some context:
Pantograph Complete             10
Vacuum Circuit Breaker (VCB)  5
Main Transformer                  2
Induction Traction Motor        6
Bogie Truck Assembly (Motor)  8
Bogie Frame                         4
Air Spring                            8
Traction Link                        6
Anti-Rolling Equipment           8
Wheel Set (M)                     16
Bogie Truck Assembly (Trailer) 6
Bogie Frame                         4
Wheel Set (T)                      16
Carbon Strip                        80
Wiper Blade With Rubber        80
Yaw Damper                        40
Lateral Damper                     40
Lateral Bump Stop Rubber      10
Brake Pad                           170
Primary Vertical Damper         40
That list is for the original GWR 800/801 fleet, and appears to be subject to revision at the contract date. But it does suggest that enough bogies could be found quickly, unless they are all trailer bogies (I don't think they can be). Assuming this is still a production item, new castings to replace the cracked ones should also be available on a slightly longer timescale.
Posted by VickiS at 23:06, 1st May 2021
Thank you very much Lee for that explenation! Much Apprechiated!
Posted by TonyK at 08:50, 3rd May 2021
So there are enough bogies and yaw dampers in stock to hopefully fix up a couple of trains until more can be brought in from Japan, if that is where they are made, or cast somewhere more local. This could be a very short term problem, provided a way of stopping it happening again has been found.
Posted by brooklea at 09:19, 3rd May 2021
I think it’s probably worth pointing out that the fix for this fault is not changing bogies or yaw dampers, as a few posts above seem to be suggesting. The cracks that have been discovered are on the body shells in the area where the yaw damper brackets are welded to the body shell
Some photos and reporting can be found on the rail business UK website (free registration maybe required to access the full article) https://www.railwaygazette.com/uk/fatigue-cracks-sideline-gwr-class-800s/59012.article
Posted by Electric train at 10:26, 3rd May 2021
I agree.
Hitachi will carry out monitoring of the fleet, identify if its a batch / build issue metallurgical analysis etc.  They will almost certainly conduct an engineering risk assessment into the likelihood, consequences and severity of a catastrophic failure.
What mitigations can they put in place, reduced max speed untill a repair is effected etc
Posted by TonyK at 13:03, 3rd May 2021
I agree.
Thank you both, for that clarification.
This happens in aviation to a degree. A certain wide-bodied jet based on an adaptation of a previous model began to show cracks at one of the points that was different to the earlier plane. At 500 mph and 38,000 feet, any failure would have been catastrophic. A fix was quickly found, tested and applied, and monitoring afterwards has shown it to have been successful. I am sure we will soon see a similar outcome with the IETs.
Posted by broadgage at 03:17, 4th May 2021
Thanks for that, I was presuming that the cracks were in the Yaw dampers or bogies, expensive but replaceable or repairable components.
Cracks in the body shell sound more challenging. Presumably minor cracks can be monitored or perhaps "stop drilled*" to prevent them spreading.
Major cracks would seem to require cutting out the damaged part and welding in a new section. Welding of aluminium is a challenge and there can be some risk of new cracks starting from the join.
Are there any publicly viewable pictures of the damage, not requiring membership or subscription to view ?
*"stop drilling" is a technique used primarily on aircraft. When a small and not yet dangerous fatigue crack occurs, it tends to spread because of the concentrated stress at the end of the crack. Spread can sometimes be prevented or delayed by drilling a small hole at the end of the crack. This spreads the forces around the circumference of the hole rather than concentrating them at one tiny point at the end of the crack.
Regular inspection is required not only of the "stop drilled" part, but also of similar parts elsewhere on the vehicle or on similar vehicles.
Posted by stuving at 10:23, 4th May 2021
However, we now have the vehicle numbers (814012 and 814013), and with formation data from the Spotlog site (now I wonder what that's about ...) these are both the same type and almost certainly type MEC3. So that's an intermediate motor coach, not a driving trailer as I had previously presumed.
814012 is out and about today on a diagram, so it can’t be too bad.  I imagine it’ll be more a case of monitoring rather than repair for the time being.
Posted by grahame at 06:05, 8th May 2021
Cancellations to services at London Paddington
Due to more trains than usual needing repairs at the same time at London Paddington fewer trains are able to run on some lines.
Train services running to and from this station have been cancelled. Disruption is expected until the end of the day.
Owing to the short notice unavailability of carriages which form our High Speed train services there will be no train services or alternative means of transport available for throughout journeys, in either direction, on the following routes :-
London Paddington - Swindon - Bath Spa - Bristol Temple Meads.
London Paddington - Swindon - Bristol Parkway - Newport - Cardiff Central - Swansea.
London Paddington - Reading - Taunton - Exeter St Davids - Plymouth - Penzance.
London Paddington - Reading - Oxford - Evesham - Worcester - Great Malvern - Hereford.
London Paddington - Reading - Swindon - Gloucester - Cheltenham Spa.
INTENDING CUSTOMERS FOR THESE ROUTES ARE ADVISED NOT TO ATTEMPT TO TRAVEL
In those areas such as Paddington / Reading / Didcot Parkway / Oxford / Bristol & Exeter local areas / Cardiff - Portsmouth and around 75% of Plymouth - Penzance services will continue to operate.
If you hold a valid single, return, or weekly ticket, you will be able to claim compensation for delays of 15 minutes or more. Please keep your ticket and visit GWR.com/DelayRepay
Last Updated:08/05/2021 05:54
Posted by grahame at 06:08, 8th May 2021
Route affected
All LNER routes
TOC(s) affected
LNER;
A problem under investigation across the LNER route means services are subject to severe delays and cancellations today.
Customers are advised to not travel on LNER services today.
You are encouraged to use an alternative mode of transport to complete your journey today.
Due to social distancing requirements, seats are extremely limited on services and reservations are mandatory. Please visit the LNER website for more information.
LNER tickets for today are valid up to and including Sunday 16 May.
If you decide not to travel, a full refund is available. Please contact your original point of ticket purchase within 28 days to claim your refund.
Ticket Acceptance:
You may use routes listed on the following disruption map.
LNER tickets will be valid with the following train operating companies:
Avanti West Coast between London Euston and Manchester for customers with an open ticket
TransPennine Express between Manchester, Leeds and York
East Midlands Railway between London St Pancras International and Sheffield
Northern services between Sheffield, Leeds and York and via any other reasonable route
Thmeslink services between London, Stevenage and Peterborough
Rail replacement coaches are in operation at York, Newcastle and Edinburgh.
Check before you travel:
You can check your journey using the National Rail Enquiries real-time Journey Planner
Twitter:
If you would like to follow this incident on Twitter, please use #LNERUpdate
Compensation:
You may be entitled to compensation if you experience a delay in completing your journey today. Please keep your train ticket and make a note of your journey, as both will be required to support any claim.
Feedback:
We want to make information better – tell us how! Fill out this online Disruption Survey.
Posted by grahame at 06:10, 8th May 2021
Hull Trains services on all routes
TOC(s) affected
Hull Trains;
A fault with Hull Trains fleet of trains means that that there will be short notice cancellations to Hull Trains services today.
Alternative travel advice:
You may use your tickets on Northern services between Hull and Sheffield. Customers are able to use East Midlands Railway services between Sheffield and London St Pancras International.
Customers at Retford and Grantham are advised to await further instructions.
Twitter:
If you would like to follow this incident on Twitter, please use #HullTrains
Compensation:
Feedback:
Posted by grahame at 06:20, 8th May 2021
And TPE services such as Newcastle to Liverpool now (06:20) starting to show up as "delayed" then "cancelled".
Posted by REVUpminster at 06:40, 8th May 2021
All GWRs are affected as well.
Posted by broadgage at 06:49, 8th May 2021
I presume that many Great Western Railway (GWR) services are also 5 car only.
These are not of course short formations, but show the merits of flexible train length.
They should have kept High Speed Train's (HST)s, not indefinitely of course, but for a few years just in case something like this happened.
Posted by REVUpminster at 06:52, 8th May 2021
Looked on Dawlish cams and 1A71 went through as a 9 car 802  7 minutes late at 06.50.
Posted by grahame at 06:56, 8th May 2021
Indeed - reported ahead of the flood of other TOCs ...
Chosen headline of "Cancellation to services at London Paddington" rather confirms how London-centric thinking is, and noting "no alternative means of transport"; at short notice, that last seems brutal but may be honest - LNER are offering some limited buses but I wonder how that will turn out.
I presume that many GWR services are also 5 car only.
They should have kept HSTs, not indefinitely of course, but for a few years just in case something like this happened.
Hmmm ... probably a massive expense with unlikely any payback.
We know there are risk assessments and contingent plans for all sorts of scenarios.  Is there such a plan for a complete fleet (class) being taken out of service - not the first time, after all - I remember something on Heathrow Express ...
Posted by grahame at 06:58, 8th May 2021
Already on the line when the "stop order" came out??
Edit to add ... it was 05:00 off Laira - though ran late.  06:00 off Laira - next train - cancelled.
Interesting to see if it runs all the way to London ...
Posted by broadgage at 06:59, 8th May 2021
GWR advice is now "do not attempt to travel" on most of their long distance services.
Posted by Timmer at 07:24, 8th May 2021
Sounds pretty serious. Shame so many High Speed Train (HST) sets have already been cut up at Sim’s Newport
Posted by grahame at 07:31, 8th May 2021
Sounds pretty serious. Shame so many HST sets have already been cut up at Sim’s Newport
Serious indeed - but do we yet know if it's going to be something to which is going to be long running, and will the problem remain as "deep" as all stop until whatever it is has been either checked or fixed on every train?   Noting that the IET that set of this morning early from Plymouth - at last look. was running all the way to London and at scheduled speed
Posted by broadgage at 07:36, 8th May 2021
Presumably Hitachi will be covering the cost of hiring alternative rolling stock, and buses. And yes I know that alternatives are limited, but every little helps.
And Hitachi will of course be applying for some form of emergency derogation to permit use of heritage stock on the less busy parts of the national network.
Use preserved steamers and mark 2 coaches on the branch lines and in the far West, thereby freeing up castles, turbos, pacers and the like for the more intensively used routes nearer London.
Is Tornado available ?
Posted by Timmer at 07:44, 8th May 2021
Looking like sets are being inspected and released for service if the issue that’s been raised isn’t found on that particular set.
Posted by grahame at 08:05, 8th May 2021
https://www.a1steam.com/where-tornado-is-now/
Tornado is currently stabled at Stewarts Lane.
Next scheduled run 22nd May.
Was you question serious
Posted by broadgage at 08:18, 8th May 2021
Semi serious.
If the IET problems carry on for more than a day or two, then yes consideration should be given to use of Tornado, Flying Scotsman, and the like to provide a limited service.
I doubt that enough charter stock is available for anything like a full service, but even a few services are better than doing nothing.
Much more likely though is simply ongoing advice not to travel.
I expect that disruption will be ongoing. Todays level of cancellations suggests a more serious problem than was the case initially. Even if only a handful of units have cracks at present, there is a risk of future cracks suggesting a need for frequent examinations.
And even if the cracks are considered minor and non dangerous, they are liable to get worse, again requiring frequent examinations and withdrawal for repairs when the cracks get worse.
Posted by infoman at 08:26, 8th May 2021
Now being reported on BBC news at 08:26am saturday morning
Posted by TaplowGreen at 08:27, 8th May 2021
Being covered on BBC News now.
Virtually no notice for those intending to travel and no alternatives provided
Another self inflicted injury and a dreadful advert for GWR/the railways as they attempt to recover some business and attract new customers - these trains are, by railway standards, brand new.
This type of regular chaos is one of the reasons why the car will always be king.
Posted by ellendune at 08:38, 8th May 2021
This is why the car will always be king.
Virtually no notice - what do expect? Run them with a potentially serious defect?  Boeing did that until there had been many fatalities!
No alternatives provided - what do expect them to do at no notice?  Perhaps you would like your season ticket price to increase to provide a whole standby fleet of trains or buses in warm storage (with regular staff training so that they can be used anywhere on the network) to be brought out at a moment's notice for just such an eventuality.
The failure is that in the drive to reduce costs we have become over-reliant on one model of train. This sort of thing happens to cars as well (though usually only as a result of accidents as they do provide notice) and they are recalled, but there are many makes and models so the impact is much smaller.
Posted by ChrisB at 08:48, 8th May 2021
National Rail on twitter
Some GWR, Hull Trains, LNER and TPE trains have been taken out of service today for safety checks as a precautionary measure. Once trains have been checked, they will be released back into service as soon as possible. Please check before travel.
Posted by ChrisB at 08:53, 8th May 2021
BBC news website
https://www.bbc.co.uk/news/uk-57036247.amp
Great Western Railway services have been cancelled after hairline cracks were found in a number of its high-speed trains.
The cracks were found in the suspension of its Hitachi 800 trains, a spokesman said.
He added that all such trains were now having to be checked.
All high-speed GWR services between London, Bristol, Cardiff and Penzance have been cancelled and customers are advised not to attempt to travel today.
The GWR spokesperson said London North Eastern Railways, which operates the East Coast Mainline, was facing similar problems, the BBC's correspondent Jon Donnison said.
LNER is also advising its customers not to travel today.
Posted by grahame at 09:12, 8th May 2021
Avanti West Coast and West Midlands Railway are conveying passengers via any reasonable route until further notice. Arrangements have been made for Great Western Railway rail tickets to be accepted for these journeys.
Good.
No SWR?   Ah ... bussed west from Salisbury!
Posted by TaplowGreen at 09:25, 8th May 2021
I didn't see myself suggesting that trains should be run with serious defects?  Contrary to the prevailing culture on the railways however, I'm looking at the fallout from the customer perspective.
You can fire back with passive/aggressive rhetoric if you wish, but it'll be the verdict of those standing on platforms in the rain, or who have had to cancel long awaited trips to see family and friends which will count in the end, and I suspect that verdict will ultimately see many of them on the M4 next time.
My understanding was that this problem was first flagged almost a fortnight ago, so one would imagine some sort of contingency  or at least advance communication could have been arranged.
Posted by broadgage at 09:37, 8th May 2021
Regretfully, I agree. Whilst this particular problem is a new problem, it needs to be taken in the context of other major failures of "the railway"
Large scale signaling failures that have resulted in no effective service from major London termini, and huge disruption resulting from moderately adverse weather during which airlines and motorways operate as normal.
For reasons previously given elsewhere in these fora, I am opposed to flying and driving. If however people are to be tempted out of cars and aircraft, then "the railway" needs to up its game.
A reliable service of full length trains, even in hot weather, cold weather , snow, rain, and high tides.
Enough capacity to cope with Christmas, School holidays, Cup finals, Easter, Rugby internationals, Pop concerts, festivals, bank holidays, and all the other events with which they miserably fail to cope with.
Had the IETs been otherwise good trains, I would be a bit more forgiving, but this is the latest and arguably the most serious failure of a generally failed design.
And yes I know that High Speed Train's (HST)s and other "proper trains" suffered from various faults and failures, but I do not EVER recall general advice  to "not travel" by train resulting.
Posted by hoover50 at 09:41, 8th May 2021
I agree. It is a crying shame that over 300 High Speed Train (HST) Mk3 carriages have now been scrapped.
These trains were very popular with the travelling public with many years of life left in them. Following refurbishment, some are still in service with Scotrail, Cross Country and GWR as "Castle" sets.
Posted by ellendune at 10:00, 8th May 2021
Apologies if my response was seen as aggressive.
I am sure we all accept that the impact on passengers will be damaging to the industry at a time when confidence is already low.
However, my point remains that you cannot go for cost cutting and have a resilient railway at the same time.
On road travel my second worst* travel experience was a 5 hours stuck on the M4 trapped by a lorry fire. So roads have their problems as well.
*My worst being on FGW when I was on the 1845 train from Paddington on Friday 8 September 1995 which was trapped by the fire on the 18.30 Paddington to Swansea train near Maidenhead after the one where the HST caught fire. Still that could have been worse as I initially got on the 18:30 train but got off again as it was too overcrowded and I couldn't face standing all the way to the first stop at Reading.
I agree. It is a crying shame that over 300 HST Mk3 carriages have now been scrapped.
They were, but as I understand it the ones that have been scrapped had severe corrosion so were probably at the end of their economic life.  The lack of any form of crash protection for the driver has also recently been highlighted on here http://www.firstgreatwestern.info/coffeeshop/index.php?topic=23891.msg305382#msg305382.  The rules were that passengers could not be in the power cars as they weren't sufficiently protected in the event of a crash, but this means that the driver is somehow seen as expendable.  Not an argument that is easy to sustain morally.
Posted by broadgage at 10:02, 8th May 2021
Good.
What a fiasco.
Time to send for the army ! and yes that IS A SERIOUS SUGGESTION. Not to run the trains, HM forces would be subject to similar constraints as the TOCs.
I would send for the army for the specific task of refueling the SWT units since "the railway" is clearly unable to cope with the logistics of this hugely complex task.
With HM forces refueling the SWT units, a limited alternative to the GWR services could be provided. AND the buses at present being used could be redeployed to replace a few GWR trains.
Under normal circumstances, the inability of the railway to refuel some DMUs away from the usual depot, would be just normal railway incompetence.
However with the defective trains on GWR, circumstances are not normal and extreme measures are called for.
Posted by bradshaw at 10:19, 8th May 2021
Now being suggested it is related to the lifting jack pockets rather than yaw damper fixing
https://twitter.com/philatrail/status/1390956711922610177?s=21
Posted by TaplowGreen at 10:25, 8th May 2021
I thought it was that from the start - those pesky jack pockets!
Posted by broadgage at 10:30, 8th May 2021
Interesting, but I do not find the linked reports entirely clear.
Are the originally reported cracks now believed to be due to the lifting jack pockets, and not due to the yaw damper fixings ?
Or are there now two different sorts of cracks, yaw damper related and lifting pocket related ?
Posted by grahame at 10:36, 8th May 2021
https://www.facebook.com/gwruk/posts/10157820336986806
Due to a number of Intercity Express Trains taken out of service for precautionary checks, there will be significant disruption across the network today
Customers are advised not to travel
Full Refunds will be provided
Visit http://gwr.com for more information
Slightly unfortunate what it's followed by a linked post saying
Buy Cheap Train Tickets | Great Western Railway | First Great Western
Buy now and save money with cheap train tickets. With no booking fees and Nectar points to collect.
- perhaps not the most tactful of things to advertised below the "don't travel today" headline?
Posted by Richard Fairhurst at 10:46, 8th May 2021
Looks like there's a skeleton service on the Cotswold Line, at least - Iris/RTT appear to show one five-coach IET running, and apparently there was a Turbo earlier.
Posted by broadgage at 10:47, 8th May 2021
Now 75 cancellations compared to 17 early this morning.
And that is about 75 EXTRA cancellations and not 58 extra as one might suppose, since the earlier cancelations have now dropped of the system as they would have completed their journey.
Many other part cancelations.
Posted by TaplowGreen at 11:03, 8th May 2021
CrossCountry apparently not accepting GWR tickets  -  someone has raised the very good point about people at the end of their trip who need to get home and are now stranded in the absence of GWR making alternative arrangements, rather than those who were planning to embark today.
GWR remaining silent on that one, but I suspect a lot of taxi drivers will be eyeing upgrades to Aston Martins after this weekend.
Posted by Incider at 11:08, 8th May 2021
I wouldn’t say this is a regular type of chaos, can you remember the last time something similar happened?
Posted by Richard Fairhurst at 11:14, 8th May 2021
Posting this from the comfort of an IET between Charlbury and Hanborough... so at least some are still running!
Posted by grahame at 11:16, 8th May 2021
Hindsight being marvellous ... what an excellent day to extend 387 services to Cardiff ... even if that reduces their frequency between Paddington and Didcot.  And what an excellent day it would be for all tickets to be "any reasonable route, any operator" in the circumstances!
The time all HEX trains were taken out of service?   When was that?
The question, is though, whether you consider "Something similar" from a train operators viewpoint (i.e. all trains of a class suddenly out of service) or from a customer's viewpoint (my train and alternative services also not running)
Posted by broadgage at 11:17, 8th May 2021
No it is not the REGULAR type of chaos, but is instead a new and improved type of chaos.
The more usual types of chaos are large scale signaling failures resulting in no effective service, and moderately adverse weather. Over-Head Line Equipment (OHLE) faults safety inspections were added  to the traditional cock ups, and now we have fatigue failures on the new trains.
Posted by REVUpminster at 11:25, 8th May 2021
Had another look at dawlish warren 1A60 as a 5 car 802 went through. Not listed on Realtime trains.
A 166 hurtled through operating 2T14 to Paignton and a shuttle 5Z42/43 etc using the 2 car 165 between Newton Abbott and Exeter
Posted by BBM at 11:25, 8th May 2021
There's currently an additional hourly fast Paddington-Didcot service stopping only at Reading and formed of 387s - departure times are at xx.30 from either end.
Posted by broadgage at 11:26, 8th May 2021
Presuming that this is accurate, and I have no reason to doubt it, I wonder what would happen to a passenger with a valid GWR ticket who boarded a Cross Country service and refused to pay again.
If the case went to court, I suspect that a jury might not convict the accused. A judge or jury MIGHT take the view that the passenger had already paid for the service, and should not be required to pay twice.
A court MIGHT rule that GWR and Cross country should sort it out among themselves and not blame the passenger.
Posted by Lee at 11:42, 8th May 2021
Interesting to note that the disruption map at the top of the forum front page currently looks like the old BR logo chopped in half.
Perhaps it's a sign...
Posted by phile at 11:45, 8th May 2021
Don't know what the 165 shuttle is because they are running with 5xxx Headcode
Posted by didcotdean at 11:51, 8th May 2021
Cross Country are accepting GWR tickets now, at least according to GWR twitter. (As well as Avanti West Coast, West Midlands Railway, & Chiltern)
Posted by grahame at 12:25, 8th May 2021
Now covered on the BBC - "most read" there ! - https://www.bbc.co.uk/news/uk-57036247
Services on two of the country's busiest railways are facing severe disruption after cracks were spotted on some high-speed trains.
Most Great Western Main Line trains to and from London Paddington have been cancelled.
London North Eastern Railways is asking passengers not to travel on the East Coast Main Line today.
Hitachi has apologised after hairline cracks were found in the suspension units of some of its 800 series trains.
Some of the trains have been taken out of service as a "precautionary measure to allow for thorough investigations", the company said, adding it was working to resolve the issue as quickly and safely as possible.
"We would like to offer our sincerest apologies to passengers for the impact this may be causing for their travel plans."
Hull Trains and TransPennine Express services are also affected by the problem.
Passengers have been advised to check train operators' websites before travelling.
On GWR it says more ...
All high-speed Great Western Railway services between London, Bristol, Cardiff and Penzance have been cancelled and customers are advised not to attempt to travel today.
It has warned the problem could affect services on Sunday too.
The company said cracks were detected on "more than one" Hitachi 800 train, so all 93 in its fleet are being inspected as a "precaution".
The spokesman added that the issue is affecting long-distance journeys between cities, which are being refunded, but that suburban and rural GWR services are still running as normal.
GWR passengers affected by cancellations can use their tickets on the following operators' services instead:
* Avanti West Coast trains between Birmingham New Street and London Euston
* London Northwestern Railway trains between Birmingham New Street and London Euston
* West Midlands Railway trains between Hereford/Worcester and Birmingham New Street
No mention on the BBC of either Cross-country or SWR, though an alternative Bristol to London route would be via Salisbury (pity about the buses between Warminster and Salisbury, but just about the only public transport option ...
Posted by grahame at 12:35, 8th May 2021
From Greatest Hits Radio
... Great Western Railway is advising passengers not to travel amid reports of cracks found in some trains ...
Surely "Passengers for Chippenham and Swindon should change at Trowbridge, from where there is a limited onward service ..."
Posted by a-driver at 12:42, 8th May 2021
Two totally unrelated issues
Posted by grahame at 12:50, 8th May 2021
Hmmm ...
12:05 Westbury to Swindon due 12:47
12:05 Westbury to Swindon due 12:47 has been delayed at Westbury and is now 30 minutes late.
Posted by grahame at 13:05, 8th May 2021
Would seem there are some shuttles running.
12:30 London Paddington to Bristol Temple Meads due 14:03
12:30 London Paddington to Bristol Temple Meads due 14:03 will be reinstated.
It will be started from Swindon.
It will no longer call at London Paddington, Reading and Didcot Parkway.
Now - are the 387s reaching Swindon in passenger service?
Posted by patch38 at 13:16, 8th May 2021
There appears to be at least one 166 shuttling between Swindon and Gloucester/Cheltenham.
Posted by ellendune at 13:30, 8th May 2021
From the BBC from a long article
Roger Ford, industry and technology editor at the magazine Modern Railways, said the problem is "with the weld cracking underneath [the train's] body shell" which he explained led to about 180 trains being taken out of service on Saturday morning for inspection.
So unrelated to the problems a couple of weeks ago
Posted by IndustryInsider at 13:43, 8th May 2021
Whatever the reason, it’s a very poor day for the reputation of Hitachi, which will of course flow along the chain to the two main operators of the train and the industry in general.  If it goes on beyond the weekend then it could become a defining moment for the train...cast your mind back to how the APT never recovered from initial troubles.
As it is, the good news is that it’s a miserable day weather wise which will help to suppress already very low passengers numbers.
There are several reasons why Turbos/387s can’t just be substituted.  There aren’t enough of them, limited crew are trained on them, and DOO regulations means I doubt you’ll see 387s running to Swindon in passenger service, unless this issue carried on for many days when alternative operating arrangements could be made.
I’ll save any more comment until the hysteria has died down a little.
Posted by broadgage at 13:55, 8th May 2021
One lot of cracks is unfortunate but could perhaps be explained away as bad luck, or some exceptional and not be repeated event.
TWO UNRELATED lots of cracks starts to look like a seriously defective design.
And these issues only about 10% into the design life of the wretched things. How many other cracks or fatigue failures await a bit further into the design life.
Posted by grahame at 14:12, 8th May 2021
... and DOO regulations means I doubt you’ll see 387s running to Swindon in passenger service ....
Grr!  - I had overlooked that ...
Posted by broadgage at 14:22, 8th May 2021
Rail minister warns of "prolonged disruption"
Posted by broadgage at 14:41, 8th May 2021
My crystal ball forecasts significant disruption for the rest of this year and perhaps for longer, for the following reasons.
1) Before these latest problems, IET reliability and availability had been poor with many short forms due to "more trains than usual needing repair" Therefore even a slight reduction in availability will have a significant impact on services.
2) Some units are known to have cracks. Repairs to structural aluminium are a specialist and time consuming job. The first few repaired units will need very frequent checks.
3) Other units may suffer from similar cracks, and even if no more cracks are found, the frequent precautionary inspections will have a significant impact on availability.
4) Units without cracks at present seem liable to suffer in future and will need future withdrawal for repairs.
5) The many detailed checks and inspections may find other faults.
Posted by bobm at 15:14, 8th May 2021
..and if the train is running, you may not be able to get on it.
Posted by grahame at 15:46, 8th May 2021
Why tell you where the zones are if it's set down only?
Posted by bobm at 15:48, 8th May 2021
Better than that - at the last minute it was swung over to platform 4 while a train to Bristol was crossed over to platform 1.
Posted by grahame at 16:26, 8th May 2021
Can't recall seeing that before - how does it get back "right line" towards London?
Posted by bobm at 16:40, 8th May 2021
Ran wrong line as far as Bourton and then crossed over.  As that was going on a non stop service to Penzance was crossed over at Bourton to also run wrong line to take the centre road through Swindon station.
Posted by bobm at 16:44, 8th May 2021
Statement from Hitachi
Posted by grahame at 16:54, 8th May 2021
From This is Wiltshire - timed a few hours ago ...
ALL INTERCITY trains through Swindon have been cancelled today for what Great Western Railway has described as "precautionary checks" on the services.
The move follows reports last month that a crack was found on a vehicle at Hitachi's North Pole depot in west London, where GWR's new Intercity trains undergo regular checks.
The cancellation is likely to cause widespread disruption, with all fast trains to and from London Paddington along the west coast main line cancelled. Local services continue to run.
Picture shows an High Speed Train (HST) and Turbo ...
Posted by stuving at 16:54, 8th May 2021
It might be helpful to see where the jacking point on an 80x is, and this picture on Wikipedia just happens to show it:
Below the door there are steps, and to the right of them is what looks like a small square foothold - that's where a steel bar can be threaded through to hoist the body by crane. Depot equipment might have a different way of engaging in the same place. There's a "jack here" symbol above it if you look closely.
That white bit, whatever you call it, is reinforcement to provide attachments strong enough to mount the bogie to. I've not found a picture that shows what happens further under the floor, but I imagine what we see is the side of a plate that runs all the way across and also has the bogie pivot bearing fixed to it. It has to spread the large point loads over multiple attachment points to the relatively flimsy body shell.
The new issue has been described as a cracked weld, which might imply that this reinforcing plate is coming away from the body shell. Then again, it might not - and it might only be near a weld. Presumably the inspections, following the earlier cracks being found, have been extended to other similar areas and that has revealed a new problem. Judging by the reaction, that all units must be inspected at once and not run at all until seen to be unaffected, it must be potentially pretty serious.
The site of the earlier cracking, the famous "yaw damper bolster", is at the left-hand end of the same white object along the underside of the body shell. The yaw damper bracket attaches at two points, and the cracks run above left-hand one of those. However, those cracks were not on one of these vehicles, but on one of the intermediate motor ones (MEC3). I'm sure there are some minor differences in the various bits, though the bogie is of the same basic design.
Posted by ray951 at 17:15, 8th May 2021
Why would DOO be a problem?
If DOO relies on infrastructure on the platform then I can see it would be an issue, but again couldn't infrastructure be replaced by a person on the platform making sure all doors are clear and or shut and then communicating that to the driver? I realise it is a bit more complicated than that as you need to find the people, make sure they can be identified by the driver, understand what their duties are, the 'workaround' then has to be communciated to everyone, etc. and all of that will take time.
If DOO doesnt rely on any off-train infrastructure then what is the issue?
And if you don't want to run as DOO could a guard not be assigned to the trains? Class 800/802 and 165/166 can operate with and without guards is the same true of class 387?
I can appreciate that it takes time to organise replacement processes when must of your trains get taken out of service but I would hope that if this continues beyond today/tomorrow then GWR will attempt to run at least a skelton service rather than just telling passengers sorry but we can't do anything.
I assume that GWR has a risk register and would be interested to know if all trains of one type being taken out of service is one of those risks and what their contigencies are to mitigate that risk?
Posted by RailCornwall at 17:17, 8th May 2021
Statement from Hitachi on Twitter
Posted by IndustryInsider at 17:23, 8th May 2021
Yes, the post Graham quoted went on to say that procedures could be modified if there was an ongoing shortage, but not to expect it this weekend.
GWR were/are planning on using 387s to and from Cardiff for events, so new procedures would have to be in place for that, but obviously the need for that has yet to materialise.
Posted by ChrisB at 17:34, 8th May 2021
There would be a need for staff training to run guards (beyond Didcot)
No staff are assigned to that job nor would any yet have the knowledge/training for that route beyond Didcot.
Where do you find guards in a staff pool that aren’t assigned to that?
How long would it take to train them once located?
Weeks is the answer, even after you’ve licated suitable staff. Minths if you have to employ them.
I’m unsure why some think they can just be deployed. The RMT has a new head honcho, who has already stated he’s looking for a fight or two. So everything would need doing by the book and agreed.
Posted by broadgage at 18:38, 8th May 2021
I have heard a report, that of the IETS checked for cracks that 80% have failed, and only 20% have passed.
I can NOT SUBSTANTIATE this report, can anyone confirm or deny ?
If true, this implies no effective service for MONTHS as repairs sound time consuming, and the remaining 20% will presumably also develop cracks.
Posted by JayMac at 18:39, 8th May 2021
You are Officer Crabtree and I claim my £5.
Posted by a-driver at 18:50, 8th May 2021
Sources within control claim:
XC will run Bristol to Swindon shuttles.
West Country services will utilise 2+4 HSTs up to Reading or possibly into Paddington.
There will only be 10 IET sets available until at least Wednesday
Posted by TaplowGreen at 18:53, 8th May 2021
Blimey - photographic evidence.
https://www.plymouthherald.co.uk/news/plymouth-news/pictures-show-cracks-stopped-gwrs-5390963?fbclid=IwAR1zC0S7L04wpPwA3ueuKPjJDAfjIGqSCV5DlrY6qxFBffcFIaQ_MCDZ7QY
Posted by devon_metro at 19:01, 8th May 2021
That picture is actually related to the issue identified a few weeks ago - the yaw damper. It was leaked onto a forum.
I read on said forum that >80% of GWR's units have failed the initial inspection with the new problem - source seems well informed.
