13.6.2025 (Friday) 05:18 - All running AOK
Re: Air India flight to London Gatwick crashed in Ahmedabad
In "Introductions and chat" [362198/30350/1]
Posted by JayMac at 21:54, 12th June 2025
Already liked by Western Pathfinder
Some reports are suggesting dual engine failure after take-off (DEFATO) That would help explain why there was a mayday call. It's something that is very noticeable to the flight crew, very quickly. If the plane had been incorrectly configured for take-off (as some have speculated - noting that flaps may have been incorrectly positioned and gear was still down) it's less likely the pilots would've figured out what was wrong in time to diagnose the problem and then communicate. The rule of thumb is: Aviate, Navigate, Communicate. There's also some suggestion that the RAT (Ram Air Turbine) was deployed, which would add weight to the DEFATO hypothesis.
A dual engine failure immediately after V2 would most likely occur due to birdstrikes. Other foreign object damage is possible, though less likely to affect both engines. It could also potentially be contaminated fuel, but there have been subsequent take-offs from that airport, so it's unlikely the source of fuel was the problem.
Dual engine failure at, or immediately after, V2. Startled pilots. No positive rate achieved so no "positive rate, gear up" call out and action. Begin the DEFATO checklist, which I suspect is mainly memory items due to the time critical nature of the fault. Continuing aviating. Issue mayday.
If it turns out to be this scenario then the sad reality is that the pilots simply did not have enough of three critical things. Time, altitude, speed. The nearest comparison would be US Airways Flight 1549. But Chesley Sullenberger and Jeffrey Skiles had nearly 4 minutes, 190kts and 3,000ft to play with.
My thoughts and sympathies go to all those affected.
Re: HMS Bristol: Last Falklands warship given send-off by veterans - 11 June 2025
In "Introductions and chat" [362197/30348/1]
Posted by Kernow Otter at 21:49, 12th June 2025
Got flown out to Hong Kong to join her. Amazing three month trip back to Portsmouth. 1990.
RMT to ballot GWR Gateline staff over lone staffing plans - June 2025
In "Across the West" [362196/30351/26]
Posted by Chris from Nailsea at 21:04, 12th June 2025
From the Morning Star:
Rail union RMT announced today that it will be balloting over 300 gateline staff across Great Western Railway (GWR) for strike action. The ballot, opening on June 17, comes in response to company plans to impose single staffing and extend working hours.
The rail union argues that this will leave staff on ticket barriers isolated, more exposed to abuse and violence, and unable to provide proper ticket enforcement and adequate assistance to passengers. RMT reports that management has attempted to intimidate workers by insisting they will not win the ballot, and that the new working arrangements will go ahead regardless.
General secretary Eddie Dempsey said: “Our members are being threatened with unsafe working conditions and told there is nothing they can do about it. GWR is trying to impose single staffing, which will put our members at greater chance of being harmed at work and we cannot allow that. RMT will not accept lone working on stations and Gatelines, and we are prepared to take strike action to stop it.”
A Great Western Railway spokesman said: “These proposals mean more colleagues at seven GWR stations on our network to offer help and support to customers. We’ve got no plans to extend the working hours for gateline colleagues and there is no suggestion of single staffing being imposed. We’ve been speaking to trades unions colleagues about recruiting an additional 30 members of staff at seven locations on our network to help us provide more staff at gatelines for longer. Rather than being imposed, we’ve been clear that minimum staffing levels would be agreed by local station teams, based on risk assessments agreed with trades unions. We’re keen to talk to colleagues and their trades union representatives to find a mutually beneficial solution here that doesn’t involve colleagues losing money through unnecessary industrial action.”
Of note is the apparently obligatory illustrative image, again from Bristol Temple Meads - which would surely be the last railway station to be subject to any proposed 'single staffing' on the ticket barriers?
Re: London to Frankfurt and Geneva - direct trains from Eurostar?
In "The Wider Picture in the United Kingdom" [362195/30344/51]
Posted by Electric train at 20:55, 12th June 2025
Press release from Railfuture:
Railfuture comments on Eurostar announcement. Planning new trains to Germany and Switzerland:
It looks as if Eurostar has finally decided to expand. The Eurostar 50 new trains order has been around for a while but without stated commitment to run from Britain.
The "concentrate in the core, high fares" strategy is fine in the short run if you have no wider economic objectives but it has opened up a plethora of open access proposals.
Perhaps the most significant result is for Eurostar to realise that they are best placed to expand with less barriers to entry than new entrants. The key is to do this fast enough to keep new entrants at bay. The announcement to add new routes from London to Germany and Switzerland is strategically significant in this respect.
Open access has, in this way, already served a purpose without even running a train. In strategic terms this is good. Railfuture welcomes this development but makes it clear that this still leaves scope for more services and more competition, particularly on the existing Paris route and to the largest air market from Britain, after Paris and Amsterdam, i.e. Spain.
Also, sooner or later, someone will realise that there are other cities in Britain that have a huge air market, More people travel from Manchester to Paris than from London to any city in Switzerland.
Railfuture contends that the timing and the economics are right for sustainable rail travel from Britain as is the market appetite.
Railfuture's suggested choice of preferred open access routes.
This is ambitious for obvious reasons against the present situation but far less so in market terms. It also makes the presumption that the current preoccupation with immigration and security will be eased, with new technology and EU technology.
This proposes two strategic stops en route here, Stratford in long haul fast services to take about 30% volume to ease St Pancras, and Ashford for the Kent catchment area with its propensity to travel to Continental Europe.
Stratford or in some case, Lille would largely replace St Pancras as the interchange point from NW England.
Draft list of contenders.
Eurostar's proposals plus;
Paris route competition
    London, Stratford - Paris (fast)
    London, Ashford - Calais, Lille, Paris
    London, Ashford - Charles de Gaulle Airport, Disneyland Paris, Lyon. Delete Lyon, add Tours, Bordeaux
    Manchester, Crewe (Merseyside and North West hub), Rugby(West Midlands hub), Stratford - Lille, Paris (all with long platforms)
South of France and Spain route competition
    London, Stratford- Barcelona, Madrid (fast)
    London, Ashford - Lyon, Avignon, Marseille
    London, Ashford - Lyon, Montpellier, Perpignan, Barcelona. Delete Barcelona, possibly combined to Avignon
Add
    London, Ashford, Charles de Gaulle Airport, Disneyland, LeMans, Nantes, with multiple service stops to provide frequency to CdG and Disneyland.
London, Ashford- Germany route competition
    London, Stratford - Hannover, Berlin (fast)
    London, Stratford - Brussels, Koln, Frankfurt, Stuttgart, Zurich, Milan
Belgium, Netherlands route competition
    Manchester, Crewe, Rugby, Stratford - Lille, Antwerp, Rotterdam, Amsterdam
Nord Pas de Calais shuttle in cooperation on fares with SE High Speed and domestic Ashford - Calais, Lille
Notes to editors:
Railfuture is the UK's leading independent organisation campaigning for better rail services for both passengers and freight.
Railfuture's website can be found at: www.railfuture.org.uk
I believe it was always Eurostar ambition to expand its services further into Europe.   A few things that dented that ambition, Covid really hit Eurostar hard financially onto top of the cost of procuring the class 375's and to a lesser extent was initially the uncertainty of the impact of Brexit border controls.  The other part of the picture has been more and more high speed lines being linked up in Europe, they get on and build theirs while we procrastinate
The full merger and rebranding of Thalys into Eurostar certainly underlines their ambition.
In "TransWilts line" [362194/29726/18]
Posted by grahame at 20:47, 12th June 2025
Already liked by matth1j
...and the 17:35 Swindon-Westbury left Chippenham on time, but then stopped for about 5 mins somewhere before Thingley, due to a red signal according to the train manager. Wasn't obvious why; I assumed something had got delayed coming from Melksham in the opposite direction on the single track we were waiting to turn into, but nothing came past us. Strange.
Nothing obvious on Real Time Trains ... the other possibility that I looked at was the possibility of something ahead of it that had to clear Bradford Junction before you could proceed, but that was NOT showing on RTT.
Signalling experts may be able to help me - but I think that the train is passed from Didcot to Westbury sit passes along the line and signallers at both ends have to co-operate to pass trains.  I get the impression that the paths / this is occasionally done very late.
In "Introductions and chat" [362193/30348/1]
Posted by Chris from Nailsea at 20:12, 12th June 2025
Thank you all for your replies to my original post: I did wonder whether it would be of any interest here, on a predominantly railway forum, but it has shown to be so.
In "TransWilts line" [362192/29726/18]
Posted by matth1j at 19:57, 12th June 2025
Re: Coldstream Guards making their way to Berwick from Kings Cross train station
In "Media about railways, and other means of transport" [362191/30340/49]
Posted by Electric train at 19:06, 12th June 2025
Already liked by broadgage
In my opinion I don't there is anything wrong with having the rifles on display, don't think they would have had bullets in them though.
I agree, but am still surprised that the military authorities allowed this. I support HM forces and have no problem with such forces carrying weapons.
I rather think that the relevant military authorities actually 'arranged' this, rather than just 'allowing' it: it was a very big public relations event, after all.
The paperwork and risk assessments for the movement of weapons is quite onerous.
But remember the armed forces regularly parade in the open public in Windsor and London.
It if it ever gets to the point where our armed forces are not allowed to march and parade in public will be the day I know for certain the lunatics have taken over the asylum
Oh they would have an armed civilian Police escort to protect the Guardsmen from ill intentioned members of the public, the armed forces do not have the powers of arrest other than civil arrest
In "Introductions and chat" [362190/30348/1]
Posted by Electric train at 18:57, 12th June 2025
I was quite surprised it lasted in service as long as it did, I suspect it would have had a much earlier retirement without the Falklands losses.
She was used as the RN Cadet and Schools acquaint and accommodation as well as being used by the RN for training until recently, she sat on permanent mooring off of HMS Excellent (Whale Island)
As a Sea Cadet adult volunteer I have spent many weekends and week living onboard HMS Bristol, sad to see her go
In "Introductions and chat" [362189/30350/1]
Posted by Chris from Nailsea at 17:19, 12th June 2025
Thank you for your post, grahame.
I held back from posting, earlier today, as the news continued to develop: this is an awful transport incident, with effects felt locally to us, as you wrote.
My thoughts and sympathies, too, are with all the families, friends and colleagues of those deceased.  A very sad day.
Re: Darwin Award Hopeful?
In "Media about railways, and other means of transport" [362188/30287/49]
Posted by Western Pathfinder at 17:12, 12th June 2025
Loss of life on the crossing was back in 2021, never heard anymore about it You ?.
Re: East - West Rail update (Oxford to Bedford) - ongoing discussion
In "Campaigns for new and improved services" [362187/1219/28]
Posted by ChrisB at 16:53, 12th June 2025
indeed.....thanks!
In "Introductions and chat" [362186/30348/1]
Posted by paul7575 at 16:48, 12th June 2025
Basically she was overtaken by events while in build, steam turbine main propulsion was about to be ruled out in surface ships in favour of all gas turbine.
The weapon and radar systems were effectively that of a Type 42 in a different hull, but in the details she had a unique Seadart missile handling system, she had no helicopter hangar, and retained the obsolescent Mortar Mk 10 for a long while until it was removed.  There was also an Ikara anti submarine system that was mothballed quite early in the ship’s life.
Paul
In "Media about railways, and other means of transport" [362185/30340/49]
Posted by Chris from Nailsea at 16:34, 12th June 2025
In "Campaigns for new and improved services" [362184/1219/28]
Posted by Red Squirrel at 16:10, 12th June 2025
£2.54million was specifically mentioned by Rachel Reeves yesterday - so no "confirmed" needed in quotes.
Three orders of magnitude out there, ChrisB. Make that £2.54 billion
In "Media about railways, and other means of transport" [362183/30340/49]
Posted by Oxonhutch at 15:50, 12th June 2025
My old man, as a National Serviceman in the late 1950's, found himself in front of the RSM having been seen cycling home to his married accommodation, 5 miles from camp, with his Lee Enfield slung over his shoulder. It was always kept safe at night in the bedroom wardrobe!
Apparently it was a no - no even then for a soldier to carry a firearm off camp. From that day hence it stayed in the armoury until his very last parade - by which time they had changed rifle type - and the drill.
I suspect that on parade - which I suspect all these Guardsmen are - things are different.
Re: Portishead Line reopening for passengers - ongoing discussion
In "Campaigns for new and improved services" [362182/231/28]
Posted by ChrisB at 15:46, 12th June 2025
Already liked by Andy
There is an infrastructure announcement due next week sometime, so it may well be in that.
In "Campaigns for new and improved services" [362181/1219/28]
Posted by ChrisB at 15:45, 12th June 2025
In "Introductions and chat" [362180/30350/1]
Posted by grahame at 15:38, 12th June 2025
From The BBC
An Air India passenger plane bound for London Gatwick crashed shortly after taking off in Ahmedabad on Thursday, leaving at least 204 people dead.
The flight was carrying 242 passengers and crew when it was involved in what the airline has called a "tragic accident" in the city in western India.
Ahmedabad's police chief told the BBC that 204 bodies had been recovered, while 41 people were being treated for injuries.
He earlier told news agencies there appeared to be no survivors from the crash, and that some local people would also have died given where the plane came down.
We are primarily a UK rail forum - but just occasionally something as major as this takes place - classified so far as a tragic accident - which goes for comment beyond our narrower sphere of interest.
My thoughts for those who died on board (I understand - stop press - at least one survivor) , those who have died or been injured on the ground. And my thoughts with family, friends and colleagues of those who have perished.  This was a flight into Gatwick - an airport that many of us use, and served by the trains we talk about.  Perhaps "meet and greet" people will have been on their way down, and arrivals planned to carry on on "our" trains.
Over coming time, we will learn what caused the plane to fall out of the sky; out of respect for those who have perished or been bereaved, I am not speculating here.
In "TransWilts line" [362179/29726/18]
Posted by matth1j at 15:38, 12th June 2025
Now both re-instated.
In "TransWilts line" [362178/29726/18]
Posted by bobm at 15:32, 12th June 2025
In "TransWilts line" [362177/29726/18]
Posted by matth1j at 15:26, 12th June 2025
17:35 Swindon to Westbury due 18:19 will be cancelled.
Re: Rail trail proposals in Gloucestershire
In "Active travel: Cyclists and walkers, including how the railways deal with them" [362176/30345/50]
Posted by Red Squirrel at 15:10, 12th June 2025
Already liked by Mark A, Richard Fairhurst, Oxonhutch, rogerw, Chris from Nailsea, eightonedee
The new estate will be about 3 miles from Kemble so absolutely prime territory for cycling. But I wonder if the Coventry VLR trials will tip the balance in future (insert usual gadgetbahn disclaimer here).
Kemble is the railhead for Cirencester and Tetbury, and (without researching this) I’d bet a fiver that part of the justification for closing both lines was that a bus could do the job. But the 882 - which looks like the modern incarnation of that substitute bus - does not integrate with the hourly train service at Kemble, so an onward connection is hit-and-miss.
So before committing to any kind of rail-based connection to Kemble, maybe it would be good to market a bus service from Tetbury to Cirencester via Kemble which connected to the trains, similar to the Bodmin and Okehampton services?
In "TransWilts line" [362175/29726/18]
Posted by grahame at 15:06, 12th June 2025
Re: Announcement - Billions of investment on tram, train and bus projects.
In "Looking forward - the next 5, 10 and 20 years" [362174/30318/40]
Posted by johnneyw at 14:06, 12th June 2025
The BBC is reporting that both Wellington and Cullompton stations will go ahead.
"The opening of two new railway stations has been given the go-ahead by the government.
Stations in Wellington, Somerset, and Cullompton in Devon will be funded by money allocated in the government's spending review.
While Chancellor Rachel Reeves did not specifically mention the stations in her speech on Wednesday, the Treasury has confirmed to the Local Democracy Reporting Service that funding would be given to the projects."
Similarly, Portishead was not specifically mentioned which prompted an article in Somerset Live.  I've mislaid the link but my guess is that it was a slow news day in the office.
In "Looking forward - the next 5, 10 and 20 years" [362173/30318/40]
Posted by Andy at 13:08, 12th June 2025
Already liked by Witham Bobby
Nothing for Devon & Cornwall - Quelle surprise!
Okehampton has been reopened, Okehampton interchange is being built, Ponsandane sidings have been laid and the Mid-Cornwall Metro is progressing.
I'm desperately hoping they'll provide enough funding to keep Tavistock moving forward at least.... and possibly go ahead with one of the two stations at Cullompton or Wellington - not sure which has the strongest case, Wellington, maybe?
Full article here:
https://www.bbc.com/news/articles/cn0g4kzp7n0o
In "Media about railways, and other means of transport" [362172/30340/49]
Posted by broadgage at 13:07, 12th June 2025
In "Campaigns for new and improved services" [362171/1219/28]
Posted by grahame at 10:23, 12th June 2025
I don't believe that this has only just been classified as an England & wales project at this stage - so why complain only now?
Oooh look, a chance to bash the London government and get my name in the paper, along with my "angry" photo.
£2.5bn "confirmed" for extension through to Cambridge, apparently: https://bsky.app/profile/oxfordclarion.bsky.social/post/3lrdl3pd6kk24
This "Wales" business has bothered me ... as I have felt it will benefit passengers from South Wales travelling to Cambridge.   Melksham to Cambridge was a journey I use to make quite often and by public transport it was awful as is Cardiff to Cambridge. And yet - just this one flow - there are around 7,000 journey tickets sold annually and how much higher might that be if the journey wasn't a nightmare one.     It would take time for me to gather other southwales-to-cambridge stats, but a quick look show things like Llandaf to Cambridge North tickets ...
In "Active travel: Cyclists and walkers, including how the railways deal with them" [362170/30345/50]
Posted by Richard Fairhurst at 10:16, 12th June 2025
In "Media about railways, and other means of transport" [362169/30287/49]
Posted by grahame at 10:11, 12th June 2025
As reported in this article, the incident has prompted Network Rail to apply for closure of this crossing.
I have two minds about the application.   Undoubtedly there are idiots sprinkled around from time to time - but is the stupid/thoughtless action of a (very?) few really justification for applying for a closure order.  Far more convenient for NR to extinguish a crossing (or remove a footbridge some times) than to fulfil their [moral/legal] duty to the wider general public.   Reminds me of the 9.11 "convenient time to release bad news".  I can understand the temptation to slip in changes ... removal of footbridge at Pilning, these idiots in the video, death on the Pilning crossing which (to me and to be confirmed?) Network Rail were hardly blameless over.
